W42Q3224KK6L00B0W0
W42Q3224KK6L00B0W0
    WEIDY(纬迪)
    DIP
    安规电容 DIP 220nF ±10% 310V
W42Q3224KK6L00B0W0 数据手册
W42 MKP series 金属化聚丙烯膜抗干扰电容器(X2 类,THB 防潮系列) Metallized polypropylene film interference suppression capacitor (class X2,THB series) ◼ 外形图 Outline Drawing ■特点 ●金属聚丙烯膜 ■Features ● Metallized polypropylene structure ● 能承受过压冲击 ●Withstanding overvoltage stressing ● 优异的阻燃性能 ●S Excellent active and passive flame resistant abilities ●广泛用于电源跨线电路等抗干扰场合 ●Widely used in across-the-line, interference suppression circuit, etc. ●High stability of capacitance under severe ambient ●在严苛的环境下(如高温高湿)长期应用 容量稳定性优异 condition, such as high temperature and high humidity 技术要求 Specifications 电容器类别 class X2 类 气候类别/阻然等级 Climatic Category/Passive Flammability Category 40/110/56/B 工作温度范围 Operating temperature -40℃~110℃ 额定电压 Rated Voltage 310VAC,50/60Hz 适用于电源电压不超过 250Vac,50/60Hz 的场合 Mains voltage can’t be higher than 250Vac,50/60Hz 最大连续直流电压 Maximum continuous DC voltage 630Vdc 电容量范围 Capacitance Range 0.0010 ~ 10.0F 电容量偏差 Capacitance Tolerance 10 (K), 20 (M) 引线之间 Between Terminals: 4.3UR(DC) (5S) 极壳之间 Between Terminals To Case: 2 120Vac (1min) 耐电压 Voltage Proof 损耗角正切 Dissipation Factor 绝缘电阻 Insulation Resistance 0.0010F ≤ CR ≤ 0.47F 0.47F < CR ≤ 1.0F 1.0F < CR ≤ 10F ≤1510-4 (1kHz,20℃) ≤2010-4(1kHz,20℃) ≤3010-4(1kHz,20℃) ≤2010-4(10kHz,20℃) ≤4010-4(10kHz,20℃) ≥15 000M, CR≤0.33F ≥5 000s, CR0.33F (20℃,100V,1min) Temperature:85℃±2℃ ; Humidity:85 +2/-3 % 防潮测试 THB test(Damp heat test with loading) Voltage setting: 240VAC 50Hz ; Time Duration:1000H Capacitance change:Δ C/C : ≤ ± 10% DF Change: C R ≤1.0μF Δtan δ : ≤ 0.8% at 1 KHZ C R >1.0μF Δtan δ : ≤ 0.5% at 1 KHZ ---------- W42 MKP series 产品代码说明 Part number system ■ 18 位产品代码说明如下: The 18 digits part number is formed as follow: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 □□□ □□ □□□ □ □ □ □□□ □□□□ W 4 2 第 1~3 位: 型号代码 Digit 1 to 3: Series code W42=MKP 第 4~5 位: 交流额定电压 Q3=310V 第 6~8 位:标称容量 举例 : 104 =10×104 PF = 0.1μf 第 9 位: 容量偏差 K=±10%, M=±20% 第 10 位: 引线脚距 J=7.5mm K=10mm M=15mm P=22mm S=27mm X=37mm 第 11 位: 引线线径 W42=MKP Digit 4 to 5: AC rated voltage Q3=310V Digit 6 to 8: Rated capacitance For example: 104 =10×104 PF = 0.1μf Digit 9: Capacitance tolerance K=±10%, M=±20% Digit 10: Pitch J=7.5mm K=10mm M=15mm P=22mm S=27mm X=37mm Digit 11: Lead Wire diameter 5= CP 0.5mm 6= CP 0.6mm 5= CP 0.5mm 6= CP 0.6mm 7= CP 0.7mm 8= CP 0.8mm 7= CP 0.7mm 8= CP 0.8mm C=CP 1.0mm C=CP 1.0mm 第 12 位: 引线加工和包装代码 L= 直脚 K= 引线成型 T= 弹带包装 第 13~18 位:内部特征码 Digit 12: Lead form and packaging code L= straight lead K= Lead kinked T= ammo-pack Digit 13 to 18: Internal use W42 MKP series ■ 外形尺寸 Dimensions (mm) 310Vac Cn (F) 0.0010 0.0012 0.0015 0.0018 0.0022 0.0027 0.0033 0.0039 0.0047 0.0056 0.0068 0.0082 0.01 0.012 0.015 0.018 0.022 0.027 0.033 0.039 0.047 0.068 0.1 0.0047 0.0056 0.0068 0.0082 0.01 0.01 0.012 0.015 0.018 0.022 0.022 0.027 0.033 0.033 0.039 0.047 0.056 0.068 0.082 0.1 0.12 0.15 0.18 0.22 0.33 0.47 W max 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 10.5 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 13.0 H max 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 