SMCJ24CA
SMCJ24CA
    WPMTEK(维攀微)
    SMC(DO-214AB)
    TVS二极管 双极性 24V 1500W SMC(DO-214AB)
SMCJ24CA 数据手册
SMCJ Series Integrated in OVP&OCP products provider 1500W Transient Voltage Suppressor Description Mechanical Characteristics TVS diodes can be used in a wide range of applications Package: SMC/DO-214AB which like consumer electronic products, automotive  Case Material: “Green” Molding Compound.  Polarity: Color band denotes cathode except industries, munitions, telecommunications, aerospace industries, and intelligent control systems. bi-directional models  Features Standard Packaging: 16mm tape (EIA STD RS-481)  Glass passivated or planar junction  Excellent clamping capability  Repetition rate (duty cycle): 0.01%  Low profile package and low inductance  1500W Peak Pulse power capability at 10×1000μs  Weight: 0.26g  Terminal Connections: See Diagram Below  Marking Information: See Below Applications waveform. Fast response time: typically less than 1.0ps from 0V  I/O Interface. to VBR min.  AC/DC Power supply  High temperature soldering: 260℃/10s at terminals.  Low frequency signal transmission line  Plastic  package has Underwriters (RS232, RS485, etc.) Laboratory Flammability 94V-0.  For surface mounted applications in order to optimize Marking Information board space. Dimensions & Symbol(Unit: mm Max) Marking Information Out line Taping Rev.A_Feb,2018 -1- Reel Per carton Reel diameters (pcs) (pcs) (mm) 3K 48K 330 www.wpmtek.com SMCJ Series Integrated in OVP&OCP products provider 1500W Transient Voltage Suppressor Electrical characteristics (TA=25℃) Part Number Marking Bi IR@VR V μA min(V) IT VC@IPP IPP① max(V) mA max(V) A VBR@IT Uni-Polar Bi-Polar SMCJ5.0A SMCJ5.0CA GDE BDE 5.0 300 6.40 7.00 10 9.2 163.0 SMCJ6.0A SMCJ6.0CA GDG BDG 6.0 250 6.67 7.37 10 10.3 145.6 SMCJ6.5A SMCJ6.5CA GDK BDK 6.5 150 7.22 7.98 10 11.2 134.0 SMCJ7.0A SMCJ7.0CA GDM BDM 7.0 100 7.78 8.60 10 12.0 125.0 SMCJ7.5A SMCJ7.5CA GDP BDP 7.5 50 8.33 9.21 1 12.9 116.3 SMCJ8.0A SMCJ8.0CA GDR BDR 8.0 30 8.89 9.83 1 13.6 110.3 SMCJ8.5A SMCJ8.5CA GDT BDT 8.5 20 9.44 10.40 1 14.4 104.2 SMCJ9.0A SMCJ9.0CA GDV BDV 9.0 10 10.00 11.10 1 15.4 97.4 SMCJ10A SMCJ10CA GDX BDX 10 5 11.10 12.30 1 17.0 88.2 SMCJ11A SMCJ11CA GDZ BDZ 11 2 12.20 13.50 1 18.2 82.4 SMCJ12A SMCJ12CA GEE BEE 12 1 13.30 14.70 1 19.9 75.4 SMCJ13A SMCJ13CA GEG BEG 13 1 14.40 15.90 1 21.5 69.8 SMCJ14A SMCJ14CA GEK BEK 14 1 15.60 17.20 1 23.2 64.7 SMCJ15A SMCJ15CA GEM BEM 15 1 16.70 18.50 1 24.4 61.5 SMCJ16A SMCJ16CA GEP BEP 16 1 17.80 19.70 1 26.0 57.7 SMCJ17A SMCJ17CA GER BER 17 1 18.90 20.90 1 27.6 