SMAJ Series
Integrated in
OVP&OCP products
provider
400W Transient Voltage Suppressor
Description
Mechanical Characteristics
TVS diodes can be used in a wide range of applications
Package: SMA/DO-214AC
which like consumer electronic products, automotive
Case Material: “Green” Molding Compound.
industries,
UL Flammability Classification Rating 94V-0
Polarity: Color band denotes cathode except
munitions,
telecommunications,
aerospace
industries, and intelligent control systems.
bi-directional models
Features
Standard Packaging: 12mm tape (EIA STD
RS-481)
Glass passivated or planar junction
Excellent clamping capability
Repetition rate (duty cycle): 0.01%
Low profile package and low inductance
400W Peak Pulse power capability at 10×1000μs
Weight: 0.07g
Terminal Connections: See Diagram Below
Marking Information: See Below
Applications
waveform.
Fast response time: typically less than 1.0ps from 0V
I/O Interface.
to VBR min.
AC/DC Power supply
High temperature soldering: 260℃/10s at terminals.
Low frequency signal transmission line
Plastic
package
has
Underwriters
(RS232, RS485, etc.)
Laboratory
Flammability 94V-0.
For surface mounted applications in order to optimize
Marking Information
board space.
Dimensions & Symbol(Unit: mm Max)
Ordering Information
Out line
Taping
Rev.B_Aug,2018
-1-
Reel
Per carton
Reel diameters
(pcs)
(pcs)
(mm)
5K
80K
330
www.wpmtek.com
SMAJ Series
Integrated in
OVP&OCP products
provider
Electrical Characteristics (TA=25℃)
Part Number
Marking
VR
I R@
VR
VBR@IT
IT
VC@IPP
IPP①
Uni-Polar
Bi-Polar
Uni
Bi
V
μA
min(V)
max(V)
mA
max(V)
A
SMAJ5.0A
SMAJ5.0CA
HE
TE
5.0
100
6.40
7.00
10
9.2
43.5
SMAJ6.0A
SMAJ6.0CA
HG
TG
6.0
100
6.67
7.37
10
10.3
38.8
SMAJ6.5A
SMAJ6.5CA
HK
TK
6.5
50
7.22
7.98
10
11.2
35.7
SMAJ7.0A
SMAJ7.0CA
HM
TM
7.0
50
7.78
8.60
10
12.0
33.3
SMAJ7.5A
SMAJ7.5CA
HP
TP
7.5
50
8.33
9.21
1
12.9
31.0
SMAJ8.0A
SMAJ8.0CA
HR
TR
8.0
9.83
1
13.6
29.4
SMAJ8.5A
SMAJ8.5CA
HT
TT
8.5
10
9.44
10.40
1
14.4
27.8
SMAJ9.0A
SMAJ9.0CA
HV
TV
9.0
5
10.00
11.10
1
15.4
26.0
SMAJ10A
SMAJ10CA
HX
TX
10.0
2
11.10
12.30
1
17.0
23.5
SMAJ11A
SMAJ11CA
HZ
TZ
11.0
1
12.20
13.50
1
18.2
22.0
SMAJ12A
SMAJ12CA
IE
UE
12.0
1
13.30
14.70
1
19.9
20.1
SMAJ13A
SMAJ13CA
IG
UG
13.0
1
14.40
15.90
1
21.5
18.6
SMAJ14A
SMAJ14CA
IK
UK
14.0
1
15.60
17.20
1
23.2
17.3
SMAJ15A
SMAJ15CA
IM
UM
15.0
1
16.70
18.50
1
24.4
16.4
SMAJ16A
SMAJ16CA
IP
UP
16.0
1
17.80
19.70
1
26.0
15.4
SMAJ17A
SMAJ17CA
IR
UR
17.0
1
18.90
20.90
1
27.6
14.5
SMAJ18A
SMAJ18CA
IT
UT
18.0
1
20.00
22.10
1
29.2
13.7
SMAJ20A
SMAJ20CA
IV
UV
20.0
1
22.20
24.50
1
32.4
12.4
SMAJ22A
SMAJ22CA
IX
UX
22.0
1
24.40
26.90
1
35.5
11.3
SMAJ24A
SMAJ24CA
IZ
UZ
24.0
1
26.70
29.50
1
38.9
10.3
SMAJ26A
SMAJ26CA
JE
VE
26.0
1
28.90
31.90
1
42.1
9.5
SMAJ28A
SMAJ28CA
JG
VG
28.0
1
