P0300SC
P0300SC
    WPMTEK(维攀微)
    SMB(DO-214AA)
    SMB SMT 25V 2.2A
P0300SC 数据手册
Integrated in OVP&OCP products provider PXXXXSC Series Thyristors Surge Protection Device(SMB 6KV) Description Mechanical Characteristics PXXXXSC series thyristors are a type of semi-conduct component. They are designed in modems, telephones, line cards, answering machines, FAX machines, SLICs, T1/E1, xDSL, PBXs and more applications. n Package: SMB/DO-214AA n Case Material: “Green” Molding Compound. n UL Flammability Classification Rating 94V-0 n Standard Packaging: 12mm tape (EIA STD RS-481) Features n Weight: 0.10g n Surface mount package to optimize board space n Terminal Connections: See Diagram Below n Low profile package n Marking Information: See Below n Bidirectional crowbar protection n Low leakage current : I = 5uA max n Low on-state voltage n Low Capacitance n n Applications Standards n TIA-968-A/B Solid-state silicon technology n ITU K.20/21 Enhanced Level* Eliminates overvoltage caused by fast rising transients n ITU K.20/21 Basic Level* n GR 1089 Inter-building* n GR 1089 Intra-building n IEC 61000-4-5 2nd edition n YD/T 1082 Dimensions & Symbol(Unit: mm Max) YD/T 993 YD/T 950 2 Marking Information 1 Ordering Information Rev.B_Oct,2019 -1- Out line Reel (pcs) Per carton (pcs) Reel diameters (mm) Taping 3K 48K 330 www.wpmtek.com Integrated in OVP&OCP products provider PXXXXSC Series Thyristors Surge Protection Device(SMB 6KV) Absolute Maximum Ratings (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Symbol Value Unit Tstg -60 to +150 ℃ Operating junction temperature range Tj -40 to +150 ℃ Repetitive peak pulse current IPP 150 A Storage temperature range Electrical Characteristics Curve (TA=25℃) Symbol Parameter VDRM Peak off-state voltage IDRM Off-state current VS Switching voltage IS Switching current VT On-state voltage IT On-state current IH Holding current CO Off-state capacitance Surge Ratings IPP (A) min Series 2×10us 8×20us 10×360us 10×1000us 500 400 175 100 C Part Number Code Series code: P indicator P XXXX S C Surge:10/700uS 6KV VDRM Package Type SMB Rev.B_Oct,2019 -2- www.wpmtek.com Integrated in OVP&OCP products provider PXXXXSC Series Thyristors Surge Protection Device(SMB 6KV) Electrical Characteristics (TA=25℃,) IDRM@VDRM Part Number VS①@IS VT@ IT IH CO ② μA V V mA V A mA pF max min max max max max min max P0080SC 5 6 20 800 4 2.2 25 80 P0220SC 5 15 28 800 4 2.2 35 80 P0300SC 5 25 40 800 4 2.2 50 80 P0640SC 5 58 77 800 4 2.2 120 65 P0720SC 5 65 88 800 4 2.2 120 65 P0900SC 5 75 98 800 4 2.2 120 65 P1100SC 5 90 130 800 4 2.2 120 65 P1300SC 5 120 160 800 4 2.2 120 65 P1500SC 5 140 180 800 4 2.2 120 65 P1800SC 5 170 220 800 4 2.2 120 60 P2000SC 5 180 220 800 4 2.2 120 60 P2300SC 5 190 260 800 4 2.2 120 60 P2600SC 5 220 300 800 4 2.2 120 55 P3100SC 5 275 350 800 4 2.2 120 70 P3500SC 5 320 400 800 4 2.2 120 50 P3800SC 5 360 460 800 4 2.2 120 50 P4200SC 5 400 540 800 4 2.2 120 45 ① Vs is measured at 100KV/s ② Off-state capacitance is measured in VDC=2V, VRMS=1V, f=1MHz Rev.B_Oct,2019 -3- www.wpmtek.com Integrated in OVP&OCP products provider PXXXXSC Series Thyristors Surge Protection Device(SMB 6KV) Soldering Parameters Pre Heat Reflow Condition Pb-Free assembly -Temperature Min (Ts(min)) +150℃ -Temperature Max (Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow -Temperature (TL) (Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed Rev.B_Oct,2019 +260℃ -4- www.wpmtek.com Integrated in OVP&OCP products provider PXXXXSC Series Thyristors Surge Protection Device(SMB 6KV) Package Mechanical Data Tape & Reel Specification - SMB Contact Information WPMTEK Incorporated Limited Room 207,2nd Floor, Block 3,Minxing lndustry Park, Minzhi, Longhua New District, Shenzhen, PRC. TEL:86755-29308003 FAX:86755-23739900 Wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.B_Oct,2019 -5- www.wpmtek.com
P0300SC 价格&库存
很抱歉,暂时无法提供与“P0300SC”相匹配的价格&库存,您可以联系我们找货
