WTM3415
P-Channel Enhancement Mode Power MOSFET
Description
The WTM3415 uses advanced trench technology to provide
excellent RDS(ON), low gate charge and operation with gate
voltages as low as1.8V. This device is suitable for use as a
load switch or in PWM applications .It is ESD protested.
General Features
● VDS = -20V,ID =-4A
Schematic diagram
RDS(ON) < 63mΩ @ VGS=-2.5V
RDS(ON) < 55mΩ @ VGS=-4.5V
ESD Rating: 2500V HBM
● High Power and current handing capability
● Lead free product is acquired
● Surface mount package
Marking and pin Assignment
Application
● PWM application
● Load switch
SOT-23
Absolute Maximum Ratings (TA=25℃unless otherwise noted)
Parameter
Symbol
Drain-Source Voltage
VDS
Gate-Source Voltage
VGS
Drain Current-Continuous
ID
Drain Current-Pulsed (Note 1)
IDM
Maximum Power Dissipation
PD
Operating Junction and Storage Temperature Range
TJ,TSTG
top view
Limit
Unit
-20
V
±8
V
-4
A
-30
A
1.4
W
-55 To 150
89.3
℃/W
Thermal Characteristic
Thermal Resistance,Junction-to-Ambient (Note 2)
RθJA
Electrical Characteristics (TA=25℃unless otherwise noted)
Parameter
Symbol
Condition
Min
Typ
Max
Unit
V
Off Characteristics
Drain-Source Breakdown Voltage
RevA_Aug,2018
BVDSS
VGS=0V ID=-250μA
-1-
-20
www.wpmtek.com
WTM3415
Zero Gate Voltage Drain Current
IDSS
VDS=-20V,VGS=0V
1
μA
Gate-Body Leakage Current
IGSS
VGS=±8V,V
±10
μA
VDS=VGS,ID=-250μA
-0.4
-0.65
-1.0
V
VGS=-4.5V, ID=-4A
34.
55
mΩ
VGS=-2.5V, ID=-4A
44
63
mΩ
VDS=-5V,ID=-4A
8
S
950
PF
165
PF
120
PF
12
nS
DS=0V
On Characteristics (Note 3)
Gate Threshold Voltage
VGS(th)
Drain-Source On-State Resistance
RDS(ON)
Forward Transconductance
gFS
Dynamic Characteristics (Note4)
Input Capacitance
Clss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
VDS=-10V,VGS=0V,
F=1.0MHz
Switching Characteristics (Note 4)
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
VDD=-10V,RL=2. 5Ω
10
nS
td(off)
VGS=-4.5V,RGEN=3Ω
19
nS
25
nS
12
nC
1.4
nC
3.6
nC
-1.2
V
-2.2
A
Turn-Off Delay Time
Turn-Off Fall Time
tf
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
VDS=-10V,ID=-4A,
VGS=-4.5V
Drain-Source Diode Characteristics
Diode Forward Voltage (Note 3)
VSD
Diode Forward Current (Note 2)
IS
VGS=0V,IS=-1A
Notes:
1. Repetitive Rating: Pulse width limited by maximum junction temperature.
2. Surface Mounted on FR4 Board, t ≤ 10 sec.
3. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%.
4. Guaranteed by design, not subject to production
RevA_Aug,2018
-2-
www.wpmtek.com
WTM3415
TYPICAL ELECTRICAL AND THERMAL CHARACTERISTICS
Vdd
Vgs
Rgen
td(on)
Rl
Vin
D
ton
tr
td(off)
Vout
90%
VOUT
G
toff
tf
90%
INVERTED
10%
10%
90%
S
VIN
50%
50%
10%
PULSE WIDTH
Figure 2:Switching Waveforms
PD Power(W)
ID- Drain Current (A)
Figure 1:Switching Test Circuit
TJ-Junction Temperature(℃)
Vds Drain-Source Voltage (V)
Figure 4
Safe Operation Area
Rdson On-Resistance(mΩ)
Figure 3 Power Dissipation
Figure 5 Output CHARACTERISTICS
RevA_Aug,2018
Figure 6 Drain-Source On-Resistance
-3-
www.wpmtek.com
WTM3415
Normalized On-Resistance
Vgs Gate-Source Voltage (V)
Figure 8 Drain-Source On-Resistance
Rdson (mΩ)
C Capacitance (pF)
Figure 7 Transfer Characteristics
Figure 10 Capacitance vs Vds
Is- Reverse Drain Current (A)
Figure 9 Rdson vs Vgs
Vsd Source-Drain Voltage (V)
Qg Gate Charge (nC)
Figure 11 Gate Charge
RevA_Aug,2018
Figure 12 Source- Drain Diode Forward
-4-
www.wpmtek.com
很抱歉,暂时无法提供与“WTM3415”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.25100
- 200+0.19916
- 600+0.17324