31.10
34.40
1
45.4
8.8
SMAJ30A
SMAJ30CA
JK
VK
30.0
1
33.30
36.80
1
48.4
8.3
SMAJ33A
SMAJ33CA
JM
VM
33.0
1
36.70
40.60
1
53.3
7.5
SMAJ36A
SMAJ36CA
JP
VP
36.0
1
40.00
44.20
1
58.1
6.9
SMAJ40A
SMAJ40CA
JR
VR
40.0
1
44.40
49.10
1
64.5
6.2
SMAJ43A
SMAJ43CA
JT
VT
43.0
1
47.80
52.80
1
69.4
5.8
SMAJ45A
SMAJ45CA
JV
VV
45.0
1
50.00
55.30
1
72.7
5.5
SMAJ48A
SMAJ48CA
JX
VX
48.0
1
53.30
58.90
1
77.4
5.2
Rev.B_Aug,2018
-2-
www.wpmtek.com
SMAJ Series
Integrated in
OVP&OCP products
provider
Electrical Characteristics (TA=25℃, continued)
Part Number
Marking
VR
I R@
VR
VBR@IT
IT
VC@IPP
IPP①
Uni-Polar
Bi-Polar
Uni
Bi
V
μA
min(V)
max(V)
mA
max(V)
A
SMAJ51A
SMAJ51CA
JZ
VZ
51.0
1
56.70
62.70
1
82.4
4.9
SMAJ54A
SMAJ54CA
RE
WE
54.0
1
60.00
66.30
1
87.1
4.6
SMAJ58A
SMAJ58CA
RG
WG
58.0
1
64.40
71.20
1
93.6
4.3
SMAJ60A
SMAJ60CA
RK
WK
60.0
1
66.70
73.70
1
96.8
4.1
SMAJ64A
SMAJ64CA
RM
WM
64.0
1
71.10
78.60
1
103.0
3.9
SMAJ70A
SMAJ70CA
RP
WP
70.0
1
77.80
86.00
1
113.0
3.6
SMAJ75A
SMAJ75CA
RR
WR
75.0
1
83.30
92.10
1
121.0
3.3
SMAJ78A
SMAJ78CA
RT
WT
78.0
1
86.70
95.80
1
126.0
3.2
SMAJ85A
SMAJ85CA
RV
WV
85.0
1
94.40
104.0
1
137.0
2.9
SMAJ90A
SMAJ90CA
RX
WX
90.0
1
100.0
111.0
1
146.0
2.8
SMAJ100A
SMAJ100CA
RZ
WZ
100.0
1
111.0
123.0
1
162.0
2.5
SMAJ110A
SMAJ110CA
SE
XE
110.0
1
122.0
135.0
1
177.0
2.3
SMAJ120A
SMAJ120CA
SG
XG
120.0
1
133.0
147.0
1
193.0
2.1
SMAJ130A
SMAJ130CA
SK
XK
130.0
1
144.0
159.0
1
209.0
1.9
SMAJ150A
SMAJ150CA
SM
XM
150.0
1
167.0
185.0
1
243.0
1.7
SMAJ160A
SMAJ160CA
SP
XP
160.0
1
178.0
197.0
1
259.0
1.6
SMAJ170A
SMAJ170CA
SR
XR
170.0
1
189.0
209.0
1
275.0
1.5
SMAJ180A
SMAJ180CA
ST
XT
180.0
1
201.0
222.0
1
292.0
1.4
SMAJ200A
SMAJ200CA
SX
XX
200.0
1
224.0
247.0
1
324.0
1.3
SMAJ220A
SMAJ220CA
ZE
YE
220.0
1
246.0
272.0
1
356.0
1.1
SMAJ250A
SMAJ250CA
ZG
YG
250.0
1
279.0
309.0
1
405.0
1.0
SMAJ300A
SMAJ300CA
ZK
YK
300.0
1
335.0
371.0
1
486.0
0.8
SMAJ350A
SMAJ350CA
ZM
YM
350.0
1
391.0
432.0
1
567.0
0.7
SMAJ400A
SMAJ400CA
ZP
YP
400.0
1
447.0
494.0
1
648.0
0.6
SMAJ440A
SMAJ440CA
ZR
YR
440.0
1
492.0
543.0
1
713.0
0.6
① Surge waveform: 10/1000μs
VR :Stand-off Voltage -- Maximum voltage that can be applied
VBR: Breakdown Voltage
VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp
IR: Reverse Leakage Current
Rev.B_Aug,2018
-3-
www.wpmtek.com
SMAJ Series
Integrated in
OVP&OCP products
provider
Part Number Code
Absolute Maximum Ratings (TA=25ºC, RH=45%-75%, unless otherwise noted)
Parameter
Storage temperature range
Operating junction temperature range
Steady state power dissipation at TL=75℃
Peak pulse power dissipation on 10/1000μs
waveform
Maximum Instantaneous Forward Voltage at
30A for Unidirectional
Symbol
Value
Unit
Tstg
-55 to +150
Tj
-55 to +150
PM(AV)
3.3
W
PPP
400
W
VF
5.0
V
