VB2703K
VB2703K
    VBSEMI(微碧)
    SOT-23
    1个P沟道 耐压:70V 电流:400MA
VB2703K 数据手册
VB2703K www.VBsemi.com P-Channel 70 V (D-S) MOSFET FEATURES PRODUCT SUMMARY VDS (V) - 70 RDS(on) () 3.6 at VGS = - 10 V VGS(th) (V) ID (mA) - 1 to - 3 -400 • Halogen-free According to IEC 61249-2-21 Definition • TrenchFET® Power MOSFET • High-Side Switching • Low On-Resistance: 3  • Low Threshold: - 2 V (typ.) • Fast Swtiching Speed: 20 ns (typ.) • Low Input Capacitance: 20 pF (typ.) • Compliant to RoHS Directive 2002/95/EC S TO-236 (SOT-23) G G 1 3 S D 2 D P-Channel MOSFET ABSOLUTE MAXIMUM RATINGS TA = 25 °C, unless otherwise noted Symbol Parameter Limit Drain-Source Voltage VDS - 70 Gate-Source Voltage VGS ± 20 Continuous Drain Currenta TA = 25 °C TA = 100 °C Pulsed Drain Currentb Power Dissipationa Maximum Junction-to-Ambienta Operating Junction and Storage Temperature Range ID IDM TA = 25 °C TA = 100 °C PD Unit V - 400 - 320 mA -1200 420 200 mW RthJA 350 °C/W TJ, Tstg - 55 to 150 °C Notes: a. Surface mounted on FR4 board. b. Pulse width limited by maximum junction temperature. 1 VB2703K www.VBsemi.com SPECIFICATIONS TA = 25 °C, unless otherwise noted Limits Parameter Symbol Test Conditions Min. VDS VGS = 0 V, ID = - 10 µA - 70 VGS(th) VDS = VGS, ID = - 250 µA -1 Typ.a Max. Unit Static Drain-Source Breakdown Voltage Gate-Threshold Voltage Gate-Body Leakage Zero Gate Voltage Drain Current On-State Drain Currenta Drain-Source On-Resistancea IGSS IDSS ID(on) RDS(on) -3 VDS = 0 V, VGS = ± 20 V ± 10 VDS = 0 V, VGS = ± 10 V ± 200 VDS = 0 V, VGS = ± 10 V, TJ = 85 °C ± 500 VDS = 0 V, VGS = ± 5 V ± 100 VDS = - 70 V, VGS = 0 V - 25 VDS = - 70 V, VGS = 0 V, TJ = 85 °C - 50 VGS = - 10 V, VDS = - 10 V - 600 VGS = - 4.5 V, ID = - 25 mA 4.0 3.6 Diode Forward Voltage VDS = - 10 V, ID = - 100 mA VSD IS = - 100 mA, VGS = 0 V nA mA VGS = - 10 V, ID = - 100 mA gfs µA - 250 VGS = - 10 V, VDS = - 4.5 V VGS = - 10 V, ID = - 100 mA, TJ =125 °C Forward Transconductancea V  9 80 mS - 1.4 V Dynamic Total Gate Charge Qg Gate-Source Charge Qgs Gate-Drain Charge Qgd Input Capacitance Ciss Output Capacitance Coss Reverse Transfer Capacitance Crss 1.9 VDS = - 30 V, VGS = - 15 V ID  - 100 mA 1.1 VDS = - 25 V, VGS = 0 V f = 1 MHz 10 nC 0.8 22 pF 5 Switchingb Turn-On Time td(on) Turn-Off Time td(off) VDD = - 25 V, RL = 150  ID  - 200 mA, VGEN = - 10 V, Rg = 10  20 35 ns Notes: a. Pulse test: PW  300 µs duty cycle  2 %. b. Switching time is essentially independent of operating temperature. Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 2 VB2703K www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 1.0 1200 VGS = 10 V TJ = - 55 °C 5V 0.8 I D - Drain Current (mA) ID - Drain Current (A) 6V 0.6 4V 0.4 3V 900 25 °C 125 °C 600 300 0.2 2V 0.0 0 0 1 2 3 4 5 0 2 VDS - Drain-to-Source Voltage (V) 4 6 8 10 VGS - Gate-to-Source Voltage (V) Output Characteristics Transfer Characteristics 40 20 VGS = 0 V VGS = 4.5 V 32 C - Capacitance (pF) RDS(on) - On-Resistance (Ω) 16 12 VGS = 5 V 8 VGS = 10 V 4 Ciss 24 16 Coss 8 Crss 0 0 0 200 400 600 800 0 1000 5 ID - Drain Current (mA) 10 25 Capacitance 15 1.8 ID = 400 mA 1.5 12 VDS = 35 V RDS(on) - On-Resistance (Normalized) VGS - Gate-to-Source Voltage (V) 20 V DS - Drain-to-Source Voltage (V) On-Resistance vs. Drain Current VDS = 58 V 9 6 3 0 0.0 15 VGS = 10 V at 400 mA 1.2 VGS = 4.5 V at 25 mA 0.9 0.6 0.3 0.3 0.6 0.9 1.2 Qg - Total Gate Charge (nC) Gate Charge 1.5 1.8 0.0 - 50 - 25 0 25 50 75 100 125 150 TJ - Junction Temperature (°C) On-Resistance vs. Junction Temperature 3 VB2703K www.VBsemi.com TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted 10 1000 RDS(on) - On-Resistance (Ω) I S - Source Current (A) VGS = 0 V 100 TJ = 125 °C 10 TJ = 25 °C 8 ID = 400 mA 6 4 ID = 200 mA 2 TJ = - 55 °C 0 1 0.00 0.3 0.6 0.9 1.2 V SD - Source-to-Drain Voltage (V) 0 1.5 4 6 8 10 VGS - Gate-to-Source Voltage (V) Source-Drain Diode Forward Voltage On-Resistance vs. Gate-Source Voltage 0.5 3 0.4 2.5 ID = 250 µA 0.3 2 0.2 Power (W) VGS(th) Variance (V) 2 0.1 1.5 - 0.0 1 TA = 25 °C - 0.1 0.5 - 0.2 - 0.3 - 50 0 - 25 0 25 50 75 100 125 150 0.1 0.01 100 10 1 TJ - Junction Temperature (°C) Time (s) Threshold Voltage Variance Over Temperature Single Pulse Power, Junction-to-Ambient 600 Normalized Effective Transient Thermal Impedance 2 1 Duty Cycle = 0.5 0.2 Notes: 0.1 PDM 0.1 0.05 t1 t2 1. Duty Cycle, D = t1 t2 2. Per Unit Base = RthJA = 350 °C/W 0.02 3. TJM - TA = PDMZthJA(t) Single Pulse 4. Surface Mounted 0.01 10-4 10-3 10-2 10-1 1 Square Wave Pulse Duration (s) 10 Normalized Thermal Transient Impedance, Junction-to-Ambient 4 100 600 VB2703K www.VBsemi.com SOT-23 (TO-236): 3-LEAD b 3 E1 1 E 2 e S e1 D 0.10 mm C 0.004" A2 A C q Gauge Plane Seating Plane Seating Plane C A1 Dim 0.25 mm L L1 MILLIMETERS INCHES Min Max Min Max 0.044 A 0.89 1.12 0.035 A1 0.01 0.10 0.0004 0.004 A2 0.88 1.02 0.0346 0.040 b 0.35 0.50 0.014 0.020 c 0.085 0.18 0.003 0.007 D 2.80 3.04 0.110 0.120 E 2.10 2.64 0.083 0.104 E1 1.20 1.40 0.047 e 0.95 BSC e1 L 1.90 BSC 0.40 L1 q 0.0748 Ref 0.60 0.016 0.64 Ref S 0.024 0.025 Ref 0.50 Ref 3° 0.055 0.0374 Ref 0.020 Ref 8° 3° 8° ECN: S-03946-Rev. K, 09-Jul-01 DWG: 5479 5 VB2703K www.VBsemi.com 0.053 (1.341) 0.097 (2.459) Recommended Minimum Pads Dimensions in Inches/(mm) 6 0.049 (0.559) (1.245) (0.950) 0.029 0.022 (0.724) 0.037 (2.692) 0.106 RECOMMENDED MINIMUM PADS FOR SOT-23 VB2703K www.VBsemi.com Disclaimer All products due to improve reliability, function or design or for other reasons, product specifications and data are subject to change without notice. Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or incomplete data contained in the table or any other any disclosure of any information related to the product.(www.VBsemi.com) Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability, including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties, including a particular purpose, non-infringement and merchantability guarantee. Statement on certain types of applications are based on knowledge of the product is often used in a typical application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific product features in the products described in the specification is appropriate for use in a particular application. Parameter data sheets and technical specifications can be provided may vary depending on the application and performance over time. All operating parameters, including typical parameters must be made by customer's technical experts validated for each customer application. Product specifications do not expand or modify Taiwan VBsemi purchasing terms and conditions, including but not limited to warranty herein. Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving, or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and other terms and conditions in writing. The information provided in this document and the company's products without a license, express or implied, by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product names and trademarks referred to herein are trademarks of their respective representatives will be all. Material Category Policy Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be oHS compliant and meets the definition of restrictions under Directive of the European Parliament 2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com) Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive 2011/65 /. Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
VB2703K 价格&库存
很抱歉,暂时无法提供与“VB2703K”相匹配的价格&库存,您可以联系我们找货
