SMDJ33A
SMDJ33A
    WPMTEK(维攀微)
    SMC(DO-214AB)
    SMC SMT 33V 53.3V
SMDJ33A 数据手册
SMDJ Series Integrated in OVP&OCP products provider 3000W Transient Voltage Suppressor Description Mechanical characteristics TVS diodes can be used in a wide range of applications which like consumer electronic products, automotive Package: SMC/DO-214AB industries, n Case Material: “Green” Molding Compound. n UL Flammability Classification Rating 94V-0 n Polarity: Color band denotes cathode except munitions, telecommunications, aerospace industries, and intelligent control systems. Features bi-directional models n Standard Packaging: 16mm tape (EIA STD n Glass passivated or planar junction n Excellent clamping capability n Weight: 0.28g n Repetition rate (duty cycle): 0.01% n Terminal Connections: See Diagram Below n Low profile package and low inductance n Marking Information: See Below n 3000W Peak Pulse power capability at 10×1000μs RS-481) Applications waveform. n Fast response time: typically less than 1.0ps from 0V to VBR min. n I/O Interface. n High temperature soldering: 260℃/10s at terminals. n AC/DC Power supply n Plastic n Low frequency signal transmission line package has Underwriters Laboratory (RS232, RS485, etc.) Flammability 94V-0. n For surface mounted applications in order to optimize board space. Marking information Dimensions & Symbol(Unit: mm Max) Ordering information Rev.A_Aug,2016 -1- Out line Reel (pcs) Per carton (pcs) Reel diameters (mm) Taping 3K 48K 330 www.wpmtek.com SMDJ Series Integrated in OVP&OCP products provider 3000W Transient Voltage Suppressor Electrical characteristics (TA=25℃) Part Number Uni-Polar Bi-Polar SMDJ5.0A Marking VR IR@VR V μA min(V) IT VC@IPP IPP① max(V) mA max(V) A VBR@IT Uni Bi SMDJ5.0CA HDE IDE 5.0 800 6.40 7.00 10 9.2 326.1 SMDJ6.0A SMDJ6.0CA HDG IDG 6.0 800 6.67 7.37 10 10.3 291.3 SMDJ6.5A SMDJ6.5CA HDK IDK 6.5 500 7.22 7.98 10 11.2 267.9 SMDJ7.0A SMDJ7.0CA HDM IDM 7.0 200 7.78 8.60 10 12.0 250.0 SMDJ7.5A SMDJ7.5CA HDP IDP 7.5 100 8.33 9.21 1 12.9 232.6 SMDJ8.0A SMDJ8.0CA HDR IDR 8.0 50 8.89 9.83 1 13.6 220.6 SMDJ8.5A SMDJ8.5CA HDT IDT 8.5 20 9.44 10.40 1 14.4 208.3 SMDJ9.0A SMDJ9.0CA HDV IDV 9.0 10 10.00 11.10 1 15.4 194.8 SMDJ10A SMDJ10CA HDX IDX 10 5 11.10 12.30 1 17.0 176.5 SMDJ11A SMDJ11CA HDZ IDZ 11 1 12.20 13.50 1 18.2 164.8 SMDJ12A SMDJ12CA HEE IEE 12 1 13.30 14.70 1 19.9 150.8 SMDJ13A SMDJ13CA HEG IEG 13 1 14.40 15.90 1 21.5 139.5 SMDJ14A SMDJ14CA HEK IEK 14 1 15.60 17.20 1 23.2 129.3 SMDJ15A SMDJ15CA HEM IEM 15 1 16.70 18.50 1 24.4 123.0 SMDJ16A SMDJ16CA HEP IEP 16 1 17.80 19.70 1 26.0 115.4 SMDJ17A SMDJ17CA HER IER 17 1 18.90 20.90 1 27.6 108.7 SMDJ18A SMDJ18CA HET IET 18 1 20.00 22.10 1 29.2 102.7 SMDJ20A SMDJ20CA HEV IEV 20 1 22.20 24.50 1 32.4 92.6 SMDJ22A SMDJ22CA HEX IEX 22 1 24.40 26.90 1 35.5 84.5 SMDJ24A SMDJ24CA HEZ IEZ 24 1 26.70 29.50 1 38.9 77.1 SMDJ26A SMDJ26CA HFE IFE 26 1 28.90 31.90 1 42.1 71.3 SMDJ28A SMDJ28CA HFG IFG 28 1 31.10 34.40 1 45.4 66.1 SMDJ30A SMDJ30CA HFK IFK 30 1 33.30 36.80 1 48.4 62.0 SMDJ33A SMDJ33CA HFM IFM 33 1 36.70 40.60 1 53.3 56.3 SMDJ36A SMDJ36CA HFP IFP 36 1 40.00 44.20 1 58.1 51.6 SMDJ40A SMDJ40CA HFR IFR 40 1 44.40 49.10 1 64.5 46.5 SMDJ43A SMDJ43CA HFT IFT 43 1 47.80 52.80 1 69.4 43.2 SMDJ45A SMDJ45CA HFV IFV 45 1 50.00 55.30 1 72.7 41.3 SMDJ48A SMDJ48CA HFX IFX 48 1 53.30 58.90 1 77.4 38.8 Rev.A_Aug,2016 -2- www.wpmtek.com SMDJ Series Integrated in OVP&OCP products provider 3000W Transient Voltage Suppressor Electrical characteristics (TA=25℃, continued) Part Number Marking VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar Uni Bi V μA min(V) max(V) mA max(V) A SMDJ51A SMDJ51CA HFZ IFZ 51 1 56.70 62.70 1 82.4 36.4 SMDJ54A SMDJ54CA HGE IGE 54 1 60.00 66.30 1 87.1 34.4 SMDJ58A SMDJ58CA HGG IGG 58 1 64.40 71.20 1 93.6 32.1 SMDJ60A SMDJ60CA HGK IGK 60 1 66.70 73.70 