WTM3400
WTM3400
    WPMTEK(维攀微)
    SOT-23
    N沟道增强型功率MOSFET 1个N沟道 耐压:30V 电流:5.8A
WTM3400 数据手册
WTM3400 N-Channel Enhancement Mode Power MOSFET Description ■ The WTM3400 uses advanced trench technology to provide excellent RDS(ON), low gate charge and operation with gate voltages as low as 2.5V. This device is suitable for use as a battery protection or in other switching application. Features ■ V DS = 30V, lD = 5.8A RDS(ON) < 59mΩ @ VGS=2.5V RDS(ON) < 45mΩ @ VGS=4.5V RDS(ON) < 41mΩ @ VGS=10V ■ High power and current handing capability ■ Lead free product is acquired ■ Surface mount package Application ■ PWM application ■ Load switch ■ Power management Schematic Diagram Package and order information Device Device Marking Device Package Reel Size Tape width Quantity WTM3400 A09T SOT-23 Ø180mm 8 mm 3000 pcs Absolute Maximum Ratings (TA=25℃, RH=45%-75%, unless otherwise noted) Parameter Symbol Value Unit VDS 30 V VGS ±12 V ID 5.8 A IDM 30 A PD 1.4 W TJ & TSTG −55 to +150 °C Parameter Symbol Value Unit Thermal Resistance and Junction-to-Ambient (Note 2) RθJA 89 ℃/W Drain-Source Voltage Gate-Source Voltage Drain Current-Continuous Drain Current-Pulsed (Note 1) Maximum Power Dissipation Operating Junction and Storage Temperature Range Thermal Characteristic V1.0_Aug,2018 -1- www.wpmtek.com WTM3400 N-Channel Enhancement Mode Power MOSFET Electrical Characteristics(TA = 25°C unless otherwise noted) Parameter Symbol Condition Min Typ Max Unit BVDSS VGS=0V ID =250μA 30 33 - V Zero Gate Voltage Drain Current IDSS VDS=30V,VGS=0V - - 1 μA Gate-Body Leakage Current IGSS VGS=±12V,VDS=0V - - ±100 nA VGS(th) VDS=VGS,ID =250μA 0.7 0.9 1.4 V VGS=2.5V, ID =4A - 45 59 mΩ VGS =4.5V,ID =5A - 31 45 mΩ VGS =10V,ID =5.8A - 28 41 mΩ VDS=5V,ID=5A 10 - - S - 820 - PF - 99 - PF Off Characteristics Drain-Source Breakdown Voltage On Characteristics (Note 3) Gate Threshold Voltage Drain-Source On-State Resistance Forward Transconductance RDS(ON) gFS Dynamic Characteristics (Note4) Input Capacitance Clss Output Capacitance Coss Reverse Transfer Capacitance Crss - 77 - PF Turn-on Delay Time td(on) - 3.3 - nS Turn-on Rise Time tr - 4.8 - nS - 26 - nS VDS=15V,VGS=0V,F=1.0MHz Switching Characteristics (Note 4) Turn-Off Delay Time td(off) VDD =15V, RL =2.7Ω VGS =10V,RGEN =3Ω Turn-Off Fall Time tf - 4 - nS Total Gate Charge Qg - 9.5 - nC Gate-Source Charge Qgs - 1.5 - nC Gate-Drain Charge Qgd - 3 - nC - - 1.2 V - - 5.8 A VDS=15V,ID=5.8A,VGS=4.5V Drain-Source Diode Characteristics Diode Forward Voltage (Note 3) VSD Diode Forward Current (Note 2) IS VGS=0V,IS =5.8A Notes: 1. Repetitive Rating: Pulse width limited by maximum junction temperature. 2. Surface Mounted on FR4 Board, t ≤ 10 sec. 3. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%. 4. Guaranteed by design, not subject to production V1.0_Aug,2018 -2- www.wpmtek.com WTM3400 N-Channel Enhancement Mode Power MOSFET Typical Electrical and Thermal Characteristics Figure 2 - Switching Waveforms PD Power (W) ID-Drain Current(A) Figure 1 - Switching Test Circuit TJ -Junction Temperature (°C) Figure 3 - Power Dissipation (°C) TJ -Junction Temperature Rdson On-Resistance(Ω) ID-Drain Current(A) Figure 4 - Drain Current ID-Drain Current(A) Vds Drain-Source Voltage (V) Figure 5 - Output Characteristics V1.0_Aug,2018 Figure 6 -Drain-Source On-Resistance -3- www.wpmtek.com WTM3400 ID-Drain Current(A) Normalized On-Resistance N-Channel Enhancement Mode Power MOSFET TJ -Junction Temperature (°C) Vgs Gate-source Voltage(V) Figure 8 – Drain-Source On-Resistance C Capacitance(pF) Rdson On-Resistance(Ω) Figure 7 – Transfer Characteristics Vgs Drain-source Voltage(V) Figure 9 – Rdson vs Vgs Figure 10 – Capacitance vs Vds Is-Reverse Drain Current(A) Vgs Gate-Source Voltage(V) Vgs Gate-source Voltage(V) Qg Gate Charge (nC) Vsd Source-Drain Voltage(V) Figure 12 –Source-Drain Diode Forward Figure 11 –Gate Charge V1.0_Aug,2018 -4- www.wpmtek.com WTM3400 ID- Drain Current(A) N-Channel Enhancement Mode Power MOSFET Vds Drain-Source Voltage(V) Transient Thermal Impedance r(t), Normalized Effective Figure 13 – Safe Operation Area Square Wave Pulse Duration(sec) Figure 14 – Normalized Maximum Transient Thermal Impedance V1.0_Aug,2018 -5- www.wpmtek.com WTM3400 N-Channel Enhancement Mode Power MOSFET Soldering parameters Reflow Condition Pre Heat Pb-Free assembly -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max -Temperature(TL) (Liquid us) +217℃ Reflow -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed V1.0_Aug,2018 +260℃ -6- www.wpmtek.com WTM3400 N-Channel Enhancement Mode Power MOSFET Package Outline Dimensions (SOT-23) Symbol Dimensions in Millimeters Min Max A 0.900 1.150 A1 0.000 0.100 A2 0.900 1.050 b 0.300 0.500 c 0.080 0.150 D 2.800 3.000 E 1.200 2.250 1.400 2.550 E1 0.950 TYP e e1 1.800 0.55 REF L L1 θ 2.000 0.300 0° 0.500 8° Recommend PAD Layout Notes: 1. All dimensions are in millimeters. 2. Tolerance ±0.10mm (4 mil) unless otherwise specified 3. Package body sizes exclude mold flash and gate burrs. Mold flash at the non-lead sides should be less than 5 mils. 4. Dimension L is measured in gauge plane. 5. Controlling dimension is millimeter, converted inch dimensions are not necessarily exact. V1.0_Aug,2018 -7- www.wpmtek.com
WTM3400 价格&库存
很抱歉,暂时无法提供与“WTM3400”相匹配的价格&库存,您可以联系我们找货
