HY-40R201C
HY-40R201C
    TTCIOTSDK(昇润)
    MODULE_25.16X15.22MM_SM
    WiFi及蓝牙模块 Original 2.4~3.3V -97dBm 陶瓷天线
HY-40R201C 数据手册
Level: Public Information HY-40R201 1 Bluetooth BLE 5.0 Module Specifications (40 pin) 11 Nov. 2017 Version:V2.2 Copyright © 2010-2017 7 SHENGRUN Technology Co., Ltd. All rights reserved. SHENGRUN Technologies assumes no responsibility for any errors which may appear in this manual, Furthermore, SHENGRUN Technologies reserves the right to alter the hardware, software, and/or specifications detailed here at any time wit without hout notice and does not make any commitment to update the information contained here. SHENGRUN’s SHENGRUN products are not authorized for use as critical components in life support devices or systems. SHENGRUN Technologies assumes no responsibility for any patents s or authorized the use of intellectual property rights. The Bluetooth trademark is owned by the Bluetooth SIG Inc., USA HY-40R201 40 pin module Version History Version V1.0 Revision Date 09/08/2017 Reviser Reviewer GKL LYC Revised Contents 1st issue 1. Added English address map. 2. Added ceramic antenna model and V2.0 17/10/2017 WF/ZLL LYC changed Model No. 3. Added application note 4. Added FCC ID No. 5. Changed document format. V2.1 25/10/2017 WF LYC V2.2 11/11/2017 WF LYC 1.Added RF Regurations pre-certified description; And Canada IC No. 1.Correct: 5. Pinout and GPIO function Description UART RX/TX GIO Port pin. HY-40R201 40 pin module CONTENTS 1. DESCRIPTION ........................................................................................................................................................1 1-1.APPLICATIONS: ........................................................................................................................................................... 1 1-2.KEY FEATURES: ........................................................................................................................................................... 1 2. PRODUCT MODEL NUMBER: HARDWARE MODEL DESCRIPTION ...........................................................2 2-1. (4 KINDS ANTENNA TYPE FOR CHOICE) ,(OPTION: WITH SHIELD CASE OR NO SHIELD CASE) ............................................................ 2 2-2: FCC ID &( IC ID/ WAIT DEFIND) PRINT FORMAT ON THE SHIELD CASE :( HY-40R201PC MODEL ONLY) ........................................ 2 3. PCBA DIMENSION SIZE AND PICTURE .............................................................................................................2 3-1: HY-40R201P / WMD40R201SR6P0( PCB IFAANTENNA) ............................................................................................... 2 &HY-40R201PC / WMD40R201SR6PC (PCB IFAANTENNA, WITH SHIELD CASE);....................................................................... 2 3-2:HY-40R201I / WMD40R201SR6I0(IPEX RF CONNECTOR TERMINAL) ................................................................................. 3 &HY-40R201IC / WMD40R201SR6IC (IPEX RF CONNECTOR WITH SHIELD CASE )....................................................................... 3 3-3: HY-40R201W / WMD40R201SR6W0( METAL WIREANTENNA)(1/4Λ HALF WAVE DIPOLE)_ ................................................. 3 &HY-40R201WC / WMD40R201SR6WC ( METAL WIRE ANTENNA, WITH SHIELD CASE) ; ......................................................... 3 3-4: HY-40R201C / WMD40R201SR6C0( CERAMICANTENNA) ............................................................................................... 3 &HY-40R201CC / WMD40R201SR6CC (CERAMIC ANTENNA, WITH SHIELD CASE) ; .................................................................. 