WPE0508PA
WPE0508PA
    WPMTEK(维攀微)
    DFN10_4.1X2MM_EP
    ESD抑制器/TVS二极管 单向 20V 5A
WPE0508PA 数据手册
WPE0508PA Integrated in OVP&OCP products provider 8-Line Ultra Low Capacitance TVS Diode Array Description Mechanical Characteristics The WPE0508PA is an ultra low capacitance TVS array,  Package: DFN4120-10 utilizing leading monolithic silicon technology to provide  Lead Finish: Matte Tin fast response time and low ESD clamping voltage, making  Case Material: “Green” Molding Compound. this device an ideal solution for protecting voltage sensitive  UL Flammability Classification Rating 94V-0 high-speed data lines. The WPE0508PA has an ultra-low  Moisture Sensitivity: Level 3 per J-STD-020 capacitance with a typical value at 0.3pF, and complies  Terminal Connections: See Diagram Below with the IEC 61000-4-2 (ESD) standard with ±15kV air and  Marking Information: See Below ±8kV contact discharge. It is assembled into a 10-pin 4.1X2.0X0.55mm Applications lead-free DFN package. The flow through style package allows for easy PCB layout and matched trace lengths necessary to maintain consistent impedance between high speed differential lines. The small size, ultra-low capacitance and high ESD surge protection make WPE0508PA an ideal choice to protect high speed ports.  USB3.0/MicroUSB3.0  HDMI Ports  high speed ports Marking information Features  Ultra low capacitance: 0.3pF typical (I/O to I/O)  Ultra low leakage: nA level  Working voltage: 5V  Low clamping voltage  Protects one power line and 7 data lines  Complies with following standards: Dot denotes Pin1 Details marking code reference customer approval list – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Ordering Information Contact discharge: ±8kV – IEC61000-4-4 (EFT) 40A (5/50ns) Part Number WPE0508PA – IEC61000-4-5 (Lightning) 5A (8/20µs)  RoHS Compliant Packaging 3000/Tape & Reel Reel Size 7 inch Dimensions & Symbol(Unit: mm Max) Rev.A_Aug,2016 -1- www.wpmtek.com WPE0508PA Integrated in OVP&OCP products provider 8-Line Ultra Low Capacitance TVS Diode Array Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 100 W Peak Pulse Current (8/20µs) Ipp 5 A ESD per IEC 61000−4−2 (Air) ±15 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range kV ±8 TJ −55 to +125 °C Tstg −55 to +150 °C Electrical Characteristics (TA=25°C unless otherwise specified) Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR Max 5 6 Unit Test Condition V V IT = 1mA µA VRWM = 5.0V Reverse Leakage Current IR Clamping Voltage VC 12 V IPP = 1A (8 x 20µs pulse) Clamping Voltage VC 20 V IPP = 5A (8 x 20µs pulse) Junction Capacitance CJ 0.8 pF Rev.A_Aug,2016 0.5 0.6 -2- Any I/O to GND pins,VR=0V, f=1MHZ www.wpmtek.com WPE0508PA Integrated in OVP&OCP products provider 8-Line Ultra Low Capacitance TVS Diode Array Typical Performance Characteristics (TA=25°C unless otherwise Specified) Rev.A_Aug,2016 -3- www.wpmtek.com WPE0508PA Integrated in OVP&OCP products provider 8-Line Ultra Low Capacitance TVS Diode Array Soldering parameters Pb-Free assembly (see FIG.2) Reflow Condition Pre Heat -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow -Temperature(TL) (Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Rev.A_Aug,2016 -4- www.wpmtek.com WPE0508PA Integrated in OVP&OCP products provider 8-Line Ultra Low Capacitance TVS Diode Array Package mechanical data Suggested Land Pattern Contact information WPMTEK Incorporated Limited Floor 1 Building 4#, Binxianghua Industry Park, No.7, Huada Road, Hualian Community, Longhua New District, Shenzhen TEL:86755-29308003 FAX:86755-23739900 wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.A_Aug,2016 -5- www.wpmtek.com
WPE0508PA 价格&库存
很抱歉,暂时无法提供与“WPE0508PA”相匹配的价格&库存,您可以联系我们找货
WPE0508PA
  • 1+0.72000
  • 100+0.67200
  • 300+0.62400
  • 500+0.57600
  • 2000+0.55200
  • 5000+0.53760
