Specifications :
3.96±0.15 01
A±0.20 02
X9396 H X - XX X - N0 XX
7.45
B±0.30 03
01
06
01
02
03
04
05
07
13.40
06
07
7.30
04
02
03
04
05
06
07
08
08
1.450
05
02 03
04 05
06
07
Series No.
Category:H-HSG
Welding Board Angle:Blank-ordinary
Row No.-Pin No.:XX-Single row ;
Plug the Pin & special No.
Material:N0-PA66 94V-0
C-Resistance to glowing filament
Poles
1.350
Circuit 1
Voltage rating: 250V AC / DC
Current rating: 7A AC / DC
Withstanding voltage: 1500V AC/minute
Temperature range: -25°C~+85°C
Insulation resistance:≥1000MΩ
Contact resistance: ≤10mΩ
After environmental testing :≤20mΩ
Dimensions(mm)
A
3.96
7.92
11.88
15.84
19.80
23.76
27.72
X9396H-XX-N0-C
Nylon 66 UL 94V-0
X9396H-XX-N0
Nylon 66 UL 94V-0
PART N0
Material
B
8.02
11.98
15.94
19.90
23.86
27.82
31.78
Poles
Dimensions(mm)
09
10
11
12
13
14
15
X9396T
Suitable XKB Terminal
A
31.68
35.64
39.60
43.56
47.52
51.48
55.44
B
35.74
39.70
43.66
47.62
51.58
55.54
59.50
X9396W
X9396H-XX-N0
3.96mm Crimp Style Connectors
XKB INDUSTRIAL PRECISION CO.,LIMITED
12.50 14
01
Specifications :
0.25±0.02
1.50
02
03
2.00
A
0.70 06
01
04
01
02
03
4.00
05
07
04
3.70
B
B
X9396 T X - B SN X - X
10.8
A
05
06
07
3.05
3.95±0.3
02
03
04
05
06
07
Series Number
Category: T-terminal
Shape:Blank-ordinary
Material:B-brass
Plating style: SN-Bright tin plating
Plating method:
Blank-Stamping before plating
B-Plating before stamping
Mold No./Mark/Special No.
3.70 08
13
11
2.85±0.3 09
2.2
3.8
12
SECTION A-A
SECTION B-B
SCALE 1∶1
SCALE 1∶1
10
X9396T-BSN
Brass
AWG#18-22 3.00mm(Max)
PART N0
Material
Wire Range Insulation O.D.
Stamping Before Plating:30u" Ni;70u"Sn
Finish
X9396H
X9396T-BSN
Specifications :
B±0.3 01
6.80
02
X9396 W R X - XX X - N0 SN XX
1
A±0.2 03
1
2
3.960 04
3
4
5
7
09
8
9.40
3.20
3.50±0.3
07
05
6
7.65
B
08
9
Poles
02
03
04
05
06
07
SQ1.14 06
10
3.96
Recommended P.C.B Layout
General Tolerance±0.05
3.80
8.00 11
Ø1.65+0.1
-0
2
3
4
5
6
7
8
9
Series No.
Category:W-wafer
Welding Board Angle:R-90°
Welding Way: Blank-DIP
Row No.-Pin No. XX-Single row
Plug the Pin & Special NO:
Planting Category: SN-Bright tin plating
Color:Blank-natural color
Dimensions(mm)
A
B
3.96
7.92
7.92
11.88
11.88
15.84
15.84
19.80
19.80
23.76
23.76
27.72
X9396WR-XX-N0SN
Nylon 66 UL 94V-0
PART N0
Material
Brass
Poles
08
09
10
11
12
Dimensions(mm)
A
B
31.68
27.72
31.68
35.64
35.64
39.60
43.56
39.60
47.52
43.56
Tin-Plated
Material(Pin) Finish(Pin)
X9396H
X9396WR-XX-N0SN
Specifications :
Circuit 1
8.50
01
B±0.3 02
X9396 W V X-XX XX-N0 SN-X
1
1
A±0.3 03
3.96±0.1 04
2
4.90 07
3
4
5
6
7
8
08
9.60
3.25
11
9
1.14±0.05 06
3.96±0.1
Poles
02
03
04
05
06
07
08
8.35 10
Ø1.80±0.1
Recommand PCB Layout
5
3 4
6
7
8
9
Series No
Category :W-WAFER
Welding Board Angle :V-180°
Row No.-Pin No.: XX-02P~15P
Plug the Pin & Special No.:
Material: N0-PA66 94V-0
Plating Category: SN-Bright Tin Plating
Blank-Spile3.60mm Total long needle14.60mm
09
3.90
14.60
05
2
Dimensions(mm)
A
B