3 4.APPLICATION NOTE: .............................................................................................................................................4 5. PINOUT AND GPIOFUNCTION DESCRIPTION .................................................................................................5 6. ELECTRICAL CHARACTERISTICS ......................................................................................................................6 6-1.RADIO PERFORMANCE & CURRENT CONSUMPTION ................................................................................................................ 7 6-2. ABSOLUTE MAXIMUM RATINGS ........................................................................................................................................ 7 6-3. ESD RATINGS ................................................................................................................................................................ 7 6-4. RECOMMENDED OPERATING CONDITIONS........................................................................................................................... 8 6-5.GPIODC CHARACTERISTICS .............................................................................................................................................. 8 6-6. TIMING REQUIREMENTS .................................................................................................................................................. 8 6-7. SWITCHING CHARACTERISTICS........................................................................................................................................... 9 7. BLOCK DIAGRAM ..................................................................................................................................................9 8. FUNCTIONAL BLOCK DIAGRAM .........................................................................................................................9 9. WORKING MODE SCHEMATIC .......................................................................................................................10 10. RECOMMEND REFLOW PROFILE( LEADLESS SOLDER CREAM: SN 96.5%, AG 3%, CU 0.5%) .........10 11.HY-40R201PC/WMD40R201SR6PC MODULE FCC/INDUSTRY CANADA STATEMENT ....................... 11 12.CONTACT US ......................................................................................................................................................13 HY-40R201 40 pin module 1. Description HY-40R201 Bluetooth low energy single mode module is a single mode device targeted for low power sensors and accessories. HY-40R201 offers all Bluetooth low energy features: radio, stack, profiles and application space for customer applications. The module also provides flexible hardware interfaces to connect sensors. HY-40R201 can be powered directly with a standard 3V coin cell batteries or pair of AAA batteries. in lowest power shutdown mode it consumes only 0.15uA and will wake up in few microseconds. HY-40R201 transmission distance of 100 meter or more. (At face to face, free space, 1.2 Meter high from Ground for testing). Bluetooth IC:TTC2640R2 6*6*0.9mm 48pin IC,Used TI CC2640R2 die chip 1-1.APPLICATIONS: Heart rate sensors Pedometers Watches Blood pressure and glucose meters Weight scales Key fobs Households sensors and collector devices Security tags Wireless keys (keyless go) Proximity sensors HID keyboards and mice Indoor GPS broadcasting devices 1-2.KEY FEATURES: Bluetooth v.5.0 single mode compliant Supports master,slaveand master/slave modes Integrated Bluetooth low energy stack GAP, GATT, L2CAP, SMP Bluetooth low energy profiles Pre-certified RF regurations for BQB BLE 5.0, CE ETSI RED, FCC, IC(Canada), (FCC and IC certified only for HY-40R201PC PCB antenna with shield case model); Another can Compliance for worldwide RF Regulations.  