SM13B-SRSS-TB(LF)(SN) 数据手册
Emboss Tape
SR /SZ CONNECTOR
1.0mm pitch/Disconnectable Insulation displacement connectors
Specifications –––––––––––––––––––
JS
T
9
• Compact insulation displacement connector
• Header designed for vacuum pick and place
robotics
• Twin U-slot insulation displacement section
• 3-point grip construction
• Through-hole type (SZ)
• Current rating: 0.7A DC
• Voltage rating: 50V DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/20m Ω max.
After environmental testing/40m Ω max.
• Insulation resistance:
100M Ω min.
• Withstanding voltage: 500V AC/minute
• Applicable wire: Conductor size/AWG #30
Conductor/7 strands,
tin-coated annealed copper
Insulation O.D./0.54 to 0.58mm
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Standards ––––––––––––––––––––––
Recognized E60389
1 Certified LR20812
PC board layout (viewed from component side) and Assembly layout
Top entry type
Side entry type
3.5
Circuit
No.1
5.4
Header
outline
2±0.05
φ0.7±0.03
5.1
2±0.05
Circuit
No.1
4
2.5±0.05
2±0.05
2±0.05
φ0.7±0.03
Header
outline
1±0.05
2±0.05
1±0.05
Top entry type
Side entry type
0.6±0.05
1.0±0.05
2.9
0.7±0.1 1.2±0.1
5.55±0.1
4.0±0.1
1.8±0.1
Header outline
0.2±0.1
4.2±0.1
1.8±0.1
0.7±0.1 1.2±0.1
0.2±0.1
4.9
Header outline
2.95
4.85
1.0±0.05
2.65±0.1
0.6±0.05
Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers.
2. Dimensions above should serve as a guideline. Contact JST for details.
3. Hole dimensions differ according to the kind of PC board and piercing method.
4. If using double-sided through-hole PC board, it is necessary to confirm the resistance to the soldering heat on the PC board to be used and the soldering
condition. Single sided paper based phenolic resin copper-clad PC board (t1.6) is recommended for a PCB used.
1
SR /SZ CONNECTOR
Socket
Circuits
Model No.
2
1.0
3.0
2,000
3
03SR-3S
2.0
4.0
2,000
4
04SR-3S
3.0
5.0
2,000
5
05SR-3S
4.0
6.0
2,000
6
06SR-3S
5.0
7.0
2,000
7
07SR-3S
6.0
8.0
2,000
8
08SR-3S
7.0
9.0
2,000
9
09SR-3S
8.0
10.0
2,000
10
10SR-3S
9.0
11.0
2,000
11
11SR-3S
10.0
12.0
2,000
12
12SR-3S
11.0
13.0
2,000
13
13SR-3S
12.0
14.0
2,000
14
14SR-3S
13.0
15.0
2,000
3.6
1.0
A
2.1
Q'ty / box
B
02SR-3S
2.45
B
Dimensions (mm)
A
Material and Finish
Contact: Phosphor bronze, tin-plated (reflow treatment)
Housing: PA, UL94V-0, natural
RoHS compliance
Shrouded header (Through-hole type)
Model No.
Circuits Top entry type Side entry type
3
B03B-SZ
S03B-SZ
Side entry type
B
2.0
5.2
12,825
9,405
4
B04B-SZ
S04B-SZ
3.0
6.2
10,800
7,920
5
B05B-SZ
S05B-SZ
4.0
7.2
9,225
6,765
6
B06B-SZ
S06B-SZ
5.0
8.2
8,100
5,940
7
B07B-SZ
S07B-SZ
6.0
9.2
7,200
5,280
8
B08B-SZ
7.0
10.2
6,525
9
B09B-SZ
8.0
11.2
5,850
11
B11B-SZ
10.0
13.2
4,950
14
*B14B-SZ
13.0
16.2
4,050
2.7
4
4.5
Circuit
No.1
Q'ty / box
Dimensions (mm)
A
B
Material and Finish
1
2.5
0.45
Contact: Brass, tin-plated (reflow treatment)
Housing: Glass-filled PBT, UL94V-0, natural (white)
A
Top entry type
RoHS compliance
Note: *Marked product is not UL approved.
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
3.5
B
S03B-SZLE(blank)...natural (white) LE...light blue
2.7
4.8
ex.
Circuit
No.1
1
A
0.55
2
2
SR /SZ CONNECTOR
Shrouded header (SMT type)
Model No.
2
BM02B-SRSS-TB SM02B-SRSS-TB
Side entry type
2.9
B
A
1.5
1.0
0.7
4.25
Top entry type
B
1.0
4.0
1,500
3,000
3
BM03B-SRSS-TB
SM03B-SRSS-TB
2.0
5.0
1,500
3,000
4
BM04B-SRSS-TB
SM04B-SRSS-TB
3.0
6.0
1,500
3,000
5
BM05B-SRSS-TB
SM05B-SRSS-TB
4.0
7.0
1,500
3,000
6
BM06B-SRSS-TB
SM06B-SRSS-TB
5.0
8.0
1,500
3,000
7
BM07B-SRSS-TB
SM07B-SRSS-TB
6.0
9.0
1,500
3,000
8
BM08B-SRSS-TB
SM08B-SRSS-TB
7.0
10.0
1,500
3,000
9
BM09B-SRSS-TB
SM09B-SRSS-TB
8.0
11.0
1,500
3,000
10
BM10B-SRSS-TB
SM10B-SRSS-TB
9.0
12.0
1,500
3,000
11
BM11B-SRSS-TB
SM11B-SRSS-TB
10.0
13.0
1,500
3,000
12
BM12B-SRSS-TB
SM12B-SRSS-TB
11.0
14.0
1,500
3,000
13
BM13B-SRSS-TB
SM13B-SRSS-TB
12.0
15.0
1,500
3,000
14
BM14B-SRSS-TB
SM14B-SRSS-TB
13.0
16.0
1,500
3,000
4.25
Material and Finish
Contact: Copper alloy, copper-undercoated, tin-plated (reflow treatment)
Wafer: PA, UL94V-0, natural
Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment)
1.0
A
3
Q'ty / reel
Dimensions (mm)
A
B
1.5
0.7
2.9
RoHS compliance This product displays (LF)(SN) on a label.
Note: 1. The products listed above are supplied on embossed-tape.
2. Contact JST for the top entry type headers with suction cap.