9.0 11.0 11.0 12.0 12.0 13.0 14.0 9.0 9.0 9.0 9.0 9.0 11.0 11.0 9.0 11.0 9.0 11.0 11.0 9.0 11.0 11.0 11.0 11.0 12.0 12.0 12.0 13.0 14.0 16.0 16.0 20.0 22.0 T max 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 4.0 5.0 5.0 6.0 6.0 7.0 8.0 4.0 4.0 4.0 4.0 4.0 5.0 5.0 4.0 5.0 4.0 5.0 5.0 4.0 5.0 5.0 5.0 5.0 6.0 6.0 6.0 7.0 8.0 9.0 9.0 10.0 12.0 310Vac P d Part number 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 7.5 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 10.0 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 W42Q3102-J6******* W42Q3122-J6******* W42Q3152-J6******* W42Q3182-J6******* W42Q3222-J6******* W42Q3272-J6******* W42Q3332-J6******* W42Q3392-J6******* W42Q3472-J6******* W42Q3562-J6******* W42Q3682-J6******* W42Q3822-J6******* W42Q3103-J6******* W42Q3123-J6******* W42Q3153-J6******* W42Q3183-J6******* W42Q3223-J6******* W42Q3273-J6******* W42Q3333-J6******* W42Q3393-J6******* W42Q3473-J6******* W42Q3683-J6******* W42Q3104-J6******* W42Q3472-K6******* W42Q3562-K6******* W42Q3682-K6******* W42Q3822-K6******* W42Q3103-K6******* W42Q3103-K6******* W42Q3123-K6******* W42Q3153-K6******* W42Q3183-K6******* W42Q3223-K6******* W42Q3223-K6******* W42Q3273-K6******* W42Q3333-K6******* W42Q3333-K6******* W42Q3393-K6******* W42Q3473-K6******* W42Q3563-K6******* W42Q3683-K6******* W42Q3823-K6******* W42Q3104-K6******* W42Q3124-K6******* W42Q3154-K6******* W42Q3184-K6******* W42Q3224-K6******* W42Q3334-K6******* W42Q3474-K6******* Cn (F) 0.01 0.012 0.015 0.018 0.022 0.027 0.033 0.039 0.047 0.056 0.068 0.082 0.1 0.1 0.12 0.15 0.15 0.18 0.18 0.22 0.22 0.27 0.33 0.33 0.39 0.47 0.47 0.47 0.56 0.56 0.68 0.82 0.1 0.15 0.18 0.22 0.22 0.27 0.33 0.33 0.33 0.39 0.47 0.47 0.56 0.56 0.68 0.68 0.68 0.82 1.0 1.0 1.0 1.2 1.5 1.8 2.2 2.2 2.2 W max 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 18.0 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.5 26.0 26.5 26.5 26.5 26.5 26.5 26.5 H max 11.0 11.0 11.0 11.0 11.0 11.0 11.0 11.0 11.0 11.0 11.0 11.0 11.0 12.0 12.0 12.0 14.5 12.0 14.5 13.0 14.5 13.5 14.5 15.5 17.0 16.0 17.5 18.5 19.0 19.0 19.0 26.0 15.0 15.0 15.0 15.0 16.5 15.0 15.0 16.0 17.0 15.0 16.0 19.0 16.0 19.0 17.0 17.0 19.0 19.0 19.0 20.0 21.5 20.0 22.0 24.5 24.5 25.0 29.5 T max 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 5.0 6.0 6.0 6.0 8.5 6.0 8.5 7.0 8.5 7.5 8.5 9.5 8.0 10.0 9.0 11.0 10.0 11.0 11.0 16.0 6.0 6.0 6.0 6.0 7.0 6.0 6.0 7.0 8.5 6.0 7.0 10.0 7.0 10.0 8.5 10.0 10.0 10.0 10.0 11.0 12.0 11.0 12.0 15.5 15.5 16.5 14.5 P d Part number 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 15.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 22.0 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.6 0.8 0.6 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 0.8 