ESD5Z5C
Integrated in
OVP&OCP products
provider
Low Capacitance Bi-directional TVS Diode
Description
Mechanical Characteristics
The ESD5Z5C is designed to protect voltage sensitive
components from ESD and transient voltage events.
Package: SOD-523
Lead Finish: Matte Tin
Case Material: “Green” Molding Compound.
on designs where board space is at a premium. Because
UL Flammability Classification Rating 94V-0
of its small size, it is suited for use in cellular phones,
Moisture Sensitivity: Level 3 per J-STD-020
portable devices, digital cameras, power supplies and
Terminal Connections: See Diagram Below
many other portable applications where board space
Marking Information: See Below
Excellent clamping capability, low leakage, and fast
response time, make these parts ideal for ESD protection
comes at a premium. Also because of its low capacitance,
it is suited for use in high frequency designs such as USB
Applications
2.0 high speed, VGA, DVI, SDI and other high speed line
applications.
Features
Cellular Handsets and Accessories
Personal Digital Assistants
Notebooks and Handhelds
Protects one data line
Portable Instrumentation
Ultra low leakage: nA level
Digital Cameras
Low operating voltage: 5V
Peripherals
Low clamping voltage
Audio Players
Complies with following standards:
Keypads, Side Keys, LCD Displays
– IEC 61000-4-2 (ESD) immunity test
Marking information
Air discharge: ±30kV
Contact discharge: ±30kV
– IEC61000-4-4 (EFT) 40A (5/50ns)
RoHS Compliant
Dimensions & Symbol(Unit: mm Max)
Details marking code reference customer approval list
Ordering Information
Part Number
ESD5Z5C
SOD523(TOP Viev)
Package Dimensions
Rev.A_Jun,2019
Packaging
3000/Tape & Reel
Reel Size
7 inch
Circuit and Pin Schematic
-1-
www.wpmtek.com
ESD5Z5C
Integrated in
OVP&OCP products
provider
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
128
W
Peak Pulse Current (8/20µs)
Ipp
8
A
ESD per IEC 61000−4−2 (Air)
±30
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
kV
±30
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Typical
Maximum
Units
5
V
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Symbol
Conditions
VRWM
VBR
IT=1mA
Reverse Leakage Current
IR
VRWM=5V, T=25℃
Clamping Voltage
VC
IPP=5A, tp=8/20μs
Clamping Voltage
VC
Junction Capacitance
Cj
Rev.A_Jun,2019
Minimum
5.6
V
1
μA
9.5
11.6
V
IPP=8A, tp=8/20μs
14
16
V
VR =0V, f =1MHz
10
15
pF
-2-
www.wpmtek.com
ESD5Z5C
Integrated in
OVP&OCP products
provider
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
Rev.A_Jun,2019
-3-
www.wpmtek.com
ESD5Z5C
Integrated in
OVP&OCP products
provider
Soldering parameters
Pb-Free assembly
(see FIG.2)
Reflow Condition
Pre Heat
-Temperature Min (Ts(min))
+150℃
-Temperature Max(Ts(max))
+200℃
-Time (Min to Max) (ts)
60-180 secs.
Average ramp up rate (Liquid us Temp (TL) to peak)
3℃/sec. Max
Ts(max) to TL - Ramp-up Rate
3℃/sec. Max
Reflow
-Temperature(TL) (Liquid us)
+217℃
-Temperature(tL)
60-150 secs.
Peak Temp (Tp)
+260(+0/-5)℃
Time within 5℃ of actual Peak Temp (tp)
30 secs. Max
Ramp-down Rate
6℃/sec. Max
Time 25℃ to Peak Temp (TP)
8 min. Max
Do not exceed
+260℃
Rev.A_Jun,2019
-4-
www.wpmtek.com
ESD5Z5C
Integrated in
OVP&OCP products
provider
Package mechanical data
Suggested Land Pattern
Contact information
WPMTEK Incorporated Limited
Floor 1 Building 4#, Binxianghua Industry Park, No.7,
Huada Road, Hualian Community, Longhua New District, Shenzhen
TEL:86755-29308003
FAX:86755-23739900
wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM
makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability
arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special,
consequential or incidental damages.
Rev.A_Jun,2019
-5-
www.wpmtek.com
很抱歉,暂时无法提供与“ESD5Z5C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.12312
- 500+0.09569
- 3000+0.07571
- 6000+0.06653
- 24000+0.05854
- 51000+0.05433
