Integrated in
OVP&OCP products
provider
PXXXXSC Series
Thyristors Surge Protection Device(SMB 6KV)
Description
Mechanical Characteristics
PXXXXSC series thyristors are a type of semi-conduct
component. They are designed in modems, telephones,
line cards, answering machines, FAX machines, SLICs,
T1/E1, xDSL, PBXs and more applications.
n
Package: SMB/DO-214AA
n
Case Material: “Green” Molding Compound.
n
UL Flammability Classification Rating 94V-0
n
Standard Packaging: 12mm tape (EIA STD
RS-481)
Features
n
Weight: 0.10g
n
Surface mount package to optimize board space
n
Terminal Connections: See Diagram Below
n
Low profile package
n
Marking Information: See Below
n
Bidirectional crowbar protection
n
Low leakage current : I = 5uA max
n
Low on-state voltage
n
Low Capacitance
n
n
Applications Standards
n
TIA-968-A/B
Solid-state silicon technology
n
ITU K.20/21 Enhanced Level*
Eliminates overvoltage caused by fast rising transients
n
ITU K.20/21 Basic Level*
n
GR 1089 Inter-building*
n
GR 1089 Intra-building
n
IEC 61000-4-5 2nd edition
n
YD/T 1082
Dimensions & Symbol(Unit: mm Max)
YD/T 993
YD/T 950
2
Marking Information
1
Ordering Information
Rev.B_Oct,2019
-1-
Out line
Reel
(pcs)
Per carton
(pcs)
Reel diameters
(mm)
Taping
3K
48K
330
www.wpmtek.com
Integrated in
OVP&OCP products
provider
PXXXXSC Series
Absolute Maximum Ratings (TA=25ºC, RH=45%-75%, unless otherwise noted)
Parameter
Symbol
Value
Unit
Tstg
-60 to +150
Operating junction temperature range
Tj
-40 to +150
Repetitive peak pulse current
IPP
150
A
Storage temperature range
Electrical Characteristics Curve (TA=25℃)
Symbol
Parameter
VDRM
Peak off-state voltage
IDRM
Off-state current
VS
Switching voltage
IS
Switching current
VT
On-state voltage
IT
On-state current
IH
Holding current
CO
Off-state capacitance
Surge Ratings
IPP (A) min
Series
2×10us
8×20us
10×360us
10×1000us
500
400
175
100
C
Part Number Code
Series code: P indicator
P XXXX S C
Surge:10/700uS 6KV
VDRM
Package Type SMB
Rev.B_Oct,2019
-2-
www.wpmtek.com
Integrated in
OVP&OCP products
provider
PXXXXSC Series
Electrical Characteristics (TA=25℃,)
IDRM@VDRM
Part Number
VS①@IS
VT@ IT
IH
CO ②
μA
V
V
mA
V
A
mA
pF
max
min
max
max
max
max
min
max
P0080SC
5
6
4
2.2
25
80
P0220SC
5
15
28
800
4
2.2
35
80
P0300SC
5
25
40
800
4
2.2
50
80
P0640SC
5
58
77
800
4
2.2
120
65
P0720SC
5
65
88
800
4
2.2
120
65
P0900SC
5
75
98
800
4
2.2
120
65
P1100SC
5
90
130
800
4
2.2
120
65
P1300SC
5
120
160
800
4
2.2
120
65
P1500SC
5
140
180
800
4
2.2
120
65
P1800SC
5
170
220
800
4
2.2
120
60
P2000SC
5
180
220
800
4
2.2
120
60
P2300SC
5
190
260
800
4
2.2
120
60
P2600SC
5
220
300
800
4
2.2
120
55
P3100SC
5
275
350
800
4
2.2
120
70
P3500SC
5
320
400
800
4
2.2
120
50
P3800SC
5
360
460
800
4
2.2
120
50
P4200SC
5
400
540
800
4
2.2
120
45
① Vs is measured at 100KV/s
② Off-state capacitance is measured in VDC=2V, VRMS=1V, f=1MHz
Rev.B_Oct,2019
-3-
www.wpmtek.com
Integrated in
OVP&OCP products
provider
PXXXXSC Series
Soldering Parameters
Pre Heat
Reflow Condition
Pb-Free assembly
-Temperature Min (Ts(min))
+150℃
-Temperature Max (Ts(max))
+200℃
-Time (Min to Max) (ts)
60-180 secs.
Average ramp up rate (Liquid us Temp (TL) to peak)
3℃/sec. Max
Ts(max) to TL - Ramp-up Rate
3℃/sec. Max
Reflow
-Temperature (TL) (Liquid us)
+217℃
-Temperature(tL)
60-150 secs.
Peak Temp (Tp)
+260(+0/-5)℃
Time within 5℃ of actual Peak Temp (tp)
30 secs. Max
Ramp-down Rate
6℃/sec. Max
Time 25℃ to Peak Temp (TP)
8 min. Max
Do not exceed
Rev.B_Oct,2019
+260℃
-4-
www.wpmtek.com
Integrated in
OVP&OCP products
provider
PXXXXSC Series
Package Mechanical Data
Tape & Reel Specification - SMB
Contact Information
WPMTEK Incorporated Limited
Room 207,2nd Floor, Block 3,Minxing lndustry Park, Minzhi,
Longhua New District, Shenzhen, PRC.
TEL:86755-29308003
FAX:86755-23739900
Wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM
makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability
arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special,
consequential or incidental damages.
Rev.B_Oct,2019
-5-
www.wpmtek.com
很抱歉,暂时无法提供与“P0080SC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.43708
- 100+0.36450
- 300+0.32822
- 3000+0.22929
- 6000+0.20747
- 9000+0.19656