W42Q3103-M6******* W42Q3123-M6******* W42Q3153-M6******* W42Q3183-M6******* W42Q3223-M6******* W42Q3273-M6******* W42Q3333-M6******* W42Q3393-M6******* W42Q3473-M6******* W42Q3563-M6******* W42Q3683-M6******* W42Q3823-M6******* W42Q3104-M6******* W42Q3104-M6******* W42Q3124-M6******* W42Q3154-M6******* W42Q3154-M8******* W42Q3184-M6******* W42Q3184-M8******* W42Q3224-M8******* W42Q3224-M8******* W42Q3274-M8******* W42Q3334-M8******* W42Q3334-M8******* W42Q3394-M8******* W42Q3474-M8******* W42Q3474-M8******* W42Q3474-M8******* W42Q3564-M8******* W42Q3564-M8******* W42Q3684-M8******* W42Q3824-M8******* W42Q3104-P8******* W42Q3154-P8******* W42Q3184-P8******* W42Q3224-P8******* W42Q3224-P8******* W42Q3274-P8******* W42Q3334-P8******* W42Q3334-P8******* W42Q3334-P8******* W42Q3394-P8******* W42Q3474-P8******* W42Q3474-P8******* W42Q3564-P8******* W42Q3564-P8******* W42Q3684-P8******* W42Q3684-P8******* W42Q3684-P8******* W42Q3824-P8******* W42Q3105-P8******* W42Q3105-P8******* W42Q3105-P8******* W42Q3125-P8******* W42Q3155-P8******* W42Q3185-P8******* W42Q3225-P8******* W42Q3225-P8******* W42Q3225-P8******* 备注:1. “-” 表示容量偏差。“-” =capacitance tolerance code, M=±20%,K=±10%, 2. 第 12 位表示引线加工和包装代码,L= 直脚 straight lead K= 引线成型 Lead kinked T= 弹带包装 ammo-pack W42 MKP series ■ 外形尺寸 Dimensions (mm) 310Vac Cn (F) W max H max T max P d Part number 0.47 32.0 18.0 9.0 27.0 0.8 W42Q3474-S8******* 0.47 31.5 19.5 9.0 27.0 0.8 W42Q3474-S8******* 0.56 32.0 18.0 9.0 27.0 0.8 W42Q3564-S8******* 0.68 32.0 18.0 9.0 27.0 0.8 W42Q3684-S8******* 0.68 31.5 19.5 11.0 27.0 0.8 W42Q3684-S8******* 0.82 32.0 18.0 9.0 27.0 0.8 W42Q3824-S8******* 0.82 31.5 19.5 9.0 27.0 0.8 W42Q3824-S8******* 1.0 32.0 18.0 9.0 27.0 0.8 W42Q3105-S8******* 1.0 31.5 19.5 11.0 27.0 0.8 W42Q3105-S8******* 1.2 32.0 20.0 11.0 27.0 0.8 W42Q3125-S8******* 1.5 32.0 20.0 11.0 27.0 0.8 W42Q3155-S8******* 1.8 32.0 22.0 13.0 27.0 0.8 W42Q3185-S8******* 2.2 32.0 25.0 13.0 27.0 0.8 W42Q3225-S8******* 2.2 32.0 25.0 15.0 27.0 0.8 W42Q3225-S8******* 2.7 32.0 28.0 14.0 27.0 0.8 W42Q3275-S8******* 3.3 32.0 28.0 17.0 27.0 0.8 W42Q3335-S8******* 3.3 31.5 32.0 16.0 27.0 0.8 W42Q3335-S8******* 3.3 32.0 33.0 18.0 27.0 0.8 W42Q3335-S8******* 3.9 32.0 33.0 18.0 27.0 0.8 W42Q3395-S8******* 4.7 32.0 33.0 18.0 27.0 0.8 W42Q3475-S8******* 4.7 31.5 31.0 21.0 27.0 0.8 W42Q3475-S8******* 5.6 32.0 37.0 22.0 27.0 0.8 W42Q3565-S8******* 1.5 41.0 22.0 11.0 37.0 1.0 W42Q3155-XC******* 1.8 41.0 22.0 11.0 37.0 1.0 W42Q3185-XC******* 2.2 41.0 24.0 13.0 37.0 1.0 W42Q3225-XC******* 2.2 41.0 25.0 14.0 37.0 1.0 W42Q3225-XC******* 2.7 41.0 24.0 13.0 37.0 1.0 W42Q3275-XC******* 3.3 41.0 26.0 15.0 37.0 1.0 W42Q3335-XC******* 3.3 41.5 28.5 16.0 37.0 1.0 W42Q3335-XC******* 3.3 41.0 30.0 15.0 37.0 1.0 W42Q3335-XC******* 3.9 41.0 30.0 16.0 37.0 1.0 W42Q3395-XC******* 4.7 41.0 30.0 16.0 37.0 1.0 W42Q3475-XC******* 4.7 41.0 32.0 19.0 37.0 1.0 W42Q3475-XC******* 4.7 41.5 32.5 18.0 37.0 1.0 W42Q3475-XC******* 5.6 41.0 33.5 18.5 37.0 1.0 W42Q3565-XC******* 6.8 41.0 33.5 19.5 37.0 1.0 W42Q3685-XC******* 6.8 41.5 39.5 20.0 37.0 1.0 W42Q3685-XC******* 8.2 41.0 37.0 22.0 37.0 1.0 W42Q3825-XC******* 10.0 41.0 41.0 26.0 37.0 1.0 W42Q3106-XC******* 10.0 41.5 42.5 28.0 37.0 1.0 W42Q3106-XC******* 10.0 41.0 45.0 30.0 37.0 1.0 W42Q3106-XC******* 备注:1. “-” 表示容量偏差。“-” =capacitance tolerance code, M=±20%,K=±10%, 2. 第 12 位表示引线加工和包装代码,L= 直脚 straight lead K= 引线成型 Lead kinked T= 弹带包装 ammo-pack
W42Q3224KK6L00B0W0 价格&库存
很抱歉,暂时无法提供与“W42Q3224KK6L00B0W0”相匹配的价格&库存,您可以联系我们找货
