MT-4617
MT-4617
    PRO'SKIT(宝工)
    Tool
    宝工(Pro'skit)MT-4617
MT-4617 数据手册
MT-4617LED LED Light Intensity Meter User’s Manual 1st Edition, 2020 © 2020 Prokit’s Industries Co., Ltd Introduction Thank you for your purchase of the MT-4617LED Light Intensity Meter designed and manufactured by our company. This meter will with proper use, provide years of reliable service; therefore, it is recommended that the user read carefully the user manual before using the light meter and keep it in right place for reference. Open-package inspection Upon receipt of the light meter, inspect it to ensure no damage happened during shipping. If the user finds obvious damage or malfunction in operation, please contact the supplier. Safety information Warning Do not use the light meter in the environment full of dusts or having gas substances and flammable steam substances! Safety mark description This manual contains basic information for MT-4617LED safety operation and maintenance. Please read carefully following safety information before use. Table 1: Safety information Important information which the user must read before using the light meter Mark of conformity Table 2: Warning message Warning It indicates that incorrect operation will lead to serious injury or even fatal accidents Notice It indicates that incorrect operation or negligence will lead to meter damage or wrong measurement results, etc. Tips Operation suggestions or prompts 1 Operation considerations User should observe the following notices to guarantee safe operation and obtain optimum performance. Preliminary check Before initial use, please check if the light meter operates normally and if it is damaged during storage and transportation. In case of any damage, please contact the supplier. Placement Operation -10~50℃ (14~122°F) environment 20000Lux—>200000Lux(或 20.00Fc—>200.0 Fc—>2000 Fc—>20000 Fc)迴圈; ‧ ‧ 27 20.00Lux 文件界 面 200.0Lux 文 2000Lux 文件 件界面 界面 20000Lux 文件界 3. 