SLIDE SWITCHES (SMD)
RoHS compliant
CJS
INTERNAL STRUCTURE
①
②
⑤
③
⑥
④
Part name
Material
■ FEATURES
①
Cover
Polyphenylenesulphide
● RoHS compliant
● Easy to set slider with line marking
● With neutral detent type lined up to 1 pole 2contacts
switch
● Compatible with most automatic pick & place machinery
● Compact and space saving SMD type
②
Slider
Polyamide
③
Housing
④
Slider contact
⑤
Fixed contact
⑥
Terminal pin
Flammability
UL94V-0
Copper alloy, Gold-plated
■ PART NUMBER DESIGNATION
C J S - 1 2 0 1 T B 1
Series name
No. of poles
1:1 pole
Structure
1:Non-washable type (Without seal tape)
Standard type
2:Non-washable type (With seal tape)
Blank : Washable type (With seal tape)
No. of contacts
2:2 contacts
Setting position
0:Top setting
Shape of terminal
A:J-hook
B:Gull wing
Neutral detent
0:Without neutral detent
1:With neutral detent
SPDT : Single Pole Double Throw
※ Please refer to the LIST OF PART NUMBERS when placing orders.
Form of packaging
T:Taping (Reel)
Blank:plastic bag
CJS
■ LIST OF PART NUMBERS
No. of
poles
1
No. of
poles
1
No. of
contacts
2
No. of
contacts
2
Setting
position
Neutral
detent
Form of
packaging
Without
neutral
detent
Taping
CJS-1200TA1
CJS-1200TB1
CJS-1200TA2
CJS-1200TB2
1000pcs./reel
Plastic bag
CJS-1200A1
CJS-1200B1
CJS-1200A2
CJS-1200B2
100pcs./pack
A
J-hook
Gull wing ) A
B (
J-hook
Gull wing
B (
Pieces in
package
Top setting
Setting
position
With
neutral
detent
Taping
CJS-1201TA1
CJS-1201TB1
CJS-1201TA2
CJS-1201TB2
1000pcs./reel
Plastic bag
CJS-1201A1
CJS-1201B1
CJS-1201A2
CJS-1201B2
100pcs./pack
Neutral
detent
Form of
packaging
Without
neutral
detent
Taping
CJS-1200TA
CJS-1200TB
1000pcs./reel
Plastic bag
CJS-1200A
CJS-1200B
100pcs./pack
Taping
CJS-1201TA
CJS-1201TB
1000pcs./reel
Plastic bag
CJS-1201A
CJS-1201B
100pcs./pack
A
J-hook
Gull wing
B (
Pieces in
package
Top setting
With
neutral
detent
※ Verify the above part numbers when placing orders.
Taping version can be supplied only in reel unit.
CJS
■ STANDARD SPECIFICATIONS
Operating temp. range
Storage temp. range
Sealing
Net weight
■ ELECTRICAL CHARACTERISTICS
Contact rating
Non-switching
Switching
Minimum
− 40 ~ 85 °C
Washable type available with seal tape
Contact resistance
Approx. 0.05g (CJS-1200)
Approx. 0.06g (CJS-1201)
Insulation resistance
Dielectric strength
■ MECHANICAL CHARACTERISTICS
Operating force
DC50 V 100 mA
DC6 V, 100 mA DC24 V, 25 mA
DC20 mV 1 μ A
100 m Ω maximum
100 M Ω (DC100 V) minimum
AC250 V, 60 s
■ ENVIRONMENTAL CHARACTERISTICS
5.9 N {0.6 kgf} maximum
Vibration
(Amplitude) 1.5 mmor (Acceleration) 98 m/s2,
10-500 Hz, 3 directions for 10 cycles each
Stop strength
10 N {1.02 kgf}, 60 s
Shock
490 m/s2, 11 ms
6 directions for 3 times each
Solderability
245 ± 3 °C, 2 ~ 3 s
Load life
Continuous load 200 cycles,
DC6 ± 0.5 V, 100 ± 10 mA
Reflow:255 °C (Peak temperature)
(Please refer to the profile below)
Humidity
Soldering heat
− 10 ~ 65 °C, Relative humidity 0 ~ 96 %,
24 h for 10 cycles
Manual soldering:350 ± 10 °C, 3 ~ 4 s
High temp. exposure
85 °C, 96 h
Shear (Adhesion)
5 N {0.51 kgf} 10 s
Low temp. exposure
− 40 °C, 96 h
Substrate bending
Width 90 mm, bend 3 mm, 5 s, 1 time
Pull-off strength
Thermal shock
5 N {0.51 kgf} 10 s
{ } : Reference only
〈Reflow profile for soldering heat evaluation〉
Temperature
250
200
150
100
50
Peak : 250
+5
Over 230 ℃
180 ℃
150 ℃
Pre Heating Zone
90 ± 30 s
30 ± 10 s
Heating time
Soldering Zone
Reflow : two times maximum
− 40 (0.5 h) ~ 85 °C (0.5 h), 5 cycles
CJS
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.3 (Unit : mm)
● CJS-1200A1
3 – 0.6
● CJS-1200B1
3 – 0.6
+0.1
–0.05
Production date code
2
C
+0.1
–0.05
C
②
2
0.