54.4 SMCJ18A SMCJ18CA GET BET 18 1 20.00 22.10 1 29.2 51.4 SMCJ20A SMCJ20CA GEV BEV 20 1 22.20 24.50 1 32.4 46.3 SMCJ22A SMCJ22CA GEX BEX 22 1 24.40 26.90 1 35.5 42.3 SMCJ24A SMCJ24CA GEZ BEZ 24 1 26.70 29.50 1 38.9 38.6 SMCJ26A SMCJ26CA GFE BFE 26 1 28.90 31.90 1 42.1 35.6 SMCJ28A SMCJ28CA GFG BFG 28 1 31.10 34.40 1 45.4 33.1 SMCJ30A SMCJ30CA GFK BFK 30 1 33.30 36.80 1 48.4 31.0 SMCJ33A SMCJ33CA GFM BFM 33 1 36.70 40.60 1 53.3 28.2 SMCJ36A SMCJ36CA GFP BFP 36 1 40.00 44.20 1 58.1 25.8 SMCJ40A SMCJ40CA GFR BFR 40 1 44.40 49.10 1 64.5 23.3 SMCJ43A SMCJ43CA GFT BFT 43 1 47.80 52.80 1 69.4 21.6 SMCJ45A SMCJ45CA GFV BFV 45 1 50.00 55.30 1 72.7 20.6 SMCJ48A SMCJ48CA GFX BFX 48 1 53.30 58.90 1 77.4 19.4 SMCJ51A SMCJ51CA GFZ BFZ 51 1 56.70 62.70 1 82.4 18.2 Rev.A_Feb,2018 Uni VR -2- www.wpmtek.com SMCJ Series Integrated in OVP&OCP products provider 1500W Transient Voltage Suppressor Electrical characteristics (TA=25℃, continued) Part Number 1 Marking VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar Uni Bi V μA min(V) max(V) mA max(V) A SMCJ54A SMCJ54CA GGE BGE 54 1 60.00 66.30 1 87.1 17.2 SMCJ58A SMCJ58CA GGG BGG 58 1 64.40 71.20 1 93.6 16.1 SMCJ60A SMCJ60CA GGK BGK 60 1 66.70 73.70 1 96.8 15.5 SMCJ64A SMCJ64CA GGM BGM 64 1 71.10 78.60 1 103.0 14.6 SMCJ70A SMCJ70CA GGP BGP 70 1 77.80 86.00 1 113.0 13.3 SMCJ75A SMCJ75CA GGR BGR 75 1 83.30 92.10 1 121.0 12.4 SMCJ78A SMCJ78CA GGT BGT 78 1 86.70 95.80 1 126.0 11.9 SMCJ85A SMCJ85CA GGV BGV 85 1 94.40 104.0 1 137.0 11.0 SMCJ90A SMCJ90CA GGX BGX 90 1 100.0 111.0 1 146.0 10.3 SMCJ100A SMCJ100CA GGZ BGZ 100 1 111.0 123.0 1 162.0 9.3 SMCJ110A SMCJ110CA GHE BHE 110 1 122.0 135.0 1 177.0 8.5 SMCJ120A SMCJ120CA GHG BHG 120 1 133.0 147.0 1 193.0 7.8 SMCJ130A SMCJ130CA GHK BHK 130 1 144.0 159.0 1 209.0 7.2 SMCJ150A SMCJ150CA GHM BHM 150 1 167.0 185.0 1 243.0 6.2 SMCJ160A SMCJ160CA GHP BHP 160 1 178.0 197.0 1 259.0 5.8 SMCJ170A SMCJ170CA GHR BHR 170 1 189.0 209.0 1 275.0 5.5 SMCJ180A SMCJ180CA GHT BHT 180 1 201.0 222.0 1 292.0 5.2 SMCJ190A SMCJ190CA GHU BHU 190 1 211.0 234.0 1 307.0 4.9 SMCJ200A SMCJ200CA GHV BHV 200 1 224.0 247.0 1 324.0 4.7 SMCJ210A SMCJ210CA GHW BHW 210 1 233.0 258.0 1 337.0 4.5 SMCJ220A SMCJ220CA GHX BHX 220 1 246.0 272.0 1 356.0 4.2 SMCJ250A SMCJ250CA GJG BJG 250 1 279.0 309.0 1 405.0 3.7 SMCJ300A SMCJ300CA GJK BJK 300 1 335.0 371.0 1 486.0 3.1 SMCJ350A SMCJ350CA GJM BJM 350 1 391.0 432.0 1 567.0 2.7 SMCJ400A SMCJ400CA GJP BJP 400 1 447.0 494.0 1 648.0 2.3 SMCJ440A SMCJ440CA GJR BJR 440 1 492.0 543.0 1 713.0 2.1 Surge waveform: 10/1000μs VR :Stand-off Voltage -- Maximum voltage