SC-1010W
SC-1010W
    NIDEC(尼得科)
    SW5_10X10MM_TM
    Nidec 1010 BCH code Real 5N 100mA 5V 10.0 x 10.0mm
SC-1010W 数据手册
ROTARY CODED SWITCHES SC-1000/2000 INTERNAL STRUCTURE SC-1000 / 2000 series RoHS compliant 1 4 3 2 6 7 ■ FEATURES ORoHS compliant OFine click with metallic spring O Low profile of 3.9 mm makes perfect for high density board mounting applications O Gold plated contact provides excellent reliability O Cross and minus slot are available O Terminal pin arrangement 4-1 5 Part name Material Flammability ① Housing Polyphenylenesulphide UL94V-0 ② Metallic spring Stainless (SUS 301) — ③ “O” ring Silicone rubber UL94HB ④ Insert rotor ⑤ Base ⑥ Contact ⑦ Terminal pin Rotor : Polyamide Pattern : Copper alloy, Gold-plated UL94V-0 Polyphenylenesulphide UL94V-0 Copper alloy, Gold-plated — ■ PART NUMBER DESIGNATION S C - 1 0 1 0 T B Series name Shape of terminal No. of positions B:Gull wing (Top setting type only) Blank : Through hole pin (Snap-in terminal pin) 1:16 positions 2:10 positions Shape of rotor Form of packaging 0:Without knob (Minus slot) 1:With knob (with extended shaft) 2:Without knob (Cross slot) T:Taping (Gull wing type only) W:Tray packaging Blank:Bulk in plastic bag Code format Setting position 1:Real code (Rotor color Yellow) 3:Complementary code (Rotor color Red) 0:Top setting 1:Side setting ※ Please refer to the LIST OF PART NUMBERS when placing orders. SC-1000 / 2000 ROTARY CODED SWITCHES ■ LIST OF PART NUMBERS OBinary coded decimal Shape of rotor Without knob (Minus slot) Top setting (Through hole With knob pin) Without knob (Cross slot) Without knob (Minus slot) Side setting (Through hole With knob pin) Without knob (Cross slot) Form of packaging Real code (Rotor : Color Yellow) Complementary code (Rotor : Color Red) Pieces in package SC-2010 SC-2010W SC-2110 SC-2110W SC-2210 SC-2210W SC-2011 SC-2011W SC-2111 SC-2111W SC-2211 SC-2211W SC-2010B SC-2010WB SC-2010TB SC-2210B SC-2210WB SC-2210TB SC-2030 SC-2030W SC-2130 SC-2130W SC-2230 SC-2230W SC-2031 SC-2031W SC-2131 SC-2131W SC-2231 SC-2231W SC-2030B SC-2030WB SC-2030TB SC-2230B SC-2230WB SC-2230TB 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 500 pcs./reel 25 pcs./pack 50 pcs./tray 500 pcs./reel Real code (Rotor : Color Yellow) Complementary code (Rotor : Color Red) Pieces in package SC-1010 SC-1010W SC-1110 SC-1110W SC-1210 SC-1210W SC-1011 SC-1011W SC-1111 SC-1111W SC-1211 SC-1211W SC-1010B SC-1010WB SC-1010TB SC-1210B SC-1210WB SC-1210TB SC-1030 SC-1030W SC-1130 SC-1130W SC-1230 SC-1230W SC-1031 SC-1031W SC-1131 SC-1131W SC-1231 SC-1231W SC-1030B SC-1030WB SC-1030TB SC-1230B SC-1230WB SC-1230TB 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 500 pcs./reel 25 pcs./pack 50 pcs./tray 500 pcs./reel Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Without knob (Minus slot) Tray packaging Taping Top setting (Gull wing) Plastic bag Without knob (Cross slot) Tray packaging Taping OBinary coded hexadecimal Shape of rotor Without knob (Minus slot) Top setting (Through hole With knob pin) Without knob (Cross slot) Without knob (Minus slot) Side setting (Through hole With knob pin) Without knob (Cross slot) Form of packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Tray packaging Plastic bag Without knob (Minus slot) Tray packaging Taping Top setting (Gull wing) Plastic bag Without knob (Cross slot) Tray packaging Taping ※ Verify the above part numbers when placing orders. ※ Taping and tray version can be supplied only in reel or tray units. SC-1000 / 2000 ROTARY CODED SWITCHES ■ STANDARD SPECIFICATIONS BCD (Real code, complementary code) BCH (Real code, complementary code) Circuit type Operating temperature range − 40 ~ 85 °C Storage temperature range Washable ※Please refer to page 150,151 Sealing ■ ELECTRICAL CHARACTERISTICS Contact rating Non-switching Switching Minimum DC50 V 100 mA DC5 V 100 mA DC20 mV 1 μA Contact resistance 100 mΩ maximum Insulation resistance 1000 MΩ (DC100 V) minimum Dielectric strength Without knob Top setting 0.63 g With knob Top setting 0.73 g Without knob Side setting 0.76 g With knob Side setting 0.86 g Net weight AC250 V, 60 s ■ ENVIRONMENTAL CHARACTERISTICS (Amplitude) 1.5 mm or (Acceleration) 98 m/s2, 10-500-10 Hz, 3 directions for 2 h each Vibration ■ MECHANICAL CHARACTERISTICS No. of positions Adjustment torque 490 m/s2, 11 ms 6 directions for 3 times each Resistance load DC50V 100mA 40 °C, Relative humidity 90 ~ 95 %, 240 h 20000 steps DC5 V, 100 mA Shock 16 (SC-1000), 10 (SC-2000) Humidity 4 ~ 20 mN·m {41 ~ 204 gf·cm} Load life 22.5° (SC-1000), 36° (SC-2000) High temperature exposure 85 °C, 96 h Terminal strength (Through hole pin only) 10 N {1.02 kgf} minimum Low temperature exposure − 40 °C, 96 h Stop strength (With knob only) 10 N {1.02 kgf}, 10 s Solderability 245 ± 3 °C, 2 ~ 3 s Stepping angle Gull wing Reflow : Peak temperature 255 °C (Please refer to the profile below.) Manual soldering:350 ± 10 °C, 3 ~ 4 s Thermal shock Solvent resistance (Dipping) − 40 (0.5 h) ~ 85 °C ( 0.5 h ), 5 cycles Solvent : IPA (Isopropyl alchol) Temperature : 23 ± 5 °C Time : 5 ± 0.5 minutes 〈Reflow profile for soldering heat evaluation〉 Through hole pin Shear (Gull wing only) Flow : 260 ± 3 °C as the temperature in a pot of molten solder, immersion from head of terminal to backside of board 5 ~ 6 s, two times maximum Manual soldering:380 ± 10 °C, 3 ~ 4 s 5 N {0.51 kgf}, 10 s Substrate bending (Gull wing only) Width 90 mm, bend 3 mm, 5 s, 1 time Pull-off strength (Gull wing only) 5 N {0.51 kgf}, 10 s { } : Reference only (℃) 250 Peak : 250 +5 0℃ Over 230 ℃ Temperature Soldering heat 