1 96.8 31.0 SMDJ64A SMDJ64CA HGM IGM 64 1 71.10 78.60 1 103.0 29.1 SMDJ70A SMDJ70CA HGP IGP 70 1 77.80 86.00 1 113.0 26.5 SMDJ75A SMDJ75CA HGR IGR 75 1 83.30 92.10 1 121.0 24.8 SMDJ78A SMDJ78CA HGT IGT 78 1 86.70 95.80 1 126.0 23.8 SMDJ85A SMDJ85CA HGV IGV 85 1 94.40 104.0 1 137.0 21.9 SMDJ90A SMDJ90CA HGX IGX 90 1 100.0 111.0 1 146.0 20.5 SMDJ100A SMDJ100CA HGZ IGZ 100 1 111.0 123.0 1 162.0 18.5 SMDJ110A SMDJ110CA HHE IHE 110 1 122.0 135.0 1 177.0 16.9 SMDJ120A SMDJ120CA HHG IHG 120 1 133.0 147.0 1 193.0 15.5 SMDJ130A SMDJ130CA HHK IHK 130 1 144.0 159.0 1 209.0 14.4 SMDJ150A SMDJ150CA HHM IHM 150 1 167.0 185.0 1 243.0 12.3 SMDJ160A SMDJ160CA HHP IHP 160 1 178.0 197.0 1 259.0 11.6 SMDJ170A SMDJ170CA HHR IHR 170 1 189.0 209.0 1 275.0 10.9 SMDJ180A SMDJ180CA HHT IHT 180 1 201.0 222.0 1 292.0 10.3 SMDJ190A SMDJ190CA HHV IHV 190 1 211.0 234.0 1 307.0 9.7 SMDJ200A SMDJ200CA HHX IHX 200 1 224.0 247.0 1 324.0 9.3 SMDJ210A SMDJ210CA HHZ IHZ 210 1 233.0 258.0 1 337.0 8.8 SMDJ220A SMDJ220CA IIE 220 1 246.0 272.0 1 356.0 8.4 HIE ① Surge waveform: 10/1000μs VR :Stand-off Voltage -- Maximum voltage that can be applied VBR: Breakdown Voltage VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp IR: Reverse Leakage Current Rev.A_Aug,2016 -3- www.wpmtek.com SMDJ Series Integrated in OVP&OCP products provider 3000W Transient Voltage Suppressor Part number code SMDJ xx C A 3000W SMC Series 5% VBR Voltage tolerance VR Voltage C: Bi-directional Absolute maximum ratings (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Storage temperature range Symbol Value Unit Tstg -55 to +150 ℃ Tj -55 to +150 ℃ PM(AV) 8.0 W PPP 3000 W VF 5.0 V Operating junction temperature range Steady state power dissipation at TL=75℃ Peak pulse power dissipation on 10/1000μs waveform Maximum Instantaneous Forward Voltage at 60A for Unidirectional Ratings and V-I characteristics curves (TA=25ºC, unless otherwise noted) FIG.1:V- I curve characteristics (Uni-directional) FIG.2:V- I curve characteristics (Bi-directional) IPP V VC VBR VR VC VBR VR VF V IR IT VR VBR VC IPP IPP Rev.A_Aug,2016 IT IR -4- www.wpmtek.com SMDJ Series Integrated in OVP&OCP products provider 3000W Transient Voltage Suppressor FIG.4: Pulse derating curve FIG.3: Pulse waveform PPP derating in percentage(%) 100 IPPM(%IRSM) 150 tr = rise time to peak value td = decay time to half value tr=10¦ Ìs 100 80 Peak value 60 Half value 40 50 20 td 0 0 1.0 t(ms) 2.0 3.0 4.0 0 0 25 TA(℃) 75 100 50 125 150 175 Soldering parameters Reflow Condition Heat +150℃ -Temperature Max(Ts(max)) +200℃ TP -Time (Min to Max) (ts) 60-180 secs. TL 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Rev.A_Aug,2016 tp Critical Zone TL to TP Ramp-up tL TS(max) Average ramp up rate (Liquid us Temp (TL) to peak) Reflow FIG.5: Reflow condition -Temperature Min (Ts(min)) -5- Temperature Pre Pb-Free assembly (see FIG.5) Ramp-down Preheat TS(min) 25 ts time to peak temperatue (t 25¡ æ to peak) Time www.wpmtek.com SMDJ Series Integrated in OVP&OCP products provider 3000W Transient Voltage Suppressor Package mechanical data Tape & reel specification - SMC Ref. A B d D D2 E F P P0 P1 W W1 Dimensions (mm) 6.27±0.20 8.30±0.20 φ1.50±0.10 φ330.00±2.00 φ13.50±0.20 1.75±0.10 7.50±0.10 8.00±0.10 4.00±0.10 2.00±0.10 16.00±0.20 20.00±2.0 Rev.A_Aug,2016 -6- www.wpmtek.com SMDJ Series Integrated in OVP&OCP products provider 3000W Transient Voltage Suppressor Contact information WPMTEK Incorporated Limited Room 207,2nd Floor, Block 3,Minxing lndustry Park, Minzhi, Longhua New District, Shenzhen, PRC. TEL:86755-29308003 FAX:86755-23739900 wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.A_Aug,2016 -7- www.wpmtek.com
SMDJ33A 价格&库存
很抱歉,暂时无法提供与“SMDJ33A”相匹配的价格&库存,您可以联系我们找货
SMDJ33A
    • 1+1.66500
    • 100+1.55400
    • 300+1.44300
    • 500+1.33200
    • 2000+1.27650
    • 5000+1.24320
