WPE0502P6
WPE0502P6
    WPMTEK(维攀微)
    DFN6_1.6X1MM
    ESD抑制器/TVS二极管 单向 15V 1A
WPE0502P6 数据手册
WPE0502P6 Integrated in OVP&OCP products provider 2-Line Ultra Low Capacitance TVS Diode Description Mechanical Characteristics The WPE0502P6 is an uni-directional TVS diode array,  utilizing leading monolithic silicon technology to provide Package: DFN1610-6  Lead Finish: NiPdAu  Case Material: “Green” Molding Compound. high-speed data lines. The WPE0502P6 has an ultralow  UL Flammability Classification Rating 94V-0 capacitance with a typical value at 0.6pF, and complies  Moisture Sensitivity: Level 3 per J-STD-020 with the IEC 61000-4-2 (ESD) standard with ±25kV air and  Terminal Connections: See Diagram Below ±20kV contact discharge. It is assembled into an  Marking Information: See Below fast response time and low ESD clamping voltage, making this device an ideal solution for protecting voltage sensitive ultra-small 1.6x1.0x0.75mm lead-free DFN package. The small size, ultra-low capacitance and high ESD surge protection make WPE0502P6 an ideal choice to protect Applications cell phone, digital video interfaces and other high speed ports. Features  Ultra small package: 1.6x1.0x0.75mm  Ultra low capacitance: 0.6pF typical  Ultra low leakage: nA level  Low operating voltage: 5V  Low clamping voltage  6-pin leadless package  Protects two lines  Complies with following standards:  Cellular Handsets and Accessories  USB Ports  Video Interface  MDDI Ports Marking information – IEC 61000-4-2 (ESD) immunity test Air discharge: ±25kV Contact discharge: ±20kV – IEC61000-4-4 (EFT) 40A (5/50ns) Dot denotes PIn1 – IEC61000-4-5 (Lightning) 5A (8/20μs)  Details marking code reference customer approval list RoHS Compliant Ordering Information Dimensions & Symbol(Unit: mm Max) Part Number WPE0502p6 Rev.A_Aug,2016 -1- Packaging 3000/Tape & Reel Reel Size 7 inch www.wpmtek.com WPE0502P6 Integrated in OVP&OCP products provider 2-Line Ultra Low Capacitance TVS Diode Absolute maximum ratings (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 125 W Peak Pulse Current (8/20µs) IPP 5 A ESD per IEC 61000−4−2 (Air) ±25 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range kV ±20 TJ −55 to +125 °C Tstg −55 to +150 °C Electrical characteristics (TA=25℃) Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR Max 5 6 Unit Test Condition V V IT = 1mA Reverse Leakage Current IR 0.5 µA VRWM = 5V Clamping Voltage VC 15 V IPP = 1A (8 x 20µs pulse) Clamping Voltage VC 25 V IPP = 12A (8 x 20µs pulse) Junction Capacitance CJ 1.0 pF VR = 0V, f = 1MHz Rev.A_Aug,2016 0.6 -2- www.wpmtek.com WPE0502P6 Integrated in OVP&OCP products provider 2-Line Ultra Low Capacitance TVS Diode Typical Performance Characteristics (TA=25°C unless otherwise Specified) Rev.A_Aug,2016 -3- www.wpmtek.com WPE0502P6 Integrated in OVP&OCP products provider 2-Line Ultra Low Capacitance TVS Diode Soldering parameters Pb-Free assembly (see FIG.2) Reflow Condition Pre Heat -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow -Temperature(TL) (Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Rev.A_Aug,2016 -4- www.wpmtek.com WPE0502P6 Integrated in OVP&OCP products provider 2-Line Ultra Low Capacitance TVS Diode Package mechanical data Suggested Land Pattern Rev.A_Aug,2016 -5- www.wpmtek.com WPE0502P6 Integrated in OVP&OCP products provider 2-Line Ultra Low Capacitance TVS Diode Contact information WPMTEK Incorporated Limited Floor 1 Building 4#, Binxianghua Industry Park, No.7, Huada Road, Hualian Community, Longhua New District, Shenzhen TEL:86755-29308003 FAX:86755-23739900 wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.A_Aug,2016 -6- www.wpmtek.com
WPE0502P6
物料型号:WPE0502P6 器件简介:WPE0502P6 是一款单向TVS二极管阵列,采用领先的单体硅技术,提供快速响应时间和低ESD钳位电压,适用于保护电压敏感的高速数据线。
具有超低电容值(典型值0.6pF),符合IEC 61000-4-2(ESD)标准,空气放电±25kV,接触放电±20kV。
封装在超小型1.6x1.0x0.75mm无铅DFN封装中。
引脚分配:1号引脚VO1,2号引脚VO2,3号引脚GND,4号引脚GND,5号引脚NC,6号引脚NC。
参数特性:超小封装尺寸1.6x1.0x0.75mm,典型电容值0.6pF,超低漏电流nA级别,工作电压5V,钳位电压6V,反向工作电压5V,反向漏电流0.5µA,钳位电压15V(1A脉冲),结电容0.6pF(1MHz时)。
功能详解:WPE0502P6 用于保护电压敏感的高速数据线,如手机、数字视频接口等,提供高ESD浪涌保护。
应用信息:适用于手机、USB端口、视频接口、MDDI端口等。
封装信息:DFN1610-6封装,引脚镀层为NiPdAu,采用“绿色”封装化合物,UL阻燃等级94V-0,潮湿敏感度等级3(依据J-STD-020标准),标记信息需参考客户批准列表。
WPE0502P6 价格&库存
很抱歉,暂时无法提供与“WPE0502P6”相匹配的价格&库存,您可以联系我们找货
WPE0502P6
  • 1+0.27000
  • 100+0.25200
  • 300+0.23400
  • 500+0.21600
  • 2000+0.20700
  • 5000+0.20160
