SD-1010W
SD-1010W
    NIDEC(尼得科)
    SW6_10X10MM_TM
    旋转编码开关
SD-1010W 数据手册
ROTARY CODED SWITCHES SD-1000/2000 RoHS compliant INTERNAL STRUCTURE SD-1000 / 2000 series ① ④ ③ ② ⑥ ⑦ ⑤ Part name Material Flammability Polyphenylenesulphide UL94V-0 Stainless (SUS 301) — Silicone rubber UL94HB ■ FEATURES ① Housing O RoHS compliant O Fine click with metallic spring O Low profile of 3.9 mm makes perfect for high density board mounting applications O Gold plated contact provides excellent reliability O Cross and minus slot are available O Terminal pin arrangement 3-3 ② Metallic spring ③ “O” ring ④ Insert rotor ⑤ Base ⑥ Contact ⑦ Terminal pin Rotor : Polyamide Pattern : Copper alloy, Gold-plated UL94V-0 Polyphenylenesulphide UL94V-0 Copper alloy, Gold-plated — ■ PART NUMBER DESIGNATION S D - 1 0 1 0 T B Series name Shape of terminal No. of positions B:Gull wing (Top setting type only) Blank : Through hole pin (Snap-in terminal pin) 1:16 positions 2:10 positions Shape of rotor Form of packaging 0:Without knob (Minus slot) 1:With knob (with extended shaft) 2:Without knob (Cross slot) T:Taping (Gull wing type only) W:Tray packaging Blank:Plastic bag コード Code format Setting position 1:Real code (Rotor color Yellow) 3:Complementary code (Rotor color Red) 0:Top setting 1:Side setting ※ Please refer to the LIST OF PART NUMBERS when placing orders. SD-1000 / 2000 ROTARY CODED SWITCHES ■ LIST OF PART NUMBERS OBinary coded decimal Shape of rotor Without knob (Minus slot) Top setting With knob (Through hole pin) Without knob (Cross slot) Without knob (Minus slot) Side setting With knob (Through hole pin) Without knob (Cross slot) Form of packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Without knob (Minus slot) Tray packaging Taping Top setting (Gull wing) Plastic bag Without knob (Cross slot) Tray packaging Taping Real code SD-2010 SD-2010W SD-2110 SD-2110W SD-2210 SD-2210W SD-2011 SD-2011W SD-2111 SD-2111W SD-2211 SD-2211W SD-2010B SD-2010WB SD-2010TB SD-2210B SD-2210WB SD-2210TB Complementary code Pieces in package SD-2030 SD-2030W SD-2130 SD-2130W SD-2230 SD-2230W SD-2031 SD-2031W SD-2131 SD-2131W SD-2231 SD-2231W SD-2030B SD-2030WB SD-2030TB SD-2230B SD-2230WB SD-2230TB 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 500 pcs./reel 25 pcs./pack 50 pcs./tray 500 pcs./reel Complementary code Pieces in package SD-1030 SD-1030W SD-1130 SD-1130W SD-1230 SD-1230W SD-1031 SD-1031W SD-1131 SD-1131W SD-1231 SD-1231W SD-1030B SD-1030WB SD-1030TB SD-1230B SD-1230WB SD-1230TB 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 500 pcs./reel 25 pcs./pack 50 pcs./tray 500 pcs./reel OBinary coded hexadecimal Shape