WPE05CT23BL
WPE05CT23BL
    WPMTEK(维攀微)
    SOT-23
    ESD抑制器/TVS二极管 SOT23-3 15V 20A
WPE05CT23BL 数据手册
WPEXXCT23BL Integrated in OVP&OCP products provider /LQH%LGLUHFWLRQDO796'LRGH$UUD\ Description Mechanical Characteristics The :3(;;&7%/ is a bi-directional TVS diode array, utilizing leading monolithic silicon technology to provide fast re-sponse time and low ESD clamping voltage, making this device an ideal solution for protecting sensitive semicon-ductor components from damage. The :3(;;&7%/ com-plies with the IEC 61000-4-2 (ESD) with ±30kV air and ±30kV contact discharge. It is assembled into a lead-free SOT-23 package. It is designed to protect components which are connected to  Package: SOT-23  Lead Finish: Matte Tin  Case Material: “Green” Molding Compound.  Moisture Sensitivity: Level 3 per J-STD-020  Terminal Connections: See Diagram Below  Marking Information: See Below data and transmission lines from voltage surges.  Cellular Handsets and Accessories  Notebooks and Handhelds  Portable Instrumentation  Set Top Box  Industrial Controls  Server and Desktop PC Features  300W peak pulse power (8/20μs)  Protects two bi-directional lines  Ultra low leakage: nA level  Operating voltage: 3.3V,5V, 12V, 15V, 24V, 32V, Applications Marking Information 36V  Low clamping voltage  Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV  XXC = Device Marking 3 XXC RoHS Compliant 1 Dimensions and Pin Configuration 2 Ordering Information Part Number Packaging Reel Size WPEXXCT23BL 3000/Tape & Reel 7 inch Circuit and Pin Schematic Rev.B_Aug,2017 -1- www.wpmtek.com WPEXXCT23BL Integrated in OVP&OCP products provider /LQH%LGLUHFWLRQDO796'LRGH$UUD\ Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Value Unit Ppk 300 W ±30 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range kV ±30 TJ −55 to +125 °C Tstg −55 to +150 °C Electrical Characteristics (TA=25°C unless otherwise specified) WPE03CT23BL Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR Max Unit 3.3 V 3.8 Test Condition V IT = 1mA Reverse Leakage Current IR 1.0 μA VRWM = 3.3V Clamping Voltage VC 6 V IPP = 1A (8 x 20µs pulse) Clamping Voltage VC 12 V IPP = 25A (8 x 20µs pulse) Peak Pulse Current IPP 25 A tp = 8/20μs Junction Capacitance CJ 100 pF VR = 0V, f = 1MHz, Pin 1 to Pin 3 or Pin 2 to Pin 3 Max Unit 5 V WPE05CT23BL Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR 6 Test Condition V IT = 1mA Reverse Leakage Current IR 1.0 μA VRWM = 5V Clamping Voltage VC 8 V IPP = 1A (8 x 20µs pulse) Clamping Voltage VC 15 V IPP = 20A (8 x 20µs pulse) Peak Pulse Current IPP 20 A tp = 8/20μs Junction Capacitance CJ 80 pF VR = 0V, f = 1MHz, Pin 1 to Pin 3 or Pin 2 to Pin 3 Rev.B_Aug,2017 -2- www.wpmtek.com WPEXXCT23BL Integrated in OVP&OCP products provider /LQH%LGLUHFWLRQDO796'LRGH$UUD\ WPE12CT23BL Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR Max Unit 12 V 13.3 Test Condition V IT = 1mA Reverse Leakage Current IR 0.5 μA VRWM = 12V Clamping Voltage VC 18 V IPP = 1A (8 x 20µs pulse) Clamping Voltage VC 25 V IPP = 12A (8 x 20µs pulse) Peak Pulse Current IPP 12 A tp = 8/20μs Junction Capacitance CJ 50 pF VR = 0V, f = 1MHz, Pin 1 to Pin 3 or Pin 2 to Pin 3 Max Unit 15 V