SM712
SM712
    WPMTEK(维攀微)
    SOT-23
    ESD抑制器/TVS二极管 SOT23 17V 36A
SM712 数据手册
SM712 Integrated in OVP&OCP products provider Asymmetrical TVS Diode Description Mechanical Characteristics The SM712 is designed for asymmetrical (12V to –7V)  Package: SOT-23 protection in multi-point data transmission application, The  Lead Finish: Matte Tin  Case Material: “Green” Molding Compound.  UL Flammability Classification Rating 94V-0 with ±30kV air and ±30kV contact discharge. It is  Moisture Sensitivity: Level 3 per J-STD-020 assembled into a lead-free SOT-23 package. It is designed  Terminal Connections: See Diagram Below to protect components which are connected to data and  Marking Information: See Below SM712 replace four discrete components by integrating two 12V and two 7V TVS diodes in a single package. The SM712 complies with the IEC 61000-4-2 (ESD) standard transmission lines from voltage surges. Applications Features  Wireless System  325W peak pulse power (8/20µs)  Networks  Ultra low leakage: nA level  Portable Instrumentation  Operating voltage: 7V or 12V  RS485 Ports  Low clamping voltage  Complies with following standards: Marking information – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV  – IEC61000-4-5 (Lightning) 36A for 12V & 7V (8/20μs)  RoHS Compliant Details marking code reference customer approval list Dimensions & Symbol(Unit: mm Max) Ordering Information Part Number SM712 Rev.A_Aug,2016 -1- Packaging 3000/Tape & Reel Reel Size 7 inch www.wpmtek.com SM712 Integrated in OVP&OCP products provider Asymmetrical TVS Diode Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) Peak Pulse Current (tp = 8/20μs), Pin 1 or 2 to Pin 3 Symbol Value Unit Ppk 600-1000 W 36 Ipp Peak Pulse Current (tp = 8/20μs), Pin 3 to Pin 1 or 2 ESD per IEC 61000−4−2 (Air) ±30 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range A 36 kV ±30 TJ −55 to +125 °C Tstg −55 to +150 °C Electrical Characteristics (TA=25°C unless otherwise specified) Pin 1 to 3 and 2 to 3 Parameter Reverse Working Voltage Breakdown Voltage Pin 3 to 1 and 3 to 2 (12V TVS) (7V TVS) Symb Min Typ Max Min Typ Max Unit Test Condition ol VRWM VBR 12 13.3 7 7.5 V V IT = 1mA Reverse Leakage Current IR 0.1 0.1 μA VR = VRWM Clamping Voltage VC 19 10 V IPP = 1A Clamping Voltage VC 25 15 V IPP = 25A (8 x 20µs pulse) Clamping Voltage VC 28 17 V IPP = 36A (8 x 20µs pulse) Junction Capacitance CJ 75 75 pF VR = 0V, f = 1MHz Junction Capacitance CJ 50 60 pF VR = VRWM, f = 1MHz Rev.A_Aug,2016 -2- (8 x 20µs pulse) www.wpmtek.com SM712 Integrated in OVP&OCP products provider Asymmetrical TVS Diode Typical Performance Characteristics (TA=25°C unless otherwise Specified) 10 Pin 1 or Pin 2 to Pin 3 70.0 Pin 3 to Pin 1 or Pin 2 Peak Power_Ppp(kW) Junction Capacitance_Cj (pF) 80.0 60.0 50.0 40.0 30.0 20.0 Pin 3 to pin1 or pin2 1 Pin 1 or pin 2 to pin 3 0.1 10.0 0.01 0.0 0 2 4 6 8 Reverse Voltage_VR (V) 10 12 0.1 1 100 10 1000 Pulse Duration_tp(μs) Junction Capacitance vs. Reverse Voltage Peak Pulse Power vs. Pulse Time 30 Pin 1 or Pin 2 to Pin 3 Clamping Voltage _Vc(V) 25 Pin 3 to Pin 1 or Pin 2 20 15 10 Waveform Parameter td=8μs tr=20μs 5 0 0 5 10 15 20 25 30 35 40 Peak Pulse Current_Ipp (A) Clamping Voltage vs. Peak Pulse Current Power Derating Curve ESD Clamping Voltage 8 kV Contact per IEC61000−4−2 8 X 20μs Pulse Waveform Rev.A_Aug,2016 -3- www.wpmtek.com SM712 Integrated in OVP&OCP products provider Asymmetrical TVS Diode Soldering parameters Pb-Free assembly (see FIG.2) Reflow Condition Pre Heat -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow -Temperature(TL) (Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Rev.A_Aug,2016 -4- www.wpmtek.com SM712 Integrated in OVP&OCP products provider Asymmetrical TVS Diode Package mechanical data Suggested Land Pattern Contact information WPMTEK Incorporated Limited Floor 1 Building 4#, Binxianghua Industry Park, No.7, Huada Road, Hualian Community, Longhua New District, Shenzhen TEL:86755-29308003 FAX:86755-23739900 wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.A_Aug,2016 -5- www.wpmtek.com
SM712
物料型号:SM712
器件简介:SM712是一款用于多点数据传输应用的非对称(12V至-7V)保护的TVS二极管。它将两个12V和两个7V TVS二极管集成在一个封装中,替代了四个分立组件。符合IEC 61000-4-2 (ESD)标准,具有±30kV空气放电和±30kV接触放电能力。采用无铅SOT-23封装。
引脚分配:文档中提供了引脚连接图,但未在摘要中列出。
参数特性: - 峰值脉冲功率:325W(8/20μs) - 超低漏电流:纳安级别 - 工作电压:7V或12V - 低钳位电压 - 符合IEC 61000-4-2 (ESD)和IEC61000-4-5 (Lightning)标准 - RoHS合规
功能详解:设计用于保护连接到数据和传输线组件免受电压浪涌的影响。
应用信息:适用于无线系统、网络、便携式仪器、RS485端口等。
封装信息:SOT-23封装,引脚镀锡,采用“绿色”模塑料,UL阻燃等级94V-0,湿度敏感性等级3(根据J-STD-020)。
订购信息:提供3000/卷带式封装,卷径7英寸。
绝对最大额定值和电气特性也详细列出,包括峰值脉冲功率、峰值脉冲电流、ESD电压、工作温度范围等。
焊接参数和封装机械数据也提供,包括回流条件、预热条件、峰值温度等。
联系信息:WPMTEK公司详细信息,包括地址、电话和传真。
SM712 价格&库存
很抱歉,暂时无法提供与“SM712”相匹配的价格&库存,您可以联系我们找货
