2.0SMBJ58CA
2.0SMBJ58CA
    WPMTEK(维攀微)
    SMC(DO-214AB)
    双向TVS 58V截止 峰值浪涌电流:21.37A@10/1000US
2.0SMBJ58CA 数据手册
2.0SMBJ Series Integrated in OVP&OCP products provider 2000W Transient Voltage Suppressor Description Mechanical Characteristics The 2.0SMBJ series is designed specifically to protect Package: SMB/DO-214AA sensitive electronic equipment from voltage transients  Case Material: “Green” Molding Compound. induced by lightning and other transient voltage events.  UL Flammability Classification Rating 94V-0  Polarity: Color band denotes cathode except Features bi-directional models  Standard Packaging: 12mm tape (EIA STD RS-481)  Glass passivated or planar junction  Excellent clamping capability  Weight: 0.10g  Repetition rate (duty cycle): 0.01%  Terminal Connections: See Diagram Below  Low profile package and low inductance  Marking Information: See Below  2000W Peak Pulse power capability at 10×1000μs Applications waveform.  Fast response time: typically less than 1.0ps from 0V to VBR min.  I/O Interface.  High temperature soldering: 260℃/10s at terminals.  AC/DC Power supply  Plastic package has Underwriters Laboratory  Low frequency signal transmission line (RS232, RS485, etc.) Flammability 94V-0.  For surface mounted applications in order to optimize Marking information board space. Dimensions & Symbol(Unit: mm Max) Details marking code reference customer approval list Ordering information Out line Taping Rev.A_Aug,2016 -1- Reel Per carton Reel diameters (pcs) (pcs) (mm) 3K 48K 330 www.wpmtek.com 2.0SMBJ Series Integrated in OVP&OCP products provider 2000W Transient Voltage Suppressor Electrical characteristics (TA=25℃) Part Number VR IR@VR VBR@IT VC@IPP IPP① mA max(V) A Bi-Polar Uni-Polar V μA min(V) 2.0SMBJ5.0CA 2.0SMBJ5.0A 5.0 800 6.40 7.25 10 9.2 217.39 2.0SMBJ6.0CA 2.0SMBJ6.0A 6.0 800 6.67 7.67 10 10.3 194.17 2.0SMBJ 6.5CA 2.0SMBJ 6.5A 6.5 500 7.22 8.30 10 11.2 178.57 2.0SMBJ7.0 CA 2.0SMBJ7.0A 7.0 200 7.78 8.95 10 12.0 166.67 2.0SMBJ 7.5CA 2.0SMBJ 7.5A 7.5 100 8.33 9.58 1 12.9 155.04 2.0SMBJ 8.0CA 2.0SMBJ 8.0A 8.0 50 8.89 10.23 1 13.6 147.06 2.0SMBJ8.5 CA 2.0SMBJ8.5A 8.5 20 9.44 10.82 1 14.4 138.89 2.0SMBJ9.0 CA 2.0SMBJ9.0 A 9.0 10 10.0 11.50 1 15.4 129.87 2.0SMBJ10CA 2.0SMBJ10A 10 10 11.10 12.30 1 17.0 117.65 2.0SMBJ11CA 2.0SMBJ11A 11 1 12.20 14.00 1 18.2 109.89 2.0SMBJ12CA 2.0SMBJ12A 12 1 13.30 14.70 1 19.9 100.50 2.0SMBJ13CA 2.0SMBJ13A 13 1 14.40 16.50 1 21.5 93.02 2.0SMBJ14CA 2.0SMBJ14A 14 1 15.60 17.20 1 23.2 86.21 2.0SMBJ15CA 2.0SMBJ15A 15 1 16.70 19.20 1 24.4 81.97 2.0SMBJ16CA 2.0SMBJ16A 16 1 17.80 19.70 1 26.0 76.92 2.0SMBJ17CA 2.0SMBJ17A 17 1 18.90 21.70 1 27.6 72.46 2.0SMBJ18CA 2.0SMBJ18A 18 1 20.00 23.30 1 29.2 68.49 2.0SMBJ20CA 2.0SMBJ20A 20 1 22.20 25.50 1 32.4 