S-1011A
S-1011A
    NIDEC(尼得科)
    SW5_10X10MM_TM
    旋转编码开关
S-1011A 数据手册
ROTARY CODED SWITCHES S-1000A/2000A INTERNAL STRUCTURE S-1000A / 2000A series RoHS compliant ⑦ ① ⑤ ⑥ ④ ② ③ ■ FEATURES Part name ● RoHS compliant ● Protection against dust and whole cleaning after soldering is possible ● Pin compatible with conventional DIP switches ● Translucent knob with flange type (S-1200A/2200A series) • Distinguished visibility with translucent flange • Settable with fingers or screwdriver Material Flammability PBT UL94HB Copper alloy, Gold-plated — ① Housing ② Contact ③ Terminal pin ④ Base ⑤ “O” ring ⑥ Insert rotor ⑦ Translucent ※ S-12 □□ A/22 □□ A のみ knob with flange Polybutyleneterephthalate PBT Polybutyleneterephthalate Silicone rubber UL94HB Rotor : Polyoxymethylene Pattern : Copper alloy, Gold-plated PAR(Polyarylate) S-12 □□ A/22 □□ A only UL94V-2 ■ PART NUMBER DESIGNATION S - 1 0 1 0 A W Series name Form of packaging W:Tray packaging Blank:Bulk in plastic bag No. of positions Setting position 1:16 positions 2:10 positions 0:Top setting 1:Side setting Shape of rotor Code format 0:Without knob 1:With knob (with extended shaft) 2:Translucent knob with flange (Black housing) 1:Real code 3:Complementary code ※ Please refer to the LIST OF PART NUMBERS when placing orders. S-1000A/2000A ROTARY CODED SWITCHES ■ LIST OF PART NUMBERS Binary coded decimal Shape Form of packging Real code Binary coded hexadecimal Complementary code Real code Pieces in package Complementary code S-2010AW S-2030AW S-1010AW S-1030AW S-2010A S-2030A S-1010A S-1030A S-2110AW S-2130AW S-1110AW S-1130AW S-2110A S-2130A S-1110A S-1130A S-2210AW S-2230AW S-1210AW S-1230AW S-2210A S-2230A S-1210A S-1230A S-2011AW S-2031AW S-1011AW S-1031AW S-2011A S-2031A S-1011A S-1031A S-2111AW S-2131AW S-1111AW S-1131AW S-2111A S-2131A S-1111A S-1131A S-2211AW S-2231AW S-1211AW S-1231AW S-2211A S-2231A S-1211A S-1231A Tray packaging Plastic bag Tray packaging Top With knob setting Plastic bag Translucent knob Tray packaging with flange Plastic bag Tray packaging Without knob Plastic bag Tray packaging Side With knob setting Plastic bag Translucent knob Tray packaging with flange Plastic bag Without knob 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack 50 pcs./tray 25 pcs./pack ※ Verify the above part numbers when placing orders. Tray version can be supplied only in tray units. Operating face Operating face of of real DIMENSIONS code complementary (Unit: code mm) ■ TERMINAL CONNECTION / Complementary P.C.B. THROUGH HOLE Real code code Top setting 8 4 2 1 C C Real code Complementary code 8 4 2 1 8 4 2 1 Position Real code