SMAJ58CA
SMAJ58CA
    WPMTEK(维攀微)
    SMA
    SMA SMT 58V 93.6V
SMAJ58CA 数据手册
SMAJ Series Integrated in OVP&OCP products provider 400W Transient Voltage Suppressor Description Mechanical Characteristics TVS diodes can be used in a wide range of applications Package: SMA/DO-214AC which like consumer electronic products, automotive  Case Material: “Green” Molding Compound. industries,  UL Flammability Classification Rating 94V-0  Polarity: Color band denotes cathode except munitions, telecommunications, aerospace industries, and intelligent control systems. bi-directional models Features  Standard Packaging: 12mm tape (EIA STD RS-481)  Glass passivated or planar junction  Excellent clamping capability  Repetition rate (duty cycle): 0.01%  Low profile package and low inductance  400W Peak Pulse power capability at 10×1000μs  Weight: 0.07g  Terminal Connections: See Diagram Below  Marking Information: See Below Applications waveform. Fast response time: typically less than 1.0ps from 0V  I/O Interface. to VBR min.  AC/DC Power supply  High temperature soldering: 260℃/10s at terminals.  Low frequency signal transmission line  Plastic  package has Underwriters (RS232, RS485, etc.) Laboratory Flammability 94V-0.  For surface mounted applications in order to optimize Marking Information board space. Dimensions & Symbol(Unit: mm Max) Ordering Information Out line Taping Rev.B_Aug,2018 -1- Reel Per carton Reel diameters (pcs) (pcs) (mm) 5K 80K 330 www.wpmtek.com SMAJ Series Integrated in OVP&OCP products provider 400W Transient Voltage Suppressor Electrical Characteristics (TA=25℃) Part Number Marking VR I R@ VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar Uni Bi V μA min(V) max(V) mA max(V) A SMAJ5.0A SMAJ5.0CA HE TE 5.0 100 6.40 7.00 10 9.2 43.5 SMAJ6.0A SMAJ6.0CA HG TG 6.0 100 6.67 7.37 10 10.3 38.8 SMAJ6.5A SMAJ6.5CA HK TK 6.5 50 7.22 7.98 10 11.2 35.7 SMAJ7.0A SMAJ7.0CA HM TM 7.0 50 7.78 8.60 10 12.0 33.3 SMAJ7.5A SMAJ7.5CA HP TP 7.5 50 8.33 9.21 1 12.9 31.0 SMAJ8.0A SMAJ8.0CA HR TR 8.0 20 8.89 9.83 1 13.6 29.4 SMAJ8.5A SMAJ8.5CA HT TT 8.5 10 9.44 10.40 1 14.4 27.8 SMAJ9.0A SMAJ9.0CA HV TV 9.0 5 10.00 11.10 1 15.4 26.0 SMAJ10A SMAJ10CA HX TX 10.0 2 11.10 12.30 1 17.0 23.5 SMAJ11A SMAJ11CA HZ TZ 11.0 1 12.20 13.50 1 18.2 22.0 SMAJ12A SMAJ12CA IE UE 12.0 1 13.30 14.70 1 19.9 20.1 SMAJ13A SMAJ13CA IG UG 13.0 1 14.40 15.90 1 21.5 18.6 SMAJ14A SMAJ14CA IK UK 14.0 1 15.60 17.20 1 23.2 17.3 SMAJ15A SMAJ15CA IM UM 15.0 1 16.70 18.50 1 24.4 16.4 SMAJ16A SMAJ16CA IP UP 16.0 1 17.80 19.70 1 26.0 15.4 SMAJ17A SMAJ17CA IR UR 17.0 1 18.90 20.90 1 27.6 14.5 SMAJ18A SMAJ18CA IT UT 18.0 1 20.00 22.10 1 29.2 13.7 SMAJ20A SMAJ20CA IV UV 20.0 1 22.20 24.50 1 32.4 12.4 SMAJ22A