P0080TVB
Integrated in
OVP&OCP products
provider
Thyristors Surge Protection Device(SMA 2K)
Description
Mechanical characteristics
P0080TVB thyristors are a type of semi-conduct
Package: SMA
component. They are designed in applications,
modems, telephones, line cards, answering machines,
FAX machines, SLICs, T1/E1, xDSL, PBXs and more.
This series can be used to provide protection in
accordance with industry standards such as FCC Part 68,
Case Material: “Green” Molding Compound.
Lead Finish: Matte Tin
UL Flammability Classification Rating 94V-0
Standard Packaging: 12mm tape (EIA STD
RS-481)
ANSI C62.41, UL 1459, GR-1089-CORE, IEC 61000-2,
IEC 61000-4 and IEC 61000-4-5 requirements
Features
Weight: 0.07g
Terminal Connections: See Diagram Below
Marking Information: See Below
Applications
Cannot be damaged by voltage
Eliminate hysteresis and heat dissipation typically
SLIC Line Card
found with clamping devices
T1/E1 Trunk & Line Card
DBX Branch Exchange Switches
Eliminate voltage overshoot caused by fast-rising
transients
Are non-degenerative
FCC Part 68 Customer Premise Equipment
Will not fatigue
Line Interface Modem
Meets MSL level 1, per J-STD-020
xDSL Architecture Interface
Dimensions & Symbol(Unit: mm Max)
Marking information
Marking
Code
Details marking code reference customer approval list
Ordering information
Out line
Taping
Rev.A_Aug,2016
-1-
Reel
Per carton
Reel diameters
(pcs)
(pcs)
(mm)
5K
80K
330
www.wpmtek.com
P0080TVB
Integrated in
OVP&OCP products
provider
Absolute Maximum Ratings (TA=25ºC, RH=45%-75%, unless otherwise noted)
Parameter
Symbol
Value
Unit
Tstg
-60 to +150
Operating junction temperature range
Tj
-40 to +150
Repetitive peak pulse current
IPP
50
A
Storage temperature range
Electrical Characteristics (TA=25℃)
Part Number
P0080TVB
VRM
Min.
V
6.5
IRM
Max.
uA
5
VBO
V
25
Max.
IBO
VT
mA
800
V
4
Max.
IT
A
2.2
CO
Typ.
pF
8
IH
Typ.
mA
25
Electrical Parameters & V-I Curve
Symbol
Parameter
VDRM
Peak off-state voltage
IDRM
Off-state current
VS
Switching voltage
IS
Switching current
VT
On-state voltage
IT
On-state current
IH
Holding current
CO
Off-state capacitance
Surge ratings
Series
A
Rev.A_Aug,2016
IPP (A) min
2×10us
8×20us
5×320us
10×1000us
100
90
50
35
-2-
www.wpmtek.com
P0080TVB
Integrated in
OVP&OCP products
provider
Ratings and V-I Characteristics Curves (TA=25ºC, unless otherwise noted)
Reflow Condition
Pre Heat
Pb-Free assembly (see FIG.2)
-Temperature Min (Ts(min))
+150℃
-Temperature Max(Ts(max))
+200℃
-Time (Min to Max) (ts)
60-180 secs.
Average ramp up rate (Liquid us Temp (TL) to peak)
3℃/sec. Max
Ts(max) to TL - Ramp-up Rate
3℃/sec. Max
Reflow
-Temperature(TL) (Liquid us)
+217℃
-Temperature(tL)
60-150 secs.
Peak Temp (Tp)
+260(+0/-5)℃
Time within 5℃ of actual Peak Temp (tp)
30 secs. Max
Ramp-down Rate
6℃/sec. Max
Time 25℃ to Peak Temp (TP)
8 min. Max
Do not exceed
+260℃
FIG.1: tr × td pulse waveform
FIG.2: Reflow condition
%IPP
tp
tr = rise time to peak value
td = decay time to half value
100
TP
Critical Zone
T L to T P
Ramp-up
Peak value
TL
tL
Temperature
T S(max)
Half value
50
t(μs)
0 tr
T S(min)
ts
25
td
FIG.3: Normalized Vs change vs. junction
temperature
Percent of Vs change(%)
time to peak temperatue
(t 25℃ to peak)
Time
FIG.4: Normalized DC holding current vs. case
temperature
2.0
12
IH(Tj )/IH(Tj =25℃)
1.8
1.6
8
1.4
4
1.2
25℃
25℃
1.0
-4
-8
-40 -20
Ramp-down
Preheat
Rev.A_Aug,2016
Tj (℃)
40
60 80
0.6
100 120 140 160
0.4
-40 -20
-3-
TC (℃)
60 80
100 120 140 160
www.wpmtek.com
P0080TVB
Integrated in
OVP&OCP products
provider
Package Mechanical Data
A
D i m e n s io n s
B
R e f.
M illim e te r s
M in .
M ax.
In c h e s
M in .
M ax.
0 .1 6 7
0 .1 8 3
A
4 .2 5
4 .6 5
B
2 .5 0
2 .9 0
0 .0 9 8
0 .1 1 4
C
1 .3 5
1 .6 5
0 .0 5 3
0 .0 6 5
D
0 .7 6
1 .5 2
0 .0 3 0
0 .0 6 0
E
E
4 .9 3
5 .2 8
0 .1 9 4
0 .2 0 8
F
0 .0 5 1
0 .2 0 3
0 .0 0 2
0 .0 0 8
J
K
G
0 .1 5
0 .3 1
0 .0 0 6
0 .0 1 2
H
1 .9 8
2 .4 1
0 .0 7 8
0 .0 9 5
J
6 .5 0
H
F
G
L
D
K
D O -2 1 4 A C (S M A )
0 .2 5 6
2 .3 0
1 .7 0
L
0 .0 9 0
0 .0 6 7
Tape & Reel Specification (SMA)
Ref.
Dimensions
Millimeters
Inches
A
2.79 ± 0.3
0.110 ± 0.012
B
5.33 ± 0.3
0.210 ± 0.012
d
1.5 ± 0.1
0.059 ± 0.004
D
330.0
13.0
D2
13 ± 1
0.512 ± 0.039
E
1.5 ± 0.2
0.059 ± 0.008
F
5.65 ± 0.2
0.222 ± 0.008
P
4.0 ± 0.2
0.157 ± 0.008
P0
4.0 ± 0.2
0.157 ± 0.008
P1
2.0 ± 0.2
0.079 ± 0.008
W
12.0 ± 0.2
0.472 ± 0.008
W1
16.8 ± 2.0
0.661 ± 0.079
Contact Information
WPMTEK Incorporated Limited
Floor 1 Building 4#, Binxianghua Industry Park, No.7,
Huada Road, Hualian Community, Longhua New District, Shenzhen
TEL:86755-29308003
FAX:86755-23739900
wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM
makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability
arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special,
consequential or incidental damages.
Rev.A_Aug,2016
-4-
www.wpmtek.com
很抱歉,暂时无法提供与“P0080TVB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.15900
- 100+0.14840
- 300+0.13780
- 500+0.12720
- 2000+0.12190
- 5000+0.11872
- 国内价格
- 10+0.34215
- 100+0.28718
- 300+0.25974
- 1000+0.23912
- 5000+0.15714
- 10000+0.14883