Code Complementary code ● …Contact closed 8 4 2 1 8 4 2 1 C 2.54±0.1 2.54±0.1 5 – φ 0.8 hole 5.08±0.1 5 – φ 0.8 hole 5.08±0.1 7.62±0.1 5 – φ 0.8 hole Operating face 2.54±0.1 5 – φ 0.8 hole 7.62±0.1 2.54±0.1 2.54±0.1 ■ CODE FORMAT 8 4 2 1 C S – 1000A/2000A case No. of positions 8 4 2 1 Operating face 2.54±0.1 2.54±0.1 P.C.B. dimensions (Bottom view) 8 4 2 1 OperatingC face of complementary code C C Side setting Operating C face of real code 2.54±0.1 Terminal pin layout (Bottom view) 8 4 2 1 8 4 2 1 S – 1000A/2000A case S – 1000A/2000A case S – 1000A/2000A case S-1000A series (16 positions) S-2000A series (10 positions) 0 1 2 3 4 5 6 7 8 9 A B C D E F ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● S-1000A/2000A ROTARY CODED SWITCHES ■ STANDARD SPECIFICATIONS Circuit type Operating temperature range Storage temperature range Sealing Net weight BCD (Real code, complementary code) BCH (Real code, complementary code) − 40 ~ 85 °C Washable by “O” ring ※ Please refer to page 150,151 Approx. 0.87 g (S-1010A, S-1030A, S-2010A, S-2030A) Approx. 1.13 g (S-1011A, S-1031A, S-2011A, S-2031A) Approx. 0.97 g (S-1110A, S-1130A, S-2110A, S-2130A) Approx. 1.23 g (S-1111A, S-1131A, S-2111A, S-2131A) Approx. 1.02 g (S-1210A, S-1230A, S-2210A, S-2230A) Approx. 1.28 g (S-1211A, S-1231A, S-2211A, S-2231A) ■ MECHANICAL CHARACTERISTICS ■ ELECTRICAL CHARACTERISTICS Contact rating Non-switching Switching Minimum Contact resistance Insulation resistance Dielectric strength Vibration Shock 16 (S-1000A), 10 (S-2000A) Adjustment torque 13 mN·m {133 gf·cm} minimum Stepping angle 22.5° (S-1000A), 36° (S-2000A) Terminal strength Solderability Soldering heat 15 N {1.53 kgf} minimum 245 ± 3 °C, 2 ~ 3 s Flow : 260 ± 3 °C as the temperature in a pot of molten solder, immer­sion from head of terminal to backside of board, 5 ~ 6 s, two times maximum Manual soldering: 380 ± 10 °C, 3 ~ 4 s { } : Reference only 100 m Ω maximum 1000 M Ω (DC100 V) minimum AC300 V, 60 s ■ ENVIRONMENTAL CHARACTERISTICS Load life No. of positions DC50 V 100 mA DC5 V 100 mA DC20 mV 1 μ A Humidity (Steady state) Amplitude 1.5 mm or Acceleration 98 m/s2, 10-500-10 Hz, 3 directions for 2 h each 490 m/s2, 11 ms 6 directions for 3 times each 10000 steps DC5 V, 100 mA Resistance load DC50V 100mA 60 °C, Relative humidity 90 ~ 95 %, 1000 h High temperature exposure 85 °C, 1000 h Low temperature exposure − 40 °C, 96 h Thermal shock − 40 (0.5 h) ~ 85 °C ( 0.5 h ), 5 cycles S-1000A/2000A ROTARY CODED SWITCHES ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) (S-1000A series) 0.6 W W ×× 2.6 2.6 LL ×× 1.7 1.7 D D 0.6 77 8 8 4 4 2.54 2.54 100.2 