5.0SMDJ30CA
5.0SMDJ30CA
    WPMTEK(维攀微)
    DO214AB
    TVS SMC 功率:5000W 反向断态电压 V(RWM):30V 反向漏电流 IR @V(RWM)1uA@30V IPP:103A
5.0SMDJ30CA 数据手册
5.0SMDJ Series Integrated in OVP&OCP products provider 5000W Transient Voltage Suppressor Description Mechanical Characteristics TVS diodes can be used in a wide range of applications Package: SMC/DO-214AB which like consumer electronic products, automotive  Case Material: “Green” Molding Compound. industries, munitions, telecommunications, aerospace  UL Flammability Classification Rating 94V-0 industries, and intelligent control systems.  Polarity: Color band denotes cathode except bi-directional models Features  RS-481)  Glass passivated or planar junction  Excellent clamping capability  Repetition rate (duty cycle): 0.01%  Low profile package and low inductance  5000W Peak Pulse power capability at 10×1000μs  Weight: 0.275g  Terminal Connections: See DiagramBelow  Marking Information: SeeBelow Applications waveform.  Standard Packaging: 13mm tape (EIA STD Fast response time: typically less than 1.0ps from 0V to VBR min.  I/O Interface.  High temperature soldering: 260℃/10s at terminals.  AC/DC Power supply  Plastic  Low frequency signal transmission line package has Underwriters Laboratory (RS232, RS485, etc.) Flammability 94V-0.  For surface mounted applications in order to optimize board space. Marking Information Dimensions & Symbol(Unit: mm Max) 5PEN 1409 5PEN : Device Marking Code 1409 : In ninth week, 2014 Ordering Information Out line Taping Rev.2_Oct,2016 -1- Reel Per carton Reel diameters (pcs) (pcs) (mm) 3K 30K 330 www.wpmtek.com 5.0SMDJ Series Integrated in OVP&OCP products provider 5000W Transient Voltage Suppressor Electrical Characteristics (TA=25℃) Part Number Marking VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar Uni Bi V μA min(V) max(V) mA max(V) A 5.0SMDJ11A 5.0SMDJ11CA 5PEN 5BEN 11 5 12.20 13.50 10 18.2 275.0 5.0SMDJ12A 5.0SMDJ12CA 5PEP 5BEP 12 5 13.30 14.70 10 19.9 252.0 5.0SMDJ13A 5.0SMDJ13CA 5PEQ 5BEQ 13 5 14.40 15.90 10 21.5 233.0 5.0SMDJ14A 5.0SMDJ14CA 5PER 5BER 14 5 15.60 17.20 10 23.2 216.0 5.0SMDJ15A 5.0SMDJ15CA 5PES 5BES 15 5 16.70 18.50 1 24.4 205.0 5.0SMDJ16A 5.0SMDJ16CA 5PET 5BET 16 5 17.80 19.70 1 26.0 193.0 5.0SMDJ17A 5.0SMDJ17CA 5PEU 5BEU 17 5 18.90 20.90 1 27.6 181.0 5.0SMDJ18A 5.0SMDJ18CA 5PEV 5BEV 18 5 20.00 22.10 1 29.2 172.0 5.0SMDJ20A 5.0SMDJ20CA 5PEW 5BEW 20 5 22.20 24.50 1 32.4 155.0 5.0SMDJ22A 5.0SMDJ22CA 5PEX 5BEX 22 1 24.40 26.90 1 35.5 141.0 5.0SMDJ24A 5.0SMDJ24CA 5PEZ 5BEZ 24 1 26.70 29.50 1 38.9 129.0 5.0SMDJ26A 