Transient Voltage Suppressors(TVS)
SMFxxxA(CA) Series
Features
■ Peak power dissipation 200W @10 x 1000 us Pulse
■ Low profile package.
■ Excellent clamping capability.
■ Glass passivated junction.
■ Fast response time: typically less than 1ns from 0 Volts to BV min
■ Typical IR less than 1uA when VBR min above 15V.
■ IEC 61000-4-2 ESD 30KV(Air), 30KV(Contact)
■ ESD protection of data lines in accordance with IEC 61000-4-2
SOD-123FL
■ EFT protection of data lines in accordance with IEC 61000-4-4
Mechanical Characteristics
■ CASE: SOD-123FL Molded Plastic over glass passivated junction.
■ Mounting Position: Any
Bi-directional
■ Polarity: by cathode band denotes uni-directional device,
None cathode band denotes bi-directional device.
Anode
Cathode
■ Terminal: Solder plated
■ Halogen free and RoHS compliant
Uni-directional
■ Lead-free finish
SYMBOL
Absolute Maximum Ratings (TA=25℃, RH=45%-75%, unless otherwise noted)
Parameter
Symbol
Value
Unit
TJ
-55 to +150
Storage Temperature Range
TSTG
-55 to +175
Steady state power dissipation at TL=75℃
PM(AV)
0.5
W
Peak pulse power dissipation on 10/1000μs waveform
PPP
200
W
Maximum instantaneous forward voltage at 20A for unidirectional
VF
3.5
V
Peak forward surge current, 8.3ms single half sine wave
IFSM
A
Typical thermal resistance junction to lead
RθJL
100
℃/W
Typical thermal resistance junction to ambient
RθJA
220
℃/W
Operating Temperature Range
a
Notes:
a. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle=4 per minute
maximum
1
Revised: Jan 11, 2019
Copyright © 2018 WPMTEK INC.
Specifications are subject to change without notice.
Please refer to http://www.wpmtek.com for current information.
SMFxxxA(CA) Series
Electrical Characteristics(TA = 25°C unless otherwise noted)
Reverse
Type
Marking
Number
Uni
Bi
Breakdown
Breakdown
Stand-Off
Voltage
Voltage
Voltage
Min. @IT
Max. @ IT
Test
Current
Maximum
Maximum
Reverse
Clamping
Peak Pulse
Leakage
Voltage@IPP
Current
@VRMW
Uni
Bi
VRMW(V)
VBR MIN(V)
VBR MAX(V)
IT (mA)
VC(V)
IPP(A)
IR(uA)
SMF5.0A
SMF5.0CA
5.0A
5.0CA
5.0
6.40
7.00
10
9.2
21.7
400.0
SMF6.0A
SMF6.0CA
6.0A
6.0CA
6.0
6.67
7.37
10
10.3
19.4
400.0
SMF6.5A
SMF6.5CA
6.5A
6.5CA
6.5
7.22
7.98
10
11.2
17.9
250.0
SMF7.0A
SMF7.0CA
7.0A
7.0CA
7.0
7.78
8.60
10
12.0
16.7
100.0
SMF7.5A
SMF7.5CA
7.5A
7.5CA
7.5
8.33
9.21
1
12.9
15.5
50.0
SMF8.0A
SMF8.0CA
8.0A
8.0CA
8.0
8.89
9.83
1
13.6
14.7
25.0
SMF8.5A
SMF8.5CA
8.5A
8.5CA
8.5
9.44
10.40
1
14.4
13.9
10.0
SMF9.0A
SMF9.0CA
9.0A
9.0CA
9.0
10.00
11.10
1
15.4
13.0
5.0
SMF10A
SMF10CA
10A
10CA
10.0
11.10
12.30
1
17.0
11.8
2.5
SMF11A
SMF11CA
11A
11CA
11.0
12.20
13.50
1
18.2
11.0
2.5
SMF12A
SMF12CA
12A
12CA
12.0
13.30
14.70
1
19.9
10.1
2.5
SMF13A
SMF13CA
13A
13CA
13.0
14.40
15.90
1
21.5
9.3
1
SMF14A
SMF14CA
14A
14CA
14.0
15.60
17.20
1
23.2
8.6
1
SMF15A
SMF15CA
15A
15CA
15.0
16.70
18.50
1
24.4
8.2
1
SMF16A
SMF16CA
16A
16CA
16.0
17.80
19.70
1
26.0
7.7
1
SMF17A
SMF17CA
17A
17CA
17.0
18.90
20.90
1
27.6
7.2
1
SMF18A
SMF18CA
18A
18CA
18.0
20.00
22.10
1
29.2
6.8
1
SMF20A
SMF20CA
20A
20CA
20.0
22.20
24.50
1
32.4
6.2
1
SMF22A
SMF22CA
22A
22CA
22.0
24.40
26.90
1
35.5
5.6
1
SMF24A
SMF24CA
24A
24CA
24.0
26.70
29.50
1
38.9
5.1
1
SMF26A
SMF26CA
26A
26CA
26.0
28.90
31.90
1
42.1
4.8
1
SMF28A
SMF28CA
28A
28CA
28.0
31.10
