CLAMP1211P
CLAMP1211P
    WPMTEK(维攀微)
    DFN1006
    双向ESD 12V截止 峰值浪涌电流:15A@8/20US
CLAMP1211P 数据手册
CLAMP1211P Integrated in OVP&OCP products provider 1-Line Bi-directional TVS Diode Description Mechanical Characteristics The CLAMP1211P is a 12V bi-directional TVS diode,  Package: DFN1006-2 (1.0×0.6×0.5mm)  Lead Finish: NiPdAu  Case Material: “Green” Molding Compound. sensitive data and power line. The CLAMP1211P  Moisture Sensitivity: Level 3 per J-STD-020 complies with the IEC 61000-4-2 (ESD) standard with  Terminal Connections: See Diagram Below ±30kV air and ±30 kV contact discharge. It is assembled  Marking Information: See Below utilizing leading monolithic silicon technology to provide fast re- sponse time and low ESD clamping voltage, making this device an ideal solution for protecting voltage into an ultra-small 1.0x0.6x0.5mm lead-free DFN package. The small size and high ESD surge protection make CLAMP1211P an ideal choice to protect cell phone, digital Applications cameras, audio play- ers and many other portable applications. Features  Cellular Handsets and Accessories  Personal Digital Assistants  Ultra small package: 1.0x0.6x0.5mm  Notebooks and Handhelds  Protects one data or power line  Portable Instrumentation  Ultra low leakage: nA level Working voltage: 12V   Digital Cameras  Low clamping voltage  Peripherals  2-pin leadless package  Audio Players  Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Marking information Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-5 (Lightning) 15A (8/20µs)  RoHS Compliant Dimensions & Symbol(Unit: mm Max) Details marking code reference specification of approval Ordering Information Part Number CLAMP1211P Rev.B_Aug,2019 -1- Packaging 10000/Tape & Reel Reel Size 7 inch www.wpmtek.com CLAMP1211P Integrated in OVP&OCP products provider 1-Line Bi-directional TVS Diode Absolute maximum ratings (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 375 W Peak Pulse Current (8/20µs) Ipp 15 A ESD per IEC 61000−4−2 (Air) ±30 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range kV ±30 TJ −55 to +125 °C Tstg −55 to +150 °C Electrical characteristics (TA=25℃) Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR Max Unit 12 V 13.3 Test Condition V IT = 1mA Reverse Leakage Current IR 100 nA VRWM = 12V Clamping Voltage VC 16 V IPP = 1A (8 x 20µs pulse) Clamping Voltage VC 25 V IPP = 10A (8 x 20µs pulse) Junction Capacitance CJ pF VR = 0V, f = 1MHz Rev.B_Aug,2019 35 -2- www.wpmtek.com CLAMP1211P Integrated in OVP&OCP products provider 1-Line Bi-directional TVS Diode Typical Performance Characteristics (TA=25°C unless otherwise Specified) Junction Capacitance vs. Reverse Voltage Peak Pulse Power vs. Pulse Time Clamping Voltage vs. Peak Pulse Current Power Derating Curve ESD Clamping Voltage 8 X 20μs Pulse Waveform Rev.B_Aug,2019 8 kV Contact per IEC61000−4−2 -3- www.wpmtek.com CLAMP1211P Integrated in OVP&OCP products provider 1-Line Bi-directional TVS Diode Soldering parameters Pb-Free assembly (see FIG.2) Reflow Condition Pre Heat -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow -Temperature(TL) (Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Rev.B_Aug,2019 -4- www.wpmtek.com CLAMP1211P Integrated in OVP&OCP products provider 1-Line Bi-directional TVS Diode Package mechanical data DIMENSIONS A MILLIMETERS MIN NOM MAX 0.45 0.50 0.55 INCHES MIN NOM 0.018 0.020 MAX 0.022 A1 0.00 0.02 0.05 0.000 0.001 0.002 b 0.45 0.50 0.55 0.018 0.020 0.022 c 0.12 0.15 0.18 0.005 0.006 0.007 D 0.95 1.00 1.05 0.037 0.039 0.041 SYM e 0.65 BSC 0.026 BSC E 0.55 0.60 0.65 0.022 0.024 0.026 L 0.20 0.25 0.30 0.008 0.010 0.012 h 0.07 0.12 0.17 0.003 0.005 0.007 Suggested Land Pattern DIMENSIONS SYM MILLIMETERS INCHES X 0.60 0.024 Y1 0.50 0.020 Y2 0.30 0.012 Y3 0.80 0.032 Z 1.30 0.052 Tape Specification - DFN1006(mm) W 8.0±0.1 P1 2.0±0.1 A 0.7±0.05 B 1.15±0.05 K 0.57±0.03 Rev.B_Aug,2019 -5- www.wpmtek.com CLAMP1211P Integrated in OVP&OCP products provider 1-Line Bi-directional TVS Diode Reel Specification - DFN1006(mm) W1 8.6 D 180.0±1.0 D2 24±1.0 Contact information WPMTEK Incorporated Limited Room 206-207,2nd Floor,Block 3,Minxing lndustry Park,Minzhi Longhua New District,Shenzhen wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.B_Aug,2019 -6- www.wpmtek.com
