SRV05-4LC
SRV05-4LC
    WPMTEK(维攀微)
    SOT23-6
    ESD抑制器/TVS二极管 SOT23-6 25V 12A
SRV05-4LC 数据手册
SRV05-4LC Integrated in OVP&OCP products provider 4-Line Low Capacitance TVS Diode Array Description Mechanical Characteristics The SRV05-4LC is a low capacitance TVS array, utilizing leading monolithic silicon technology to provide fast response time and low ESD clamping voltage, making this device an ideal solution for protecting voltage sensitive high-speed data lines. The SRV05-4LC complies with the IEC 61000-4-2 (ESD) standard with ±30kV air and ±30kV contact discharge. It is assembled into a 6-lead SOT23-6 lead-free package. The leads are finished with lead-free matte tin. Each device will protect up to four high-speed  Package: SOT23-6  Lead Finish: Matte Tin  Case Material: “Green” Molding Compound.  UL Flammability Classification Rating 94V-0  Moisture Sensitivity: Level 3 per J-STD-020  Terminal Connections: See Diagram Below  Marking Information: See Below Applications lines. The combination of small size, low capacitance, and high surge capability makes them ideal for use in applications such as 10/100 Ethernet, USB 2.0, and video  USB 2.0 and power line interfaces.  USB OTG  Monitor and Flat Panel Displays  Set-top box and digital TV Features  Ultra low capacitance: 1.5 pF typical (I/O to I/O)  Gigabit Ethernet  Ultra low leakage: nA level  IEEE 1394 Firewire Ports  Working voltage: 5V Low clamping voltage   SIM Ports  Up to 4 data lines and one power line protects  Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Marking information Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-5 (Lightning) 12A (8/20µs)  RoHS Compliant Dimensions & Symbol(Unit: mm Max) Dot denotes Pin1 Details marking code reference customer approval list Ordering Information Part Number SRV05-4LC Packaging 3000/Tape & Reel Reel Size 7 inch Circuit Diagram & Pin Schematic Rev.A_Aug,2016 -1- www.wpmtek.com SRV05-4LC Integrated in OVP&OCP products provider 4-Line Low Capacitance TVS Diode Array Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 300 W Peak Pulse Current (8/20µs) Ipp 12 A ESD per IEC 61000−4−2 (Air) ±30 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range kV ±30 TJ −55 to +125 °C Tstg −55 to +150 °C Electrical Characteristics (TA=25°C unless otherwise specified) Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR Max Unit 5 V Pin 5 to Pin 2 V IT = 1mA, Pin 5 to Pin 2 6 Test Condition Reverse Leakage Current IR 0.2 µA VRWM = 5V, Pin 5 to Pin 2 Forward Voltage VF 1.2 V IF = 15mA Clamping Voltage VC 10 V IPP = 1A (8 x 20µs pulse), any I/O pin to ground Clamping Voltage VC 25 V IPP = 12A (8 x 20µs pulse), any I/ O pin to ground Junction Capacitance CJ 1.5 pF VR = 0V, f = 1MHz, between I/O pins Junction Capacitance CJ 3.0 pF VR = 0V, f = 1MHz, any I/O pin to ground Note 1: I/O pins are Pin 1, 3, 4 and 6 Rev.A_Aug,2016 -2- www.wpmtek.com SRV05-4LC Integrated in OVP&OCP products provider 4-Line Low Capacitance TVS Diode Array Typical Performance Characteristics (TA=25°C unless otherwise Specified) Junction Capacitance_Cj (pF) 5 4 Line to GND 3 2 Line to Line 1 0 0 1 2 3 4 Reverse Voltage_VR (V) 5 Peak Pulse Power vs. Pulse Time 30 120 25 100 % of Rated Power Clamping Voltage_Vc (V) Junction Capacitance vs. Reverse Voltage 20 15 10 5 80 60 40 20 0 0 3 6 9 12 Peak Pulse Current_Ipp (A) 0 15 0 25 50 75 100 125 Ambient Temperature_Ta(℃) Power Derating Curve Clamping Voltage vs. Peak Pulse Current 100 90 80 70 60 50 40 30 20 10 0 300 250 Voltage (V) % of Peak Pulse Current 150 TA = 25OC Corrected for 20dB attenuator 1M Ohm Scope input impedance 200 150 100 50 0 0 20 40 60 -50 -20 80 0 20 Time (nS) 40 60 80 Time_t(μs) 8 X 20μs Pulse Waveform ESD Clamping Voltage 8 kV Contact per IEC61000−4−2 Rev.A_Aug,2016 -3- www.wpmtek.com SRV05-4LC Integrated in OVP&OCP products provider 4-Line Low Capacitance TVS Diode Array Soldering parameters Pb-Free assembly (see FIG.2) Reflow Condition Pre Heat -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max Reflow -Temperature(TL) (Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp (tp) 30 secs. Max Ramp-down Rate 6℃/sec. Max Time 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Rev.A_Aug,2016 -4- www.wpmtek.com SRV05-4LC Integrated in OVP&OCP products provider 4-Line Low Capacitance TVS Diode Array Package mechanical data Suggested Land Pattern Contact information WPMTEK Incorporated Limited Floor 1 Building 4#, Binxianghua Industry Park, No.7, Huada Road, Hualian Community, Longhua New District, Shenzhen TEL:86755-29308003 FAX:86755-23739900 wpmtek Incorporated Limited (WPM) reserves the right to make changes to the product specification and data in this document without notice. WPM makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does WPM assume any liability arising from the application or use of any products or circuits, and specifically dis- claims any and all liability, including without limitation special, consequential or incidental damages. Rev.A_Aug,2016 -5- www.wpmtek.com
SRV05-4LC 价格&库存
很抱歉,暂时无法提供与“SRV05-4LC”相匹配的价格&库存,您可以联系我们找货