Transmit power :+5 dBm typical  Receiver sensitivity: -97dBm typical  Ultra low current consumption :Shutdown. No clocks running, no retention: 150 nA(Typical)  Programmable ARM Cortex-M3 processor for embedding full applications      1 /16 V1.0www.tuner168.com HY-40R201 40 pin module 2. Product model Number: Hardware Model Description 2-1. (4 kinds Antenna type for choice) ,(Option: with shield case or no shield case) Product Mode Item PCB NO. Description 1 WMD40R201SR6P0 HY-40R201P PCB Helix Antenna 2 WMD40R201SR6I0 HY-40R201I IPEX Connector for External Antenna 3 WMD40R201SR6W0 HY-40R201W Metal Wire Antenna(λ/4 Half wave dipole) 4 WMD40R201SR6C0 HY-40R201C Ceramic Antenna 6 WMD40R201SR6PC HY-40R201PC PCB Helix Antenna with shield case 5 WMD40R201SR6IC HY-40R201IC IPEX Connector for External Antenna with shield case 7 WMD40R201SR6WC HY-40R201WC Metal Wire Antenna with shield case 8 WMD40R201SR6CC HY-40R201CC CeramicAntenna with shield case 2-2: FCC ID &( IC ID/ wait defind) Print Format on the Shield Case :( HY-40R201PC model only) Model:HY-40R201PC FCC ID:2ADXE-HY-40R201PC IC : 23267-HY40R201PC Shield Case Size: 13.0*18.4*1.5mm Word Type: Calibri Direction: Horizon 3. PCBA dimension size and picture 3-1: HY-40R201P / WMD40R201SR6P0( PCB IFAAntenna) &HY-40R201PC / WMD40R201SR6PC (PCB IFAAntenna, with shield case); (PCBA dimension size : ( 25.16*15.22*2.0/2.6 mm ). 2 /16 V1.0www.tuner168.com HY-40R201 40 pin module 3-2:HY-40R201I / WMD40R201SR6I0(IPEX RF connector terminal) &HY-40R201IC / WMD40R201SR6IC (IPEX RF connector with shield case ) (PCBA dimension size : 25.16*15.22*2.6 mm). 3-3: HY-40R201W / WMD40R201SR6W0( Metal WireAntenna)(1/4λ half wave dipole)_ &HY-40R201WC / WMD40R201SR6WC ( Metal Wire Antenna, with shield case) ; (PCBA dimension size : 23.2*15.22*2.0/2.6 mm). 3-4: HY-40R201C / WMD40R201SR6C0( CeramicAntenna) &HY-40R201CC / WMD40R201SR6CC (Ceramic Antenna, with shield case) ; (PCBA dimension size : 25.16 * 15.22 * 2.0/2.6 mm ). 3 /16 V1.0www.tuner168.com HY-40R201 40 pin module 4.Application Note: 4-1.Attention to the electrostatic protection, prevent the soldering iron and the equipment grounding bad; And the workbench, working environment, packaging materials and from the human bodyTouch with static electricity, etc., destroy IC and software be fly; Manual welding module solder iron temperature, should pay attention to avoid the PCB copper stripping off;Soldering iron strictlyGrounding requirements, eliminating iron power failure module; 4-2.Attention to avoid the overall motherboard power supply circuit of bad welding connected to short circuit or open circuit, causing the bluetooth chip, abnormal voltage,Thesoftwarewill fly and problems of IC was damaged. 4-3.When programming firm ware , the VDDS supply voltage must in DC 2.4~3.3V, To avoid programming has not completely, and abnormal status occur.. 4-4. Use the module in the production and the transport process, please insure module’scomponent protection, prevent the precision parts on the moduleDamaged (welding furnace exit and assembly, testing, delivery process, suggest using collision buffer material, not collide with each other) 4-5. The module for the humidity sensitive components, if used in SMT reflow soldering operations, please strictly follow the IPC/JEDECJ - STD - 020 regulation, completes the drying dehumidifying , and for this module has second processing work after placed in the functional test environment, the humidity of the chip is no guarantee that in a certain ratio, the honored guest please understand;(The attention note show in below Fig.) 4-6. The diagram (show in below Fig.) of the module application on external filter parts, whenneed, please design in the mainboard, the parts parameter can depend on the actual need to changes. 4 /16 V1.0www.tuner168.com HY-40R201 40 pin module 4-7.Assembly recommendation 1: Underneath the module antenna and RF circuit on themain boardPCB copper need to clearance, and place close to the main board edge, as show in below Fig. The antenna can't be near aroundmetal parts and prevent material existence of electromagnetic radiation , Can affect the manipulation of the distance. 