Ratings And V-I Characteristics Curves (TA=25ºC, unless otherwise noted)
FIG.1:V- I curve characteristics
(Uni-directional)
FIG.2:V- I curve characteristics
(Bi-directional)
IPP
V C V BR V R
VF
V
V C V BR V R
IR
IT
V
V R V BR V C
IPP
IPP
Rev.B_Aug,2018
IT
IR
-4-
www.wpmtek.com
SMAJ Series
Integrated in
OVP&OCP products
provider
FIG.4: Pulse derating curve
FIG.3: Pulse waveform
IPPM (%IRSM )
150
tr = rise time to peak value
td = decay time to half value
tr=10μs
100
P PP derating in percentage(%)
100
80
Peak value
60
Half value
40
50
td
t(ms)
2.0
3.0
4.0
T A (℃ )
75
100
50
125
150
175
Soldering Parameters
Reflow Condition
Heat
+150℃
-Temperature Max(Ts(max))
+200℃
TP
-Time (Min to Max) (ts)
60-180 secs.
TL
Average ramp up rate (Liquid us Temp
(TL) to peak)
Ts(max) to TL - Ramp-up Rate
Reflow
FIG.5: Reflow condition
-Temperature Min (Ts(min))
3℃/sec. Max
3℃/sec. Max
-Temperature(TL)(Liquid us)
+217℃
-Temperature(tL)
60-150 secs.
Peak Temp (Tp)
+260(+0/-5)℃
Time within 5℃ of actual Peak Temp (tp)
30 secs. Max
Ramp-down Rate
6℃/sec. Max
Time 25℃ to Peak Temp (TP)
8 min. Max
Do not exceed
+260℃
Rev.B_Aug,2018
tp
Critical Zone
TL to TP
Ramp-up
tL
TS(max)
-5-
Temperature
Pre
Pb-Free assembly
(see FIG.5)
Ramp-down
Preheat
TS(min)
25
ts
time to peak temperatue
(t 25℃ to peak)
Time
www.wpmtek.com
SMAJ Series
Integrated in
OVP&OCP products
provider
Package Mechanical Data
A
Dimensions
B
Ref.
Millimeters
Inches
Min.
Max.
Min.
Max.
A
4.25
4.65
0.167
0.183
B
2.50
2.90
0.098
0.114
C
1.35
1.65
0.053
0.065
D
0.76
1.52
0.030
0.060
E
E
4.93
5.28
0.194
0.208
F
0.051
0.203
0.002
0.008
J
K
G
0.15
0.31
0.006
0.012
H
1.98
2.41
0.078
0.095
J
6.50
H
F
G
L
D
2.30
K
DO-214AC (SMA)
0.256
1.70
L
0.090
0.067
Tape & Reel Specification - SMA
Ref.
Dimensions
Millimeters
Inches
A
2.79 ± 0.3
0.110 ± 0.012
B
5.33 ± 0.3
0.210 ± 0.012
d
1.5 ± 0.1
0.059 ± 0.004
D
330.0
13.0
D2
13 ± 1
0.512 ± 0.039
E
1.5 ± 0.2
0.059 ± 0.008
F
5.65 ± 0.2
0.222 ± 0.008
P
4.0 ± 0.2
0.157 ± 0.008
P0
4.0 ± 0.2
0.157 ± 0.008
P1
2.0 ± 0.2
0.079 ± 0.008
W
12.0 ± 0.2
0.472 ± 0.008
W1
16.8 ± 2.0
0.661 ± 0.079
Rev.B_Aug,2018
-6-
www.wpmtek.com
SMAJ Series
Integrated in
OVP&OCP products
provider
Contact Information
WPMTEK Incorporated Limited
Floor 1 Building 4#, Binxianghua Industry Park, No.7,
Huada Road, Hualian Community, Longhua New District, Shenzhen
TEL:86755-29308003
FAX:86755-23739900
wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM
makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability
arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special,
consequential or incidental damages.
Rev.B_Aug,2018
-7-
www.wpmtek.com
很抱歉,暂时无法提供与“SMAJ16CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.31169
- 100+0.25208
- 300+0.22227
- 1000+0.19991
- 5000+0.14937
- 10000+0.14040