100.2 FF0011 8899 6677 AA 344 55 223 C C 2 2 CD BBC DEE 5–0.5 5–0.50.1 0.1 t t==0.2 0.2 1 1 Part No. No. & & Production Production date date code code Part A/1130A 外形図 Part No. No. & & Production Production date date code code Part ● S-1011A ● S-1031A Side setting 100.2 100.2 100.2 100.2 4455 2233 3.50.5 3.50.5 7 8899 667 88 11.5 11.5 0.6 W W ×× 2.6 2.6 LL ×× 1.7 1.7 D D 0.6 CCDD AABB EE 01 FF 01 11 5 – 0.50.1 5 – 0.50.1 100.2 100.2 10 ± 0.2 5.08 5.08 77 6.6 6.6 6.6 CD AB CD BBC DEE Part No. No. & & Production Production date date code code Part 4.5 ± 0.5 7 Straight knurl knurl Straight M == 0.2 0.2 M Part No. & Production date code Part No. No. & & Production Production date date code code Part ● S-1111A ● S-1131A Side setting 6 89 67 45 2 3 22334455 8 F 01 2.54 01 FF 0 1 2.54 2.54 88 44 4 22 2 2.54 2.54 2.54 0.7 W 1 D 11 5 – 0.50.1 5 – 0.50.1 1 6.6 6.6 18.1 18.1 6.6 11.5 φ 3.9 φφ3.9 3.9 89 10 677±8 90.2 CCDD AABB EAEBCDE 3.5 ± 0.5 10 ± 0.2 3.50.5 100.2 3.50.5 100.2 100.2 0.7 W Wdate D Part100.2 No. & Production 0.7 ×× 11 code D 0.2 tt == 0.2 52.54 – 0.5 ± 0.1 2.54 t = 0.2 2.54 12.6 12.6 Straight knurl knurl Straight 6 7.62 7.62 7.62 4.50.5 4.50.5 0.5 8899 6677 6A7A8 9 01 E F FF0011 66 0.7 W W ×× 11 D D 0.7 0.7 W × 1 D 344 55 223 45 23 10 ± 0.2 100.2 100.2 C C 0.2 tt == 0.2 2.54 2.54 2.54 2.54 2.54 2.54 ● S-1110A ● S-1130A Top setting 22 5–0.5 ± 0.1 5–0.5 5–0.50.1 0.1 t = 0.2 t t==0.2 0.2 2.54 2.54 2.54 2.54 2.542.54 2.54 2.54 2.54 44 φ 3.9φφ3.9 3.9 1131A 外形図 7.62 7.62 4.50.5 4.50.5 2.54 2.54 100.2 100.2 2.54 2.54 ● S-1010A ● S-1030A Top setting C 5.08 C 5.08 C M == 0.2 0.2 M 5.08 8 8 C C C 4 8 4 2 4 2 1 2 1 1 S-1000A/2000A ROTARY CODED SWITCHES ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) (S-2000A series) 10 ± 0.2 10 ± 0.2 0.6 W × 2.6 L × 1.7 D 7 4.5 ± 0.5 0.6 W × 2.6 L × 1.7 D 7 4.5 ± 0.5 0 9 09 1 1 ± 0.2 10 ±100.2 5 4 54 6 6 23 23 5–0.5 ± 0.1 5–0.5 ± 0.1 t = 0.2 t = 0.2 78 78 Part No. & Production date code Part No. & Production date code ● S-2011A ● S-2031A Side setting 7.62 7.62 8 48 C 24 C 12 1 Part No. & Production date code 100.2 100.2 8 4 2 4 2 2.54 2.54 2.54 ● S-2110A ● S-2130A Top setting 11.5 0.6 W × 2.6 L × 1.7 D S-2110A 1 C 外形図 5 –S-2130A 0.5 ± 0.1 1 t = 0.2 5 – 0.5 ± 0.1 2.54 t = 0.2 2.54 0.7 W × 1 D 0.7W×1D 0.710W±× 0.2 1D 5.08 6 5.08 7 4.5 ± 0.5 77 4.5 0.5 4.5 ± ±0.5 3.9φ 3.9 Ø φ3.9 5 4 54 6 6 S-2111A S-2131A 外形図 7 8 7 8 Straight knurl M = 0.2 Part No. & Production date code Straight knurl M = 0.2 Straight knurl 5–0.5±0.1 Part No. & Production date code Part No. & Production date code C 6.6 0.5 23 23 0 9 091 1 6 6.6 6.6 10 ±0.2 ± 0.2 1010±0.2 ± 0.2 ±100.2 11.5 5–0.5 ± 0.1 5–0.5 t=0.2 ± 0.1 t = 0.2 2.54 2.54 t =2.54 0.2 2.542.54 2.542.54 2.542.54 2 32 3 ± 0.5 ± 0.2 3.5 3.5 ± 0.5 10 ±100.2 901 901 8 Part No. & Production date code 0.6 W × 2.6 L × 1.7 D 7 87 8 456 456 2.54 Part No. & Production date code date code 0.7 W × 1 D 6.6 0.7W×1D 0.7 W × 1 D 6.6 18.1 & Production PartPart No. &No. Production date code 10 ± 0.2 3.5 ±0.5 2.54 2.54 8 4 2 1 4 2 1 2.54 8 2.54 4 2 2.54 φ 3.9φ 3.9 2 32 3 8 Ø 3.9 10 ±0.2 2.54 56 456 4 ±0.2 10 9 01 9 01 ± 0.5 ± 0.2 3.5 3.5 ± 0.5 10 ±100.2 10 ± 0.2 7 87 8 ● S-2111A ● S-2131A Side setting 2.542.54 2.542.54 2.542.54 ● S-2010A ● S-2030A Top setting 5 – 0.5 ± 0.1 t5=–0.2 0.5 ± 0.1 2.54 t = 0.2 1 2.54 5 – 0.5±0.1 t=0.2 2.54 18.1 18.1 6.6 6.5 12.6 5.08 C C 12.6knurl Straight 5.08 M = 0.2 Straight knurl M = 0.2 C 12.6 5.08 Straight knurl M=0.2 7.62 7.62 7.62 8 48 C C C 8 24 4 12 2 1 1 S-1000A/2000A ROTARY CODED SWITCHES ■ OUTLINE DIMENSIONS Unless otherwise specified, tolerance: ± 0.3 (Unit: mm) (S-1200A/2200A series) 10 ± 0.2 4.5 ± 0.5 2.54 4 C 2 BCD 1 0.7 W × 1 D Part No. & Production date code 5 – 0.5 ± 0.1 t = 0.2 2.54 01 EF 2 8 9A 10 ± 0.2 345 ● S-1211A ● S-1231A Side setting 7.62 2.54 12 67 Part No. & Production date code 10 ± 0.2 5 11.5 23 456 3.5 ± 0.5 10 ± 0.2 CD AB E 7 9 F0 1 0.7 W × 1 D 8 4 2 1 2.54 2.54 ● S-2210A ● S-2230A Top setting C 5 – 0.5 ± 0.1 2.54 t = 0.2 6 12 4.5±0.5 23 2.54 901 10±0.2 6 78 5 11.5 6 4 23 78 901 10±0.2 10±0.2 3.5±0.5 ④ 4 Part No. & Production date code Part No. & Production date code ⑧ ④ ② ① 2.54 ⑧ 2.54 Ⓒ ② ① 0.7 W × 1 D ● S-2211A ● S-2231A Side setting 7.62 2.54 10±0.2 5.08 5 – 0.5±0.1 t = 0.2 2.54 ● S-1210A ● S-1230A Top setting 0.7 W × 1 D 5 – 0.5±0.1 2.54 t = 0.2 C 6 5.08 S-1000A/2000A ROTARY CODED SWITCHES ■ Snap-in terminal pin with translucent knob with flange (Made to order basis) ● S-1200AK and S-2200AK ■ PACKAGING SPECIFICATIONS ● Tray version is packaged in 50 pcs. per tyay. Orders will be accepted for units of 50 pcs., i. e., 50, 100, 150 pcs. etc. ● Tray version is boxed with 10 trays. ● The smallest unit of bulk pack in a plastic bag is 10 pcs. per pack. Orders will be accepted for unit of minimum 10 pcs., i.e., 10, 20, 30 pcs. , etc. ● Boxing of bulk in a plastic bag is performed with 25 pcs. (standard 50 pcs.) per box. S-1000長軸用ツマミ付き ■ SWITCHES WITH KNOB AS EXTENDED SHAFT 10 φ 5.5 φ 9.5 1 0.7 The large knob is common to S-1000A, S-2000A, SA-5000 and SS-10 series. ※ Knob can’t be dettached due to being fixed. Simple knob can’t be sold. (Unit: mm)
S-1011A 价格&库存
很抱歉,暂时无法提供与“S-1011A”相匹配的价格&库存,您可以联系我们找货
S-1011A
  • 2+22.34810
库存:6
S-1011A
    • 1+7.63460