5.0SMDJ26CA 5PFE 5BFE 26 1 28.90 31.90 1 42.1 119.0 5.0SMDJ28A 5.0SMDJ28CA 5PFG 5BFG 28 1 31.10 34.40 1 45.4 110.0 5.0SMDJ30A 5.0SMDJ30CA 5PFK 5BFK 30 1 33.30 36.80 1 48.4 103.0 5.0SMDJ33A 5.0SMDJ33CA 5PFM 5BFM 33 1 36.70 40.60 1 53.3 93.9 5.0SMDJ36A 5.0SMDJ36CA 5PFP 5BFP 36 1 40.00 44.20 1 58.1 86.1 5.0SMDJ40A 5.0SMDJ40CA 5PFR 5BFR 40 1 44.40 49.10 1 64.5 77.6 5.0SMDJ43A 5.0SMDJ43CA 5PFT 5BFT 43 1 47.80 52.80 1 69.4 72.1 5.0SMDJ45A 5.0SMDJ45CA 5PFV 5BFV 45 1 50.00 55.30 1 72.7 68.8 5.0SMDJ48A 5.0SMDJ48CA 5PFX 5BFX 48 1 53.30 58.90 1 77.4 64.7 5.0SMDJ51A 5.0SMDJ51CA 5PFZ 5BFZ 51 1 56.70 62.70 1 82.4 60.7 5.0SMDJ54A 5.0SMDJ54CA 5PGE 5BGE 54 1 60.00 66.30 1 87.1 57.5 5.0SMDJ58A 5.0SMDJ58CA 5PGG 5BGG 58 1 64.40 71.20 1 93.6 53.5 5.0SMDJ60A 5.0SMDJ60CA 5PGK 5BGK 60 1 66.70 73.70 1 96.8 51.7 5.0SMDJ64A 5.0SMDJ64CA 5PGM 5BGM 64 1 71.10 78.60 1 103.0 48.6 5.0SMDJ70A 5.0SMDJ70CA 5PGP 5BGP 70 1 77.80 86.00 1 113.0 44.3 5.0SMDJ75A 5.0SMDJ75CA 5PGR 5BGR 75 1 83.30 92.10 1 121.0 41.4 5.0SMDJ78A 5.0SMDJ78CA 5PGT 5BGT 78 1 86.70 95.80 1 126.0 39.7 5.0SMDJ85A 5.0SMDJ85CA 5PGV 5BGV 85 1 94.40 104.0 1 137.0 36.5 Rev.2_Oct,2016 -2- www.wpmtek.com 5.0SMDJ Series Integrated in OVP&OCP products provider 5000W Transient Voltage Suppressor Electrical Characteristics (TA=25℃, Continued) Part Number Marking VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar Uni Bi V μA min(V) max(V) mA max(V) A 5.0SMDJ90A 5.0SMDJ90CA 5PGX 5BGX 90 1 100.0 111.0 1 146.0 34.3 5.0SMDJ100A 5.0SMDJ100CA 5PGZ 5BGZ 100 1 111.0 123.0 1 162.0 30.9 5.0SMDJ110A 5.0SMDJ110CA 5PHE 5BHE 110 1 122.0 135.0 1 177.0 28.3 5.0SMDJ120A 5.0SMDJ120CA 5PHG 5BHG 120 1 133.0 147.0 1 193.0 26.0 5.0SMDJ130A 5.0SMDJ130CA 5PHK 5BHK 130 1 144.0 159.0 1 209.0 24.0 5.0SMDJ150A 5.0SMDJ150CA 5PHM 5BHM 150 1 167.0 185.0 1 243.0 20.6 5.0SMDJ160A 5.0SMDJ160CA 5PHP 5BHP 160 1 178.0 197.0 1 259.0 19.3 5.0SMDJ170A 5.0SMDJ170CA 5PHR 5BHR 170 1 189.0 209.0 1 275.0 18.2 ① Surge waveform: 10/1000μs VR:Stand-off Voltage -- Maximum voltage that can be applied VBR: Breakdown Voltage VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp IR: Reverse Leakage Current Part Number Code 5.0SMDJ XX C A 5000W SMC Series VR Voltage 5%VBR Volatage C:Bi-directional tolerance Absolute Maximum Ratings (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Storage temperature range Operating junction temperature range Steady state power dissipation at TL=75℃ Peak pulse power dissipation on 10/1000μs waveform Maximum Instantaneous Forward Voltage at 100A for Unidirectional Rev.2_Oct,2016 Symbol Value Unit Tstg -55 to +150 ℃ Tj -55 to +150 ℃ PM(AV) 10 W PPP 5000 W VF 5.0 V -3- www.wpmtek.com 5.0SMDJ Series Integrated in OVP&OCP products provider 5000W Transient Voltage Suppressor Ratings And V-I Characteristics Curves (TA=25ºC, unless otherwise noted) FIG.1:V- I curve characteristics (Uni-directional) FIG.2:V- I curve characteristics (Bi-directional) I PP V C V BR V R V VF V C V BR V R 100 V R V BR V C FIG.4: Pulse derating curve FIG.3: Pulse waveform P PP derating in percentage(%) 100 tr = rise time to peak value td = decay time to half value tr=10μs IR IT V I PP I PP IPPM (%IRSM ) 150 IT IR 80 Peak value 60 Half value 40 50 20 0 0 td Rev.2_Oct,2016 1.0 t(ms) 2.0 3.0 0 0 4.0 -4- 25 50 T A (℃ ) 75 100 125 150 175 www.wpmtek.com 5.0SMDJ Series Integrated in OVP&OCP products provider 5000W Transient Voltage Suppressor Soldering Parameters Pb-Free assembly Reflow Condition +150℃ -Temperature Max(Ts(max)) +200℃ TP -Time (Min to Max) (ts) 60-180 secs. TL Average ramp up rate (Liquid us Temp (TL)to peak) Ts(max) to TL - Ramp-up Rate Reflow FIG.5: Reflow condition -Temperature Min (Ts(min)) tp Critical Zone TL to TP Ramp-up tL TS(max) Temperature Pre Heat (see FIG.5) 3℃/sec. Max TS(min) 3℃/sec. Max -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Ramp-down Preheat 25 ts time to peak temperatue (t 25℃ to peak) Time Package Mechanical Data A Dimensions B C Ref. Max. Min. Max. A 6.60 7.11 0.260 0.280 B 5.59 6.20 0.220 0.244 C 2.75 3.20 0.108 0.126 D 0.76 1.52 0.030 0.060 E E 7.74 8.13 0.305 0.320 F 0.051 0.203 0.002 0.008 J K G 0.15 0.31 0.006 0.012 H 2.15 2.62 0.085 0.103 J 8.12 F H L DO-214AB (SMC) 0.320 4.69 K Rev.2_Oct,2016 Inches Min. G D Millimeters 3.07 L -5- 0.185 0.121 www.wpmtek.com 5.0SMDJ Series Integrated in OVP&OCP products provider 5000W Transient Voltage Suppressor Tape & Reel Specification – SMC/DO-214AB Contact Information WPMTEK Incorporated Limited Floor 1 Building 4#, Binxianghua Industry Park, No.7, Huada Road, Hualian Community, Longhua New District, Shenzhen TEL:86755-29308003 wpmtek Incorporated FAX:86755-23739900 Limited(WPM)reservestherighttomakechangestotheproductspecificationanddatainthisdocumentwithoutnotice.WPMmakesno warranty,representationorguaranteeregardingthesuitabilityofitsproductsforanyparticularpurpose,nordoesWPMassumeanyliabilityarisingfromtheapplicatio noruseofanyproductsorcircuits,andspecificallydis-claimsanyandallliability,includingwithoutlimitationspecial,consequentialorincidentaldamages. Rev.2_Oct,2016 -6- www.wpmtek.com
5.0SMDJ30CA 价格&库存
很抱歉,暂时无法提供与“5.0SMDJ30CA”相匹配的价格&库存,您可以联系我们找货
