CT-6EP203
CT-6EP203
    NIDEC(尼得科)
    插件-3P
    可调电阻/电位器 20KΩ ±10% 500mW 插件-3P ±100ppm/℃
CT-6EP203 数据手册
SINGLE TURN CERMET TRIMMERS RoHS compliant CT-6 INTERNAL STRUCTURE 1 2 3 4 5 !0 6 9 8 Part name ■ FEATURES ORoHS compliant OVarious configurations to choose from OWide variety (14 types) O “O”ring sealed and washable 7 Material 1 Housing 2 Rotor 3 Wiper Multi metal alloy 4 Rubber cushion Silicone rubber 5 “O” ring Silicone rubber 6 Resistive element 7 Terminal pin 8 Adhesive 9 Base element !0 Electrode Flammability Polybutyleneterephthalate UL94V-0 — UL94HB RuO2 cermet Copper, Tin-plated — Epoxy UL94V-0 Ceramic — Ag-Pd cermet ■ PART NUMBER DESIGNATION C T - 6 E T V 5 kΩ ( 5 0 2 ) Series name Resistance code Terminal pin Resistance value E:Sn (Lead-free) Product shape Form of packaging T:Taping (Ammo pack type) M:Magazine (stick) Blank:Bulk in plastic bag P:Top adjustment W:Top adjustment R:Top adjustment V:Top adjustment F:Rear adjustment ※ Please refer to the LIST OF PART NUMBERS when placing orders. S:Side adjustment X:Side adjustment H:Side adjustment N:Side adjustment CT-6 CERMET TRIMMERS ■ LIST OF PART NUMBERS Adjustment position Shape of terminal (Top view) Form of packaging Remarks Taping Magazine (stick) Plastic bag CT-6ETP Ammo pack type CT-6EMP CT-6EP The pin length of CT-6ETP & CT-6EMP is different from CT-6EP. 3 CT-6EW — 3 A CT-6ER — CT-6EV — 2 1 Top adjustment 3 2 1 1 2 2 1 3 CT-6ETV Ammo pack type 2 1 3 3 1 CT-6EMS CT-6ES The pin length of CT-6EMS is different from CT-6ES. — CT-6EX 2 Side adjustment ( ↑ Adjustment direction) 2 1 3 1 3 CT-6ETH Ammo pack type CT-6EH 2 The pin length of CT-6ETH is different from CT-6EH. CT-6EN — A CT-6EF — 50 pcs./pack — 2 2 Rear adjustment 1 Pieces in package 3 1000 pcs./taping 75 pcs./stick  :Not manufactured The products indicated by A mark are manufactured upon receipt of order basis. ※ The above part numbers are all available with the respective combination of (Fig. 1). ※ Verify the above part numbers when placing orders. ※ Taping and magazine specifications are not sold separately and must be purchased in taping or stick units. Fig. 1 〈Nominal resistance values〉 A 10 Ω A 20 Ω 50 Ω 100 Ω 200 Ω 500 Ω 50 k Ω 1kΩ 2kΩ 5kΩ 10 k Ω 20 k Ω 100 k Ω 200 k Ω 500 k Ω 1MΩ 2MΩ CT-6 CERMET TRIMMERS ■ ELECTRICAL CHARACTERISTICS 10 Ω ~ 2 M Ω Nominal resistance range Resistance tolerance ■ MECHANICAL CHARACTERISTICS Mechanical angle 260 ° (1 turn) Operating torque 2 ~ 20 mN·m {20 ~ 204 gf·cm} Stop strength 50 mN·m {510 gf·cm} minimum Rotational life 200 cycles [ Δ R/R ≦ ± (2 Ω +3 %)] ± 10 % Power ratings 0.5 W (70 °C) 0 W (120 °C) (B) Resistance law Linear law Maximum input voltage DC200 V or power rating, whichever is smaller Maximum wiper current 100 mA or power rating, whichever is smaller Effective electrical angle 220 ° (1 turn) Teminal strength 10 N {1.02 kgf} minimum (Tensile strength) Thrust to rotor 10 N {1.02 kgf} minimum 245 ± 3 °C, 2 ~ 3 s Solderability { }:Reference only ■ ENVIRONMENTAL CHARACTERISTICS End resistance 1 % or 2 Ω , whichever is greater C.R.V. 1 % or 3 Ω , whichever is greater Test item Operating temp. range Temp. coefficient Thermal shock Humidity − 55 ~ 120 °C 10 Ω ~ 20 Ω : ± 250 10-6/°C maximum 50 Ω ~ 2 M Ω : ± 100 10-6/°C maximum Insulation resistance Dielectric strength Specifications − 65 ~ 125 °C (0.5 h), 5 cycles [ Δ R/R ≦ 1 %] [S.S. ≦ 1 %] − 10 ~ 65 °C (80 ~ 98 %), 10 cycles, 240 h 981 m/s2, 6 ms 6 directions for 3 times each Vibration (Amplitude) 1.52 mm or (Acceleration) 196 m/s2, 10 ~ 2000 Hz, 3 directions, 12 times each Load life 70 °C, 0.5 W, 1000 h 1000 M Ω minimum (DC500 V) [ Δ R/R ≦ 2 %] [ Δ R/R ≦ 1 %] [S.S. ≦ 1 %] [ Δ R/R ≦ 3 %] [S.S. ≦ 1 %] [ Δ R/R ≦ 2 %] [S.S. ≦ 2 %] [ Δ R/R ≦ 3 %] [S.S. ≦ 2 %] AC900 V, 60 s Approx. 