SD08
SD08
    WPMTEK(维攀微)
    SOD-323
    单向 击穿电压 V(BR) @IT:7.8V 反向漏电流 IR @V(RWM):10uA 钳位电压(VC@ Ipp):13.5V封装:SOD-323
SD08 数据手册
SDXX Integrated in OVP&OCP products provider 3.3V~36V Unidirectional TVS Diode Description Mechanical Characteristics The SDXX series is designed for applications requiring n Package: SOD-323 transient overvoltage protection capability. They are n Lead Finish: Matte Tin intended for use in voltage and ESD sensitive equipment n Case Material: “Green” Molding Compound. n UL Flammability Classification Rating 94V-0 board space is at a premium. This series has been n Moisture Sensitivity: Level 3 per J-STD-020 specifically designed to protect sensitive components n Terminal Connections: See Diagram Below which are connected to power, data and transmission lines n Marking Information: See Below such as computers, printers, medical equipment and other applications. These devices are ideal for situations where form overvoltage caused by ESD,CDE(Cable discharge Events),and EFT(electrical fast transients) Applications Features n USB Ports n Smart Phones n Wireless Systems n Ethernet 10/100/1000 Base T n 350W peak pulse power (8/20us) n Protects one data or power line n Ultra low leakage: nA level n Stand−off Voltage: 3.3 V ~ 36 V n Ultra low clamping voltage n Complies with following standards: Marking information – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Contact discharge: ±8kV – IEC61000-4-4 (EFT) 40A (5/50ns) n Bar denotes cathode RoHS Compliant Details marking code reference customer approval list Dimensions & Symbol(Unit: mm Max) Ordering Information Part Number SD03 SD05 SD12 SD15 SD24 SD36 Rev.C_Aug,2018 -1- Packaging 3000/Tape & Reel 3000/Tape & Reel 3000/Tape & Reel 3000/Tape & Reel 3000/Tape & Reel 3000/Tape & Reel Reel Size 7 inch 7 inch 7 inch 7 inch 7 inch 7 inch www.wpmtek.com SDXX Integrated in OVP&OCP products provider 3.3V~36V Unidirectional TVS Diode Absolute Maximum Ratings (TA=25°C unless otherwise specified) SD03 Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 350 W Peak Pulse Current (8/20µs) Ipp 20 A ESD per IEC 61000−4−2 (Air) ±15 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range ±8 kV TJ −55 to +150 °C Tstg −55 to +150 °C Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 350 W Peak Pulse Current (8/20µs) Ipp 17 A Storage Temperature Range SD05 Parameter ESD per IEC 61000−4−2 (Air) ±15 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range ±8 kV TJ −55 to +150 °C Tstg −55 to +150 °C Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 350 W Peak Pulse Current (8/20µs) Ipp 11 A Storage Temperature Range SD12 Parameter ESD per IEC 61000−4−2 (Air) ±15 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range Rev.C_Aug,2018 -2- ±8 kV TJ −55 to +150 °C Tstg −55 to +150 °C www.wpmtek.com SDXX Integrated in OVP&OCP products provider 3.3V~36V Unidirectional TVS Diode SD15 Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 350 W Peak Pulse Current (8/20µs) Ipp 10 A ESD per IEC 61000−4−2 (Air) ±15 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range ±8 kV TJ −55 to +150 °C Tstg −55 to +150 °C Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 350 W Peak Pulse Current (8/20µs) Ipp 7 A Storage Temperature Range SD24 Parameter ESD per IEC 61000−4−2 (Air) ±15 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range ±8 kV TJ −55 to +150 °C Tstg −55 to +150 °C Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 350 W Peak Pulse Current (8/20µs) Ipp 5 A Storage Temperature Range SD36 Parameter ESD per IEC 61000−4−2 (Air) ±15 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range Rev.C_Aug,2018 -3- ±8 kV TJ −55 to +150 °C Tstg −55 to +150 °C www.wpmtek.com SDXX Integrated in OVP&OCP products provider 3.3V~36V Unidirectional TVS Diode Electrical Characteristics (TA=25°C unless otherwise specified) SD03 Parameter Symbol Reverse Working Voltage VRWM Breakdown Voltage VBR Reverse Leakage Current IR Clamping Voltage VC Clamping Voltage VC Junction Capacitance CJ Min Typ Max Unit 3.3 V 4.0 40 6.5 10.5 450 Test Condition V IT = 1mA uA VRWM = 3.3V V IPP = 1A (8 x 20uS pulse) V IPP = 20A (8 x 20uS pulse) pF VR = 0V, f = 1MHz SD05 Parameter Symbol Reverse Working Voltage VRWM Breakdown Voltage VBR Reverse Leakage Current IR Clamping Voltage VC Clamping Voltage VC Junction Capacitance CJ Min Typ Max Unit 5 V 6.0 10 9.8 18.0 300 Test Condition V IT = 1mA uA VRWM = 5V V IPP = 1A (8 x 20uS pulse) V IPP = 17A (8 x 20uS pulse) pF VR = 0V, f = 1MHz SD12 Parameter Symbol Reverse Working Voltage VRWM Breakdown Voltage VBR Reverse Leakage Current IR Clamping Voltage VC Clamping Voltage VC Junction Capacitance CJ Rev.C_Aug,2018 Min Typ Max Unit 12 V 13.3 1 19 32 130 -4- Test Condition V IT = 1mA uA VRWM = 12V V IPP = 1A (8 x 20uS pulse) V IPP =11A (8 x 20uS pulse) pF VR = 0V, f = 1MHz www.wpmtek.com SDXX Integrated in OVP&OCP products provider 3.3V~36V Unidirectional TVS Diode SD15 Parameter Symbol Reverse Working Voltage VRWM Breakdown Voltage VBR Reverse Leakage Current IR Clamping Voltage VC Clamping Voltage VC Junction Capacitance CJ Min Typ Max Unit 15 V 16.7 1 24 38 120 Test Condition V IT = 1mA uA VRWM =15V V IPP = 1A (8 x 20uS pulse) V IPP = 10A (8 x 20uS pulse) pF VR = 0V, f = 1MHz SD24 Parameter Symbol Reverse Working Voltage VRWM Breakdown Voltage VBR Reverse Leakage Current IR Clamping Voltage VC Clamping Voltage VC Junction Capacitance CJ Min Typ Max Unit 24 V 26.7 1 43 52 80 Test Condition V IT = 1mA uA VRWM = 24V V IPP = 1A (8 x 20uS pulse) V IPP =7A (8 x 20uS pulse) pF VR = 0V, f = 1MHz SD36 Parameter Symbol Reverse Working Voltage VRWM Breakdown Voltage VBR Reverse Leakage Current IR Clamping Voltage VC Clamping Voltage VC Junction Capacitance CJ Rev.C_Aug,2018 Min Typ Max Unit 36 V 40 1 60 75 60 -5- Test Condition V IT = 1mA uA VRWM =40V V IPP = 1A (8 x 20uS pulse) V IPP = 5A (8 x 20uS pulse) pF VR = 0V, f = 1MHz www.wpmtek.com SDXX Integrated in OVP&OCP products provider 3.3V~36V Unidirectional TVS Diode Typical Performance Characteristics (TA=25°C unless otherwise Specified) Rev.C_Aug,2018 -6- www.wpmtek.com SDXX Integrated in OVP&OCP products provider 3.3V~36V Unidirectional TVS Diode Soldering parameters Pb-Free assembly (see FIG.2) Reflow Condition Pre Heat -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow -Temperature(TL) (Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Rev.C_Aug,2018 -7- www.wpmtek.com SDXX Integrated in OVP&OCP products provider 3.3V~36V Unidirectional TVS Diode Package Mechanical Data (SOD-323) Suggested Land Pattern Contact Information WPMTEK Incorporated Limited Room 207,2nd Floor, Block 3,Minxing lndustry Park, Minzhi, Longhua New District, Shenzhen, PRC. TEL:86755-29308003 FAX:86755-23739900 Wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.C_Aug,2018 -8- www.wpmtek.com
很抱歉,暂时无法提供与“SD08”相匹配的价格&库存,您可以联系我们找货
SD08
  • 1+0.10500
  • 100+0.09800
  • 300+0.09100
  • 500+0.08400
  • 2000+0.08050
  • 5000+0.07840
