ESD5Z5CH
ESD5Z5CH
    WPMTEK(维攀微)
    SOD-523(SC-79)
    单线双向TVS二极管
ESD5Z5CH 数据手册
ESD5Z5CH Integrated in OVP&OCP products provider 1-Line Bi-directional TVS Diode Description Mechanical Characteristics The ESD5Z5CH is a bi-directional TVS diode, utilizing n Package: SOD-523 n Lead Finish: Matte Tin n Case Material: “Green” Molding Compound. data and power line. The ESD5Z5CH complies with the n UL Flammability Classification Rating 94V-0 IEC 61000-4-2 (ESD) with ±30 kV air and ±30 kV contact n Moisture Sensitivity: Level 3 per J-STD-020 discharge. It is assembled into an ultra-small SOD-523 n Terminal Connections: See Diagram Below lead-free package. The small size and high ESD surge n Marking Information: See Below leading monolithic silicon technology to provide fast response time and low ESD clamping voltage, making this device an ideal solution for protecting voltage sensitive protection make ESD5Z5CH an ideal choice to protect cell phone, digital cameras, audio players and many other Applications portable applications. Features n Cellular Handsets and Accessories n Personal Digital Assistants n Protects one data line n Notebooks and Handhelds n Ultra low leakage: nA level n Portable Instrumentation n Low operating voltage: 5V n Digital Cameras n Low clamping voltage n Peripherals n Complies with following standards: n Audio Players n Keypads, Side Keys, LCD Displays – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Marking information Contact discharge: ±30kV – IEC61000-4-5 (Lightning) 8A (8/20μs) n RoHS Compliant Symbol & Pin Configuration Details marking code reference customer approval list Ordering Information Part Number ESD5Z5CH Packaging 3000/Tape & Reel Reel Size 7 inch Circuit and Pin Schematic Rev.A_Aug,2017 -1- www.wpmtek.com ESD5Z5CH Integrated in OVP&OCP products provider 1-Line Bi-directional TVS Diode Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 80 W Peak Pulse Current (8/20µs) Ipp 8 A ESD per IEC 61000−4−2 (Air) ±30 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range kV ±30 TJ −55 to +125 °C Tstg −55 to +150 °C Electrical Characteristics (TA=25°C unless otherwise specified) Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR 6 Max Unit Test Condition 5 V 8 V IT = 1mA Reverse Leakage Current IR 0.2 uA VRWM = 5V Clamping Voltage VC 8 V IPP = 1A Clamping Voltage VC 10 V IPP = 8A Junction Capacitance CJ 20 pF VR = 0V, f = 1MHz Rev.A_Aug,2017 -2- www.wpmtek.com ESD5Z5CH Integrated in OVP&OCP products provider 1-Line Bi-directional TVS Diode Typical Performance Characteristics (TA=25°C unless otherwise Specified) Rev.A_Aug,2017 -3- www.wpmtek.com ESD5Z5CH Integrated in OVP&OCP products provider 1-Line Bi-directional TVS Diode Soldering Parameters Reflow Condition Pre Heat Pb-Free assembly -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow -Temperature(TL) (Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Rev.A_Aug,2017 -4- www.wpmtek.com ESD5Z5CH Integrated in OVP&OCP products provider 1-Line Bi-directional TVS Diode Package Mechanical Data Suggested Land Pattern (mm) Contact Information WPMTEK Incorporated Limited Room 207,2nd Floor,Block3, Minxing Industry Park,Minzhi, Long Hua New District,Shenzhen ,PRC TEL:86755-29308003 FAX:86755-23739900 Wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.A_Aug,2017 -5- www.wpmtek.com
ESD5Z5CH 价格&库存
很抱歉,暂时无法提供与“ESD5Z5CH”相匹配的价格&库存,您可以联系我们找货
ESD5Z5CH
    • 1+0.08100
    • 100+0.07560
    • 300+0.07020
    • 500+0.06480
    • 2000+0.06210
    • 5000+0.06048
