CLAMP0561P1
CLAMP0561P1
    WPMTEK(维攀微)
    DFN1006
    TVS二极管 5V 0.2 µA DFN1006
CLAMP0561P1 数据手册
CLAMP0561P1 Integrated in OVP&OCP products provider 1-Line Bi-directional Low Capacitance TVS Diode Description Mechanical Characteristics The CLAMP0561P1 is a bi-directional TVS diode, utilizing  Package: DFN1006-2 (1.0×0.6×0.5mm) leading monolithic silicon technology to provide fast re-  Lead Finish: NiPdAu sponse time, very low capacitance and low ESD clamping  Case Material: “Green” Molding Compound. voltage, making this device an ideal solution for protect-  UL Flammability Classification Rating 94V-0 ing voltage sensitive data and power line. The  Moisture Sensitivity: Level 3 per J-STD-020  Terminal Connections: See Diagram Below CLA M P 0 56 1 P1 complies with the IEC 61000-4-2 (ESD) standard with ±15kV air and ±8kV contact discharge. It  Marking Information: See Below is assembled into an ultra-small 1.0x0.6x0.5mm lead-free DFN pack- age. The small size and very low capacitance Applications make CLAMP0561P1 an ideal choice to protect cell phone, digital cameras, audio players, data interface and  Cellular Handsets and Accessories many other portable applications.  Personal Digital Assistants  Notebooks and Handhelds  Portable Instrumentation  Digital Cameras  Peripherals  Audio Players  Keypads, Side Keys, USB 2.0, LCD Displays Features  Ultra small package: 1.0x0.6x0.5mm  Protects one data or power line  Ultra low leakage: nA level  Working voltage: 5V  Low clamping voltage  2-pin leadless package  Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air Marking information discharge: ±15kV Details marking code reference customer approval list Contact discharge: ±8kV – IEC61000-4-5 (Lightning) 2A (8/20μs)  RoHS Compliant Ordering Information Dimensions & Symbol(Unit: mm Max) Part Number Packaging CLAMP0561P1 10000/Tape & Reel Rev.N_Aug,2016 -1- Reel Size 7 inch www.wpmtek.com CLAMP0561P1 Integrated in OVP&OCP products provider 1-Line Bi-directional Low Capacitance TVS Diode Absolute maximum ratings (TA=25ºC, RH=45%-75%, unless otherwise noted) Parameter Symbol ESD per IEC 61000−4−2 (Air) Value ±15 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range Unit kV ±8 TJ −55 to +125 °C Tstg −55 to +150 °C Electrical characteristics (TA=25℃) Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR Max Unit 5.0 V 6 Test Condition V IT = 1mA Reverse Leakage Current IR 0.2 µA VRWM = 5.0V Clamping Voltage VC 10 V IPP = 1A (8 x 20µs pulse) Junction Capacitance CJ 3 pF VR = 0V, f = 1MHz Rev.N_Aug,2016 2.5 -2- www.wpmtek.com CLAMP0561P1 Integrated in OVP&OCP products provider 1-Line Bi-directional Low Capacitance TVS Diode Typical Performance Characteristics (TA=25°C unless otherwise Specified) Junction Capacitance vs. Reverse Voltage Peak Pulse Power vs. Pulse Time Clamping Voltage vs. Peak Pulse Current (tp = 8/20us) Power Derating Curve Note:Data is taken with a 10x attenuator ESD Clamping Voltage 8 X 20μs Pulse Waveform Rev.N_Aug,2016 -3- +8 kV Contact per IEC61000−4−2 www.wpmtek.com Integrated in OVP&OCP products provider CLAMP0561P1 1-Line Bi-directional Low Capacitance TVS Diode Soldering parameters Pb-Free assembly (see FIG.2) Reflow Condition Pre Heat -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow -Temperature(TL) (Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Rev.N_Aug,2016 -4- www.wpmtek.com CLAMP0561P1 Integrated in OVP&OCP products provider 1-Line Bi-directional Low Capacitance TVS Diode Package mechanical data DIMENSIONS SYM MILLIMETERS NOM MAX 0.50 0.55 A A1 0.00 0.02 0.05 0.000 0.001 0.002 b 0.45 0.50 0.55 0.018 0.020 0.022 c 0.12 0.15 0.18 0.005 0.006 0.007 D 0.95 1.00 1.05 0.037 0.039 0.041 e MIN 0.018 INCHES NOM 0.020 MIN 0.45 0.65 BSC MAX 0.022 0.026 BSC E 0.55 0.60 0.65 0.022 0.024 0.026 L 0.20 0.25 0.30 0.008 0.010 0.012 h 0.07 0.12 0.17 0.003 0.005 0.007 Suggested Land Pattern DIMENSIONS SYM MILLIMETERS INCHES X 0.60 0.024 Y1 0.50 0.020 Y2 0.30 0.012 Y3 0.80 0.032 Z 1.30 0.052 Contact information WPMTEK Incorporated Limited Floor 1 Building 4#, Binxianghua Industry Park, No.7, Huada Road, Hualian Community, Longhua New District, Shenzhen TEL:86755-29308003 FAX:86755-23739900 wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.N_Aug,2016 -5- www.wpmtek.com