61.73 2.0SMBJ22CA 2.0SMBJ22A 22 1 24.40 28.0 1 35.5 56.34 2.0SMBJ24CA 2.0SMBJ24A 24 1 26.70 30.70 1 38.9 51.41 2.0SMBJ26CA 2.0SMBJ26A 26 1 28.90 33.20 1 42.1 47.51 2.0SMBJ28CA 2.0SMBJ28A 28 1 31.10 35.80 1 45.4 44.05 2.0SMBJ30CA 2.0SMBJ30 30 1 33.30 38.30 1 48.4 41.32 2.0SMBJ33CA 2.0SMBJ33A 33 1 36.70 42.20 1 53.3 37.52 2.0SMBJ36CA 2.0SMBJ36A 36 1 40.00 46.00 1 58.1 34.42 2.0SMBJ40CA 2.0SMBJ40A 40 1 44.40 51.10 1 64.5 31.01 2.0SMBJ43CA 2.0SMBJ43A 43 1 47.80 52.80 1 69.4 28.82 2.0SMBJ45CA 2.0SMBJ45A 45 1 50.00 57.50 1 72.7 27.51 2.0SMBJ48CA 2.0SMBJ48A 48 1 53.30 58.90 1 77.4 25.84 Rev.A_Aug,2016 -2- max(V) IT www.wpmtek.com 2.0SMBJ Series Integrated in OVP&OCP products provider 2000W Transient Voltage Suppressor Electrical characteristics (TA=25℃, continued) Part Number VR IR@VR VBR@IT IT VC@IPP IPP① Uni-Polar Bi-Polar V μA min(V) max(V) mA max(V) A 2.0SMBJ51CA 2.0SMBJ51A 51 1 56.70 65.20 1 82.4 24.27 2.0SMBJ54CA 2.0SMBJ54A 54 1 60.00 69.00 1 87.1 22.96 2.0SMBJ58CA 2.0SMBJ58A 58 1 64.40 71.20 1 93.6 21.37 2.0SMBJ60CA 2.0SMBJ60A 60 1 66.70 73.70 1 96.8 20.66 2.0SMBJ64CA 2.0SMBJ64A 64 1 71.10 81.80 1 103.0 19.42 2.0SMBJ70CA 2.0SMBJ70A 70 1 77.80 95.10 1 113.0 17.70 2.0SMBJ75CA 2.0SMBJ75A 75 1 83.30 92.10 1 121.0 16.53 2.0SMBJ78CA 2.0SMBJ78A 78 1 86.70 99.70 1 126.0 15.87 2.0SMBJ85CA 2.0SMBJ85A 85 1 94.40 108.20 1 137.0 14.60 2.0SMBJ90CA 2.0SMBJ90A 90 1 100.00 111.00 1 146.0 13.70 2.0SMBJ100CA 2.0SMBJ100A 100 1 111.00 123.00 1 162.0 12.35 2.0SMBJ110CA 2.0SMBJ110A 110 1 122.00 135.00 1 177.0 11.30 2.0SMBJ120CA 2.0SMBJ120A 120 1 133.00 147.00 1 193.0 10.36 2.0SMBJ130CA 2.0SMBJ110A 130 1 144.00 159.00 1 209.0 9.57 2.0SMBJ150CA 2.0SMBJ150A 150 1 167.00 185.00 1 243.0 8.23 2.0SMBJ160CA 2.0SMBJ160A 160 1 178.00 197.00 1 259.0 7.72 2.0SMBJ170CA 2.0SMBJ170A 170 1 189.00 209.00 1 275.0 7.27 2.0SMBJ180CA 2.0SMBJ180A 180 1 201.00 222.00 1 292.0 6.85 2.0SMBJ190CA 2.0SMBJ190A 190 1 211.00 233.00 1 308.0 6.49 ① Surge waveform: 10/1000μs VR :Stand-off Voltage -- Maximum voltage that can be applied VBR: Breakdown Voltage VC:Clamping Voltage -- Peak voltage measured across the suppressor at a specified Ipp IR: Reverse Leakage Current Rev.A_Aug,2016 -3- www.wpmtek.com 2.0SMBJ Series Integrated in OVP&OCP products provider 2000W Transient Voltage Suppressor Part number code 2000W 2.0 SMBJ XXX A: Uni-polar CA CA: Bi-polar SMB Package VR Absolute maximum ratings (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Symbol Value Unit Tstg -55 to +150 ℃ Operating junction temperature range Tj -55 to +150 ℃ Power Dissipation on infinite heat sink at TA=50℃ PD 6.5 W PPP 2000 W VF 5.0 V IFSM 300 A Storage temperature range Peak Pulse Power Dissipation at TA=25℃ by 10x1000μs waveform(Fig.3)(Note 1) (Note 2) Maximum Instantaneous Forward Voltage at 50A for Unidirectional Peak Forward Surge Current, 8.3ms Single Half Sine Wave Unidirectional only(Note 3) Notes: 1.Non-repetitive current pulse, per Fig.3and derated above TA=25℃per Fig. 2. 