4-8. Assembly recommendation 2: Signal trace and power supply trace, don't cross layout, as show in below Fig.To avoid crosstalk, affect the receiving sensitivity. The module assemble in the motherboard, must pay attention to: Around the antenna and all layer’s copper must be clear, Module antenna should be on the edge, And there are no metal or obstruct electromagnetic radiation material to surround antenna area. 5. Pinout and GPIOfunction Description Pin Name Type Function Description 1 GND Power GND Ground 2 DIO_0 Digital I/O GPIO, Sensor Controller (I:4mA max) 3 DIO_1 Digital I/O GPIO, Sensor Controller (I:4mA max) 4 DIO_2 Digital I/O UART RX; GPIO, Sensor Controller (I:4mA max) 5 DIO_3 Digital I/O 6 DIO_4 Digital I/O 7 DIO_5 Digital I/O 8 DIO_6 Digital I/O 9 DIO_7 Digital I/O 10 DIO_8 Digital I/O UART TX; GPIO, Sensor Controller (I:4mA max) WAKE UP; Don't floating GPIO, Sensor Controller (I:4mA max) GPIO, Sensor Controller, high-drive capability (8mA max). GPIO, Sensor Controller, high-drive capability (8mA max). GPIO, Sensor Controller, high-drive capability (8mA max). GPIO (I: 4mA max) 11 DIO_9 Digital I/O GPIO (I: 4mA max) 12 DIO_10 Digital I/O GPIO (I: 4mA max) 5 /16 V1.0www.tuner168.com HY-40R201 40 pin module 13 DIO_11 Digital I/O GPIO (I: 4mA max) 14 GND Power GND Ground 15 DIO_12 Digital I/O GPIO (I: 4mA max) 16 DIO_13 Digital I/O GPIO (I: 4mA max) 17 DIO_14 Digital I/O GPIO (I: 4mA max) 18 DIO_15 Digital I/O GPIO (I: 4mA max) JTAG Digital I/O 20 TMSC JTAG TCKC JTAG TMSC; high-drive capability Digital I/O 21 DIO_16 TDO Digital I/O GPIO,JTAG_TDO; high-drive capability(8mA max). 22 DIO_17 TDI Digital I/O GPIO,JTAG_TDI; high-drive capability(8mA max). 23 DIO_18 Digital I/O GPIO (I: 4mA max) 24 DIO_19 Digital I/O GPIO (I: 4mA max) 25 DIO_20 Digital I/O GPIO (I: 4mA max) 26 DIO_21 Digital I/O GPIO (I: 4mA max) 27 GND Power GND Ground 28 DIO_22 Digital I/O GPIO (I: 4mA max) 29 VDD Power Supply +1.8V to +3.8V (Recommended 2.7~3.3V) 30 GND Power GND Ground 31 RESET Digital input Reset, active-low. Module have pull up. 32 DIO_23 Digital I/O GPIO, Sensor Controller, Analog(I: 4mA max) 33 DIO_24 Digital I/O GPIO, Sensor Controller, Analog(I: 4mA max) 34 DIO_25 Digital I/O GPIO, Sensor Controller, Analog(I: 4mA max) 35 DIO_26 Digital I/O GPIO, Sensor Controller, Analog(I: 4mA max) 36 DIO_27 Digital I/O GPIO, Sensor Controller, Analog(I: 4mA max) 37 DIO_28 Digital I/O GPIO, Sensor Controller, Analog(I: 4mA max) 38 DIO_29 Digital I/O GPIO, Sensor Controller, Analog(I: 4mA max) 39 DIO_30 Digital I/O GPIO, Sensor Controller, Analog(I: 4mA max) 40 GND Power GND Ground 19 JTAG TCKC 6. Electrical Characteristics (Test condition: With Ta = 25 ℃, VDD =3.0V with internal DC-DC converter, standardmeasure:1Mbps GFSKmodulation ,FRF = 2440MHz Bluetooth Low energy mode.) 6 /16 V1.0www.tuner168.com HY-40R201 40 pin module 6-1.Radio performance & current consumption (Test condition:With Ta = 25 ℃, VDD =3.0V, with internal DC-DC converter, standardmeasure:1Mbps GFSKmodulation ,FRF = 2440MHz Bluetooth Low energy mode.)  Modulation Mode: GFSK  Frequency range: 2402~2480MHZ (2.4GHz ISM band)  Transmit power setting Range: -21 ~ +5 dBm typical ( differential mode o/p point characteristics ; programmable by software)  Receiver sensitivity: -97dBm typical( differential mode o/p point characteristics)  Pre-certified RF regurations for BQB BLE 4.2/5.0, CE ETSI RED, FCC, IC(Canada), (FCC and IC only for HY-40R201PC PCB antenna with shield case model); Another can Compliance for worldwide RF Regulations.  