WPE5V02LUB-G
WPE5V02LUB-G
    WPMTEK(维攀微)
    DFN1006-2
    ESD抑制器/TVS二极管 单向 14V 4A
WPE5V02LUB-G 数据手册
Integrated in OVP&OCP products provider WPE5V02LUB-G Ultra Low Capacitance ESD Protection Diode Description Mechanical Characteristics WPE5V02LUB-G is a low-capacitance Transient Voltage n Package: DFN1006-2 (1.0×0.6×0.5mm) n Case Material: “Green” Molding Compound. n Moisture Sensitivity: Level 3 per J-STD-020 designed to protect parasitic-sensitive systems against n Terminal Connections: See Diagram Below over-voltage and over-current transient events. It complies n Marking Information: See Below Suppressor (TVS) designed to provide electrostatic discharge (ESD) protection for high-speed data interfaces. With typical capacitance of 0.4pF, WPE5V02LUB-G is with IEC 61000-4-2 (ESD), Level 4 (±20kV air, ±20kV contact discharge). The combined features of low capacitance, ultra-small size and high ESD robustness Applications make WPE5V02LUB-G ideal for high-speed data port and high-frequency line applications, such as cellular phones and HD visual devices. Features n Serial ATA n MDDI Ports n Display Ports n Cellular Phones n Ultra small package: 1.0x0.6x0.5mm n USB Data Line Protection n Protects one data or power line n Digital Visual Interfaces (DVI) n Ultra low leakage: nA level n Desktops, Servers and Notebooks n Working voltage: 5V n Low clamping voltage n Complies with following standards: Marking information – IEC 61000-4-2 (ESD) immunity test Air discharge: ±20kV Contact discharge: ±20kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 4A (8/20μs) n RoHS Compliant Ordering Information Dimensions & Symbol(Unit: mm Max) Part Number WPE5V02LUB-G Rev.B_Aug,2016 -1- Packaging 10000/T & R Reel Size 7 inch www.wpmtek.com Integrated in OVP&OCP products provider WPE5V02LUB-G Ultra Low Capacitance ESD Protection Diode Absolute Maximum Ratings (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 60 W Peak Pulse Current (8/20µs) IPP 4 A ESD per IEC 61000−4−2 (Air) ±20 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range kV ±20 TJ −55 to +125 °C Tstg −55 to +150 °C Electrical characteristics (TA=25℃) Parameter Reverse Working Voltage Breakdown Voltage Reverse Leakage Current Symbol Min Typ VRWM VBR Max Unit 5.0 V 6.0 Test Condition V IT = 1mA IR 0.1 µA VRWM = 5V VC 10 V IPP = 1A (8 x 20µs pulse) VC 14 V IPP = 4A (8 x 20µs pulse) 0.5 pF VR = 0V, f = 1MHz Clamping Voltage Junction Capacitance Rev.B_Aug,2016 CJ 0.4 -2- www.wpmtek.com Integrated in OVP&OCP products provider WPE5V02LUB-G Ultra Low Capacitance ESD Protection Diode Typical Performance Characteristics (TA=25°C unless otherwise Specified) Soldering Parameters Reflow Condition Pre Heat Pb-Free assembly -Temperature Min (Ts(min)) +150℃ -Temperature Max (Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow -Temperature (TL) (Liquid us) +217℃ -Temperature (tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Rev.B_Aug,2016 -3- www.wpmtek.com Integrated in OVP&OCP products provider WPE5V02LUB-G Ultra Low Capacitance ESD Protection Diode Package Mechanical Data Contact Information WPMTEK Incorporated Limited Room 207,2nd Floor, Block 3,Minxing lndustry Park,Minzhi Longhua New District, Shenzhen, PRC TEL:86755-29308003 FAX:86755-23739900 Wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.B_Aug,2016 -4- www.wpmtek.com
WPE5V02LUB-G 价格&库存
很抱歉,暂时无法提供与“WPE5V02LUB-G”相匹配的价格&库存,您可以联系我们找货
WPE5V02LUB-G
  • 1+0.07500
  • 100+0.07000
  • 300+0.06500
  • 500+0.06000
  • 2000+0.05750
  • 5000+0.05600