5
①
Terminal No.1
③
C
Terminal No.1
Schematic
③
5.4
4.2
Stroke 0.6
2.5
0.15 +0.1
–0.05
0.3
0.1 –0.1
2.5 max.
0.15 +0.1
–0.05
2.5 max.
0.1 –0.1
①
2.5
1.1
● CJS-1201A1
3.5
0.4 min.
0.4 min.
● CJS-1201B1
3 – 0.6
+0.1
–0.05
2
C
+0.1
–0.05
C
②
5
①
③
Terminal No.1
Schematic
C
0.
5
①
③
Stroke
2.8 +0.3
–0.05
–0.1
2.5 max.
0.15 +0.1
–0.05
2.5
0.6
0.3
0.6
0.3
2.5 max.
4.2
6
2.5
0.6
Schematic
Stroke
6
1.1
3.5
3.5
0.1
0.6
C
②
2
0.
Terminal No.1
0.1 –0.1
5
2.8 +0.3
3 – 0.6
0.
Schematic
0.3
5.4
Stroke 0.6
C
②
0.4 min.
0.4 min.
3.5
3.5
1200A□ 1201A□
1200A□ 1201A□
2.6
3-1
2.6
0.7
1.6
3-1
1.3
0.7
1.6
1.6
B type
1.6
A type
1.3
■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS
3-1
3-1
3.5
(Unit : mm)
1200B□ 1201B□
1200B□ 1201B□
Note)
The zero point is the center of mounting.
CJS
■ PACKAGING SPECIFICATIONS
● Taping version is packaged in 1000 pcs. per reel.
Orders will be accepted for units of 1000 pcs., i.e., 1000,
2000, 3000 pcs., etc.
● Taping version is boxed with two reels (2000 pcs.).
Maximum number of consecutive missing pieces=2
Leader length and reel dimension are shown in the
diagrams below:
● Embossed tape dimensions
● Reel dimensions
(Unit: mm)
(Conforms to JIS C 0806)
17.4 ± 1
Empty
End
φ 13±0.2
Head
40 mm min.
2±0.5
20 pitches min.
Leader
400 mm min.
Direction of feed
φ 50 min.
Filled
φ 254 ± 2
Empty
φ 21±0.8
21.4 ± 1
● CJS-1200TA□ , 1200TB□ , 1201TA□ , 1201TB□
2 ± 0.1
0.3 ± 0.1
(CJS-1200B1)
Installation example
16
8 ± 0.1
4 ± 0.1
1.75 ± 0.1
+0.1
7.5 ± 0.1
φ 1.5
(Unit: mm)
Terminal No.1
Direction of feed
● Boxing of bulk pack in a plastic bag is performed with
100 pcs. (standard 500 pcs.) per box.
3
很抱歉,暂时无法提供与“CJS-1201TB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+10.349001+1.33900
- 10+8.8517010+1.14520
- 25+8.1810025+1.05850
- 100+7.29460100+0.94380
- 250+6.75560250+0.87410
- 500+6.39630500+0.82760
- 1000+6.036901000+0.78110
- 2000+5.581702000+0.72220
- 5000+5.294305000+0.68500
- 国内价格 香港价格
- 1+10.448481+1.35179
- 10+8.8887010+1.14999
- 25+8.2581525+1.06842
- 100+7.36136100+0.95239
- 250+6.82080250+0.88246
- 500+6.44665500+0.83405
- 国内价格 香港价格
- 1000+6.104841000+0.78983
- 2000+5.796182000+0.74989
- 3000+5.630843000+0.72850
- 5000+5.438215000+0.70358
- 7000+5.320597000+0.68836
- 10000+5.2036110000+0.67323
- 国内价格
- 1+5.11920
- 10+4.19040
- 30+3.72600
- 100+3.26160
- 500+2.86200
- 1000+2.72160
- 国内价格 香港价格
- 1+10.393681+1.34470
- 10+9.4329210+1.22040
- 50+8.8215350+1.14130
- 100+8.29748100+1.07350
- 250+7.77343250+1.00570
- 500+7.33672500+0.94920
- 1000+6.812671000+0.88140
- 国内价格 香港价格
- 6+8.811376+1.13999
- 10+7.7246610+0.99939
- 25+7.2093025+0.93272
- 100+6.07714100+0.78624
- 500+5.74439500+0.74319
- 1000+4.819191000+0.62349