that can be applied VBR: Breakdown Voltage VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp IR: Reverse Leakage Current Rev.A_Feb,2018 -3- www.wpmtek.com SMCJ Series Integrated in OVP&OCP products provider 1500W Transient Voltage Suppressor Part Number Code Absolute Maximum Ratings (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Storage temperature range Symbol Value Unit Tstg -55 to +150 ℃ Tj -55 to +150 ℃ PM(AV) 8.0 W PPP 1500 W VF 5.0 V Operating junction temperature range Steady state power dissipation at TL=75℃ Peak pulse power dissipation on 10/1000μs waveform Maximum Instantaneous Forward Voltage at 60A for Unidirectional Ratings And V-I Characteristics Curves (TA=25ºC, unless otherwise noted) FIG.1:V- I curve characteristics (Uni-directional) FIG.2:V- I curve characteristics (Bi-directional) IPP V C V BR V R VF V V C V BR V R IR IT V V R V BR V C IPP IPP Rev.A_Feb,2018 IT IR -4- www.wpmtek.com SMCJ Series Integrated in OVP&OCP products provider 1500W Transient Voltage Suppressor FIG.4: Pulse derating curve FIG.3: Pulse waveform IPPM (%IRSM ) 150 tr = rise time to peak value td = decay time to half value tr=10μs 100 P PP derating in percentage(%) 100 80 Peak value 60 Half value 40 50 20 td 0 0 1.0 t(ms) 2.0 3.0 4.0 0 0 25 T A (℃ ) 75 100 50 125 150 175 Soldering Parameters Reflow Condition Heat +150℃ -Temperature Max(Ts(max)) +200℃ TP -Time (Min to Max) (ts) 60-180 secs. TL Average ramp up rate (Liquid us Temp (TL) to peak) Ts(max) to TL - Ramp-up Rate Reflow FIG.5: Reflow condition -Temperature Min (Ts(min)) 3℃/sec. Max 3℃/sec. Max -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Rev.A_Feb,2018 tp Critical Zone TL to TP Ramp-up tL TS(max) -5- Temperature Pre Pb-Free assembly (see FIG.5) Ramp-down Preheat TS(min) 25 ts time to peak temperatue (t 25℃ to peak) Time www.wpmtek.com SMCJ Series Integrated in OVP&OCP products provider 1500W Transient Voltage Suppressor Package Mechanical Data Tape & Reel Specification - SMC Ref. Dimensions (mm) A 6.27±0.20 B 8.30±0.20 d φ1.50±0.10 D φ330.00±2.00 D2 φ13.50±0.20 E 1.75±0.10 F 7.50±0.10 P 8.00±0.10 P0 4.00±0.10 P1 2.00±0.10 W 16.00±0.20 W1 20.00±2.0 Contact Information WPMTEK Incorporated Limited Floor 1 Building 4#, Binxianghua Industry Park, No.7, Huada Road, Hualian Community, Longhua New District, Shenzhen TEL:86755-29308003 FAX:86755-23739900 wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.A_Feb,2018 -6- www.wpmtek.com
SMCJ24CA 价格&库存
很抱歉,暂时无法提供与“SMCJ24CA”相匹配的价格&库存,您可以联系我们找货
SMCJ24CA
  • 5+0.93312
  • 50+0.74132
  • 150+0.64541
  • 500+0.57348
库存:532