WPE15CT23BL Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR 16.7 Test Condition V IT = 1mA Reverse Leakage Current IR 0.5 μA VRWM = 15V Clamping Voltage VC 20 V IPP = 1A (8 x 20µs pulse) Clamping Voltage VC 37.5 V IPP = 8A (8 x 20µs pulse) Peak Pulse Current IPP 8 A tp = 8/20μs Junction Capacitance CJ 40 pF VR = 0V, f = 1MHz, Pin 1 to Pin 3 or Pin 2 to Pin 3 Rev.B_Aug,2017 -3- www.wpmtek.com WPEXXCT23BL Integrated in OVP&OCP products provider /LQH%LGLUHFWLRQDO796'LRGH$UUD\ WPE24CT23BL Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR Max Unit 24 V 27 Test Condition V IT = 1mA Reverse Leakage Current IR 0.2 μA VRWM = 24V Clamping Voltage VC 40 V IPP = 1A (8 x 20µs pulse) Clamping Voltage VC 60 V IPP = 5A (8 x 20µs pulse) Peak Pulse Current IPP 5 A tp = 8/20μs Junction Capacitance CJ 15 30 pF VR = 0V, f = 1MHz, Pin 1 to Pin 3 or Pin 2 to Pin 3 Typ Max Unit 32 V WPE32CT23BL Parameter Reverse Working Voltage Breakdown Voltage Symbol Min VRWM VBR 35.6 Test Condition V IT = 1mA Reverse Leakage Current IR 0.2 μA VRWM = 36V Clamping Voltage VC 45 V IPP = 1A (8 x 20µs pulse) Clamping Voltage VC 67 V IPP = 4.5A (8 x 20µs pulse) Peak Pulse Current IPP 4 A tp = 8/20μs Junction Capacitance CJ 15 25 pF VR = 0V, f = 1MHz, Pin 1 to Pin 3 or Pin 2 to Pin 3 Typ Max Unit 36 V WPE36CT23BL Parameter Reverse Working Voltage Breakdown Voltage Symbol Min VRWM VBR 38 Test Condition V IT = 1mA Reverse Leakage Current IR 0.2 μA VRWM = 36V Clamping Voltage VC 50 V IPP = 1A (8 x 20µs pulse) Clamping Voltage VC 75 V IPP = 4A (8 x 20µs pulse) Peak Pulse Current IPP 4 A tp = 8/20μs Junction Capacitance CJ 20 pF VR = 0V, f = 1MHz, Pin 1 to Pin 3 or Pin 2 to Pin 3 Rev.B_Aug,2017 12 -4- www.wpmtek.com WPEXXCT23BL Integrated in OVP&OCP products provider /LQH%LGLUHFWLRQDO796'LRGH$UUD\ Typical Performance Characteristics (TA=25°C unless otherwise Specified) Power Derating Curve Peak Pulse Power vs. Pulse Time 8 X 20μs Pulse Waveform Rev.B_Aug,2017 -5- www.wpmtek.com WPEXXCT23BL Integrated in OVP&OCP products provider /LQH%LGLUHFWLRQDO796'LRGH$UUD\ SOT-23 Package Outline Drawing DIMENSIONS SYM MIN MILLIMETERS NOM A 0.90 -- 1.15 0.035 -- 0.045 A1 0.00 -- 0.10 0.000 -- 0.004 A2 0.90 -- 1.05 0.035 -- 0.041 b 0.30 -- 0.50 0.012 -- 0.020 c 0.08 -- 0.15 0.003 -- 0.006 D 2.80 -- 3.00 0.110 -- 0.118 E 1.20 -- 1.40 0.047 -- 0.055 E1 2.25 -- 2.25 0.089 e e1 MAX MIN INCHES NOM MAX 0.95TYP 1.80 L -- 0.100 0.037TYP 2.00 0.071 0.55REF -- 0.079 0.022REF L1 0.30 -- 0.50 0.012 -- 0.020 Θ 0° -- 8° 0° -- 8° Rev.B_Aug,2017 -6- www.wpmtek.com WPEXXCT23BL Integrated in OVP&OCP products provider /LQH%LGLUHFWLRQDO796'LRGH$UUD\ Suggested Land Pattern SYM DIMENSIONS INCHES MILLIMETERS C .087 2.20 E .037 0.95 E1 .075 1.90 G .031 0.80 X .039 1.00 Y .055 1.40 Z .141 3.60 Contact information WPMTEK Incorporated Limited Room 206-207,2nd Floor,Block 3,Minxing lndustry Park,Minzhi Longhua New District,Shenzhen TEL:86755-29308003 FAX:86755-23739900 wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.B_Aug,2017 -7- www.wpmtek.com
WPE05CT23BL 价格&库存
很抱歉,暂时无法提供与“WPE05CT23BL”相匹配的价格&库存,您可以联系我们找货
WPE05CT23BL
  • 1+0.16500
  • 100+0.15400
  • 300+0.14300
  • 500+0.13200
  • 2000+0.12650
  • 5000+0.12320
