P0080TB-LC
P0080TB-LC
    WPMTEK(维攀微)
    SMA
    晶闸管浪涌保护装置SMA VDRM=6V VT=4V IT=2.2A
P0080TB-LC 数据手册
P0080TB-LC Integrated in OVP&OCP products provider Thyristors Surge Protection Device(SMA 4K) Description Mechanical Characteristics P0080TB-LC thyristors are a type of semi-conduct Package: SMA/DO-214AC component. They are designed in applications, modems, telephones, line cards, answering machines, FAX machines, SLICs, T1/E1, xDSL, PBXs and more. This series can be used to provide protection in accordance with industry standards such as FCC Part 68, IEC 61000-4 and IEC 61000-4-5 requirements Features Cannot be damaged by voltage  Eliminate hysteresis and heat dissipation typically  Case Material: “Green” Molding Compound.  Lead Finish: Matte Tin  UL Flammability Classification Rating 94V-0  Standard Packaging: 12mm tape (EIA STD RS-481) ANSI C62.41, UL 1459, GR-1089-CORE, IEC 61000-2,    Weight: 0.07g  Terminal Connections: See Diagram Below  Marking Information: See Below Applications found with clamping devices  SLIC Line Card Eliminate voltage overshoot caused by fast-rising  T1/E1 Trunk & Line Card  DBX Branch Exchange Switches transients  Are non-degenerative  Will not fatigue  FCC Part 68 Customer Premise Equipment  Meets MSL level 1, per J-STD-020  Line Interface Modem  xDSL Architecture Interface Dimensions & Symbol(Unit: mm Max) Marking Information Marking Code Details marking code reference customer approval list Ordering Information Out line Taping Rev.A_Aug,2016 -1- Reel Per carton Reel diameters (pcs) (pcs) (mm) 5K 80K 330 www.wpmtek.com P0080TB-LC Integrated in OVP&OCP products provider Thyristors Surge Protection Device(SMA 4K) Absolute Maximum Ratings (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Symbol Value Unit Tstg -60 to +150 ℃ Operating junction temperature range Tj -40 to +150 ℃ Repetitive peak pulse current IPP 100 A Storage temperature range Electrical Characteristics (TA=25℃) Part Number P0080TB-LC VRM Min. V 6 IRM Max. uA 5 VBO V 25 Max. IBO VT mA 800 V 4 Max. IT A 2.2 Typ Max. pF 15 IH Typ. mA 10 Electrical Parameters & V-I Curve Symbol Parameter VDRM Peak off-state voltage IDRM Off-state current VS Switching voltage IS Switching current VT On-state voltage IT On-state current IH Holding current CO Off-state capacitance Surge Ratings Series B Rev.A_Aug,2016 IPP (A) min 2×10us 8×20us 10×320us 10×1000us 250 250 100 80 -2- www.wpmtek.com P0080TB-LC Integrated in OVP&OCP products provider Thyristors Surge Protection Device(SMA 4K) Ratings And V-I Characteristics Curves (TA=25ºC, unless otherwise noted) Reflow Condition Pre Heat Pb-Free assembly (see FIG.2) -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow -Temperature(TL) (Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ FIG.1: tr × td pulse waveform FIG.2: Reflow condition %IPP tp tr = rise time to peak value td = decay time to half value 100 TP Critical Zone T L to T P Ramp-up Peak value TL tL Temperature T S(max) Half value 50 t(μs) 0 0 tr T S(min) ts 25 td FIG.3: Normalized Vs change vs. junction temperature Percent of Vs change(%) time to peak temperatue (t 25℃ to peak) Time FIG.4: Normalized DC holding current vs. case temperature 2.0 12 IH(Tj )/IH(Tj =25℃) 1.8 1.6 8 1.4 4 1.2 25℃ 25℃ 1.0 0 0.8 -4 -8 -40 -20 Ramp-down Preheat 0 20 Rev.A_Aug,2016 Tj (℃) 40 60 80 0.6 100 120 140 160 0.4 -40 -20 -3- 0 20 40 TC (℃) 60 80 100 120 140 160 www.wpmtek.com P0080TB-LC Integrated in OVP&OCP products provider Thyristors Surge Protection Device(SMA 4K) Package Mechanical Data DIM A B C D E F H Millimeters Min Max 3.90 4.40 2.45 2.76 1.45 1.95 0.15 0.20 0.76 1.52 0.85 5.25 1.90 2.40 Inches Min Max 0.154 0.173 0.096 0.109 0.057 0.077 0.006 0.008 0.030 0.060 0.194 0.210 0.075 0.094 Tape & Reel Specification - SMA-S Ref. Dimensions Millimeters Inches A 2.79 ± 0.3 0.110 ± 0.012 B 5.33 ± 0.3 0.210 ± 0.012 d 1.5 ± 0.1 0.059 ± 0.004 D 330.0 13.0 D2 13 ± 1 0.512 ± 0.039 E 1.5 ± 0.2 0.059 ± 0.008 F 5.65 ± 0.2 0.222 ± 0.008 P 4.0 ± 0.2 0.157 ± 0.008 P0 4.0 ± 0.2 0.157 ± 0.008 P1 2.0 ± 0.2 0.079 ± 0.008 W 12.0 ± 0.2 0.472 ± 0.008 W1 16.8 ± 2.0 0.661 ± 0.079 Contact Information WPMTEK Incorporated Limited Floor 1 Building 4#, Binxianghua Industry Park, No.7, Huada Road, Hualian Community, Longhua New District, Shenzhen TEL:86755-29308003 FAX:86755-23739900 wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.A_Aug,2016 -4- www.wpmtek.com
P0080TB-LC 价格&库存
很抱歉,暂时无法提供与“P0080TB-LC”相匹配的价格&库存,您可以联系我们找货
P0080TB-LC
  • 1+0.16500
  • 100+0.15400
  • 300+0.14300
  • 500+0.13200
  • 2000+0.12650
  • 5000+0.12320