200 150 100 50 180 ℃ 150 ℃ Pre Heating Zone 90 ± 30 s 30 ± 10 s Heating time Soldering Zone Reflow : two times maximum SC-1000 / 2000 ROTARY CODED SWITCHES ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) OSC-1010 (Real code) OSC-1030 (Complementary code) OSC-2010 (Real code) OSC-2030 (Complementary code) 0.6 W × 3.2 L × 1.2 D 10 3.9 0.6 W × 3.2 L × 1.2 D 3.3±0.5 1.27 10 3.9 3.3±0.5 Ⓒ 1.27 Ⓒ 7.62 10 7.62 45 23 6 10 CD AB E 789 F01 5 – 0.6 ± 0.1 t = 0.15 2.54 Production date code ① ② ④ ⑧ 2.54 2.54 OSC-1210 (Real code) OSC-1230 (Complementary code) 3.9 ① ② ④ ⑧ 2.54 2.54 OSC-2210 (Real code) OSC-2230 (Complementary code) 0.6 W × 3.2 L × 1.5 D 10 5 – 0.6 ± 0.1 t = 0.15 2.54 Production date code 0.6 W × 3.2 L × 1.5 D 3.3±0.5 1.27 10 3.9 3.3±0.5 Ⓒ 1.27 Ⓒ 7.62 10 7.62 45 23 6 10 CD AB E 789 F01 5 – 0.6 ± 0.1 t = 0.15 2.54 Production date code ① ② ④ ⑧ 2.54 2.54 OSC-1110 (Real code) OSC-1130 (Complementary code) 3.9 3.3±0.5 1.27 10 6.5 3.9 3.3±0.5 2.54 F01 5 – 0.6 ± 0.1 t = 0.15 2.54 ① ② ④ ⑧ Production date code 2.54 2.54 7.62 23 10 7.62 901 φ 3.9 78 CD AB E Production date code 1.27 Ⓒ 456 φ 3.9 Ⓒ 45 23 6 2.54 0.7 W × 1 D 6.5 789 10 ① ② ④ ⑧ OSC-2110 (Real code) OSC-2130 (Complementary code) 0.7 W × 1 D 10 5 – 0.6 ± 0.1 t = 0.15 2.54 Production date code 5 – 0.6 ± 0.1 t = 0.15 2.54 ① ② ④ ⑧ 2.54 2.54 SC-1000 / 2000 ROTARY CODED SWITCHES ■ OUTLINE DIMENSIONS OSC-1011 (Real code) OSC-1031 (Complementary code) 0.6 W × 3.2 L × 1.2 D 6.8 10 Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) OSC-2011 (Real code) OSC-2031 (Complementary code) 0.6 W × 3.2 L × 1.2 D 6.8 10 Production date code Production date code 23 10 78 10 456 3.3 ± 0.5 3.3 ± 0.5 901 2.54 ⑧ ④ ② ① Ⓒ 0.6 ± 0.1 t = 0.15 2.54 3.3 2.54 2.54 0.6 W × 3.2 L × 1.5 D 6.8 Ⓒ 0.6 ± 0.1 t = 0.15 2.54 2.54 OSC-1211 (Real code) OSC-1231 (Complementary code) 10 ⑧ ④ ② ① 3.3 2.54 2.54 OSC-2211 (Real code) OSC-2231 (Complementary code) 0.6 W × 3.2 L × 1.5 D 6.8 10 Production date code Production date code 23 10 78 10 456 3.3 ± 0.5 3.3 ± 0.5 901 2.54 ⑧ ④ ② ① Ⓒ 0.6 ± 0.1 t = 0.15 2.54 3.3 2.54 2.54 2.54 OSC-1111 (Real code) OSC-1131 (Complementary code) ⑧ ④ ② ① 2.54 3.3 2.54 2.54 OSC-2111 (Real code) OSC-2131 (Complementary code) 0.7 W × 1 D 10 Ⓒ 0.6 ± 0.1 t = 0.15 0.7 W × 1 D 6.5 6.8 10 Production date code 6.5 6.8 Production date code φ 3.9 10 φ 3.9 45 23 6 10 CD AB E 789 2.54 3.3 ± 0.5 3.3 ± 0.5 F01 2.54 Ⓒ ⑧ ④ ② ① 0.6 ± 0.1 t = 0.15 2.54 3.3 2.54 2.54 Ⓒ ⑧ ④ ② ① 2.54 0.6 ± 0.1 t = 0.15 2.54 3.3 2.54 SC-1000 / 2000 ROTARY CODED SWITCHES ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) 0.6 W × 3.2 L × 1.2 D 4 1.27 1 10 OSC-2010B (Real code) OSC-2030B (Complementary code) 0.6 W × 3.2 L × 1.2 D 4 10 Ⓒ 1.27 1 OSC-1010B (Real code) OSC-1030B (Complementary code) Ⓒ 23 13 10 13 78 10 456 901 2.54 Production date