200000Lux 長按 RAN面 鍵 1 秒,LCD 左上方的“MANU”字樣熄滅,LCD 左上角顯示 “AUTO”字樣,退出手動切換量程功能,返回自動切換量程; 档界面 提示 在峰值測量、相對值測量和最大最小值查詢模式下短按 RAN 鍵方有效。 在相對值測量模式和最大最小值查詢模式下長按該鍵 1 秒, 則返回自動切換量 程。 3. 在峰值測量模式、資料保持模式和零點校準模式下長按 RAN 鍵無效。 4. 在此模式中,當測量值超過當前量程時,LCD 顯示“OL”,提示超量程。此 時用戶應切換測量量程; 相對值與峰值測量模式應用 1. 短按 REL/PEAK 鍵(相對值測量、峰值測量複合鍵),LCD 介面左上方顯示 “REL”字樣(如下圖 3-1-2A 所示),進入相對值測量模式; 2. 再次短按 REL/PEAK 鍵則退出相對值測量模式,LCD 介面左上方“REL”字樣 熄滅,返回原來的測量模式; 1. 2. 28 3. 4. 長按“REL/PEAK”鍵 1 秒,進入峰值測量模式,LCD 介面右上方顯示“PEAK” 字樣,同時 LCD 左上方顯示“MENU”字樣(如圖 3-1-2B 所示); 再次長按該鍵 1 秒,LCD 右上方的“PEAK”字樣熄滅,LCD 左上方顯示 “AUTO”字樣,返回自動測量模式(如圖 3-1-2C 所示)。 圖 3-1-2A 圖 3-1-2B 圖 3-1-2C 提示 在自動測量模式、峰值測量模式、最大最小值查詢模式和資料保持模式下短 按 REL/PEAK 鍵方有效。 2. 在非零點校準模式下長按“REL/PEAK”鍵 1 秒,均能進入峰值測量模式。 最大最小值查詢模式應用 1. 短按“MAX/MIN/LS”鍵,LCD 正上方顯示“MAX”字樣(如圖 3-1-3 所示), 進入最大最小值查詢模式; 2. 最大最小值查詢模式下,每次短按“MAX/MIN”鍵,則按 MAXMIN 迴圈 切換; 3. 長按“MAX/MIN”鍵 1 秒,LCD 介面正上方的“MAX/MIN”字樣消失,退出 最大最小值查詢模式。 1. 图 3-1-3 29 提示 在非零點校準模式下,短按 MAX/MIN”鍵均有效,都可進行最大最小值查詢功能; 資料保持與零點校準模式應用 1. 短按“HOLD/ZERO”鍵,LCD 介面右上方上方顯示“HOLD”字樣(如圖 3-1-4A 所示) ,進入資料保持模式; 2. 再次短按該鍵,LCD 介面左上方的“HOLD”字樣消失,退出資料保持模式; 3. 將光感測器保護蓋蓋住光感測器,長按“HOLD/ZERO”鍵 1 秒,LCD 介面顯 示“ADJ”字樣(如圖 3-1-4B 所示) ,進入零點校準模式,幾秒後 LCD 介面顯 示的“ADJ”字樣消失,自動退出零點校準模式,返回自動測量模式。 圖 3-1-4A 圖 3-1-4B 注意 在零點校準前,一定要將光感測器保護蓋蓋住光感測器,方可進行。 提示 在非零點校準模式下,短按“HOLD/ZERO”鍵均有效,都可進入資料保持模 式。 2. 在任何模式下都可進行零點校準。 光源選擇模式應用 1. 光源選擇: 長按“MAX/MIN/L.S.”鍵 1 秒,LCD 介面的“L.S.LN”字元跳動表示進入光 源選擇模式,此時短按“MAX/MIN/L.S.”或“Lx/Fc”鍵,則光源在 L0 到 L9 之間變化,按"HOLD/ZERO"鍵確定,進入正常測量模式;即可進行測量。 2. 光源參數設定: 2.1. 長按“MAX/MIN/L.S.”鍵 1 秒,LCD 介面的“L.S.LN”字樣的“N”字元 跳動表示進入光源選擇模式,此時短按“MAX/MIN/L.S.”或“Lx/Fc” 鍵,則光源在 L0 到 L9 之間變化;選擇需要設置的光源代碼 L0~L9 2.2. 