WTM2306
WTM2306
    WPMTEK(维攀微)
    SOT-23
    N沟道增强型功率MOSFET 1个N沟道 耐压:30V 电流:3.6A
WTM2306 数据手册
WTM2306 N-Channel Enhancement Mode Power MOSFET Description ■ The WTM2306 uses advanced trench technology to provide excellent RDS(ON), This device is suitable for use as a battery protection or in other switching application. Features ■ V DS = 30V, lD = 3.6A RDS(ON) < 73mΩ @ VGS=4.5V RDS(ON) < 58mΩ @ VGS=10V ■ High power and current handing capability ■ Lead free product is acquired ■ Surface mount package Application ■ Battery protection. ■ Load switch Schematic Diagram ■ Power management Package and order information Device Device Marking Device Package Reel Size Tape width Quantity WTM2306 A6SHB SOT-23 Ø180mm 8 mm 3000 pcs Absolute Maximum Ratings (TA=25℃, RH=45%-75%, unless otherwise noted) Parameter Drain-Source Voltage Gate-Source Voltage Symbol Value Unit VDS 30 V VGS ±20 V ID Drain Current-Continuous 3.6 A IDM 15 A PD 1.7 W TJ & TSTG −55 to +150 °C Parameter Symbol Value Unit Thermal Resistance and Junction-to-Ambient (Note 2) RθJA 73.5 ℃/W Drain Current-Pulsed (Note 1) Maximum Power Dissipation Operating Junction and Storage Temperature Range Thermal Characteristic V1.0_Aug,2018 -1- www.wpmtek.com WTM2306 N-Channel Enhancement Mode Power MOSFET Electrical Characteristics(TA = 25°C unless otherwise noted) Parameter Symbol Condition Min Typ Max Unit BVDSS VGS=0V ID =250μA 30 33 - V Zero Gate Voltage Drain Current IDSS VDS=30V,VGS=0V - - 1 μA Gate-Body Leakage Current IGSS VGS=±20V,VDS=0V - - ±100 nA Gate Threshold Voltage VGS(th) VDS=VGS,ID =250μA 1.2 1.5 2.2 V Drain-Source On-State Resistance RDS(ON) 58 73 mΩ Off Characteristics Drain-Source Breakdown Voltage On Characteristics (Note 3) Forward Transconductance VGS=4.5V, ID =3.1A gFS VGS =10V,ID =3.6A - 40 58 mΩ VDS=5V,ID=3.6A - 11 - S - 230 - PF - 40 - PF Dynamic Characteristics (Note4) Input Capacitance Clss Output Capacitance Coss Reverse Transfer Capacitance Crss - 17 - PF Turn-on Delay Time td(on) - 10 - nS Turn-on Rise Time tr VDD =10V,ID =3.6A - 50 - nS VGS =4.5V,RGEN =6Ω - 10 - nS VDS=15V,VGS=0V,F=1.0MHz Switching Characteristics (Note 4) Turn-Off Delay Time td(off) Turn-Off Fall Time tf - 20 - nS Total Gate Charge Qg - 4.0 - nC Gate-Source Charge Qgs - 0.75 - nC Gate-Drain Charge Qgd - 0.65 - nC - 0.8 1.2 V - - 1.6 A VDS=15V,ID=3.6A,VGS=10V Drain-Source Diode Characteristics Diode Forward Voltage (Note 3) VSD Diode Forward Current (Note 2) IS VGS=0V,IS =2.7A Notes: 1. Repetitive Rating: Pulse width limited by maximum junction temperature. 2. Surface Mounted on FR4 Board, t ≤ 10 sec. 3. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%. 4. Guaranteed by design, not subject to production V1.0_Aug,2018 -2- www.wpmtek.com WTM2306 N-Channel Enhancement Mode Power MOSFET Typical Electrical and Thermal Characteristics Figure 2 - Switching Waveforms PD Power (W) ID-Drain Current(A) Figure 1 - Switching Test Circuit TJ -Junction Temperature (°C) (°C) Figure 3 - Power Dissipation Rdson On-Resistance(Ω) ID-Drain Current(A) Figure 4 - Drain Current ID-Drain Current(A) Vds Drain-Source Voltage (V) Figure 5 - Output Characteristics V1.0_Aug,2018 TJ -Junction Temperature Figure 6 -Drain-Source On-Resistance -3- www.wpmtek.com WTM2306 ID-Drain Current(A) Normalized On-Resistance N-Channel Enhancement Mode Power MOSFET TJ -Junction Temperature (°C) Vgs Gate-source Voltage(V) Figure 8 – Drain-Source On-Resistance C Capacitance(pF) Rdson On-Resistance(Ω) Figure 7 – Transfer Characteristics Vgs Gate-source Voltage(V) Vgs Drain-source Voltage(V) Figure 9 – Rdson vs Vgs V1.0_Aug,2018 Is-Reverse Drain Current(A) Vgs Gate-Source Voltage(V) Figure 10 – Capacitance vs Vds Qg Gate Charge (nC) Vsd Source-Drain Voltage(V) Figure 11 –Gate Charge Figure 12 –Gate Charge -4- www.wpmtek.com WTM2306 ID- Drain Current(A) N-Channel Enhancement Mode Power MOSFET Vds Drain-Source Voltage(V) Transient Thermal Impedance r(t), Normalized Effective Figure 13 – Safe Operation Area Square Wave Pulse Duration(sec) Figure 14 – Normalized Maximum Transient Thermal Impedance V1.0_Aug,2018 -5- www.wpmtek.com WTM2306 N-Channel Enhancement Mode Power MOSFET Soldering parameters Reflow Condition Pre Heat Pb-Free assembly -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max -Temperature(TL) (Liquid us) +217℃ Reflow -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed V1.0_Aug,2018 +260℃ -6- www.wpmtek.com WTM2306 N-Channel Enhancement Mode Power MOSFET Package Outline Dimensions (SOT-23) Symbol Dimensions in Millimeters Min Max A 0.900 1.150 A1 0.000 0.100 A2 0.900 1.050 b 0.300 0.500 c 0.080 0.150 D 2.800 3.000 E 1.200 2.250 1.400 2.550 E1 0.950 TYP e e1 1.800 0.55 REF L L1 θ 2.000 0.300 0° 0.500 8° Recommend PAD Layout Notes: 1. All dimensions are in millimeters. 2. Tolerance ±0.10mm (4 mil) unless otherwise specified 3. Package body sizes exclude mold flash and gate burrs. Mold flash at the non-lead sides should be less than 5 mils. 4. Dimension L is measured in gauge plane. 5. Controlling dimension is millimeter, converted inch dimensions are not necessarily exact. V1.0_Aug,2018 -7- www.wpmtek.com
WTM2306 价格&库存
很抱歉,暂时无法提供与“WTM2306”相匹配的价格&库存,您可以联系我们找货
WTM2306
  • 20+0.21503
  • 200+0.16492
  • 600+0.13706
  • 3000+0.11988
  • 9000+0.10541
  • 21000+0.09753
库存:2186
