Integrated in
OVP&OCP products
provider
CLAMP0521P
1-Line Bi-directional Ultra-low Capacitance TVS Diode
Description
Mechanical Characteristics
The CLAMP0521P is designed with WPMTEK
Package: DFN1006-2 (1.0×0.6×0.5mm)
Lead Finish: NiPdAu
Case Material: “Green” Molding Compound.
best in class protection on designs that are exposed to
Moisture Sensitivity: Level 3 per J-STD-020
ESD. Because of its small size, it is suited for use in
Terminal Connections: See Diagram Below
cellular phones, MP3 players, digital cameras and many
Marking Information: See Below
Punch-Through process TVS technology to protect voltage
sensitive components from ESD. Excellent clamping
capability, low leakage, and fast response time provide
other portable applications where board space comes at a
premium. Also because of its low capacitance, it is suited
for use in high frequency designs such as USB 2.0 high
Applications
speed, USB 3.0 super speed, VGA, DVI, HDMI, eSATA
and other high speed line applications. It has been
specifically designed to protect sensitive components
which are connected to data and transmission lines from
High Speed Line :USB1.0/2.0/3.0/3.1, VGA, DVI.SDI
High Definition Multi-Media Interface
(HDMI1.3/1.4/2.0)
overvoltage caused by ESD(electrostatic discharge), and
EFT (electrical fast transients). .
Features
Ultra small package: 1.0x0.6x0.5mm
Ultra low capacitance: 0.3pF typical
No insertion loss to 3.0GHz
Working voltage: 5V
Low clamping voltage
2-pin leadless package
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test Air
Serial and Parallel Ports
Notebooks, Desktops, Servers
Peripherals
Cellular handsets and accessories
Portable instrumentation
Marking information
discharge: ±15kV
Contact discharge: ±8kV
– IEC61000-4-5 (Lightning) 4A (8/20µs)
RoHS Compliant
Details marking code reference specification of approval
Dimensions & Symbol(Unit: mm Max)
Ordering Information
Part Number
CLAMP0521P
Rev.1Y_Aug,2016
-1-
Packaging
10000/Tape & Reel
Reel Size
7 inch
www.wpmtek.com
CLAMP0521P
Integrated in
OVP&OCP products
provider
Absolute maximum ratings (TA=25ºC, RH=45%-75%, unless otherwise noted)
Parameter
Symbol
Value
Unit
Pppp
100
W
Peak Pulse Power (tp=8/20μs waveform)
ESD per IEC 61000−4−2 (Air)
±25
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
kV
±22
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Electrical characteristics (TA=25℃)
Parameter
Symbol
Reverse Working Voltage
VRWM
Breakdown Voltage
VBR
Min
Typ
6
Max
Unit
Test Condition
5
V
10
V
IT = 1mA
Reverse Leakage Current
IR
0.2
µA
VRWM = 5.0V
Clamping Voltage
VC
12
V
IPP = 1A (8 x 20µs pulse)
Clamping Voltage
VC
25
V
IPP = 4A (8 x 20µs pulse)
Junction Capacitance
CJ
0.5
pF
VR = 0V, f = 1MHz
Rev.1Y_Aug,2016
0.3
-2-
www.wpmtek.com
Integrated in
OVP&OCP products
provider
CLAMP0521P
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
Peak Pulse Power vs. Pulse Time
Junction Capacitance vs. Reverse Voltage
Power Derating Curve
Clamping Voltage vs. Peak Pulse Current
Note:Data is taken with a 10x attenuator
ESD Clamping Voltage
8 X 20μs Pulse Waveform
Rev.1Y_Aug,2016
8 kV Contact per IEC61000−4−2
-3-
www.wpmtek.com
CLAMP0521P
Integrated in
OVP&OCP products
provider
Package mechanical data
Suggested Land Pattern
DIMENSIONS
SYM
MILLIMETERS
INCHES
X
0.60
0.024
Y1
0.50
0.020
Y2
0.30
0.012
Y3
0.80
0.032
Z
1.30
0.052
Tape Specification - DFN1006(mm)
W
8.0±0.1
P1
2.0±0.1
A
0.7±0.05
B
1.15±0.05
K
0.57±0.03
Reel Specification - DFN1006(mm)
W1
8.6
D
180.0±1.0
D2
24±1.0
Rev.1Y_Aug,2016
-4-
www.wpmtek.com
Integrated in
OVP&OCP products
provider
CLAMP0521P
Soldering parameters
Pb-Free assembly
(see FIG.2)
Reflow Condition
Pre Heat
-Temperature Min (Ts(min))
+150℃
-Temperature Max(Ts(max))
+200℃
-Time (Min to Max) (ts)
60-180 secs.
Average ramp up rate (Liquid us Temp (TL) to peak)
3℃/sec. Max
Ts(max) to TL - Ramp-up Rate
3℃/sec. Max
Reflow
-Temperature(TL) (Liquid us)
+217℃
-Temperature(tL)
60-150 secs.
Peak Temp (Tp)
+260(+0/-5)℃
Time within 5℃ of actual Peak Temp (tp)
30 secs. Max
Ramp-down Rate
6℃/sec. Max
Time 25℃ to Peak Temp (TP)
8 min. Max
Do not exceed
+260℃
Contact information
WPMTEK Incorporated Limited
Room 206-207,2nd Floor,Block 3,Minxing lndustry Park,Minzhi
Longhua New District,Shenzhen
TEL:86755-29308003
FAX:86755-23739900
wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM
makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability
arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special,
consequential or incidental damages.
Rev.1Y_Aug,2016
-5-
www.wpmtek.com
很抱歉,暂时无法提供与“CLAMP0521P”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.08850
- 100+0.08260
- 300+0.07670
- 500+0.07080
- 2000+0.06785
- 5000+0.06608