0.51 g (CT-6EP, EW, ER, EV) Approx. 0.65 g (CT-6ES, EX, EH, EN) Approx. 0.92 g (CT-6EF) Net weight Shock Test conditions Low temp. operation − 55 °C, 2 h High temp. exposure 120 °C, 250 h Immersion seal 85 °C, 60 s No leaks (No continuous bubbles) Soldering heat Flow:260 ± 3 ℃、5 ~ 6 s, two times maximum Manual soldering:380 ± 10 °C, 3 ~ 4 s [ Δ R/R ≦ 1 %] Δ R/R:Change in total resistance S.S. :Setting stability ■ MAXIMUM INPUT RATINGS Resistance code Maximum input voltage (V) Maximum wiper current (mA) 10 20 50 100 200 500 100 200 500 101 201 501 1.00 2.00 5.00 7.07 10.0 15.8 100 100 100 70.7 50.0 31.6 1k 2k 5k 10 k 20 k 50 k 102 202 502 103 203 503 22.4 31.6 50.0 70.7 100 158 22.4 15.8 10.0 7.07 5.00 3.16 100 k 200 k 500 k 1M 2M 104 204 504 105 205 200 200 200 200 200 2.00 1.00 0.40 0.20 0.10 Nominal resistance values ( Ω ) A A The products indicated by A mark are manufactured upon receipt of order basis. CT-6 CERMET TRIMMERS ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) OCT-6EP Top adjustment 1 CW rotation 3 – q 0.45 0.6 W = 2.6 L = 1.6 D 260°Nom. 2 2 7 2.5 Lead-free Identification mark 3 1 3 7 5.8 Resistance code & Production date code 7±2 2.5 2.5 OCT-6EW Top adjustment 3 – q 0.45 0.6 W = 2.6 L = 1.6 D 2 0.6 7 1.3 Lead-free Identification mark 260°Nom. 3 7 5.8 Resistance code & Production date code 7±2 1 1.8 1.8 ★ Pin pitch in W type is different from P type. OCT-6EV Top adjustment 0.6 W = 2.6 L = 1.6 D 3 – q 0.45 1 2 3 7 Lead-free Identification mark 260°Nom. 13.5 ± 2 7 Resistance code & Production date code 5.8 2.5 2.5 16 ± 2 OCT-6ES Side adjustment 0.6 W × 2.6 L × 1.6 D Resistance code & Production date code Adjustment 8.2 1 3 2 4.6 7.5 2 2.5 3 – φ 0.45 3.5 7 +– 0.4 0.2 Lead-free Identification mark 2.5 7 + 00.4 2.5 CT-6 CERMET TRIMMERS ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) OCT-6EX Side adjustment 1 3 Resistance code & Production date code 0.6 W×2.6 L×1.6 D 2 Adjustment 2 7 +– 0.4 0.2 4.6 2.5 8.2 3.5 7 + 00.4 CW rotation 3 10 2 Lead-free Identification mark 1 2.5 2.5 3 – q0.45 OCT-6EH Side adjustment 0.6 W×2.6 L×1.6 D Resistance code & Production date code 7 + 00.4 Adjustment 2 7 +– 0.4 0.2 1 2.5 2.5 9.5 2 7 2 4.6 8.2 3 3.5 Lead-free Identification mark 3 – q 0.45 OCT-6EN Side adjustment 0.6 W×2.6 L×1.6 D 2 7 +– 0.4 0.2 Adjustment 4.6 2.5 8.2 3.5 Resistance code & Production date code 1 2 7 7.5 Lead-free Identification mark + 0.4 0 3 2.5 2.5 3 – q 0.45 ★ Terminals 1 & 3 position in N type is different from X type. CT-6 CERMET TRIMMERS ■ OUTLINE DIMENSIONS OCT-6EF Rear adjustment Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) < Semi-standard products > 3 3 – q 0.45 0.6 W = 2.6 L = 1.6 D 2 1 CW rotation 2 q 10.5 max. 4.4 Lead-free Identification mark 1 3 4.4 0.3 4.4 5.5 ± 2 OCT-6ER Top adjustment Resistance code& Production date code 7.6 < Semi-standard products > 3 – q 0.45 0.6 W = 2.6 L = 1.6 D 260°Nom. 1 2 3 2.5 7 Lead-free Identification mark 7 Resistance