短按“RAN”鍵,則“N”字元停止跳動,參數值跳動,表示進入參數設 置模式,此時短按“MAX/MIN/L.S.”或者“Lx/Fc/CD”鍵可以改變參數 值; 2.3. 再短按“RAN”鍵,則進入光源選擇模式,“N”字元跳動,參數值不跳 動,依次來回切換; 2.4. 長按“MAX/MIN/L.S.”鍵 1 秒,則保存設置完的光源參數值進入正常測 量模式; 1. 30 3. 光源參數預設值: L0—>標準光源 A:1.000 L1—>LED 白色光:0.990 L2—>LED 紅色光:0.516 L3—>LED 琥珀色(黃色)光:0.815 L4—>LED 綠色光:1.216 L5—>LED 藍色光:1.475 L6—>LED 紫色光:1.148 L7--L9—>默認標準光源 A:1.000 (建議:如需要修改光源參數最好選擇 L7~L9 參數修改) 其他功能 靜音功能 短按電源/按鍵音複合銨鈕開啟或關閉按鍵音。 自動關機功能 在 10 分鐘內無任何操作,儀錶將自動關機。 技術資料 1. 溫度範圍: 工作:-10~50 ℃,最大 80 %的相對濕度(非凝結)。 儲存:-10~50 ℃,最大 80 %的相對濕度(非凝結)(取掉電池)。 2. 採樣速率:≥2 次/秒。 3. 顯示幕:3½ 位元,最大讀數 1999,帶類比條顯示; 4. 感測器: 矽光電二極體 5. 測量光譜範圍:320~730nm 6. 測量範圍:20、200、2000、20000、200000 Lux 20、200、2000、20000 FC 7. 使用環境:室內使用 8. 海拔: 最高 2000m 9. 電池壽命:大約 200 小時 10. 電源:1×9 V,IEC 6LR61 11. 尺寸(高×寬×深) :170 mm×85 mm×45 mm 12. 精度:±3%(在 2854K 時依照普通白熾燈校準),±6% 其他可見光光源 31 余弦角度 余弦角度偏差特性 誤差 30° ±2% 60° ±6% 注:余弦角度依照 JIS C 1609:1993 和 CNS 5119 A 級通用規範修正。 光靈敏度特性: Relative Sensitivity (%) 100 80 60 40 20 400 500 600 700 800 900 1000 Wave Length (nm) 維護和維修 維修 注意 如果儀錶在使用過程中似乎存在故障,應執行下列步驟確定問題的根源: 1. 2. 3. 檢查電池。當液晶顯示幕上出現“ ” 符號時應立即更換電池。 查閱操作說明確定操作步驟是否有誤。 儀錶的維修必須由經廠家授權的服務中心或其他具備資格的儀器維修人員承 擔。 清潔 先用沾有清水或中性清潔劑的軟布擦拭探測儀,最後用幹布擦幹。 注意 在進行清潔工作之前,請您確保設備已經關機。 在清潔工作中,請勿使用苯類,酒精,丙酮,乙醚,酮,稀釋劑,汽油等,這 些會造成設備變形或退色。 3. 在清潔之後要等到設備完全乾燥之後,方可繼續使用。 更換電池 如果顯示幕上出現電池符號閃爍(LCD 介面⑨)則必須更換電池。更換電池步驟如 下: 1. 將儀錶關機; 2. 擰儀錶備背面的螺釘,揭開儀錶的電池格蓋罩; 1. 2. 32 3. 4. 取出耗盡的電池; 按照正確的極性安裝新的電池; 注意 1. 在更換電池之前,必須將儀錶關機。 2. 只能夠使用在技術資料中指定的電池。 3. 如果在較長時期內不使用儀錶,則要將其中的電池取出來。 4. 在處理廢舊電池時,必須遵照現行的關於電池回收、再利用和處理的規定。 各種場所照度標準參考表 將 Lux 照度值除以 10.764,即可求得 Fc 照度值。 