Ultra low current consumption  Transmit:6.1mA(typical)(O/P Power setting :0dBm)  Transmit:9.1mA(typical)(O/P Power setting :5dBm)  Receive(high gain setting): 6.1 mA(typical)  Idle. Supply Systems and RAM powered:550uA(Typical)  Standby. With Cache, RTC, CPU, RAM and partial register retention. XOSC_LF: 3.0 uA(Typical)  Shutdown. No clocks running, no retention: 150 nA(Typical) 6-2. Absolute Maximum Ratings Note: These are absolute maximum ratings beyond which the module can be permanently damaged, these are not Maximum operating conditions, the maximum recommended operating conditions are in the table 6. Rating Min Max Unit VDDS -0.3 4.1 V Other Terminal Voltages VSS-0.3 VDDS+0.3 V Storage Temperature -40 +85 °C 6-3. ESD Ratings Value Human body model (HBM), per VESDElectrostatic ANSI/ESDA/JEDECJS001 discharge Charged device model (CDM), per JESD22-C101 7 /16 V1.0www.tuner168.com All pins ±2500 RF pins ±750 Non-RFpins ±750 Unit V HY-40R201 40 pin module 6-4. Recommended Operating Conditions Supply voltage noise should be less than 10mVpp. Excessive noise at the supply voltage will reduce the RF performance. Rating Min Max Unit VDD (when BlueTooth Active) 1.8 3.8 V VDD( whenflash programming) 2.4 3.3 V +85 °C Operating Temperature Range -40 Note: (1).VDD power supply recommended voltage : 2.7~3.3V (2).When programming firm ware , the VDD supply voltage must in DC 2.4~3.3V, To avoid programming has not completely, or abnormal status occur.. (3).For smaller coin cell batteries, with high worst-case end-of-life equivalent source resistance, a 22-μF VDDS input capacitor must be used to ensure compliance with this slew rate(6-6 timing req.). 6-5.GPIODC Characteristics Parameter Test Condition Typical Unit GPIO VOH at 8-mA load IOCURR = 2, high-drive GPIOs only 2.68 V GPIO VOL at 8-mA load IOCURR = 2, high-drive GPIOs only 0.33 V GPIO VOH at 4-mA load IOCURR = 1 2.72 V GPIO VOL at 4-mA load IOCURR = 1 0.28 V 6-6. Timing Requirements Description MIN Rising supply-voltage slew rate Falling supply-voltage slew rate NOM MAX UNIT 0 100 0 20 mV/uS mV/uS 3 mV/uS 5 °C/s Falling supply-voltage slew rate, with low-power flash settings(1) No limitation for negative temperature gradient, or outside standby mode CONTROL INPUT AC CHARACTERISTICS(3) Positive temperature gradient in standby(2) RESET_N low duration 1 uS (1) For smaller coin cell batteries, with high worst-case end-of-life equivalent source resistance, a 22-μF VDDS input capacitor must be used to ensure compliance with this slew rate. (2) Applications using RCOSC_LF as sleep timer must also consider the drift in frequency caused by a change in temperature . 8 /16 V1.0www.tuner168.com HY-40R201 40 pin module 6-7. Switching Characteristics Measured with Tc = 25°C, VDDS = 3.0 V, unless otherwise noted. Parameter Test Condition Min Typical Max Unit Wakeup and Timing Idle →Active 14 μs Standby →Active 151 μs Shutdown →Active 1015 μs 7. Block Diagram 8. Functional Block Diagram 9 /16 V1.0www.tuner168.com HY-40R201 40 pin module 9. Working mode schematic 10. Recommend Reflow Profile( Leadless solder cream: Sn 96.5%, Ag 3%, Cu 0.5%) Pb-Free Assembly Profile Feature Large Body Average ramp-up rate(TL to TP) 3°C/second max Preheat-Temperature Min (Tsmin) 150°C -Temperature Max (Tsmax) -Time Small Body 200°C (min to max)(ts) 60-180 seconds Tsmaxto TL-Ramp-up Rate 3°C/second max Time maintained above-Temperature (TL) 217°C -Time (tL) 60-150 seconds Peak Temperature (TP) 245 +0/-5°C 250 +0/-5°C Time within 5°C of actualPeakTemperature (tp) 10-30 seconds 20-40 seconds Ramp-down Rate 6°C/second max Time 25°C to PeakTemperature 8 minutes max 10 /16 V1.0www.tuner168.com HY-40R201 40 pin module Reflow Curve Classification 11.HY-40R201PC/WMD40R201SR6PC Module FCC/Industry Canada Statement (to be placed on End Products)Federal Communications Commission (FCC) Statement FCC Statements (OEM) Integrator has to assure compliance of the entire end-product incl. the integrated RF Module. For 15 B (§15.107 and if applicable §15.109) compliance, the host manufacturer is required to show compliance with 15 while the module is installed and operating. Furthermore the module should be transmitting and the evaluation