X9396WV-05-N0SN
X9396WV-05-N0SN
    XKB(中国星坤)
    插件,P=3.96mm
    线对板针座 1x5P 直插 间距:3.96mm
X9396WV-05-N0SN 数据手册
Specifications : 3.96±0.15 01 A±0.20 02 X9396 H X - XX X - N0 XX 7.45 B±0.30 03 01 06 01 02 03 04 05 07 13.40 06 07 7.30 04 02 03 04 05 06 07 08 08 1.450 05 02 03 04 05 06 07 Series No. Category:H-HSG Welding Board Angle:Blank-ordinary Row No.-Pin No.:XX-Single row ; Plug the Pin & special No. Material:N0-PA66 94V-0 C-Resistance to glowing filament Poles 1.350 Circuit 1 Voltage rating: 250V AC / DC Current rating: 7A AC / DC Withstanding voltage: 1500V AC/minute Temperature range: -25°C~+85°C Insulation resistance:≥1000MΩ Contact resistance: ≤10mΩ After environmental testing :≤20mΩ Dimensions(mm) A 3.96 7.92 11.88 15.84 19.80 23.76 27.72 X9396H-XX-N0-C Nylon 66 UL 94V-0 X9396H-XX-N0 Nylon 66 UL 94V-0 PART N0 Material B 8.02 11.98 15.94 19.90 23.86 27.82 31.78 Poles Dimensions(mm) 09 10 11 12 13 14 15 X9396T Suitable XKB Terminal A 31.68 35.64 39.60 43.56 47.52 51.48 55.44 B 35.74 39.70 43.66 47.62 51.58 55.54 59.50 X9396W Suitable XKB Terminal X9396H-XX-N0 3.96mm Crimp Style Connectors XKB INDUSTRIAL PRECISION CO.,LIMITED 12.50 14 01 Specifications : 0.25±0.02 Voltage rating: 250V AC / DC Current rating: 7A AC / DC Withstanding voltage: 1500V AC/minute Temperature range: -25°C~+85°C Insulation resistance:≥1000MΩ Contact resistance: ≤10mΩ After environmental testing :≤20mΩ 1.50 02 03 2.00 A 0.70 06 01 04 01 02 03 4.00 05 07 04 3.70 B B X9396 T X - B SN X - X 10.8 A 05 06 07 3.05 3.95±0.3 02 03 04 05 06 07 Series Number Category: T-terminal Shape:Blank-ordinary Material:B-brass Plating style: SN-Bright tin plating Plating method: Blank-Stamping before plating B-Plating before stamping Mold No./Mark/Special No. 3.70 08 13 11 2.85±0.3 09 2.2 3.8 12 SECTION A-A SECTION B-B SCALE 1∶1 SCALE 1∶1 10 X9396T-BSN Brass AWG#18-22 3.00mm(Max) PART N0 Material Wire Range Insulation O.D. Stamping Before Plating:30u" Ni;70u"Sn Finish X9396H Suitable XKB Terminal X9396T-BSN 3.96mm Crimp Style Connectors XKB INDUSTRIAL PRECISION CO.,LIMITED Specifications : B±0.3 01 Voltage rating: 250V AC / DC Current rating: 7A AC / DC Withstanding voltage: 1500V AC/minute Temperature range: -25°C~+85°C Insulation resistance:≥1000MΩ Contact resistance: ≤10mΩ After environmental testing :≤20mΩ 6.80 02 X9396 W R X - XX X - N0 SN XX 1 A±0.2 03 1 2 3.960 04 3 4 5 7 09 8 9.40 3.20 3.50±0.3 07 05 6 7.65 B 08 9 Poles 02 03 04 05 06 07 SQ1.14 06 10 3.96 Recommended P.C.B Layout General Tolerance±0.05 3.80 8.00 11 Ø1.65+0.1 -0 2 3 4 5 6 7 8 9 Series No. Category:W-wafer Welding Board Angle:R-90° Welding Way: Blank-DIP Row No.-Pin No. XX-Single row Plug the Pin & Special NO: Material:N0-PA66 94V-0 Planting Category: SN-Bright tin plating Color:Blank-natural color Dimensions(mm) A B 3.96 7.92 7.92 11.88 11.88 15.84 15.84 19.80 19.80 23.76 23.76 27.72 X9396WR-XX-N0SN Nylon 66 UL 94V-0 PART N0 Material Brass Poles 08 09 10 11 12 Dimensions(mm) A B 31.68 27.72 31.68 35.64 35.64 39.60 43.56 39.60 47.52 43.56 Tin-Plated Material(Pin) Finish(Pin) X9396H Suitable XKB Terminal X9396WR-XX-N0SN 3.96mm Crimp Style Connectors XKB INDUSTRIAL PRECISION CO.,LIMITED Specifications : Circuit 1 Voltage rating: 250V AC / DC Current rating: 7A AC / DC Withstanding voltage: 1500V AC/minute Temperature range: -25°C~+85°C Insulation resistance:≥1000MΩ Contact resistance: ≤10mΩ After environmental testing :≤20mΩ 8.50 01 B±0.3 02 X9396 W V X-XX XX-N0 SN-X 1 1 A±0.3 03 3.96±0.1 04 2 4.90 07 3 4 5 6 7 8 08 9.60 3.25 11 9 1.14±0.05 06 3.96±0.1 Poles 02 03 04 05 06 07 08 8.35 10 Ø1.80±0.1 Recommand PCB Layout 5 3 4 6 7 8 9 Series No Category :W-WAFER Welding Board Angle :V-180° Welding Way: Blank-DIP Row No.