of rotor Without knob (Minus slot) Top setting With knob (Through hole pin) Without knob (Cross slot) Without knob (Minus slot) Side setting With knob (Through hole pin) Without knob (Cross slot) Form of packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Without knob (Minus slot) Tray packaging Taping Top setting (Gull wing) Plastic bag Without knob (Cross slot) Tray packaging Taping ※ Verify the above part numbers when placing orders. ※ Taping and tray version can be supplied only in reel or tray units. Real code SD-1010 SD-1010W SD-1110 SD-1110W SD-1210 SD-1210W SD-1011 SD-1011W SD-1111 SD-1111W SD-1211 SD-1211W SD-1010B SD-1010WB SD-1010TB SD-1210B SD-1210WB SD-1210TB SD-1000 / 2000 ROTARY CODED SWITCHES ■ STANDARD SPECIFICATIONS BCD (Real code, complementary code) BCH (Real code, complementary code) Circuit type Operating temperature range − 40 ~ 85 °C Storage temperature range Non washable Sealing ■ ELECTRICAL CHARACTERISTICS Contact rating Non-switching Switching Minimum DC50 V 100 mA DC5 V 100 mA DC20 mV 1 μA Contact resistance Insulation resistance Without knob Top setting 0.65 g With knob Top setting 0.76 g Without knob Side setting 0.95 g With knob Side setting 1.05 g Net weight Dielectric strength 100 mΩ maximum 1000 MΩ (DC100 V) minimum AC250 V, 60 s ■ MECHANICAL CHARACTERISTICS No. of positions ■ ENVIRONMENTAL CHARACTERISTICS (Amplitude) 1.5 mm or (Acceleration) 98 m/s2, 10-500-10 Hz, 3 directions for 2 h each Vibration 490 m/s2, 11 ms 6 directions for 3 times each Resistance load DC50V 100mA 40 °C, Relative humidity 90 ~ 95 %, 240 h 20000 steps DC5 V, 100 mA Shock Humidity Load life High temperature exposure 85 °C, 96 h Low temperature exposure − 40 °C, 96 h Thermal shock − 40 (0.5 h) ~ 85 °C ( 0.5 h ), 5 cycles 〈Reflow profile for soldering heat evaluation〉 (℃) 250 Peak : 250 16 (SD-1000), 10 (SD-2000) Adjustment torque 4 ~ 25 mN·m {41 ~ 255 gf·cm} 22.5° (SD-1000), 36° (SD-2000) Stepping angle Terminal strength (Through hole pin only) 10 N {1.02 kgf} minimum Stop strength (With knob only) 10 N {1.02 kgf}, 10 s Solderability 245 ± 3 °C, 2 ~ 3 s Gull wing Reflow : Peak temperature 255 °C (Please refer to the profile below.) Manual soldering:350 ± 10 °C, 3 ~ 4 s Through hole pin Flow : 260 ± 3 °C as the temperature in a pot of molten solder, immersion from head of terminal to backside of board 5 ~ 6 s, two times maximum Manual soldering:380 ± 10 °C, 3 ~ 4 s Soldering heat +5 0℃ Temperature Over 230 ℃ 200 150 100 50 180 ℃ 150 ℃ Pre Heating Zone Shear (Gull wing only) 90 ± 30 s 30 ± 10 s Heating time Soldering Zone Reflow : two times maximum 5 N {0.51 kgf}, 10 s Substrate bending (Gull wing only) Width 90 mm, bend 3 mm, 5 s, 1 time Pull-off strength (Gull wing only) 5 N {0.51 kgf}, 10 s { } : Reference only SD-1000 / 2000 ROTARY CODED SWITCHES ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) OSD-1010 (Real code) OSD-1030 (Complementary code) OSD-2010 (Real code) OSD-2030 (Complementary code) 0.6 W × 3.2 L × 1.2 D 0.6 W × 3.2 L × 1.2 D 10 3.9 10 3.3±0.5 3.9 3.3±0.5 ② Ⓒ ⑧ ② Ⓒ ⑧ 7.62 10 7.62 01 EF 2 10 89 67 A 345 BCD 6 – 0.6 ± 0.1 t = 0.15 2.54 Production date code ④ Ⓒ ① 2.54 OSD-1210 (Real code) OSD-1230 (Complementary code) 3.9 ④ Ⓒ ① 2.54 OSD-2210 (Real code) OSD-2230 (Complementary code) 0.6 W × 3.2 L × 1.5 D 10 6 – 0.6 ± 0.1 t = 0.15 2.54 Production date code 0.6 W × 3.2 L × 1.5 D 3.3±0.5 10 3.9 3.3±0.5 ② Ⓒ ⑧ ② Ⓒ ⑧ 7.62 10 7.62 01 EF 2 10 89 67 A 345 BCD 6 – 0.6 ± 0.1 t = 0.15 2.54 Production date code ④ Ⓒ ① 2.54 OSD-1110 (Real code) OSD-1130 (Complementary code) 3.9 3.3±0.5 10 6.5 3.9 3.3±0.5 ② Ⓒ ⑧ BCD 7.62 φ 3.9 78 Production date code 901 10 7.62 φ 3.9 23 456 89 67 A 345 01 EF 2 2.54 0.7 W × 1 D 6.5 ② Ⓒ ⑧ 10 ④ Ⓒ ① OSD-2110 (Real code) OSD-2130 (Complementary code) 0.7 W × 1 D 10 6 – 0.6 ± 0.1 t = 0.15 2.54 Production date code 6 – 0.6 ± 0.1 t = 0.15 2.54 ④ Ⓒ ① Production date code 2.54 6 – 0.6 ± 0.1 t = 0.15 2.54 ④ Ⓒ ① 2.54 SD-1000 / 2000 ROTARY CODED SWITCHES ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) OSD-1011 (Real code) OSD-1031 (Complementary code) OSD-2011 (Real code) OSD-2031 (Complementary code) 0.6 W × 3.2 L × 1.2 D 10 0.6 W × 3.2 L × 1.2 D Production date code 6.8 Production date code 6.8 10 10 10 01 EF 2 89 67 A 345 3.3±0.5 3.3±0.5 BCD ① Ⓒ ④ 2.54 ② Ⓒ ⑧ 3.3 2.54 6 – 0.6 ± 0.1 t = 0.15 2.54 OSD-1211 (Real code) OSD-1231 (Complementary code) ① Ⓒ ④ 2.54 6 – 0.6 ± 0.1 t = 0.15 2.54 OSD-2211 (Real code) OSD-2231 (Complementary code) 0.6 W × 3.2 L × 1.5 D 10 ② Ⓒ ⑧ 3.3 2.54 0.6 W × 3.2 L × 1.5 D Production date code 6.8 Production date code 6.8 10 10 10 01 EF 2 89 67 A 345 3.3±0.5 ② Ⓒ ⑧ 3.3 2.54 6 – 0.6 ± 0.1 t = 0.15 2.54 OSD-1111 (Real code) OSD-1131 (Complementary code) ① Ⓒ ④ 2.54 0.7 W × 1 D 6.5 Production date code 6.8 10 901 10 φ 3.9 01 EF 2 10 Production date code 6.8 78 3.3 2.54 6 – 0.6 ± 0.1 t = 0.15 3.3±0.5 BCD ② Ⓒ ⑧ ① Ⓒ ④ 2.54 456 89 67 A 3.3±0.5 6.5 23 345 2.54 6 – 0.6 ± 0.1 t = 0.15 2.54 OSD-2111 (Real code) OSD-2131 (Complementary code) 0.7 W × 1 D 10 ② Ⓒ ⑧ 3.3 2.54 φ 3.9 3.3±0.5 BCD ① Ⓒ ④ 2.54 ② Ⓒ ⑧ ① Ⓒ ④ 2.54 2.54 3.3 2.54 6 – 0.6 ± 0.1 t = 0.15 SD-1000 / 2000 ROTARY CODED SWITCHES ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) OSD-1010B (Real code) OSD-1030B (Complementary code) OSD-2010B (Real code) OSD-2030B (Complementary