WPE0531P
Integrated in
OVP&OCP products
provider
2-Line Ultra Low Capacitance TVS Diode
Description
Mechanical Characteristics
The WPE0531P is an uni-directional TVS diode, utilizing
n
Package: DFN1006-3 (1.0×0.6×0.5mm)
leading monolithic silicon technology to provide fast
n
Lead Finish: NiPdAu
response time and low ESD clamping voltage, making this
n
Case Material: “Green” Molding Compound.
device an ideal solution for protecting voltage sensitive
n
Moisture Sensitivity: Level 3 per J-STD-020
n
Terminal Connections: See Diagram Below
n
Marking Information: See Below
high-speed data lines. The WPE0531P has an ultra-low
capacitance with a typical value at 0.6pF, and complies
with the IEC 61000-4-2 (ESD) standard with ±25kV air and
±20kV contact discharge. It is assembled into an ultra
small 1.0x0.6x0.5mm lead-free DFN package. The small
Applications
size, ultra-low capacitance and high ESD surge protection
make WPE0531P an ideal choice to protect cell phone,
digital video interfaces and other high-speed ports.
Features
n
Ultra small package: 1.0x0.6x0.5mm
n
Ultra low capacitance: 0.6pF typical
n
Ultra low leakage: nA level
n
Working voltage: 5V
n
Low clamping voltage
n
3-pin leadless package
n
Complies with following standards:
n
Cellular Handsets and Accessories
n
Display Ports
n
MDDI Ports
n
HDMI 1.3 and 1.4
n
Digital Video Interface (DVI)
n
PCI Express and Serial SATA Ports
n
Notebook Computer
n
USB 2.0 and 3.0 Ports
Marking Information
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±25kV
Contact discharge: ±20kV
n
– IEC61000-4-5 (Lightning) 5A (8/20μs)
n
RoHS Compliant
Dimensions & Symbol(Unit: mm Max)
Dot denotes pin1
Details marking code reference customer approval list
Ordering Information
Part Number
WPE0531P
Rev.A_Aug,2016
-1-
Packaging
10000/Tape & Reel
Reel Size
7 inch
www.wpmtek.com
WPE0531P
Integrated in
OVP&OCP products
provider
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
75
W
Peak Pulse Current (8/20µs)
Ipp
5
A
ESD per IEC 61000−4−2 (Air)
±25
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
kV
±20
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
Symbol
Reverse Working Voltage
VRWM
Breakdown Voltage
VBR
Min
Typ
Max
Unit
5
V
6
V
Test Condition
Pin 1 or pin 2 to pin 3 and between
pin 1 and pin 2
IT = 1mA, pin 1 or pin 2 to pin 3
and between pin 1 and pin 2
VRWM = 5V, Pin 1 or pin 2 to pin 3
Reverse Leakage Current
IR
0.5
uA
Clamping Voltage
VC
10
V
IPP = 1A (8 x 20uS pulse), pin 1 or
pin 2 to pin 3
Clamping Voltage
VC
15.5
V
IPP = 5A (8 x 20uS pulse), pin 1
or pin 2 to pin 3
Junction Capacitance
CJ
0.2
0.3
pF
CJ
0.4
0.6
pF
Rev.A_Aug,2016
-2-
VR = 0V, f = 1MHz, between pin 1
and pin 2
VR = 0V, f = 1MHz, pin 1 or pin 2
to pin 3
www.wpmtek.com
WPE0531P
Integrated in
OVP&OCP products
provider
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
Rev.A_Aug,2016
-3-
www.wpmtek.com
WPE0531P
Integrated in
OVP&OCP products
provider
Soldering Parameters
Reflow Condition
Pre Heat
Pb-Free assembly
-Temperature Min (Ts(min))
+150℃
-Temperature Max(Ts(max))
+200℃
-Time (Min to Max) (ts)
60-180 secs.
Average ramp up rate (Liquid us Temp (TL) to peak)
3℃/sec. Max
Ts(max) to TL - Ramp-up Rate
3℃/sec. Max
Reflow
-Temperature(TL) (Liquid us)
+217℃
-Temperature(tL)
60-150 secs.
Peak Temp (Tp)
+260(+0/-5)℃
Time within 5℃ of actual Peak Temp (tp)
30 secs. Max
Ramp-down Rate
6℃/sec. Max
Time 25℃ to Peak Temp (TP)
8 min. Max
Do not exceed
+260℃
Rev.A_Aug,2016
-4-
www.wpmtek.com
WPE0531P
Integrated in
OVP&OCP products
provider
Package Mechanical Data
Suggested Land Pattern
Contact Information
WPMTEK Incorporated Limited
Floor 1 Building 4#, Binxianghua Industry Park, No.7,
Huada Road, Hualian Community, Longhua New District, Shenzhen
TEL:86755-29308003
FAX:86755-23739900
wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes
no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising
from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential
or incidental damages.
Rev.A_Aug,2016
-5-
www.wpmtek.com
很抱歉,暂时无法提供与“WPE0531P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.12000
- 100+0.11200
- 300+0.10400
- 500+0.09600
- 2000+0.09200
- 5000+0.08960
