ESD9D5CB
ESD9D5CB
    WPMTEK(维攀微)
    SOD-923
    双向ESD 5V截止 峰值浪涌电流:5A
ESD9D5CB 数据手册
ESD9D5CB Integrated in OVP&OCP products provider 1-Line Bi-directional TVS Diode Description Mechanical Characteristics The ESD9D5CB is designed to protect voltage sensitive components from ESD and transient voltage events.  Package: SOD-923 (1.0×0.6×0.4mm) Excellent clamping capability, low leakage, and fast  response time, make these parts ideal for ESD protection Lead Finish: NiPdAu  Case Material: “Green” Molding Compound.  UL Flammability Classification Rating 94V-0 players, digital cameras and many other portable  Moisture Sensitivity: Level 3 per J-STD-020 applications where board space is at a premium.  Terminal Connections: See Diagram Below on designs where board space is at a premium. Because of its small size, it is suited for use in cellular phones, MP3  Features  Small Body Outline Dimensions:1.0 mm x 0.60 mm  Low Body Height: 0.43 mm Max  Low Clamping Voltage  Response Time is Typically < 1 ns  Complies with following standards: Applications – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV  IEC61000-4-4 (EFT) 40A (5/50ns)  IEC 61000-4-5 (Lightning) 5A (8/20μs)  RoHS Compliant Marking Information: See Below  Cellular Handsets and Accessories  Display Ports  MDDI Ports  USB Ports  Digital Video Interface (DVI)  PCI Express and Serial SATA Ports Marking information Dimensions & Symbol(Unit: mm Max) Details marking code reference customer approval list Ordering Information Part Number ESD9D5CB Rev.A_Aug,2016 -1- Packaging 10000/Tape & Reel Reel Size 7 inch www.wpmtek.com ESD9D5CB Integrated in OVP&OCP products provider 1-Line Bi-directional TVS Diode Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 80 W Peak Pulse Current (8/20µs) Ipp 5 A ESD per IEC 61000−4−2 (Air) ±30 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range kV ±30 TJ −55 to +125 °C Tstg −55 to +150 °C Electrical Characteristics (TA=25°C unless otherwise specified) Parameter Reverse Working Voltage Symbol Min Typ VRWM Breakdown Voltage VBR Reverse Leakage Current IR Clamping Voltage Max Unit 5 V 6 Test Condition V IT = 1mA 0.2 uA VRWM = 5V VC 10 V IPP = 1A (8 x 20uS pulse) Clamping Voltage VC 12 V IPP = 5A (8 x 20uS pulse) Junction Capacitance CJ 15 pF Rev.A_Aug,2016 0.1 -2- VR = 0V, f = 1MHz www.wpmtek.com ESD9D5CB Integrated in OVP&OCP products provider 1-Line Bi-directional TVS Diode Typical Performance Characteristics (TA=25°C unless otherwise Specified) Rev.A_Aug,2016 -3- www.wpmtek.com ESD9D5CB Integrated in OVP&OCP products provider 1-Line Bi-directional TVS Diode Soldering parameters Pb-Free assembly (see FIG.2) Reflow Condition Pre Heat -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow -Temperature(TL) (Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Rev.A_Aug,2016 -4- www.wpmtek.com ESD9D5CB Integrated in OVP&OCP products provider 1-Line Bi-directional TVS Diode Package mechanical data Suggested Land Pattern Contact information WPMTEK Incorporated Limited Floor 1 Building 4#, Binxianghua Industry Park, No.7, Huada Road, Hualian Community, Longhua New District, Shenzhen TEL:86755-29308003 FAX:86755-23739900 wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.A_Aug,2016 -5- www.wpmtek.com
ESD9D5CB
物料型号:ESD9D5CB
器件简介: - ESD9D5CB设计用于保护电压敏感元件免受ESD(静电放电)和瞬态电压事件的影响。具有出色的钳位能力、低漏电流和快速响应时间,非常适合在板空间有限的设计中进行ESD保护。
引脚分配: - 引脚分配图示在文档中有详细说明,但未提供具体文字描述。
参数特性: - 封装尺寸:1.0 mm x 0.60 mm,最大高度0.43 mm - 低钳位电压 - 响应时间通常小于1纳秒 - 符合IEC 61000-4-2(ESD)空气放电±30kV和接触放电±30kV标准 - 符合RoHS标准
功能详解: - 适用于手机、MP3播放器、数码相机等便携式应用,以及显示端口、MDDI端口、USB端口、数字视频接口(DVI)、PCI Express和串行SATA端口的ESD保护。
应用信息: - 适用于手机及其配件、显示端口、MDDI端口、USB端口、DVI、PCI Express和串行SATA端口。
封装信息: - 封装类型:SOD-923(1.0×0.6×0.4mm) - 引脚镀层:NiPdAu - 封装材料:“绿色”模具化合物 - UL阻燃等级:94V-0 - 湿度敏感性:按照J-STD-020标准为3级
订购信息: - 型号:ESD9D5CB - 包装:10000/卷带 - 卷带尺寸:7英寸
绝对最大额定值: - 峰值脉冲功率(8/20μs):80W - 峰值脉冲电流(8/20μs):5A - 工作温度范围:-55°C至+125°C - 存储温度范围:-55°C至+150°C
电气特性: - 反向工作电压:5V - 击穿电压:6V - 反向漏电流:0.1μA至0.2μA(在5V反向工作电压下) - 钳位电压:10V(在1A脉冲电流下,8×20μs脉冲) - 钳位电压:12V(在5A脉冲电流下,8×20μs脉冲) - 结电容:15pF(在0V反向电压下,频率1MHz)
焊接参数: - 无铅组装,具体温度和时间参数在文档中有详细说明。
封装机械数据: - 提供了详细的尺寸数据和建议的焊盘图案。
联系信息: - WPMTEK公司地址、电话、传真和网址。
