WPE5V02LUB
WPE5V02LUB
    WPMTEK(维攀微)
    DFN1006-2
    TVS二极管 VRWM=5V VBR(Min)=6V VC=16V IPP=5A Ppk=80W DFN1006-2
WPE5V02LUB 数据手册
WPE5V02LUB 报��: Mtek· provider 仰Incorporated WPE5V02LUB 。 ��u伽 1-Line Ultra Low Capacitance Uni-directional TVS Di de 。 Abs lute maximum ratinas (TA=25°C, RH=45%-75%, unless otherwise noted) Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 80 w Peak Pulse Current (8/20µs) IPP 5 A Parameter ESD per IEC 61000-4-2(Air) 土25 VESD ESD per IEC 61000-4-2(Con恒ct) Operating Temperature Range Storage Tempe阳tu陪 Range kV 土20 TJ -55 to +125 。C Tstg -55 to +150 。C Electrical characteristics (TA=25℃) Parame·幅r Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR Max 5.0 6.0 Unit v v 。 Test Conditi n IT= 1mA Reverse Leakage Current IR 0. 5 µA VRWM= 5.0V Clamping Voltage Ve 10 v IPP= 1A(8x20µs pulse) Clamping Voltage Ve 16 v IPP= SA(8x20µs pulse) Junction Capacitance CJ 0.8 pF VR = OV, f= 1MHz E旦A且&盟主豆 0.5 -2- www.wpmtek.com: ��: ��u伽 Mtek· 报 provider 仰 Incorporated 。 WPE5V02LUB 。 1-Line Ultra Low Capacitance Uni-directional TVS Di de Tvoical Perf1 rrnance Characteristics (TA=25。C unless othe『wise Specified) Junction Capacitance vs. Reverse Voltage Peak Pulse Power vs. Pulse Time Clamping Voltage vs. Peak Pulse Current Power Derating Curve Note:Data is taken with a 10x attenuator ESD Clamping Voltage 8 X 20μs Pulse Waveform E旦A且&盟主豆 8 kV Contact per IEC61000−4−2 -3- www.wpmtek.com: Mtek· 仰Incorporated 报��: provider WPE5V02LUB 。 ��u伽 1-Line Ultra Low Capacitance Uni-directional TVS Di de Solderins: Darameters -Temperatu陪 Min (Ts(min)) Pb-Free assembly (see FIG.2) +150℃ -Temperatu陪 Max(T s仙似)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Reflow Condition Pre Heat Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max T s(m缸) t TL - Ramp-up Rate 3℃/sec. Max 。 Reflow -Temperature(TL) (Liquid us) +21TC -Temperature(tL) 60-150 secs. Peak Temp (T p) +260(+0/-5)℃ Time within 5℃of actual Peak Temp (t p) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃to Peak Temp (T P) 8 min. Max D not exceed +260℃ 。 TP← 一--一-- -------一--- TL• - - - - - - - - J旦,1 ---- 『 TS(m以) ::J CU 主 / I /Preheat: I 号 TS(『川卜-/- - -Is .- - - - - ← I I ! - ! 自u a e- Hu - - r’- ‘O 一 e P --创 me P - e u n k- FE a 「’ eFL P5 - 02 !!- , ‘ , - - ’ ’ 飞 e m 一- ! 瓦d n/』 E旦A且&盟主豆 Timec中 -4- www.wpmtek.com: " ����roducts Mtek �!�� w:1Incorporated provider WPE5V02LUB 。 1-Line Ultra Low Capacitance Uni-directional TVS Di de Packaae mechanical data �_il 卧 I I E 三二;;丁 J - L二土- b - eERRa m一 胁 趾旦l旦l SEATING PLANE R BOTIOMVIEW NOTES: 1. CONTROLLING DIMENSIONS ARE IN MILLIMETERS (ANGLES IN DEGREES) Suaaested Land Pattern tt FR=h 「己二」 I I + z _j x 」 DIM c x y DIMENSIONS INCHES MILLIMETERS (.033) .012 .024 022 055 (0.85) 0.30 0.60 0.55 1.40 NOTES: 1. CONTROLLING DIMENSIONS ARE IN MILLIMETERS (ANGLES IN DEGREES). 2. THIS LAND PATTERN IS FOR REFERENCE PURPOSES ONLY CONSULT YOUR MANUFACTURING GROUP TO ENSURE YOUR COMPANY'S MANUFACTURING GUIDELINES ARE MET c。ntact information 。 WPMTEKlnc。rp rated Limited Floor 1 Bulldlng 4#, Blnxlanghua Industry Park, No.7, Huada Road, Hualian Community, Longhua New District, Shenzhen TEL: 86755-29308003 FAX: 86755-23739900 wpmtek Incorporated Limi饱d W ( PM) reserves the 『ight to make changes to the product specifi俑白。n and data in this document without noti佣.WPM makes no warranty, representation or guarantee rega『甘ing the sui恒bility of its products for any particular purpose, nor doesWPM assume any liability arising from the appli臼tion or use of any products 。『circuits, and speci自由lly dis- claims any and all liabilit弘including without limitation special, · consequential or incidental damages. [ Rev.A主皿 2016 -5- www.wP-mtek.co刚
WPE5V02LUB 价格&库存
很抱歉,暂时无法提供与“WPE5V02LUB”相匹配的价格&库存,您可以联系我们找货