code) 0.6 W × 3.2 L × 1.2 D 10 1 4 ⑧ Ⓒ ② 4 1 0.6 W × 3.2 L × 1.2 D 10 ⑧ Ⓒ ② 13 10 13 01 EF 2 10 89 67 A 345 BCD 2.54 6 – 0.6 ± 0.1 t = 0.15 OSD-1210B (Real code) OSD-1230B (Complementary code) 2.54 6 – 0.6 ± 0.1 t = 0.15 0.6 W × 3.2 L × 1.5 D 10 1 4 Production date code OSD-2210B (Real code) OSD-2230B (Complementary code) 0.6 W × 3.2 L × 1.5 D 10 1 ① Ⓒ ④ Production date code ⑧ Ⓒ ② 4 1 2.54 1 ① Ⓒ ④ 2.54 ⑧ Ⓒ ② 13 10 13 01 EF 2 2.54 ① Ⓒ ④ 1 ① Ⓒ ④ 2.54 Production date code 6 – 0.6 ± 0.1 t = 0.15 2.54 2.54 1 BCD 10 89 67 A 345 Production date code 6 – 0.6 ± 0.1 t = 0.15 SD-1000 / 2000 ROTARY CODED SWITCHES ■ CODE FORMAT No. of positions Position Real code Code Complementary code 0 8 4 2 1 8 4 2 1     O O O O 1 2 SD-1000 series (16 positions) SD-2000 series (10 positions) 3 4 5 6 7 8 9 O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O A B C D E F O O O O O O O O O O O O O O O O O O O O O O O O O…Contact closed ■ TERMINAL CONNECTION / P.C.B. THROUGH HOLE DIMENSIONS Top setting Real code Terminal pin layout (Bottom view) 8 C 2 Side setting Operating face of real code Complementary code 1 C 4 8 C 2 1 C 4 1 C 4 1 C 4 8 C 2 8 C 2 2.54 ± 0.1 6 – φ 0.8 hole 2.54 ± 0.1 2.54 ± 0.1 2.54 ± 0.1 6 – φ 0.8 hole P.C.B. dimensions (Bottom view) Operating face of complementary code SD-1000/2000 case SD-1000/2000 case ■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS 1.75 2.54 6–1 2.54 1.75 10.5 (14) (Unit: mm) SD-1000 / 2000 ROTARY CODED SWITCHES ■ PACKAGING SPECIFICATIONS O Taping version is packaged in 500 pcs. per reel. Orders will be accepted for units of 500 pcs., i.e., 500, 1000, 1500 pcs., etc. OTaping version is boxed with one reel (500 pcs.). Maximum number of consecutive missing pieces=2 Leader length and reel dimension are shown in the diagrams below: OEmbossed tape dimensions OReel dimensions (Unit: mm) (In accordance with EIAJ ET-7200A) Empty Filled 2 ± 0.5 End φ 13 ± 0.2 Head 40 mm min. Direction of feed φ 80 ± 1 Empty φ 330 ± 2 25.4 ± 1 φ 21 ± 0.8 20 pitches min. Leader 400 mm min. Part No. label 29.4 ± 1 (Unit: mm) 16 ± 0.1 4 ± 0.1 2 ± 0.1 0.4 ± 0.1 11.5 ± 0.1 24 φ 1.5 +0.1 0 1.75 ± 0.1 (In accordance with EIAJ RC-1009B) Direction of feed 4.8 O Tray version is packaged in 50 pcs. per tray. Orders will be accepted for units of 50 pcs., i. e., 50, 100, 150 pcs. etc. OTray version is boxed with 10 trays. OThe smallest unit of bulk pack in a plastic bag is 10 pcs. per pack. Orders will be accepted for unit of minimum 10 pcs., i.e., 10, 20, 30 pcs. , etc. O Boxing of bulk in a plastic bag is performed with 25 pcs. (standard 50 pcs.) per box.
SD-1010W 价格&库存
很抱歉,暂时无法提供与“SD-1010W”相匹配的价格&库存,您可以联系我们找货
