WP61065AB
High Property Device for Surge & Overvoltage noise Protection
WP61065AB
This device has been especially designed to protect 1 low voltage or signal line, as well as classical RS-485
interface, against transient over-voltages.
ESD-voltages are clamped by 2 TVS diodes. Surges are suppressed by 2 thyristors, their breakdown
voltage close to 8V,then their leakage current as low as 1uA.
This devices are not subject to ageing and provide a fail safe mode in short circuit for a better protection.
WPG are used to help equipment to meet various standards such as UL1950, IEC950 / CSA C22.2, UL1459 and
FCC part68.
Features
Integrated the two TVS diodes and two thyristor
Accurate voltage of protection
Low switching voltages: VBR
Low leakage current: IR = 2 uA max
High Peak pulse current
Solid-state silicon technology
Meets MSL 1 Requirements
ROHS compliant
WeiPan technology
SMA-J
Main applications
Signal Line
RS-485 interface
Telecommunications infrastructure
PBX's and other switches
Set-top box
Ammeter
Ordering Information
Device
Marking
Qty per Reel
Reel Size
WP61065AB
P065B
5000
13 Inch
WP61065AB
Maximum ratings (Tamb=25℃ Unless Otherwise Specified)
Parameter
Symbol
Value
Unit
IPPSM
70
A
Non-repetitive peak on-state current:
WP61065AB
10/1000 us (Telcordia(Bellcore)Gr-1089-CORE.Issue 2.February 1999,Section4)
5/320 us (ITU-T K.20, K.21& K.45, K.44 open-circuit voltage wave shape 10/700us)
100
1.2/50 us (Telcordia(Bellcore)Gr-1089-CORE.Issue 2.February 1999,Section4)
250
Lead Soldering Temperature
TL
260 (10 sec.)
Operating Temperature Range
TJ
-40 ~ 85
TSTG
-55 ~ 150
TL
260
RθJA
100
℃/W
Storage Temperature Range
Lead Solder Temperature − Maximum (10 Second Duration)
Junction To ambient
Maximum ratings are those values beyond which device damage can occur. Maximum ratings applied to the device are individual stress limit
values (not normal operating conditions) and are not valid simultaneously. If these limits are exceeded, device functional operation is not
implied,damage may occur and reliability may be affected.
Electrical characteristics ( Tamb=25℃ Unless Otherwise Specified)
Parameter
Symbol
Repetitive peak off-state voltage,
WP61065AB
Leakage Current, VR=6.5V
WP61065AB
Breakdown Voltage, IR=1mA
WP61065AB
Impulse breakover voltage, dv/dt ≤ ±100 V/μs, Linear voltage ramp,
WP61065AB
On-state voltage(Clamp Voltage), T = ±2.2 A, t w = 100 μs
WP61065AB
Off-state capacitance, f =1 MHz, Vd =0.3V rms, VDC =2V
WP61065AB
!2!
Value
Min.
Typ.
Max.
Unit
VDRM
±6.5
V
IR
±2
uA
VDC
±8.3
V
VBO
±25
V
VC
±4
V
Coff
80
pF
WP61065AB
Package Information
SMA-J
Mechanical Data
Case: SMA-J
Case Material: Molded Plastic. UL Flammability
Classification Rating 94V-0
Polarity Indicator: Cathode Band (Note: Bi-directional devices have no polarity indicator.)
Weight: 0.069grams (approximate)
A
C
B
MARKING
WPM
H
D
F
E
SMA-J
DIM
Millimeters
A
Min
3.39
Max
4.60
B
C
2.40
1.25
2.79
1.65
D
E
0.150
0.310
F
0.76
4.80
1.52
5.28
H
1.90
2.29
!3!
WP61065AB
Contact Information
WPMTEK Incorporated Limited
Floor 1 Building 4#, Binxianghua Industry Park, No.7,
Huada Road, Hualian Community, Longhua New District, Shenzhen
TEL:86755-29308003
FAX:86755-23739900
!4!
很抱歉,暂时无法提供与“WP61065AB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.32940
- 100+0.26201
- 300+0.22832
- 1000+0.20304
- 5000+0.17864
- 10000+0.16848