SMAJ22CA IX UX 22.0 1 24.40 26.90 1 35.5 11.3 SMAJ24A SMAJ24CA IZ UZ 24.0 1 26.70 29.50 1 38.9 10.3 SMAJ26A SMAJ26CA JE VE 26.0 1 28.90 31.90 1 42.1 9.5 SMAJ28A SMAJ28CA JG VG 28.0 1 31.10 34.40 1 45.4 8.8 SMAJ30A SMAJ30CA JK VK 30.0 1 33.30 36.80 1 48.4 8.3 SMAJ33A SMAJ33CA JM VM 33.0 1 36.70 40.60 1 53.3 7.5 SMAJ36A SMAJ36CA JP VP 36.0 1 40.00 44.20 1 58.1 6.9 SMAJ40A SMAJ40CA JR VR 40.0 1 44.40 49.10 1 64.5 6.2 SMAJ43A SMAJ43CA JT VT 43.0 1 47.80 52.80 1 69.4 5.8 SMAJ45A SMAJ45CA JV VV 45.0 1 50.00 55.30 1 72.7 5.5 SMAJ48A SMAJ48CA JX VX 48.0 1 53.30 58.90 1 77.4 5.2 Rev.B_Aug,2018 -2- www.wpmtek.com SMAJ Series Integrated in OVP&OCP products provider 400W Transient Voltage Suppressor Electrical Characteristics (TA=25℃, continued) Part Number Marking VR I R@ VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar Uni Bi V μA min(V) max(V) mA max(V) A SMAJ51A SMAJ51CA JZ VZ 51.0 1 56.70 62.70 1 82.4 4.9 SMAJ54A SMAJ54CA RE WE 54.0 1 60.00 66.30 1 87.1 4.6 SMAJ58A SMAJ58CA RG WG 58.0 1 64.40 71.20 1 93.6 4.3 SMAJ60A SMAJ60CA RK WK 60.0 1 66.70 73.70 1 96.8 4.1 SMAJ64A SMAJ64CA RM WM 64.0 1 71.10 78.60 1 103.0 3.9 SMAJ70A SMAJ70CA RP WP 70.0 1 77.80 86.00 1 113.0 3.6 SMAJ75A SMAJ75CA RR WR 75.0 1 83.30 92.10 1 121.0 3.3 SMAJ78A SMAJ78CA RT WT 78.0 1 86.70 95.80 1 126.0 3.2 SMAJ85A SMAJ85CA RV WV 85.0 1 94.40 104.0 1 137.0 2.9 SMAJ90A SMAJ90CA RX WX 90.0 1 100.0 111.0 1 146.0 2.8 SMAJ100A SMAJ100CA RZ WZ 100.0 1 111.0 123.0 1 162.0 2.5 SMAJ110A SMAJ110CA SE XE 110.0 1 122.0 135.0 1 177.0 2.3 SMAJ120A SMAJ120CA SG XG 120.0 1 133.0 147.0 1 193.0 2.1 SMAJ130A SMAJ130CA SK XK 130.0 1 144.0 159.0 1 209.0 1.9 SMAJ150A SMAJ150CA SM XM 150.0 1 167.0 185.0 1 243.0 1.7 SMAJ160A SMAJ160CA SP XP 160.0 1 178.0 197.0 1 259.0 1.6 SMAJ170A SMAJ170CA SR XR 170.0 1 189.0 209.0 1 275.0 1.5 SMAJ180A SMAJ180CA ST XT 180.0 1 201.0 222.0 1 292.0 1.4 SMAJ200A SMAJ200CA SX XX 200.0 1 224.0 247.0 1 324.0 1.3 SMAJ220A SMAJ220CA ZE YE 220.0 1 246.0 272.0 1 356.0 1.1 SMAJ250A SMAJ250CA ZG YG 250.0 1 279.0 309.0 1 405.0 1.0 SMAJ300A SMAJ300CA ZK YK 300.0 1 335.0 371.0 1 486.0 0.8 SMAJ350A SMAJ350CA ZM YM 350.0 1 391.0 432.0 1 567.0 0.7 SMAJ400A SMAJ400CA ZP YP 400.0 1 447.0 494.0 1 648.0 0.6 SMAJ440A SMAJ440CA ZR YR 440.0 1 492.0 543.0 1 713.0 0.6 ① Surge waveform: 10/1000μs VR :Stand-off Voltage -- Maximum voltage that can be applied VBR: Breakdown Voltage VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp IR: Reverse Leakage Current Rev.B_Aug,2018 -3- www.wpmtek.com SMAJ Series Integrated in OVP&OCP products provider 400W Transient Voltage Suppressor Part Number Code Absolute Maximum Ratings (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Storage temperature range Operating junction