34.40
1
45.4
4.4
1
SMF30A
SMF30CA
30A
30CA
30.0
33.30
36.80
1
48.4
4.1
1
SMF33A
SMF33CA
33A
33CA
33.0
36.70
40.60
1
53.3
3.8
1
SMF36A
SMF36CA
36A
36CA
36.0
40.00
44.20
1
58.1
3.4
1
SMF40A
SMF40CA
40A
40CA
40.0
44.40
49.10
1
64.5
3.1
1
SMF43A
SMF43CA
43A
43CA
43.0
47.80
52.80
1
69.4
2.9
1
SMF45A
SMF45CA
45A
45CA
45.0
50.00
55.30
1
72.7
2.8
1
SMF48A
SMF48CA
48A
48CA
48.0
53.30
58,90
1
77.4
2.6
1
SMF51A
SMF51CA
51A
51CA
51.0
56.70
62.70
1
82.4
2.4
1
SMF54A
SMF54CA
54A
54CA
54.0
60.00
66.30
1
87.1
2.3
1
SMF58A
SMF58CA
58A
58CA
58.0
64.40
71.20
1
93.6
2.1
1
SMF60A
SMF60CA
60A
60CA
60.0
66.70
73.70
1
96.8
1.8
1
SMF64A
SMF64CA
64A
64CA
64.0
71.10
78.60
1
103.0
1.7
1
SMF70A
SMF70CA
70A
70CA
70.0
77.80
86.00
1
113.0
1.5
1
SMF75A
SMF75CA
75A
75CA
75.0
83.30
92.10
1
121.0
1.4
1
2
SMFxxxA(CA) Series
Reverse
Type
Marking
Number
Uni
Bi
Breakdown
Breakdown
Stand-Off
Voltage
Voltage
Voltage
Min. @IT
Max. @ IT
Maximum
Test
Clamping
Current
Voltage@IPP
VC(V)
Uni
Bi
VRMW(V)
VBR MIN(V)
VBR MAX(V)
IT (mA)
Maximum
Reverse
Peak Pulse Leakage
Current
@VRMW
IPP(A)
IR(uA)
SMF78A
SMF78CA
78A
78CA
78.0
86.70
95.80
1
126.0
1.4
1
SMF85A
SMF85CA
85A
85CA
85.0
94.40
104.00
1
137.0
1.3
1
SMF90A
SMF90CA
90A
90CA
90.0
100.00
111.00
1
146.0
1.2
1
SMF100A
SMF100CA
100
100C
100.0
111.00
123.00
1
162.0
1.1
1
SMF110A
SMF110CA
110
110C
110.0
122.00
135.00
1
177.0
1.0
1
SMF120A
SMF120CA
120
120C
120.0
133.00
147.00
1
193.0
0.9
1
SMF130A
SMF130CA
130
130C
130.0
144.00
159.00
1
209.0
0.8
1
SMF150A
SMF150CA
150
150C
150.0
167.00
185.00
1
243.0
0.7
1
SMF160A
SMF160CA
160
160C
160.0
178.00
197.00
1
259.0
0.7
1
SMF170A
SMF170CA
170
170C
170.0
189.00
209.00
1
275.0
0.6
1
SMF180A
SMF180CA
180
180C
180.0
198.00
222.00
1
292.0
0.6
1
SMF190A
SMF190CA
190
190C
190.0
209.00
233.00
1
308.0
0.5
1
※ For Bi-directional type having VRWM of 10 Volts and less, the IR limit is double
I-V Curve Characteristics
PPPM
Peak Pulse Power Dissipation ----------------------------------------------------------------------------------------- Max power dissipation
VR
Stand-off Voltage ---------------------------------------- Maximum voltage that can be applied to the TVS without operation
VBR
Breakdown Voltage -------------------------- Maximum voltage that flows though the TVS at a specified test current (IT)
VC
Clamping Voltage -------------- Peak voltage measured across the TVS at a specified IPPM (peak impulse current)
IR
Reverse Leakage Current -- Current measured at VR
VF
Forward Voltage Drop for Uni-directional
3
SMFxxxA(CA) Series
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
4
SMFxxxA(CA) Series
Package Outline Dimensions
Dim
Millimeters
SOD-123FL
Inches
Min
Max
Min
Max
A
3.40
3.95
0.142
0.155
B
2.50
2.90
0.098
0.114
C
1.40
1.95
0.055
0.077
D
0.90
1.35
0.035
0.053
E
0.50
1.10
0.020
0.043
G
0.25
0.010
H
0.20
0.008
Suggested PAD Layout
SOD-123FL
SIZE
D
(mm)
(inch)
A
A
3.47
0.137
E
B
0.78
0.031
C
1.22
0.048
D
4.25
0.167
E
2.70
0.106
C
B
Ordering information
Part Number
Package
SMFxxxA(CA)
SOD-123FL
Weight
Base qty
Reel Size
grams(approx.)
(pcs)
(inch)
0.014
3000
7
5
Delivery mode
Tape and reel
很抱歉,暂时无法提供与“SMF13A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.26190
- 100+0.20747
- 300+0.18026
- 3000+0.15498
- 6000+0.13868
- 9000+0.13047
