CLAMP0524P-LC
CLAMP0524P-LC
    WPMTEK(维攀微)
    DFN2510-10
    单向 反向断态电压 V(RWM):5V 反向漏电流 IR @V(RWM):0.2uA@5V 击穿电压 V(BR) @IT:6V 峰值脉冲电流(Ipp):4A 封装:DFN2510-10
CLAMP0524P-LC 数据手册
CLAMP0524P_LC Integrated in OVP&OCP products provider 4-Line Ultra Low Capacitance TVS Diode Array Description Pin Configuration The CLAMP0524P_LC is an ultra low capacitance TVS array,utilizing leading monolithic silicon technology to provide fast response time and low ESD clamping voltage, making this device an ideal solution for protecting voltage sensitive high-speed data lines. The CLAMP0524P_LC has an ultra-low capacitance with a typical value at 0.2pF, and complies with the IEC 61000-4-2 (ESD) standard with ±25kV air and ±20kV contact discharge. It is assembled into a 10-pin 2.5x1.0x0.5mm lead-free DFN package. The Mechanical Characteristics flow through style package allows for easy PCB layout and matched trace lengths necessary to maintain con- sistent impedance between high speed differential lines such as  Package: DFN2510-10 (2.5×1.0×0.5mm) USB 3.0 and HDMI. The small size, ultra-low capacitance  Lead Finish: Matte Tin  Case Material: “Green” Molding Compound.  Moisture Sensitivity: Level 3 per J-STD-020  Terminal Connections: See Diagram Below  Marking Information: See Below and high ESD surge protection make CLAMP0524P_LC an ideal choice to protect HDMI, MDDI, USB3.0 and other high speed ports. Features  Ultra low capacitance: 0.3pF typical (I/O to I/O)  Ultra low leakage: nA level  Low operating voltage: 5V  Low clamping voltage  HDMI 1.3 & 1.4, USB 2.0 & 3.0 and MDDI ports  Up to 4 lines protects  Monitors and flat panel displays  Leadless flow-through package  Set-top box and Digital TV  Complies with following standards:  Video graphics cards – IEC 61000-4-2 (ESD) immunity test  Digital Video Interface (DVI) Air discharge: ±25kV  Notebook Computers Contact discharge: ±20kV  PCI Express and Serial SATA Ports  IEC61000-4-5 (Lightning) 4A (8/20µs)  RoHS Compliant Applications Marking information Dot denotes Pin1 Ordering Information Part Number CLAMP0524P_LC Rev.A_Aug,2016 Packaging 3000/Tape & Reel Details marking code reference specification of approval Reel Size 7 inch -1- www.wpmtek.com CLAMP0524P_LC Integrated in OVP&OCP products provider 4-Line Ultra Low Capacitance TVS Diode Array Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 60 W Peak Pulse Current (8/20µs) IPP 4 A ESD per IEC 61000−4−2 (Air) ±25 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range ±20 kV TJ −55 to +125 °C Tstg −55 to +150 °C Electrical Characteristics (TA=25°C unless otherwise specified) Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR Max Unit 5 V Any I/O pin to ground V IT = 1mA, any I/O pin to ground 0.5 µA VRWM = 5V, any I/O pin to ground 6 Reverse Leakage Current IR Clamping Voltage VC 10 V Clamping Voltage VC 15 V Junction Capacitance CJ 0.2 0.3 pF Junction Capacitance CJ 0.4 0.5 pF Rev.A_Aug,2016 0.2 -2- Test Condition IPP = 1A (8 x 20µs pulse), any I/O pin to ground IPP = 4A (8 x 20µs pulse), any I/O pin to ground VR = 0V, f = 1MHz, between I/O pins VR = 0V, f = 1MHz, any I/O pin to ground www.wpmtek.com CLAMP0524P_LC Integrated in OVP&OCP products provider 4-Line Ultra Low Capacitance TVS Diode Array Typical Performance