temperature range Steady state power dissipation at TL=75℃ Peak pulse power dissipation on 10/1000μs waveform Maximum Instantaneous Forward Voltage at 30A for Unidirectional Symbol Value Unit Tstg -55 to +150 ℃ Tj -55 to +150 ℃ PM(AV) 3.3 W PPP 400 W VF 5.0 V Ratings And V-I Characteristics Curves (TA=25ºC, unless otherwise noted) FIG.1:V- I curve characteristics (Uni-directional) FIG.2:V- I curve characteristics (Bi-directional) IPP V C V BR V R VF V V C V BR V R IR IT V V R V BR V C IPP IPP Rev.B_Aug,2018 IT IR -4- www.wpmtek.com SMAJ Series Integrated in OVP&OCP products provider 400W Transient Voltage Suppressor FIG.4: Pulse derating curve FIG.3: Pulse waveform IPPM (%IRSM ) 150 tr = rise time to peak value td = decay time to half value tr=10μs 100 P PP derating in percentage(%) 100 80 Peak value 60 Half value 40 50 20 td 0 0 1.0 t(ms) 2.0 3.0 4.0 0 0 25 T A (℃ ) 75 100 50 125 150 175 Soldering Parameters Reflow Condition Heat +150℃ -Temperature Max(Ts(max)) +200℃ TP -Time (Min to Max) (ts) 60-180 secs. TL Average ramp up rate (Liquid us Temp (TL) to peak) Ts(max) to TL - Ramp-up Rate Reflow FIG.5: Reflow condition -Temperature Min (Ts(min)) 3℃/sec. Max 3℃/sec. Max -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Rev.B_Aug,2018 tp Critical Zone TL to TP Ramp-up tL TS(max) -5- Temperature Pre Pb-Free assembly (see FIG.5) Ramp-down Preheat TS(min) 25 ts time to peak temperatue (t 25℃ to peak) Time www.wpmtek.com SMAJ Series Integrated in OVP&OCP products provider 400W Transient Voltage Suppressor Package Mechanical Data A Dimensions B Ref. Millimeters Inches Min. Max. Min. Max. A 4.25 4.65 0.167 0.183 B 2.50 2.90 0.098 0.114 C 1.35 1.65 0.053 0.065 D 0.76 1.52 0.030 0.060 E E 4.93 5.28 0.194 0.208 F 0.051 0.203 0.002 0.008 J K G 0.15 0.31 0.006 0.012 H 1.98 2.41 0.078 0.095 J 6.50 H F G L D 2.30 K DO-214AC (SMA) 0.256 1.70 L 0.090 0.067 Tape & Reel Specification - SMA Ref. Dimensions Millimeters Inches A 2.79 ± 0.3 0.110 ± 0.012 B 5.33 ± 0.3 0.210 ± 0.012 d 1.5 ± 0.1 0.059 ± 0.004 D 330.0 13.0 D2 13 ± 1 0.512 ± 0.039 E 1.5 ± 0.2 0.059 ± 0.008 F 5.65 ± 0.2 0.222 ± 0.008 P 4.0 ± 0.2 0.157 ± 0.008 P0 4.0 ± 0.2 0.157 ± 0.008 P1 2.0 ± 0.2 0.079 ± 0.008 W 12.0 ± 0.2 0.472 ± 0.008 W1 16.8 ± 2.0 0.661 ± 0.079 Rev.B_Aug,2018 -6- www.wpmtek.com SMAJ Series Integrated in OVP&OCP products provider 400W Transient Voltage Suppressor Contact Information WPMTEK Incorporated Limited Floor 1 Building 4#, Binxianghua Industry Park, No.7, Huada Road, Hualian Community, Longhua New District, Shenzhen TEL:86755-29308003 FAX:86755-23739900 wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.B_Aug,2018 -7- www.wpmtek.com
SMAJ58CA 价格&库存
很抱歉,暂时无法提供与“SMAJ58CA”相匹配的价格&库存,您可以联系我们找货