學校: 照度(Lux) 場所 1500~300 製圖教室、縫紉教室、電腦教室 750~200 教室、實驗室、實習工廠、研究室、圖書閱覽室、書庫、辦公 室、教職員休息室、會議室、保健室、餐廳、廚房、配膳室、 廣播室、印刷室、總機室、守衛室、室內運動場 300~150 大教室、禮堂、貯櫃室、休息室、樓梯間 150~75 走廊、電梯走道、廁所、值班室、工友室、天橋、校內室外運 動場 75~30 倉庫、車庫、安全梯 事務所: 照度(Lux) 2000~1500 1500~750 750~300 300~150 150~75 75~30 場所 設計室、事務室 大廳通道(白天)、營業室、製圖室、打卡、打字 計算器室、會議室、印刷室、總機室、控制室、招待室、娛樂室、 餐廳 書庫、娛樂室、餐廳教室、休息室、警衛室、電梯(走道)、盥洗室、 廁所 喝茶室、更衣室、倉庫、值夜室(入口處) 太平梯 33 工廠: 照度(Lux) 3000~1500 1500~750 750~300 300~150 150~75 75~30 醫院: 照度(Lux) 10000~5000 1500~750 750~300 300~150 150~75 75~30 理髮院: 照度(Lux) 1500~750 750~300 300~150 150~75 場所 超精密作業、設計、製圖、精密檢查 設計室、分析、組立線、塗裝 包裝、計量、表面處理、倉庫辦公室 染色、鑄造、電氣室 進出口、走廊、通道、樓梯、化粧室、廁所、附作業場倉庫 太平梯、倉庫、屋外動力設備(裝卸貨、存貨移動作業) 場所 視機能檢查室(眼科明室) 開刀房 診療室、治療室、制藥室、配藥室、藥局室、解剖室、病理細菌 室、急救室、產房、院長室、辦公室、護士室、會議室 病房、藥品室、病床看書、換藥、骨折石膏包紮、嬰房、紀錄室、 候診室、會診室、門診走廊 更衣室、物療室、X 光室、病房走廊、藥品室、滅菌室、病房室、 樓梯、內視鏡室 動物室、暗室(照片)、太平梯 場所 剪燙髮、染整發、化妝 修臉、洗髮、前廳掛號台、整裝 店內廁所 走廊、樓梯 旅館、飯店、娛樂場: 照度(Lux) 場所 1500~750 櫃檯 750~300 玄關、宴會場、事務室、停車處、廚房 300~150 餐廳、洗手間、日式大房間 150~75 娛樂室、走廊、樓梯、客房、浴室、庭院重點照明、更衣室 75~30 太平梯 34 商店、百貨店: 照度(Lux) 場所 3000~750 室內陳列、飾窗陳列、示範表演場所、結帳櫃檯、包裝台 750~300 電梯大廳、電扶梯 300~150 商談室、化粧室、廁所、樓梯、走道 150~75 休息室、店內一般照明 住家: 照度(Lux) 2000~750 1000~500 750~300 300~150 150~70 75~30 場所 手工藝、裁縫 寫作、作業 讀書、化妝、廚桌、調理、電話 洗水槽、娛樂室、客廳、團聚、玄關(內側)鏡子 衣櫃、寢室、廁所、樓梯、走廊 門牌、信箱、門鈴鈕、陽臺 35 MT-4617LED-C LED 照度计使用说明书 声明 根据国际版权法,未经允许和书面同意,不得以任何形式复制本说明书的任何内容。 本说明书在将来的版本中如有更改,恕不另行通知。 安全声明 小心或注意 “小心”或”注意”标志表示会对仪表或设备造成损坏的状况和操作。 它要求在执行此操作时必须小心,如果不正确执行此操作或不遵循此操作步骤,则 可能导致仪表或设备损坏。在不满足这些条件或没有完全理解的情况下,请勿继续 执行小心标志所指示的任何操作。 警告 “警告”标志表示会对用户造成危险的状况和操作。 它要求在执行此操作时必须注意,如果不正确执此行操作或不遵守此操作步骤,则 可能导致人身伤害或伤亡。在不满足这些条件或没有完全理解的情况下,请勿继续 执行警告标志所指示的任何操作。 安全信息 警告 请勿在存在爆炸性气体物质、可燃蒸汽物质及充满粉尘的环境中使用本仪表! 安全符号说明 本说明书包含安全操作和维护的基本要素。使用前,请仔细阅读下面的安全信息。 表 1:安全信息 用户在使用前必须阅读的重要信息 符合欧盟 CE 安全规范 表 2:警告信息 警告 表明错误的操作将导致严重的伤害甚至死亡事故发生 注意 表明错误的操作或疏忽将导致仪表损坏或测量结果错 误等 提示 操作建议或提示 36 操作注意事项 遵从以下注意事项,确保安全操作和获得最佳的性能。 1. 首次使用前,请检查照度计是否工作正常,确认在存储和运输期间没有受到 损坏。 2. 使用环境:温度-10°C~50°C;湿度2000Lux—>20000Lux—>200000Lux(或 20.00Fc—>200.0 Fc—>2000 Fc—>20000 Fc)循环; ‧ ‧ 41 20.00Lux 文件界 面 200.0Lux 文 2000Lux 文件 件界面 界面 20000Lux 文件界 3. 