SD15C
SD15C
    WPMTEK(维攀微)
    SOD-323
    SOD323 SMT 350W 15V
SD15C 数据手册
SDXXC Integrated in OVP&OCP products 3.3V~36V Ultra Low Capacitance Bi-directional TVS Diode provider Description Mechanical Characteristics The SDXXC is designed to replace multilayer varistors (MLVs) in portable applications such as cell phones, n Package: SOD-323 notebook computers and PDA’s, using monolithic silicon n technology to provide fast response time and ultra low Lead Finish: Matte Tin n Case Material: “Green” Molding Compound. n UL Flammability Classification Rating 94V-0 components from damage. The SDXXC complies with the n Moisture Sensitivity: Level 3 per J-STD-020 IEC 61000- 4-2 (ESD) standard with ±30kV air and ±30kV n Terminal Connections: See Diagram Below contact discharge. The SDXXC is assembled into a lead- n Marking Information: See Below ESD clamping voltage, making this device an ideal solution for protecting sensitive semiconductor free SOD- 323 package and will protect one unidirectional Applications line. These devices will fit on the same PCB pad area as an 0805 MLV device. Features n 350W peak pulse power (8/20us) n Protects one data or power line n Ultra low leakage: nA level n Stand−off Voltage: 3.3 V ~ 36 V n Ultra low clamping voltage n Complies with following standards: n Cellular Handsets and Accessories n Personal Digital Assistants n Notebooks and Handhelds n Portable Instrumentation n Peripherals n Pagers Peripherals n Desktop and Servers Marking information – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Contact discharge: ±8kV n IEC61000-4-4 (EFT) 40A (5/50ns) n RoHS Compliant Details marking code reference customer approval list Dimensions & Symbol(Unit: mm Max) Ordering Information Part Number SD03C SD05C SD08C SD12C SD15C SD18C SD24C SD36C Rev.C_29, Mar,2019 -1- Packaging 3000/Tape & Reel 3000/Tape & Reel 3000/Tape & Reel 3000/Tape & Reel 3000/Tape & Reel 3000/Tape & Reel 3000/Tape & Reel 3000/Tape & Reel Reel Size 7 inch 7 inch 7 inch 7 inch 7 inch 7 inch 7 inch 7 inch www.wpmtek.com SDXXC Integrated in OVP&OCP products 3.3V~36V Ultra Low Capacitance Bi-directional TVS Diode provider Absolute Maximum Ratings (TA=25°C unless otherwise specified) PARAMETER SYMBOL VALUE UNITS Peak Pulse Power (t p= 8/20µs) PPP 350 Watts Operating Temperature TJ -55°C to 125°C °C TSTG -55°C to 150°C °C Storage Temperature Electrical Characteristics (TA = 25 °C unless otherwise noted) VRWM VB IT VC@1A VC IR CT (V) (V) (mA) (V) (V) (µA) (pF) (max.) (min.) SD03C 3.3 4.0 SD05C 5.0 SD08C PART NUMBER (max.) (max.) (@A) (max.) (max.) 1 7.5 16.0 20 40 450 6.0 1 9.8 18.0 17 10 200 8.0 8.5 1 13.4 24.0 15 2 120 SD12C 12.0 13.3 1 19.0 32.0 11 1 75 SD15C 15.0 16.7 1 24.0 38.0 10 1 68 SD18C 18.0 20.0 1 29.0 45.0 9 1 57 SD20C 20.0 22.3 1 35.0 50.0 8 1 52 SD24C 24.0 26.7 1 43.0 52.0 7 1 50 SD36C 36.0 40.0 1 60.0 75.0 4.5 1 35 !"#$!&/1 * Mar*/0'1 -2- www.wpmtek.com SDXXC Integrated in OVP&OCP products 3.3V~36V Ultra Low Capacitance Bi-directional TVS Diode provider Typical Performance Characteristics (TA=25°C unless otherwise Specified) !"#$!&/1 * Mar*/0'1 -3- www.wpmtek.com SDXXC Integrated in OVP&OCP products 3.3V~36V Ultra Low Capacitance Bi-directional TVS Diode provider Soldering parameters Pb-Free assembly (see FIG.2) Reflow Condition Pre Heat -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow -Temperature(TL) (Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ !"#$!&/1 *Mar*/0'1 -4- www.wpmtek.com SDXXC Integrated in OVP&OCP products 3.3V~36V Ultra Low Capacitance Bi-directional TVS Diode provider Package mechanical data (mm/inch) Suggested Land Pattern Contact information WPMTEK Incorporated Limited Room 206-207,2nd Floor,Block 3,Minxing lndustry Park,Minzhi Longhua New District,Shenzhen TEL:86755-29308003 FAX:86755-23739900 WPMtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. !"#$!&/1 * Mar*/0'1 -5- www.wpmtek.com
SD15C 价格&库存
很抱歉,暂时无法提供与“SD15C”相匹配的价格&库存,您可以联系我们找货
SD15C
    • 1+0.13800
    • 100+0.12880
    • 300+0.11960
    • 500+0.11040
    • 2000+0.10580
    • 5000+0.10304