-Pin No.: XX-02P~15P Plug the Pin & Special No.: Material: N0-PA66 94V-0 Plating Category: SN-Bright Tin Plating Blank-Spile3.60mm Total long needle14.60mm 09 3.90 14.60 05 2 Dimensions(mm) A B 3.96 7.92 7.92 11.88 11.88 15.84 15.84 19.80 19.80 23.76 23.76 27.72 31.68 27.72 9396WV-XX-N0SN Nylon 66 UL 94V-0 PART N0 Material Brass Poles 09 10 11 12 13 14 15 Dimensions(mm) A B 35.64 31.68 39.60 35.64 43.56 39.60 43.56 47.52 47.52 51.48 55.44 51.48 59.40 55.44 Tin-Plated Material(Pin) Finish(Pin) X9396H Suitable XKB Terminal X9396WV-XX-N0SN 3.96 mm Crimp Style Connectors XKB INDUSTRIAL PRECISION CO.,LIMITED Specifications : Voltage rating: 250V AC / DC Current rating: 7A AC / DC Withstanding voltage: 1500V AC/minute Temperature range: -25°C~+85°C Insulation resistance:≥1000MΩ Contact resistance: ≤10mΩ After environmental testing :≤20mΩ X9396 W V S-XX XX-9T SN-X 1 1 2 3 4 5 6 7 8 9 Poles 02 03 04 05 06 07 08 9396WVS-XX-N0SN 9396WVS-02 9396WVS-03 PART N0 Nylon 66 UL 94V-0 Material 2 3 4 5 6 7 8 9 Series No Category :W-WAFER Welding Board Angle :V-180° Welding Way: S-SMT Row No.-Pin No.: XX-02P~15P Plug the Pin & Special No.: Material: 9T-PA9T 94V-0 Plating Category: SN-Bright Tin Plating Blank-Spile3.60mm Total long needle14.60mm Dimensions(mm) Dimensions(mm) Poles A A B B C C 3.96 11.88 8.60 09 31.68 39.60 36.32 7.92 15.84 12.56 10 35.64 43.56 40.28 . 11.88 19.80 16.52 11 39.60 47.52 44.24 15.84 23.76 20.48 12 43.56 51.48 48.20 19.80 27.72 24.44 13 47.52 55.44 52.16 . 23.76 31.68 28.40 14 51.48 59.40 56.12 . 27.72 35.64 32.36 15 55.44 63.36 60.08 Brass Tin-Plated Material(Pin) Finish(Pin) X9396H Suitable XKB Terminal X9396WVS-XX-9TSN 3.96 mm Crimp Style Connectors XKB INDUSTRIAL PRECISION CO.,LIMITED Specifications : Voltage rating: 250V AC / DC Current rating: 7A AC / DC Withstanding voltage: 1500V AC/minute Temperature range: -25°C~+85°C Insulation resistance:≥1000MΩ Contact resistance: ≤10mΩ After environmental testing :≤20mΩ X9396 W R S- XX X - 9TSN XX 1 1 2 3 4 5 6 7 8 9 Poles 02 03 04 05 06 07 08 Mating PCB detail 9396WRS-02 2 3 4 5 6 7 8 9 Series No. Category:W-wafer Welding Board Angle:R-90° Welding Way: S-SMT Row No.-Pin No. XX-Single row Plug the Pin & Special NO: Material:9T -PA9T 94V-0 Planting Category: SN-Bright tin plating Color:Blank-natural color Dimensions(mm) Dimensions(mm) Poles A A B B C C 3.96 11.88 8.60 09 31.68 39.60 36.32 7.92 15.84 12.56 10 35.64 43.56 40.28 . 11.88 19.80 16.52 11 39.60 47.52 44.24 15.84 23.76 20.48 12 43.56 51.48 48.20 19.80 27.72 24.44 13 47.52 55.44 52.16 . 23.76 31.68 28.40 14 51.48 59.40 56.12 . 