code & Production date code 5.8 7±2 2.5 2.5 ■ PACKAGING SPECIFICATIONS OTaping version is packaged in 1000 pcs. per reel. Orders will be accepted for units of 1000 pcs., i.e., 1000, 2000, 3000 pcs., etc. O Taping version (ammo pack type) is boxed with one reel (1000 pcs.). Ammo Pack Ammo pack type Direction of feed 45 #1 terminal 1 OPackage size: 330 mm × 330 mm × 45 mm O The leader and end of the tape have an empty par t of minimum 300 mm respectively. O There are two tape outlets on the package for different terminal alignment directions, for which details refer to the sketch above. (e.g.) When the tape is fed from the right outlet marked 3, #3 terminal comes out first. OGross weight of the boxing version ETV : Approx. 840 g ETH : Approx. 930 g ETP : Approx. 850 g 3 Direction of feed 33 0 0 33 #3 terminal CT-6 CERMET TRIMMERS OCT-6ETV Top adjustment Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) Lead-free Identification mark 0.6 W = 2.6 L = 1.6 D 260°Nom. 1 Resistance code & Production date code 2 7 12.7 ± 1 Δ 2 max. 5.8 18 ± 0.5 9 2.5 Δ 2 max. 6 ± 0.5 + 0.7 – 0.5 0.5 max. 3 min. 19 ± 0.75 24.8 ± 1 7 1 3 2.5 0.9 6.35 ± 0.5 12.7 ± 0.3 q 4 ± 0.2 0.45 ± 0.02 OCT-6ETH Side adjustment 0.6 W = 2.6 L = 1.6 D Resistance code & Production date code 12.7 ± 1 7 +– 0.4 0.1 7 + 00.4 Δ 2 max. 6 ± 0.5 2.5 18 ± 0.5 3.5 9 +– 0.7 0.5 0.5 max. 3 min. 19 ± 0.75 27.2 ± 1 1 3 2.5 6.35 ± 0.5 12.7 ± 0.3 0.45 ± 0.02 4.6 260°Nom. 8.2 Lead-free Identification mark q 4 ± 0.2 3 CW rotation 0.9 Δ 2 max. CT-6 CERMET TRIMMERS OCT-6ETP Top adjustment Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) Lead-free Identification mark 0.6W = 2.6L = 1.6D 260 Nom. 1 3 CW rotation 2 Resistance code & Production date code 7 12.7 ± 1 6 2 max. 6 2 max. 2.5 1 2.5 18 ± 0.5 9 +0.7 –0.5 6 ± 0.5 0.5 max. 3 min. 16 ± 1 19 ± 0.75 24.8 ± 1 5.8 7 2.5 0.9 3 q 4 ± 0.2 6.35 ± 0.5 12.7 ± 0.3 0.45 ± 0.02 OMagazine is packaged 75 pcs. per stick. Orders will be accepted for units of 75 pcs. i.e., 150, 225 pcs., etc. OMagazine is packed 3000 pcs. sticks per box. Plastic magazine length = 580 mm (Without rubber cap) 9.1 7.4 9.8 16.6 16.6 9.1 CT-6EMP Plastic magazine type CT-6EMS CT-6 CERMET TRIMMERS OCT-6EMP Top adjustment Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) 3 – q 0.45 0.6 W = 2.6 L = 1.6 D 1 260°Nom. 3 2 CW rotation Lead-free Identification mark 7 2.5 2 1 3 7 Resistance code & Production date code 5.8 3.1 2.5 2.5 OCT-6EMS Side adjustment 0.6 W ×2.6 L×1.6 D Lead-free Identification mark Adjustment 7 +0.4 –0.2 8.2 1 3 3.1 4.6 2.5 2 3 – q 0.45 3.5 7 +0.4 0 2.5 2.5 Resistance code & Production date code OUnit of bulk pack in a plastic bag is 50 pcs. per pack. O Boxing of bulk in a plastic bag is performed with 200 pcs. (CT-6EF is 100 pcs.) per box. ■ ADJUSTMENT TOOL, MODEL TA-64 OGood for both minus and cross slot rotors / shafts. ORecommended for use with the following copal trimmers. Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) + bit Tip thickness 0.5±0.05 0 Tip 2.4 –0.1 – bit Tip thickness 0.5±0.05 Tip 2.0 Recommended models − bit CT-6 ST-4 FT-63 130 12 12 2 2 RJ-4 RJ-6 TM-7 COPAL ELECTRONICS 2.7 φ 10 + bit Material : Polyoxymethylene ※ Note : Please do not use the tool for purposes other than adjustment of electronic components. 2.7
CT-6EP203 价格&库存
很抱歉,暂时无法提供与“CT-6EP203”相匹配的价格&库存,您可以联系我们找货
CT-6EP203
  • 1+1.57300