should confirm that the module's intentional emissions (15C) are compliant (fundamental / out-of-band). Finally the integrator has to apply the appropriate equipment authorization (e.g. Verification) for the new host device per definition in §15.101. Integrator is reminded to assure that these installation instructions will not be made available to the end-user of the final host device. The final host device, into which this RF Module is integrated" has to be labeled with an auxiliary label stating the FCC ID of the RF Module, such as "Contains FCC ID: 2ADXE-HY-40R201PC "This device complies with part 15 of the FCC rules. Operation is subject to the following two conditions: (1)this device may not cause harmful interference, and 11 /16 V1.0www.tuner168.com HY-40R201 40 pin module (2)this device must accept any interference received, including interference that may cause undesired operation." "Changes or modifications to this unit not expressly approved by the party responsible for compliance could void the user’s authority to operate the equipment." the Integrator will be responsible to satisfy SAR/ RF Exposure requirements, when the module integrated into the host device. Module statement The single-modular transmitter is a self-contained, physically delineated, component for which compliance can be demonstrated independent of the host operating conditions, and which complies with all eight requirements of § 15.212(a)(1) as summarized below. 1) The radio elements have the radio frequency circuitry shielded. 2) The module has buffered modulation/data inputs to ensure that the device will complywith Part 15 requirements with any type of input signal. 3) The module contains power supply regulation on the module. 4) The module contains a permanently attached antenna. 5) The module demonstrates compliance in a stand-alone configuration. 6) The module is labeled with its permanently affixed FCC ID label. 7) The module complies with all specific rules applicable to the transmitter, including all the conditions provided in the integration instructions by the grantee. 8) The module complies with RF exposure requirements. NOTE: This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures: - Reorient or relocate the receiving antenna. - Increase the separation between the equipment and receiver. -Connect the equipment into an outlet on a circuit different from that to which the receiver is connected. -Consult the dealer or an experienced radio/TV technician for help 12 /16 V1.0www.tuner168.com HY-40R201 40 pin module Industry Canada (IC) Statement This device complies with Industry Canada licence‐exempt icence‐exempt RSS standard(s). Operation is subject to the followingtwo conditions: (1) This his device may not cause interference, and (2) This device must accept any interference,including interference that may cause undesired operation of the device. Canada, avisd’Industry Canada (IC) Le présentappareilestconforme aux CNR d'Industrie Canada applicables aux appareils radio exempts de licence. L'exploitationestautorisée exploitationestautorisée aux deux conditions suivantes: (1) l'appareil ne doit pas produire de brouillage, et (2) l'utilisateur de l'appareildoit accepter tout brouillageradioélectriquesubi, mêmesi lebrouillageest susceptible d'en comp 12.Contact Us ShenZhenShengRun ShengRun Technology Co.,Ltd. Phone: +86-755-86233846 Fax: +86-755-82970906 Official Website:www.tuner168.com www.tuner168.com Alibaba Website:http://shop1439435278127.1688.com http://shop1439435278127.1688.com E-mail: marketing@tuner168.com Address: Room 602,B Block of Longjing Jingu Hi-tech Pioneer Park, Longzhu 4th Road, Xili Town, Nanshan District, Shenzhen, Guangdong, China China. 13 /16 V1.0www.tuner168.com
HY-40R201C 价格&库存
很抱歉,暂时无法提供与“HY-40R201C”相匹配的价格&库存,您可以联系我们找货
HY-40R201C
  • 1+22.66650
  • 10+21.82700
  • 100+19.30850
  • 500+18.80480