27.72 35.64 32.36 15 55.44 63.36 60.08 X9396WRS-XX-9TSN Nylon 66 UL 94V-0 PART N0 Material Brass Tin-Plated Material(Pin) Finish(Pin) X9396H Suitable XKB Terminal 9396WRS-03 X9396WRS-XX-9TSN 3.96mm Crimp Style Connectors XKB INDUSTRIAL PRECISION CO.,LIMITED Specifications : Voltage rating: 250V AC / DC Current rating: 5A AC / DC Withstanding voltage: 1500V AC/minute Temperature range: -25°C~+85°C Insulation resistance:≥1000MΩ Contact resistance: ≤10mΩ After environmental testing :≤20mΩ X9396 W V X-XX XX-N0 SN-X 1 1 2 3 4 5 6 7 8 9 X9396WV-XX-N0SN PART N0 5 6 7 Dimensions(mm) A B 3.96 7.94 7.92 11.94 11.88 15.90 15.84 19.86 19.80 23.82 23.76 27.78 27.72 31.74 Nylon 66 UL 94V-0 Material 3 4 8 9 Series No Category :W-WAFER Welding Board Angle :V-180° Welding Way: Blank-DIP Row No.-Pin No.: XX-02P~15P Plug the Pin & Special No.: Material: N2-PA66 94V-2 Plating Category: SN-Bright Tin Plating Blank-Spile3.60mm Total long needle14.60mm Poles 02 03 04 05 06 07 08 2 Brass Poles 09 10 11 12 13 14 15 Tin-Plated Material(Pin) Finish(Pin) Dimensions(mm) A B 31.68 35.70 35.64 39.66 39.60 43.62 43.56 47.58 47.52 51.54 51.48 55.50 55.44 63.42 X9396H Suitable XKB Terminal X9396WRS-XX-9TSN 3.96mm Crimp Style Connectors XKB INDUSTRIAL PRECISION CO.,LIMITED Specifications : Voltage rating: 250V AC / DC Current rating: 5A AC / DC Withstanding voltage: 1500V AC/minute Temperature range: -25°C~+85°C Insulation resistance:≥1000MΩ Contact resistance: ≤10mΩ After environmental testing :≤20mΩ X9396 W V X-XX XX-N0 SN-X 1 1 2 3 4 5 6 7 8 9 X9396WV-XX-N0SN PART N0 5 6 7 Dimensions(mm) A B 3.96 7.98 7.92 11.94 11.88 15.90 15.84 19.86 19.80 23.82 23.76 27.78 27.72 31.74 Nylon 66 UL 94V-0 Material 3 4 8 9 Series No Category :W-WAFER Welding Board Angle :V-180° Welding Way: Blank-DIP Row No.-Pin No.: XX-02P~15P Plug the Pin & Special No.: Material: N2-PA66 94V-2 Plating Category: SN-Bright Tin Plating Blank-Spile3.60mm Total long needle14.60mm Poles 02 03 04 05 06 07 08 2 Brass Poles 09 10 11 12 13 14 15 Tin-Plated Material(Pin) Finish(Pin) Dimensions(mm) A B 31.68 35.70 35.64 39.66 39.60 43.62 43.56 47.58 47.52 51.54 51.48 55.50 55.44 63.42 X9396H Suitable XKB Terminal X9396WRS-XX-9TSN 3.96mm Crimp Style Connectors XKB INDUSTRIAL PRECISION CO.,LIMITED Specifications : Voltage rating: 250V AC / DC Current rating: 5A AC / DC Withstanding voltage: 1500V AC/minute Temperature range: -25°C~+85°C Insulation resistance:≥1000MΩ Contact resistance: ≤10mΩ After environmental testing :≤20mΩ X9396 W V X-XX XX-N0 SN-X 1 1 2 3 4 5 6 7 8 9 X9396WV-XX-N0SN PART N0 5 6 7 Dimensions(mm) A B 3.96 7.98 7.92 11.94 11.88 15.90 15.84 19.86 19.80 23.82 23.76 27.78 27.72 31.74 Nylon 66 UL 94V-0 Material 3 4 8 9 Series No Category :W-WAFER Welding Board Angle :V-180° Welding Way: Blank-DIP Row No.-Pin No.: XX-02P~15P Plug the Pin & Special No.: Material: N2-PA66 94V-2 Plating Category: SN-Bright Tin Plating Blank-Spile3.60mm Total long needle14.60mm Poles 02 03 04 05 06 07 08 2 Brass Poles 09 10 11 12 13 14 15 Tin-Plated Material(Pin) Finish(Pin) Dimensions(mm) A B 31.68 35.70 35.64 39.66 39.60 43.62 43.56 47.58 47.52 51.54 51.48 55.50 55.44 63.42 X9396H Suitable XKB Terminal X9396WRS-XX-9TSN 3.96mm Crimp Style Connectors XKB INDUSTRIAL PRECISION CO.,LIMITED
X9396WV-05-N0SN 价格&库存
很抱歉,暂时无法提供与“X9396WV-05-N0SN”相匹配的价格&库存,您可以联系我们找货
X9396WV-05-N0SN
  • 1+0.16200
  • 100+0.14850
库存:12
X9396WV-05-N0SN
  • 5+0.68127
  • 50+0.54809
  • 150+0.48150
  • 1000+0.38588
  • 2000+0.34587
  • 5000+0.32596
库存:36