code 5 – 0.6 ± 0.1 t = 0.15 OSC-1210B (Real code) OSC-1230B (Complementary code) 0.6 W × 3.2 L × 1.5 D 4 2.54 Production date code 5 – 0.6 ± 0.1 t = 0.15 OSC-2210B (Real code) OSC-2230B (Complementary code) 1.27 1 10 2.54 2.54 0.6 W × 3.2 L × 1.5 D 4 10 Ⓒ 1.27 1 2.54 1 ⑧ ④ ② ① 1 ⑧ ④ ② ① 2.54 Ⓒ 23 13 10 13 78 10 456 901 2.54 2.54 1 ⑧ ④ ② ① 1 ⑧ ④ ② ① 2.54 Production date code 5 – 0.6 ± 0.1 t = 0.15 2.54 2.54 2.54 Production date code 5 – 0.6 ± 0.1 t = 0.15 ■ VARIOUS KNOBS Yellow, red, white, gray and transparent knob, and translucent thumbwheel type are available as a semi standard item. (Switches with knob are not washable) Colored knob Translucent thumbwheel SC-1000 / 2000 ROTARY CODED SWITCHES ■ CODE FORMAT SC-1000 series (16 positions) SC-2000 series (10 positions) 3 4 5 6 7 8 9 No. of positions Position Real code Code Complementary code 0 8 4 2 1 8 4 2 1     O O O O 1 2 O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O O A B C D E F O O O O O O O O O O O O O O O O O O O O O O O O O…Contact closed ■ RECOMMENDED P.C.B. THROUGH HOLE DIMENSIONS Top setting Side setting Real code Complementary code 8 4 2 1 8 4 2 1 Operating face of complementary code 8 4 2 1 2.54 8 4 2 1 C C 7.62 C (14) C Operating face of real code 10.5 Terminal pin layout (Bottom view) P.C.B. PAD OUTLINE DIMENSIONS (Unit: mm) 1.75 ■ TERMINAL CONNECTION / 0 Operating face SC-1000/2000 case SC-1000/2000 case 5 – φ 0.8 hole 5–1 1.75 2.54 ± 0.1 2.54 ± 0.1 5 – φ 0.8 hole 7.62 ± 0.1 P.C.B. dimensions (Bottom view) 2.54 ± 0.1 2.54 ± 0.1 SC-1000 / 2000 ROTARY CODED SWITCHES ■ PACKAGING SPECIFICATIONS OTaping version is packaged in 500 pcs. per reel. Orders will be accepted for units of 500 pcs., i.e., 500, 1000, 1500 pcs., etc. OTaping version is boxed with one reel (500 pcs.). Maximum number of consecutive missing pieces = 2 Leader length and reel dimension are shown in the diagrams below: OEmbossed tape dimensions OReel dimensions (Unit: mm) (In accordance with EIAJ ET-7200A) Empty Filled 2 ± 0.5 End φ 13 ± 0.2 Head 40 mm min. Direction of feed φ 80 ± 1 Empty φ 330 ± 2 25.4 ± 1 φ 21 ± 0.8 20 pitches min. Leader 400 mm min. Part No. label 29.4 ± 1 (Unit: mm) 16 ± 0.1 4 ± 0.1 2 ± 0.1 0.4 ± 0.1 11.5 ± 0.1 24 φ 1.5 +0.1 0 1.75 ± 0.1 (In accordance with EIAJ RC-1009B) Direction of feed 4.8 O Tray version is packaged in 50 pcs. per tray. Orders will be accepted for units of 50 pcs., i. e., 50, 100, 150 pcs. etc. OTray version is boxed with 10 trays. OThe smallest unit of bulk pack in a plastic bag is 10 pcs. per pack. Orders will be accepted for unit of minimum 10 pcs., i.e., 10, 20, 30 pcs. , etc. O Boxing of bulk pack in a plastic bag is performed with 25 pcs. (standard 50 pcs.) per box.
SC-1010W 价格&库存
很抱歉,暂时无法提供与“SC-1010W”相匹配的价格&库存,您可以联系我们找货
SC-1010W
  • 2+18.84384
  • 10+17.67749
库存:44