3.96
7.92
7.92
11.88
11.88
15.84
15.84
19.80
19.80
23.76
23.76
27.72
31.68
27.72
9396WV-XX-N0SN
Nylon 66 UL 94V-0
PART N0
Material
Brass
Poles
09
10
11
12
13
14
15
Dimensions(mm)
A
B
35.64
31.68
39.60
35.64
43.56
39.60
43.56
47.52
47.52
51.48
55.44
51.48
59.40
55.44
Tin-Plated
X9396H
X9396WV-XX-N0SN
3.96 mm Crimp Style Connectors
Specifications :
X9396 W V S-XX XX-9T SN-X
1
1
2
3
4
5
6
7
8
9
Poles
02
03
04
05
06
07
08
9396WVS-XX-N0SN
9396WVS-02
9396WVS-03
PART N0
Nylon 66 UL 94V-0
Material
2
3 4
5
6
7
8
9
Series No
Category :W-WAFER
Welding Way: S-SMT
Material: 9T-PA9T 94V-0
Dimensions(mm)
Dimensions(mm)
Poles
A
A
B
B
C
C
3.96 11.88 8.60
09 31.68 39.60 36.32
7.92 15.84 12.56 10 35.64 43.56 40.28
11.88 19.80 16.52
11 39.60 47.52 44.24
15.84 23.76 20.48 12 43.56 51.48 48.20
19.80 27.72 24.44 13 47.52 55.44 52.16
23.76 31.68 28.40 14 51.48 59.40 56.12
27.72 35.64 32.36 15 55.44 63.36 60.08
Brass
Tin-Plated
X9396H
X9396WVS-XX-9TSN
Specifications :
X9396 W R S- XX X - 9TSN XX
1
1
2
3
4
5
6
7
8
9
Poles
02
03
04
05
06
07
08
Mating PCB detail
9396WRS-02
2
3
4
5
6
7
8
9
Series No.
Category:W-wafer
Welding Way: S-SMT
Material:9T -PA9T 94V-0
Dimensions(mm)
Dimensions(mm)
Poles
A
A
B
B
C
C
3.96 11.88 8.60
11.88 19.80 16.52
X9396WRS-XX-9TSN
Nylon 66 UL 94V-0
PART N0
Material
Brass
Tin-Plated
X9396H
9396WRS-03
X9396WRS-XX-9TSN
Specifications :
Current rating: 5A AC / DC
1
1
2
3
4
5
6
7
8
9
X9396WV-XX-N0SN
PART N0
5
6
7
Dimensions(mm)
A
B
3.96 7.94
7.92 11.94
11.88 15.90
15.84 19.86
19.80 23.82
23.76 27.78
27.72 31.74
Nylon 66 UL 94V-0
Material
3 4
8
9
Series No
Category :W-WAFER
Material: N2-PA66 94V-2
Poles
02
03
04
05
06
07
08
2
Brass
Poles
09
10
11
12
13
14
15
Tin-Plated
Dimensions(mm)
A
B
31.68 35.70
35.64 39.66
39.60 43.62
43.56 47.58
47.52 51.54
51.48 55.50
55.44 63.42
X9396H
X9396WRS-XX-9TSN
Specifications :
1
1
2
3
4
5
6
7
8
9
X9396WV-XX-N0SN
PART N0
5
6
7
Dimensions(mm)
A
B
3.96 7.98
7.92 11.94
11.88 15.90
15.84 19.86
19.80 23.82
23.76 27.78
27.72 31.74
Nylon 66 UL 94V-0
Material
3 4
8
9
Series No
Category :W-WAFER
Poles
02
03
04
05
06
07
08
2
Brass
Poles
09
10
11
12
13
14
15
Tin-Plated
Dimensions(mm)
A
B
31.68 35.70
35.64 39.66
39.60 43.62
43.56 47.58
47.52 51.54
51.48 55.50
55.44 63.42
X9396H
X9396WRS-XX-9TSN
Specifications :
1
1
2
3
4
5
6
7
8
9
X9396WV-XX-N0SN
PART N0
5
6
7
Dimensions(mm)
A
B
3.96 7.98
7.92 11.94
11.88 15.90
15.84 19.86
19.80 23.82
23.76 27.78
27.72 31.74
Nylon 66 UL 94V-0
Material
3 4
8
9
Series No
Category :W-WAFER
Poles
02
03
04
05
06
07
08
2
Brass
Poles
09
10
11
12
13
14
15
Tin-Plated
Dimensions(mm)
A
B
31.68 35.70
35.64 39.66
39.60 43.62
43.56 47.58
47.52 51.54
51.48 55.50
55.44 63.42
X9396H
X9396WRS-XX-9TSN
很抱歉,暂时无法提供与“X9396WV-02-N0SN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.31850
- 100+0.25942
- 300+0.22983
- 1000+0.18692
- 5000+0.17098
- 10000+0.16291
- 国内价格
- 20+0.14500
- 200+0.13500
- 600+0.12500
- 3000+0.11500
