PUDP-22V-S
PUDP-22V-S
    JST
    P=2mm
    2X11P 2MM
PUDP-22V-S 数据手册
PUD CONNECTOR 2.0mm pitch/Disconnectable Crimp style connectors • High reliability contact • Superior operability • Secure locking structure • Polarizing key for mounting on PC board Specifications ––––––––––––––––––– This is a board-to-wire connector with secure locking device that has been designed to 2.0 mm pitch, crimping style and double-row. In spite of realizing low insertion force, the stable electric connection is demonstrated against the condition such as vibration, pinching and dry circuit. It is possible to unfasten the locking even if the header is surrounded with a case wall within height of header because the tip of locking device in receptacle does not protrude from its area. • Current rating: 3 A AC, DC (AWG #22) • Voltage rating: 250 V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 800 VAC/minute • Applicable wire: Conductor size/ AWG #28 to #22 Insulation O.D./ 0.76 to 1.5 mm * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. Standards––––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 PC board layout and Assembly layout Connector outline (0.4) 8.3 (14.1) φ1.6 +0.1 0 Even number circuits 0.9 ±0.05 φ0.7 φ1.3+0.1 0 2 ±0.05 Odd number circuits +0.1 0 A ±0.05 2 ±0.05 Even number circuits 7.7 ±0.05 8.5 2±0.05 11 3.4±0.05 (2) 1.2±0.05 2±0.05 (2.4) A±0.05 (0.4) Side entry type (2.4) Top entry type 2 10.1 Circuit No.1 Connector outline φ0.7 +0.1 0 2 Odd number circuits Circuit No.1 (2) Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ±0.05 mm for all centers. 3. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. SMT type A±0.05 2±0.05 1min 8.8 (1.6) Odd number circuits Connector outline Circuit No.1 1min (12.3) (0.8) 3min 5.7±0.1 3min Even number circuits Note: 1. The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ±0.05 mm for all centers. The dimensions above should serve as a guideline. Contact JST for details. 1 PUD CONNECTOR Contact Applicable wire Model No. SPUD-001T-P0.5 SPUD-002T-P0.5 7.5 mm2 AWG# Insulation O.D. (mm) 0.13∼0.33 26∼22 0.95∼1.5 0.08∼0.22 28∼24 0.76∼1.5 Q’t y/ reel 8,000 Material and Finish 2.85 Copper alloy, tin-plated (reflow treatment) 1.35 1.45 RoHS compliance Contact 1.65 Crimping machine Crimp applicator MKS-L SPUD-001T-P0.5 AP-K2N Applicator Dies ー MKS-L SPUD-002T-P0.5 AP-K2N Crimp applicator with dies MK/SPUD-001-05 APLMK SPUD001-05 ー ー MK/SPUD-002-05 APLMK SPUD002-05 ー ー ー Housing B A Circuit No.1 mark Circuit No.1 mark 9.1 2 9.1 2 8.3 B A 8.3 B A B A 8.3 8.3 2 9.1 9.1 Circuit No.1 mark 2 Circuit No.1 mark Circuits Model No. 8 PUDP-08V-S PUDP-10V-S PUDP-12V-S PUDP-14V-S PUDP-16V-S PUDP-18V-S PUDP-20V-S PUDP-22V-S PUDP-24V-S PUDP-26V-S PUDP-28V-S PUDP-30V-S PUDP-32V-S PUDP-34V-S PUDP-36V-S PUDP-38V-S PUDP-40V-S 10 12 B A 8.3 14 Circuit No.1 mark 2 16 18 20 9.1 22 24 26 28 30 32 34 36 8.3 A 2 38 Circuit No.1 mark 40 Q'ty/ bag 6.0 10.0 1,000 8.0 12.0 1,000 10.0 14.0 1,000 12.0 16.0 1,000 14.0 18.0 1,000 16.0 20.0 1,000 18.0 22.0 1,000 20.0 24.0 1,000 22.0 26.0 1,000 24.0 28.0 1,000 26.0 30.0 500 28.0 32.0 500 30.0 34.0 500 32.0 36.0 500 34.0 38.0 500 36.0 40.0 500 38.0 42.0 500 Material PBT, UL94V-0, natural 9.1 B Dimensions (mm) A B RoHS compliance As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. PUDP-08V-S S...natural Z...ivory E...blue R...red K...black TR...tomato red MG...moss green DPK...dark pink