200000Lux 长按 RAN面 键 1 秒,LCD 左上方的“MANU”字样熄灭,LCD 左上角显示 “AUTO”字样,退出手动切换量程功能,返回自动切换量程; 档界面 提示 在峰值测量、相对值测量和最大最小值查询模式下短按 RAN 键方有效。 在相对值测量模式和最大最小值查询模式下长按该键 1 秒, 则返回自动切换量 程。 7. 在峰值测量模式、数据保持模式和零点校准模式下长按 RAN 键无效。 8. 在此模式中,当测量值超过当前量程时,LCD 显示“OL”,提示超量程。此 时用户应切换测量量程; 相对值与峰值测量模式应用 1. 短按 REL/PEAK 键(相对值测量、峰值测量组合键) ,LCD 接口左上方显示 “REL”字样(如下图 3-1-2A 所示),进入相对值测量模式; 2. 再次短按 REL/PEAK 键则退出相对值测量模式,LCD 接口左上方“REL”字样 5. 6. 42 3. 4. 熄灭,返回原来的测量模式; 长按“REL/PEAK”键 1 秒,进入峰值测量模式,LCD 接口右上方显示“PEAK” 字样,同时 LCD 左上方显示“MENU”字样(如图 3-1-2B 所示); 再次长按该键 1 秒,LCD 右上方的“PEAK”字样熄灭,LCD 左上方显示 “AUTO”字样,返回自动测量模式(如图 3-1-2C 所示)。 图 3-1-2A 圖 3-1-2B 圖 3-1-2C 提示 在自动测量模式、峰值测量模式、最大最小值查询模式和数据保持模式下短 按 REL/PEAK 键方有效。 2. 在非零点校准模式下长按“REL/PEAK”键 1 秒,均能进入峰值测量模式。 最大最小值查询模式应用 1. 短按“MAX/MIN/LS”键,LCD 正上方显示“MAX”字样(如图 3-1-3 所示) , 进入最大最小值查询模式; 2. 最大最小值查询模式下,每次短按“MAX/MIN”键,则按 MAXMIN 循环 切换; 3. 长按“MAX/MIN”键 1 秒,LCD 界面正上方的“MAX/MIN”字样消失,退出 最大最小值查询模式。 1. 图 3-1-3 43 提示 在非零点校准模式下,短按 MAX/MIN”键均有效,都可进行最大最小值查询功能; 数据保持与零点校准模式应用 1. 短按“HOLD/ZERO”键,LCD 接口右上方上方显示“HOLD”字样(如图 3-1-4A 所示) ,进入数据保持模式; 2. 再次短按该键,LCD 接口左上方的“HOLD”字样消失,退出数据保持模式; 3. 将光传感器保护盖盖住光传感器,长按“HOLD/ZERO”键 1 秒,LCD 接口显 示“ADJ”字样(如图 3-1-4B 所示),进入零点校准模式,几秒后 LCD 接口显 示的“ADJ”字样消失,自动退出零点校准模式,返回自动测量模式。 图 3-1-4B 图 3-1-4A 注意 在零点校准前,一定要将光传感器保护盖盖住光传感器,方可进行。 提示 1. 在非零点校准模式下,短按“HOLD/ZERO”键均有效,都可进入数据保持模 式。 2. 在任何模式下都可进行零点校准。 光源选择模式应用 1. 光源选择: 长按“MAX/MIN/L.S.”键 1 秒,LCD 界面的“L.S.LN”字符跳动表示进入光 源选择模式,此时短按“MAX/MIN/L.S.”或“Lx/Fc”键,则光源在 L0 到 L9 之间变化,按"HOLD/ZERO"键确定,进入正常测量模式;即可进行测量。 2. 光源参数设定: 2.1. 长按“MAX/MIN/L.S.”键 1 秒,LCD 界面的“L.S.LN”字样的“N”字符 跳动表示进入光源选择模式,此时短按“MAX/MIN/L.S.”或“Lx/Fc”键, 则光源在 L0 到 L9 之间变化;选择需要设置的光源代码 L0~L9 2.2. 短按“RAN”键,则“N”字符停止跳动,参数值跳动,表示进入参数 设置模式,此时短按“MAX/MIN/L.S.”或者“Lx/Fc/CD”键可以改变参数 值; 2.3. 再短按“RAN”键,则进入光源选择模式,“N”字符跳动,参数值不 跳动,依次来回切换; 2.4. 长按“MAX/MIN/L.S.”