2.Mounted on copper pad area of 0.31x0.31” (8.0 x 8.0mm) to eachterminal. 3.Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle=4 per minute maximum. Rev.A_Aug,2016 -4- www.wpmtek.com 2.0SMBJ Series Integrated in OVP&OCP products provider 2000W Transient Voltage Suppressor Ratings and V-I characteristics curves (TA=25ºC, unless otherwise noted) I-V Curve Characteristics bi-polar Percent of Rated Power or Ipp I-V Curve Characteristics uni-polar Ambient Temperature - TA (℃) Figure 2: Pulse Derating Curve Figure 3: Pulse waveform Rev.A_Aug,2016 Steady State Power Dissipation PM(AV) (W) Figure 1 - Peak Pulse Power Rating Curve Ambient Temperature - TA (℃) Figure 4: Steady State Power Dissipation Derating Curve -5- www.wpmtek.com 2.0SMBJ Series Integrated in OVP&OCP products provider 2000W Transient Voltage Suppressor Soldering parameters Pb-Free assembly Reflow Condition Heat +150℃ -Temperature Max(Ts(max)) +200℃ TP -Time (Min to Max) (ts) 60-180 secs. TL Average ramp up rate (Liquid us Temp (TL) to peak) Ts(max) to TL - Ramp-up Rate Reflow FIG.5: Reflow condition -Temperature Min (Ts(min)) tp Critical Zone TL to TP Ramp-up tL TS(max) Temperature Pre (see FIG.5) 3℃/sec. Max TS(min) 3℃/sec. Max -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Ramp-down Preheat 25 ts time to peak temperatue (t 25℃ to peak) Time Package mechanical data A Dimensions B C Ref. Max. Min. Max. A 4.25 4.75 0.167 0.187 B 3.30 3.94 0.130 0.155 C 1.85 2.21 0.073 0.087 D 0.76 1.52 0.030 0.060 E E 5.08 5.59 0.200 0.220 F 0.051 0.203 0.002 0.008 J K G 0.15 0.31 0.006 0.012 H 2.11 2.44 0.083 0.096 J 6.80 F H L DO-214AA (SMB) L -6- 0.270 2.60 K Rev.A_Aug,2016 Inches Min. G D Millimeters 2.40 0.100 0.090 www.wpmtek.com 2.0SMBJ Series Integrated in OVP&OCP products provider 2000W Transient Voltage Suppressor Tape & reel specification - SMA Ref. Dimensions Millimeters Inches A 3.76 ± 0.2 0.144 ± 0.012 B 5.69 ± 0.2 0.244 ± 0.012 d 1.5 ± 0.25 0.059 ± 0.004 D 330.0 13.0 D2 13 ± 1 0.512 ± 0.039 E 1.75 ± 0.2 0.059 ± 0.008 F 5.5 ± 0.1 0.222 ± 0.008 P 8.0 ± 0.2 0.315 ± 0.008 P0 4.0 ± 0.2 0.157 ± 0.008 P1 2.0 ± 0.2 0.079 ± 0.008 W 12.0 ± 0.3 0.472 ± 0.008 W1 16.8 ± 2.0 0.661 ± 0.079 Contact information WPMTEK Incorporated Limited Floor 1 Building 4#, Binxianghua Industry Park, No.7, Huada Road, Hualian Community, Longhua New District, Shenzhen TEL:86755-29308003 FAX:86755-23739900 wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.A_Aug,2016 -7- www.wpmtek.com
2.0SMBJ58CA 价格&库存
很抱歉,暂时无法提供与“2.0SMBJ58CA”相匹配的价格&库存,您可以联系我们找货