CB...cobalt blue DO...dark orange DP...dark purple DH...dark gray LE...light blue 2 PUD CONNECTOR Through-hole type shrouded header Top entry type Circuits 8 8.3 B 10 A 12 9.6 14 0.8 16 18 3.1 20 2 22 Circuit No.1 3.4 2 24 26 28 8.3 B A 30 32 34 9.6 36 0.8 38 3.1 40 3.4 2 B 0.8 9.6 3.1 ex. Circuit No.1 3.4 2 0.8 2 12.7 7.7 10.1 8.5 3 Circuit No.1 B 8.5 0.8 2 12.7 7.7 10.1 A Circuit No.1 2 3 0.8 2 12.7 7.7 10.1 8.5 B A 2 3 10.0 3,300 8.0 12.0 2,750 10.0 14.0 2,310 12.0 16.0 1,980 14.0 18.0 1,760 16.0 20.0 1,650 18.0 22.0 1,430 20.0 24.0 1,320 22.0 26.0 1,210 24.0 28.0 1,100 26.0 30.0 1,100 28.0 32.0 990 30.0 34.0 880 32.0 36.0 880 34.0 38.0 770 36.0 40.0 770 38.0 42.0 770 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. Side entry type 2 6.0 RoHS compliance This product displays (LF)(SN) on a label. Note: Color indication was changed. Berofe change; S...natural (ivory) ,After change; S...natural 8.3 A B A Dimensions Q'ty/ (mm) box A B Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural 2 Side entry type With boss S08B-PUDSS-1 S10B-PUDSS-1 S12B-PUDSS-1 S14B-PUDSS-1 S16B-PUDSS-1 S18B-PUDSS-1 S20B-PUDSS-1 S22B-PUDSS-1 S24B-PUDSS-1 S26B-PUDSS-1 S28B-PUDSS-1 S30B-PUDSS-1 S32B-PUDSS-1 S34B-PUDSS-1 S36B-PUDSS-1 S38B-PUDSS-1 S40B-PUDSS-1 Material and Finish Circuit No.1 2 Model No. Top entry type Without boss With boss B08B-PUDSS B08B-PUDSS-1 B10B-PUDSS B10B-PUDSS-1 B12B-PUDSS B12B-PUDSS-1 B14B-PUDSS B14B-PUDSS-1 B16B-PUDSS B16B-PUDSS-1 B18B-PUDSS B18B-PUDSS-1 B20B-PUDSS B20B-PUDSS-1 B22B-PUDSS B22B-PUDSS-1 B24B-PUDSS B24B-PUDSS-1 B26B-PUDSS B26B-PUDSS-1 B28B-PUDSS B28B-PUDSS-1 B30B-PUDSS B30B-PUDSS-1 B32B-PUDSS B32B-PUDSS-1 B34B-PUDSS B34B-PUDSS-1 B36B-PUDSS B36B-PUDSS-1 B38B-PUDSS B38B-PUDSS-1 B40B-PUDSS B40B-PUDSS-1 Circuit No.1 3 B08B-PUDSS-1 S...natural Z...ivory E...blue R...red K...black TR...tomato red MG...moss green DPK...dark pink CB...cobalt blue DO...dark orange DP...dark purple DH...dark gray LE...light blue PUD CONNECTOR SMT type shrouded header B A Circuits Model No. 10 BM10B-PUDSS -TFC BM12B-PUDSS -TFC BM14B-PUDSS -TFC BM16B-PUDSS -TFC BM18B-PUDSS -TFC BM20B-PUDSS -TFC BM22B-PUDSS -TFC BM24B-PUDSS -TFC BM26B-PUDSS -TFC BM28B-PUDSS -TFC BM30B-PUDSS -TFC BM32B-PUDSS -TFC BM34B-PUDSS -TFC BM36B-PUDSS -TFC BM38B-PUDSS -TFC BM40B-PUDSS -TFC 12 8.8 14 2 16 18 10.8 20 22 24 26 Circuit No.1 28 30 32 34 B A 36 8.8 38 2 40 Dimensions (mm) A B Q'ty/ reel 8.0 14.0 400 10.0 16.0 400 12.0 18.0 400 14.0 20.0 400 16.0 22.0 400 18.0 24.0 400 20.0 26.0 400 22.0 28.0 400 24.0 30.0 400 26.0 32.0 400 28.0 34.0 400 30.0 36.0 400 32.0 38.0 400 34.0 40.0 400 36.0 42.0 400 38.0 44.0 400 10.8 Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Polyamide, UL94V-0, natural RoHS compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. Circuit No.1 ex. B A 8.8 10.8 2 BM-10B-PUDSS-TFC S...natural Z...ivory K...black TR...tomato red MG...moss green DPK...dark pink CB...cobalt blue DO...dark orange DP...dark purple DH...dark gray LE...light blue Circuit No.1 B A 8.8 10.8 2 Circuit No.1 B A 8.8 10.8 2 Circuit No.1 4
PUDP-22V-S 价格&库存
很抱歉,暂时无法提供与“PUDP-22V-S”相匹配的价格&库存,您可以联系我们找货
PUDP-22V-S
    • 200+0.90550
    库存:3302
    PUDP-22V-S
      • 1+2.931821+0.38002
      • 50+2.8241550+0.36607
      • 100+2.31067100+0.29951
      • 300+1.96283300+0.25442
      • 500+1.89657500+0.24584
      • 1000+1.846881000+0.23939
      • 4000+1.805474000+0.23403
      库存:4821
