ED555/3DS
ED555/3DS
    OST
    TERMINAL BLOCK 3.5MM 3POS PCB
ED555/3DS 数据手册
ED555/XDS ED590/XDS 2-16 poles, Spacing 3.5 mm insert required no. of poles x 2-12 poles, Spacing 5.0 mm insert required no. of poles x How to order see page 5 Ratings: Rated Voltage Rated Current Wire Size Test Voltage Rated Torque/ScrewSize 130 V 13.5 A (T60) 1.0 mm 2 2.0 kV 0.4 Nm/M2 Ratings: Rated Voltage Rated Current Wire Size Test Voltage Rated Torque/ScrewSize Max. Rated Cross Section Single Wire (solid) Stranded Wire (flexible) Stranded wire with Ferrules 1.5 mm 2 1.5 mm 2 0.75 mm2 Max. Rated Cross Section Single Wire (solid) Stranded Wire (flexible) Stranded wire with Ferrules 1.5 mm 2 1.5 mm 2 0.75 mm2 Dimensions Spacing PCB Hole Diameter Stripped Length 3.5 mm 1.2 mm 5.5 mm Dimensions Spacing PCB Hole Diameter Stripped Length 5.0 mm 1.3 mm 6.0 mm Materials Insulating Material Flammability Class Temperature Range Terminal Block Wire Guard PA UL94 V-0 -30 C/+105 C CuZn Stainless Steel Materials Insulating Material Flammability Class Temperature Range Terminal Block Wire Guard PA UL94 V-0 -30 C/+105 C CuZn Stainless Steel Color Grey 19 How to order see page 5 150 V 6A AWG 28-16 300 V 15 A AWG 22-14 250 V 17.5 A (T60) 1.5 mm 2 2.0 kV 0.4 Nm/M2.6 Color Blue ON-SHORE TECHNOLOGY INC 1917 West Third Street Tempe, Arizona USA 85281 Tel. (480)921-3000 Fax(480) 968-4444 19
ED555/3DS 价格&库存
很抱歉,暂时无法提供与“ED555/3DS”相匹配的价格&库存,您可以联系我们找货