键 1 秒,则保存设置完的光源参数值进入正常 测量模式; 44 光源参数默认值: L0—>标准光源 A:1.000 L1—>LED 白色光:0.990 L2—>LED 红色光:0.516 L3—>LED 琥珀色(黄色)光:0.815 L4—>LED 绿色光:1.216 L5—>LED 蓝色光:1.475 L6—>LED 紫色光:1.148 L7--L9—>默认标准光源 A:1.000 (建议:如需要修改光源参数最好选择 L7~L9 参数修改) 3. 其他功能 静音功能 短按电源/按键音复合铵钮开启或关闭按键音。 自动关机功能 在 10 分钟内无任何操作,仪表将自动关机。 技术数据 1. 温度范围: 工作:-10~50 ℃,最大 80 %的相对湿度(非凝结) 。 储存:-10~50 ℃,最大 80 %的相对湿度(非凝结)(取掉电池)。 2. 采样速率:≥2 次/秒。 3. 显示屏:3½ 位,最大读数 1999,带模拟条显示; 4. 传感器: 硅光电二极管 5. 测量光谱范围:320~730nm 6. 测量范围:20、200、2000、20000、200000 Lux / 20、200、2000、20000 FC 7. 使用环境:室内使用 8. 海拔: 最高 2000m 9. 电池寿命:大约 200 小时 10. 电源:1×9 V,IEC 6LR61 11. 尺寸(高×宽×深) :170 mm×85 mm×45 mm 12. 精度:±3%(在 2854K 时依照普通白炽灯校准),±6% 其他可见光光源 45 余弦角度 30° 余弦角度偏差特性 误差 ±2% 60° ±6% 注:余弦角度依照 JIS C 1609:1993 和 CNS 5119 A 级通用规范修正。 光灵敏度特性: Relative Sensitivity (%) 100 80 60 40 20 400 500 600 700 800 900 1000 Wave Length (nm) 维护和维修 维修 注意 如果仪表在使用过程中似乎存在故障,应执行下列步骤确定问题的根源: 1. 2. 3. 检查电池。当液晶显示屏上出现“ ” 符号时应立即更换电池。 查阅操作说明确定操作步骤是否有误。 仪表的维修必须由经厂家授权的服务中心或其他具备资格的仪器维修人员承 担。 清洁 先用沾有清水或中性清洁剂的软布擦拭探测仪,最后用干布擦干。 注意 在进行清洁工作之前,请您确保设备已经关机。 在清洁工作中,请勿使用苯类,酒精,丙酮,乙醚,酮,稀释剂,汽油等,这 些会造成设备变形或退色。 3. 在清洁之后要等到设备完全干燥之后,方可继续使用。 更换电池 如果显示屏上出现电池符号闪烁(LCD 接口⑨)则必须更换电池。更换电池步骤如 下: 1. 将仪表关机; 2. 拧仪表备背面的螺钉,揭开仪表的电池格盖罩; 1. 2. 46 3. 4. 取出耗尽的电池; 按照正确的极性安装新的电池; 注意 1. 在更换电池之前,必须将仪表关机。 2. 只能够使用在技术数据中指定的电池。 3. 如果在较长时期内不使用仪表,则要将其中的电池取出来。 4. 在处理废旧电池时,必须遵照现行的关于电池回收、再利用和处理的规定。 各种场所照度标准参考表 将 Lux 照度值除以 10.764,即可求得 Fc 照度值。 学校: 照度(Lux) 场所 1500~300 制图教室、缝纫教室、计算机教室 750~200 教室、实验室、实习工厂、研究室、图书阅览室、书库、办公 室、教职员休息室、会议室、保健室、餐厅、厨房、配膳室、 广播室、印刷室、总机室、守卫室、室内运动场 300~150 大教室、礼堂、贮柜室、休息室、楼梯间 150~75 走廊、电梯走道、厕所、值班室、工友室、天桥、校内室外运 动场 75~30 仓库、车库、安全梯 事务所: 照度(Lux) 2000~1500 1500~750 750~300 300~150 150~75 75~30 场所 设计室、事务室 大厅通道(白天)、营业室、制图室、打卡、打字 计算器室、会议室、印刷室、总机室、控制室、招待室、娱乐室、 餐厅 书库、娱乐室、餐厅教室、休息室、警卫室、电梯(走道)、盥洗室、 厕所 喝茶室、更衣室、仓库、值夜室(入口处) 