BM11B-SRSS-TB(LF)(SN)
    JST
    CONN HEADER SH 11POS TOP 1MM TIN
BM11B-SRSS-TB(LF)(SN) 数据手册
Emboss Tape SR /SZ CONNECTOR 1.0mm pitch/Disconnectable Insulation displacement connectors Specifications ––––––––––––––––––– JS T 9 • Compact insulation displacement connector • Header designed for vacuum pick and place robotics • Twin U-slot insulation displacement section • 3-point grip construction • Through-hole type (SZ) • Current rating: 0.7A DC • Voltage rating: 50V DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/20m Ω max. After environmental testing/40m Ω max. • Insulation resistance: 100M Ω min. • Withstanding voltage: 500V AC/minute • Applicable wire: Conductor size/AWG #30 Conductor/7 strands, tin-coated annealed copper Insulation O.D./0.54 to 0.58mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– 0 Recognized E60389 1 Certified LR20812 PC board layout (viewed from component side) and Assembly layout Top entry type Side entry type 3.5 Circuit No.1 5.4 Header outline 2±0.05 φ0.7±0.03 5.1 2±0.05 Circuit No.1 4 2.5±0.05 2±0.05 2±0.05 φ0.7±0.03 Header outline 1±0.05 2±0.05 1±0.05 Top entry type Side entry type 0.6±0.05 1.0±0.05 2.9 0.7±0.1 1.2±0.1 5.55±0.1 4.0±0.1 1.8±0.1 Header outline 0.2±0.1 4.2±0.1 1.8±0.1 0.7±0.1 1.2±0.1 0.2±0.1 4.9 Header outline 2.95 4.85 1.0±0.05 2.65±0.1 0.6±0.05 Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. 2. Dimensions above should serve as a guideline. Contact JST for details. 3. Hole dimensions differ according to the kind of PC board and piercing method. 4. If using double-sided through-hole PC board, it is necessary to confirm the resistance to the soldering heat on the PC board to be used and the soldering condition. Single sided paper based phenolic resin copper-clad PC board (t1.6) is recommended for a PCB used. 1 SR /SZ CONNECTOR Socket Circuits Model No. 2 1.0 3.0 2,000 3 03SR-3S 2.0 4.0 2,000 4 04SR-3S 3.0 5.0 2,000 5 05SR-3S 4.0 6.0 2,000 6 06SR-3S 5.0 7.0 2,000 7 07SR-3S 6.0 8.0 2,000 8 08SR-3S 7.0 9.0 2,000 9 09SR-3S 8.0 10.0 2,000 10 10SR-3S 9.0 11.0 2,000 11 11SR-3S 10.0 12.0 2,000 12 12SR-3S 11.0 13.0 2,000 13 13SR-3S 12.0 14.0 2,000 14 14SR-3S 13.0 15.0 2,000 3.6 1.0 A 2.1 Q'ty / box B 02SR-3S 2.45 B Dimensions (mm) A Material and Finish Contact: Phosphor bronze, tin-plated (reflow treatment) Housing: PA, UL94V-0, natural RoHS compliance Shrouded header (Through-hole type) Model No. Circuits Top entry type Side entry type 3 B03B-SZ S03B-SZ Side entry type B 2.0 5.2 12,825 9,405 4 B04B-SZ S04B-SZ 3.0 6.2 10,800 7,920 5 B05B-SZ S05B-SZ 4.0 7.2 9,225 6,765 6 B06B-SZ S06B-SZ 5.0 8.2 8,100 5,940 7 B07B-SZ S07B-SZ 6.0 9.2 7,200 5,280 8 B08B-SZ ― 7.0 10.2 6,525 ― 9 B09B-SZ ― 8.0 11.2 5,850 ― 11 B11B-SZ ― 10.0 13.2 4,950 ― 14 *B14B-SZ ― 13.0 16.2 4,050 ― 2.7 4 4.5 Circuit No.1 Q'ty / box Dimensions (mm) A B Top entry type Side entry type Material and Finish 1 2.5 0.45 Contact: Brass, tin-plated (reflow treatment) Housing: Glass-filled PBT, UL94V-0, natural (white) A Top entry type RoHS compliance Note: *Marked product is not UL approved. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 3.5 B S03B-SZLE(blank)...natural (white) LE...light blue 2.7 4.8 ex. Circuit No.1 1 A 0.55 2 2 SR /SZ CONNECTOR Shrouded header (SMT type) Model No. Circuits Top entry type Side entry type 2 BM02B-SRSS-TB SM02B-SRSS-TB Side entry type 2.9 B A 1.5 1.0 0.7 4.25 Top entry type B 1.0 4.0 1,500 3,000 3 BM03B-SRSS-TB SM03B-SRSS-TB 2.0 5.0 1,500 3,000 4 BM04B-SRSS-TB SM04B-SRSS-TB 3.0 6.0 1,500 3,000 5 BM05B-SRSS-TB SM05B-SRSS-TB 4.0 7.0 1,500 3,000 6 BM06B-SRSS-TB SM06B-SRSS-TB 5.0 8.0 1,500 3,000 7 BM07B-SRSS-TB SM07B-SRSS-TB 6.0 9.0 1,500 3,000 8 BM08B-SRSS-TB SM08B-SRSS-TB 7.0 10.0 1,500 3,000 9 BM09B-SRSS-TB SM09B-SRSS-TB 8.0 11.0 1,500 3,000 10 BM10B-SRSS-TB SM10B-SRSS-TB 9.0 12.0 1,500 3,000 11 BM11B-SRSS-TB SM11B-SRSS-TB 10.0 13.0 1,500 3,000 12 BM12B-SRSS-TB SM12B-SRSS-TB 11.0 14.0 1,500 3,000 13 BM13B-SRSS-TB SM13B-SRSS-TB 12.0 15.0 1,500 3,000 14 BM14B-SRSS-TB SM14B-SRSS-TB 13.0 16.0 1,500 3,000 4.25 Material and Finish Contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: PA, UL94V-0, natural Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment) 1.0 A 3 Q'ty / reel Dimensions (mm) A B Top entry type Side entry type 1.5 0.7 2.9 RoHS compliance This product displays (LF)(SN) on a label. Note: 1. The products listed above are supplied on embossed-tape. 2. Contact JST for the top entry type headers with suction cap.
1. 物料型号:文档列出了多种型号的连接器,例如02SR-3S、03SR-3S、04SR-3S等,每种型号都有其特定的尺寸和电路数量。
2. 器件简介:SR/SZ系列连接器是1.0mm间距的可断开绝缘位移连接器,设计用于自动真空拾取和放置机器人。
3. 引脚分配:文档提供了不同类型连接器的引脚分配图,包括通孔类型和SMT类型。
4. 参数特性: - 电流额定值:0.7A DC - 电压额定值:50V DC - 温度范围:-25°C至+85°C - 接触电阻:初始值/20mΩ最大,环境测试后/40mΩ最大 - 绝缘电阻:最小100MΩ - 耐压:500V AC/分钟 - 适用导线:AWG #30,7股镀锡退火铜线,外径0.54至0.58mm
5. 功能详解:文档提供了连接器的详细功能描述,包括其紧凑的设计、三点抓取结构、双U型槽绝缘位移部分等。
6. 应用信息:连接器适用于多种应用,文档建议使用单面纸基酚醛树脂铜覆板(t1.6)作为PCB。
7. 封装信息:提供了不同类型连接器的尺寸和每盒/每卷的数量,以及材料和表面处理信息,例如接触材料为磷青铜镀锡(回流处理),外壳为PA,UL94V-0,自然RoHS合规。
BM11B-SRSS-TB(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“BM11B-SRSS-TB(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
    • 1+3.470151+0.44980
    • 50+3.1471550+0.40793
    • 100+2.63367100+0.34138
    • 300+2.29411300+0.29736
    • 500+2.22785500+0.28878
    • 1000+2.178161000+0.28233
    • 4000+2.136754000+0.27697
    库存:715
