ESD5Z15V
ESD5Z15V
    WPMTEK(维攀微)
    SOD-523(SC-79)
    TVS二极管 15V 11A 350W SOD-523
ESD5Z15V 数据手册
ESD5Z15V Integrated in OVP&OCP products provider 15V 1-Line Uni-directional TVS Diode Description Mechanical Characteristics The ESD5Z15V is an uni-directional TVS diode, utilizing leading monolithic silicon technology to provide fast re-sponse time and ultra low ESD clamping voltage, making this device an ideal solution for protecting voltage sensi-tive data and power line. The ESD5Z15V complies with the IEC 61000-4-2 (ESD) with ± 30kV air and ± 30kV con-tact discharge. It is assembled into an ultra-small SOD-523 lead-free package. The small size and high ESD surge protection make ESD5Z15V an ideal choice to pro-tect cell phone, digital cameras,  Package: SOD-523  Case Material: “Green” Molding Compound.  Lead Finish: Matte Tin  Moisture Sensitivity: Level 3 per J-STD-020  Terminal Connections: See Diagram Below  Marking Information: See Below  Cellular Handsets and Accessories audio players and many other portable applications.  Personal Digital Assistants  Notebooks, Desktops, Servers  Portable Instrumentation  Printers  Analog Inputs  Video equipment  Communication systems  Laser Diode Protection Features  Protects one line  Ultra low leakage: nA level  Operating voltage: 15V  Low clamping voltage  Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-5 (Lightning) 11A (8/20μs)  Applications Marking Information RoHS Compliant Bar denotes cathode Details marking code reference customer approval list Dimensions and Pin Configuration Ordering Information Part Number Packaging Reel Size ESD5V15V 3000/Tape & Reel 7 inch Circuit and Pin Schematic Rev.B_Aug,2018 1 of 4 www.wpmtek.com ESD5Z15V Integrated in OVP&OCP products provider 15V 1-Line Uni-directional TVS Diode Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 350 W Peak Pulse Current (8/20µs) Ipp 11 A ESD per IEC 61000−4−2 (Air) ±30 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range kV ±30 TJ −55 to +125 °C Tstg −55 to +150 °C Electrical Characteristics (TA=25°C unless otherwise specified) Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR Max Unit 15 V 18 Test Condition V IT = 1mA Reverse Leakage Current IR 0.2 μA VRWM = 15V Clamping Voltage VC 23 V IPP = 1A (8 x 20µs pulse) Clamping Voltage VC 32 V IPP = 11A (8 x 20µs pulse) Junction Capacitance CJ 80 pF VR = 0V, f = 1MHz Rev.B_Aug,2018 2 of 4 www.wpmtek.com ESD5Z15V Integrated in OVP&OCP products provider 15V 1-Line Uni-directional TVS Diode Typical Performance Characteristics (TA=25°C unless otherwise Specified) Junction Capacitance vs. Reverse Voltage Clamping Voltage vs. Peak Pulse Current Peak Pulse Power vs. Pulse Time Power Derating Curve Note:Data is taken with a 10x attenuator ESD Clamping Voltage 8 X 20μs Pulse Waveform Rev.B_Aug,2018 +8 kV Contact per IEC61000−4−2 3 of 4 www.wpmtek.com ESD5Z15V Integrated in OVP&OCP products provider 15V 1-Line Uni-directional TVS Diode SOD-523 Package Outline Drawing SY M DIMENSIONS MILLIMETERS INCHES MIN NOM MAX MIN NOM MAX A 0.51 -- 0.77 0.020 -- 0.031 A1 0.50 -- 0.70 0.020 -- 0.028 b 0.25 -- 0.35 0.010 -- 0.014 c 0.08 -- 0.15 0.003 -- 0.006 D 0.75 -- 0.85 0.030 -- 0.033 E 1.10 -- 1.30 0.043 -- 0.051 E1 1.50 -- 1.70 0.059 E2 L Θ 0.20REF 0.01 -7°REF 0.067 0.008REF 0.07 0.001 -- 0.003 7°REF Suggested Land Pattern Unit: mm Contact Information WPMTEK Incorporated Limited Room 206-207,2nd Floor,Block 3,Minxing lndustry Park,Minzhi Longhua New District,Shenzhen TEL:86755-29308003 FAX:86755-23739900 WPMtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.B_Aug,2018 4 of 4 www.wpmtek.com
ESD5Z15V 价格&库存
很抱歉,暂时无法提供与“ESD5Z15V”相匹配的价格&库存,您可以联系我们找货