太平梯 47 工厂: 照度(Lux) 3000~1500 1500~750 750~300 300~150 150~75 75~30 医院: 照度(Lux) 10000~5000 1500~750 750~300 300~150 150~75 75~30 理发院: 照度(Lux) 1500~750 750~300 300~150 150~75 场所 超精密作业、设计、制图、精密检查 设计室、分析、组立线、涂装 包装、计量、表面处理、仓库办公室 染色、铸造、电气室 进出口、走廊、通道、楼梯、化妆室、厕所、附作业场仓库 太平梯、仓库、屋外动力设备(装卸货、存货移动作业) 场所 视机能检查室(眼科明室) 开刀房 诊疗室、治疗室、制药室、配药室、药局室、解剖室、病理细菌 室、急救室、产房、院长室、办公室、护士室、会议室 病房、药品室、病床看书、换药、骨折石膏包扎、婴房、纪录室、 候诊室、会诊室、门诊走廊 更衣室、物疗室、X 光室、病房走廊、药品室、灭菌室、病房室、 楼梯、内视镜室 动物室、暗室(照片)、太平梯 场所 剪烫发、染整发、化妆 修脸、洗发、前厅挂号台、整装 店内厕所 走廊、楼梯 旅馆、饭店、娱乐场: 照度(Lux) 场所 1500~750 柜台 750~300 玄关、宴会场、事务室、停车处、厨房 300~150 餐厅、洗手间、日式大房间 150~75 娱乐室、走廊、楼梯、客房、浴室、庭院重点照明、更衣室 75~30 太平梯 48 商店、百货店: 照度(Lux) 场所 3000~750 室内陈列、饰窗陈列、示范表演场所、结账柜台、包装台 750~300 电梯大厅、电扶梯 300~150 商谈室、化妆室、厕所、楼梯、走道 150~75 休息室、店内一般照明 住家: 照度(Lux) 2000~750 1000~500 750~300 300~150 150~70 75~30 场所 手工艺、裁缝 写作、作业 读书、化妆、厨桌、调理、电话 洗水槽、娱乐室、客厅、团聚、玄关(内侧)镜子 衣柜、寝室、厕所、楼梯、走廊 门牌、信箱、门铃钮、阳台 49 中国地区产品保固卡 购买日期 店章 公司名称 联络电话 电子邮箱 联络地址 产品型号 □ MT-4617LED-C ※ 在正常使用情况下,自原购买日起 12 个月免费维修保证(不含耗材、消耗品) 。 ※ 产品保固卡需盖上店章、日期章,其保固效力始生效。 ※ 本卡请妥善保存,如需维修服务时,请出示本卡以为证明。 ※ 保固期满后,属调整、保养或是维修性质之服务,则酌收检修工时费用。若 有零件需更换,则零件费另计。 产品保固说明  保固期限内,如有下列情况者,维修中心则得酌收材料成本或修理费(由本公司 维修人员判定): • 对产品表面的损伤,包括外壳裂缝或刮痕 • 因误用、疏忽、不当安装或测试,未经授权打开产品修理,修改产品或者任 何其它超出预期使用范围的原因所造成的损害 • 因事故、火灾、电力变化、其它危害,或自然灾难所造成的损害。  非服务保证内容: • 机件本体外之消耗品:如电池...等消耗品 • 机件本体之外之附配件:如耳机麦克风,等附配件。  超过保证期限之检修或服务,虽未更换零件,将依公司保固维修政策酌收服务 费。 制造商 :宝工实业股份有限公司 地 址 :台湾新北市新店区民权路 130 巷 7 号 5 楼 电 话 :886-2-22183233 E-mail :pk@mail.prokits.com.tw 销售/生产商 :上海宝工工具有限公司 地址 :上海市浦东新区康桥东路 1365 弄 25 号 原产地 :中国.上海 服务热线 :021-68183050 50 寶工實業股份有限公司 PROKIT’S INDUSTRIES CO., LTD http://www.prokits.com.tw Email: pk@mail.prokits.com.tw © 2020 Prokit’s Industries Co., LTD. All rights reserved 2020001(C) 51
MT-4617 价格&库存
很抱歉,暂时无法提供与“MT-4617”相匹配的价格&库存,您可以联系我们找货
MT-4617
    • 1+224.24822