Characteristics (TA=25°C unless otherwise Specified) Insertion Loss S21 of I/O to GND Normalized Capacitance vs. Reverse Voltage 2.0 1.5 0.0 1.4 1.3 Normalized Capacitance Insertion Loss (dB) -2.0 -4.0 -6.0 -8.0 -10.0 1.2 1.1 1.0 0.9 0.8 0.7 -12.0 0.6 0.5 -14.0 1.0E+05 1.0E+06 1.0E+07 1.0E+08 0 1.0E+09 1 2 ESD Clamping (+8kV Contact per IEC 61000-4-2) 4 5 ESD Clamping (-8kV Contact per IEC 61000-4-2) 20.0 60.0 10.0 50.0 0.0 Clamping Voltage (V) 70.0 . . Clamping Voltage (V) 3 Reverse Voltage (V) Frequency (Hz) 40.0 30.0 20.0 10.0 -10.0 -20.0 -30.0 -40.0 0.0 -50.0 -10.0 -60.0 -70.0 -20.0 -50 0 50 100 150 -50 200 50 100 150 200 Time (ns) Time (ns) Rev.A_Aug,2016 0 -3- www.wpmtek.com CLAMP0524P_LC Integrated in OVP&OCP products provider 4-Line Ultra Low Capacitance TVS Diode Array Typical Application The CLAMP0524P_LC is designed for easy PCB layout by allowing the traces to run straight through the device. ThePCB traces could be used to connect the pin pairs for each line. For example, line 1 enters at pin 1 and exits at pin 10 and the PCB trace connects Pin 1 and Pin 10 together. Ground is connected at Pin 3 and Pin 8. 10 1 9 2 8 3 7 4 6 5 CLAMP0524P_LC on USB 3.0 Port Application Rev.A_Aug,2016 -4- www.wpmtek.com CLAMP0524P_LC Integrated in OVP&OCP products provider 4-Line Ultra Low Capacitance TVS Diode Array CLAMP0524P_LC on DVI Port Application Rev.A_Aug,2016 -5- www.wpmtek.com CLAMP0524P_LC Integrated in OVP&OCP products provider 4-Line Ultra Low Capacitance TVS Diode Array CLAMP0524P_LC on HDMI Port Application Rev.A_Aug,2016 -6- www.wpmtek.com CLAMP0524P_LC Integrated in OVP&OCP products provider 4-Line Ultra Low Capacitance TVS Diode Array CLAMP0524P_LC on VGA Port Application CLAMP0524P_LC on eSATA Port Application Rev.A_Aug,2016 -7- www.wpmtek.com CLAMP0524P_LC Integrated in OVP&OCP products provider 4-Line Ultra Low Capacitance TVS Diode Array Soldering parameters Pb-Free assembly (see FIG.2) Reflow Condition Pre Heat -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow -Temperature(TL) (Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Rev.A_Aug,2016 -8- www.wpmtek.com CLAMP0524P_LC Integrated in OVP&OCP products provider 4-Line Ultra Low Capacitance TVS Diode Array Package mechanical data DIMENSIONS SYM MILLIMETERS MIN NOM MAX INCHES MIN NOM MAX A 0.45 0.50 0.55 0.018 0.020 0.022 A1 0.00 0.02 0.05 0.000 0.001 0.002 b 0.15 0.20 0.25 0.006 0.008 0.010 b1 0.35 0.40 0.45 0.014 0.016 0.018 b2 0.20 0.25 0.30 0.008 0.010 0.012 c 0.10 0.15 0.20 0.004 0.006 0.008 D 2.45 2.50 2.55 0.098 0.100 0.102 e 0.50BSC 0.020BSC Nd 2.00BSC 0.080BSC E 0.95 1.00 1.05 0.038 0.040 0.042 L 0.35 0.40 0.45 0.014 0.016 0.018 L1 0.075REF 0.003REF L2 0.050REF 0.002REF h 0.08 0.12 0.15 0.003 0.005 0.006 R 0.05 0.10 0.15 0.002 0.004 0.006 Suggested Land Pattern DIMENSIONS SYM MILLIMETERS INCHES X1 0.200 0.008 X2 0.400 0.016 X3 0.500 0.020 Y 0.600 0.024 Z 1.400 0.056 Contact information WPMTEK Incorporated Limited Floor 1 Building 4#, Binxianghua Industry Park, No.7, Huada Road, Hualian Community, Longhua New District, Shenzhen TEL:86755-29308003 FAX:86755-23739900 wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.A_Aug,2016 -9- www.wpmtek.com
CLAMP0524P-LC 价格&库存
很抱歉,暂时无法提供与“CLAMP0524P-LC”相匹配的价格&库存,您可以联系我们找货
