WPE0501P1
WPE0501P1
    WPMTEK(维攀微)
    DFN1006-2
    TVS二极管 VRWM=5V VBR(Min)=6V VC=10V IPP=3A DFN1006-2
WPE0501P1 数据手册
Integrated in OVP&OCP products provider WPE0501P1 1-Line Bi-directional Low Capacitance TVS Diode Description Mechanical Characteristics The WPE0501P1 is a bi-directional TVS diode, utilizing  Package: DFN1006-2 (1.0×0.6×0.5mm) leading monolithic silicon technology to provide fast re-  Lead Finish: NiPdAu sponse time, very low capacitance and low ESD  Case Material: “Green” Molding Compound. clamping voltage, making this device an ideal solution  UL Flammability Classification Rating 94V-0 for protect- ing voltage sensitive data and power line.  Moisture Sensitivity: Level 3 per J-STD-020  Terminal Connections: See Diagram Below The WP E 0 50 1 P 1 complies with the IEC 61000-4-2 (ESD)  standard with ±25kV air and ±22kV contact Marking Information: See Below discharge. It is assembled into an ultra-small 1.0x0.6x0.5mm lead-free DFN pack- age. The small size Applications and very low capacitance make WPE0501P1 an ideal choice to protect cell phone, digital cameras, audio  Cellular Handsets and Accessories players, data interface and many other portable  Personal Digital Assistants  Notebooks and Handhelds  Portable Instrumentation  Digital Cameras  Peripherals  Audio Players  Keypads, Side Keys, USB 2.0, LCD Displays applications. Features  Ultra small package: 1.0x0.6x0.5mm  Protects one data or power line  Ultra low leakage: nA level  Working voltage: 5V  Low clamping voltage  2-pin leadless package  Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Marking information Air discharge: ±25kV Details marking code reference customer approval list Contact discharge: ±22kV – IEC61000-4-4 (EFT) 40A (5/50ns)  Ordering Information RoHS Compliant Dimensions & Symbol(Unit: mm Max) Rev.A_Aug,2016 Part Number WPE0501P1 -1- Packaging 10000/Tape & Reel Reel Size 7 inch www.wpmtek.com WPE0501P1 Integrated in OVP&OCP products provider 1-Line Bi-directional Low Capacitance TVS Diode Absolute maximum ratings (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Symbol ESD per IEC 61000−4−2 (Air) Value ±25 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range Unit kV ±22 TJ −55 to +125 °C Tstg −55 to +150 °C Electrical characteristics (TA=25℃) Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR 6.0 Max Unit Test Condition 5.0 V 8.0 V IT = 1mA Reverse Leakage Current IR 0.2 µA VRWM = 5.0V Clamping Voltage VC 8 V IPP = 1A (8 x 20µs pulse) Clamping Voltage VC 10 V IPP = 3A (8 x 20µs pulse) Junction Capacitance CJ pF VR = 0V, f = 1MHz Rev.A_Aug,2016 5.5 -2- www.wpmtek.com Integrated in OVP&OCP products provider WPE0501P1 1-Line Bi-directional Low Capacitance TVS Diode Typical Performance Characteristics (TA=25°C unless otherwise Specified) Junction Capacitance vs. Reverse Voltage Peak Pulse Power vs. Pulse Time Clamping Voltage vs. Peak Pulse Current Power Derating Curve 200 Voltage (V) 150 TA = 25OC Corre rrected for 20dB attenuator 1M Ohm 100 50 0 -50 -20 0 20 Time (ns) 40 60 80 ESD Clamping Voltage 8 X 20μs Pulse Waveform Rev.A_Aug,2016 -3- 8 kV Contact per IEC61000−4−2 www.wpmtek.com Integrated in OVP&OCP products provider WPE0501P1 1-Line Bi-directional Low Capacitance TVS Diode Soldering parameters Pb-Free assembly (see FIG.2) Reflow Condition Pre Heat -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow -Temperature(TL) (Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Rev.A_Aug,2016 -4- www.wpmtek.com WPE0501P1 Integrated in OVP&OCP products provider 1-Line Bi-directional Low Capacitance TVS Diode Package mechanical data DIMENSIONS SYM MILLIMETERS NOM MAX 0.50 0.55 A A1 0.00 0.02 0.05 0.000 0.001 0.002 b 0.45 0.50 0.55 0.018 0.020 0.022 c 0.12 0.15 0.18 0.005 0.006 0.007 D 0.95 1.00 1.05 0.037 0.039 0.041 e MIN 0.018 INCHES NOM 0.020 MIN 0.45 0.65 BSC MAX 0.022 0.026 BSC E 0.55 0.60 0.65 0.022 0.024 0.026 L 0.20 0.25 0.30 0.008 0.010 0.012 h 0.07 0.12 0.17 0.003 0.005 0.007 Suggested Land Pattern DIMENSIONS SYM MILLIMETERS INCHES X 0.60 0.024 Y1 0.50 0.020 Y2 0.30 0.012 Y3 0.80 0.032 Z 1.30 0.052 Contact information WPMTEK Incorporated Limited Floor 1 Building 4#, Binxianghua Industry Park, No.7, Huada Road, Hualian Community, Longhua New District, Shenzhen TEL:86755-29308003 FAX:86755-23739900 wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.A_Aug,2016 -5- www.wpmtek.com
WPE0501P1 价格&库存
很抱歉,暂时无法提供与“WPE0501P1”相匹配的价格&库存,您可以联系我们找货
WPE0501P1
  • 1+0.06000
  • 100+0.05600
  • 300+0.05200
  • 500+0.04800
  • 2000+0.04600
  • 5000+0.04480
