B32B-PNDZS-1(T)(LF)(SN)
    JST
    插件,P=2mm
    线对板针座 2x16P 插件 间距:2mm
B32B-PNDZS-1(T)(LF)(SN) 数据手册
PND CONNECTOR 2.0 mm pitch/Disconnectable Crimp style connectors PND CONNECTOR Specifications The PND connector is the high-density dipping type connector with secure lock for wire to board connection and enabled to achieve excellent workability and withstand the unexpected external force. ● Superior operability (Low insertion force) ● Withstanding external force and secure locking device ● Countermeasure for inverse insertion and mismatching insertion ● High density ● Polarizing boss ® • Current rating: 3 A AC/DC (AWG #22) • Voltage rating: 250 V AC/DC • Temperature range: -25℃ to +85℃                     (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 800 VAC/minute • Applicable wire: Conductor size/ AWG #28 to #22 Insulation O.D./ 0.76 to 1.5 mm * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. Standards ® ® PC board layout and Assembly layout Recognized E60389 ® ® +0.1 0 φ0.7 (3.6) 5 ±0.05 Connector outline 2 ±0.05 11.7 (12.9) +0.1 0 1.55 ±0.05 φ1 (10.7) A±0.05 1.45±0.05 (2) (B) Note: 1  . The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ± 0.05 mm for all centers. 3. H  ole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. Contact Applicable wire mm2 AWG # Model No. SPND-001T-C0.5 SPND-002T-C0.5 0.13~0.33 26~22 1.0~1.5 0.08~0.22 28~24 0.76~1.5 7.5 3.9 Q'ty/ reel 8,000 Material and Finish 1.5 Copper alloy, tin-plated (reflow treatment) RoHS2 compliance 2.08 3 Insulation O.D. (mm) Contact SPND- 001T-C0.5 SPND-002T-C0.5 Crimping machine Crimp applicator AP-K2N MKS-L Applicator Dies Crimp applicator with dies MK/SPND-001-05 APLMK SPND001-05 MK/SPAD/ND-002-05 APLMK SPAD/ND002-05 Note: Contact JST for fully automatic crimping applicator. 1 PND CONNECTOR 2 H JST 28 26 Housing Shrouded header H JST 26 1番極 1 1 1番極 25 B 11.7 10.7 3.2 11 1.2 9.9 B □0.5 2 A No. of circuits 5 Dimensions (mm) A B Model No. PNDP-08V-Z PNDP-10V-Z PNDP-12V-Z PNDP-14V-Z PNDP-16V-Z PNDP-18V-Z PNDP-20V-Z PNDP-22V-Z PNDP-24V-Z PNDP-26V-Z PNDP-28V-Z PNDP-30V-Z PNDP-32V-Z PNDP-34V-Z PNDP-36V-Z PNDP-38V-Z PNDP-40V-Z PNDP-42V-Z 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 1.45 Q’ty/ bag No. of circuits 6.0 10.0 500 8 8.0 12.0 500 10 10.0 14.0 500 12 12.0 16.0 500 14 14.0 18.0 300 16 16.0 20.0 300 18 18.0 22.0 300 20 20.0 24.0 300 22.0 26.0 250 24.0 28.0 250 26.0 30.0 250 28.0 32.0 150 30.0 34.0 150 32.0 36.0 150 34.0 38.0 100 36.0 40.0 100 38.0 42.0 100 40.0 44.0 100 22 24 26 28 30 32 34 36 38 40 42 A Model No. With boss Without boss B08B-PNDZS-1 B08B-PNDZS B10B-PNDZS-1 B10B-PNDZS B12B-PNDZS-1 B12B-PNDZS B14B-PNDZS-1 B14B-PNDZS B16B-PNDZS-1 B16B-PNDZS B18B-PNDZS-1 B18B-PNDZS B20B-PNDZS-1 B20B-PNDZS B22B-PNDZS-1 B22B-PNDZS B24B-PNDZS-1 B24B-PNDZS B26B-PNDZS-1 B26B-PNDZS B28B-PNDZS-1 B28B-PNDZS B30B-PNDZS-1 B30B-PNDZS B32B-PNDZS-1 B32B-PNDZS B34B-PNDZS-1 B34B-PNDZS B36B-PNDZS-1 B36B-PNDZS B38B-PNDZS-1 B38B-PNDZS B40B-PNDZS-1 B40B-PNDZS B42B-PNDZS-1 5 1.55 Dimensions (mm) A B Q’ty/ box 6.0 10.0 736 8.0 12.0 608 10.0 14.0 512 12.0 16.0 448 14.0 18.0 416 16.0 20.0 352 18.0 22.0 320 20.0 24.0 288 22.0 26.0 288 24.0 28.0 256 26.0 30.0 224 28.0 32.0 224 30.0 34.0 192 32.0 36.0 192 34.0 38.0 192 36.0 40.0 160 38.0 42.0 160 40.0 44.0 160 Material and Finish Material and Finish Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, ivory PA 66, UL94V- 0, ivory RoHS2 compliance RoHS2 compliance This product displays (LF)(SN) on a label. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. 2 As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. PNDP-28V-ZZ...ivory K...black R...red E...blue M...green N...brown PK...pink D...orange ex. B28B-PNDZS-1Z...ivory K...black R...red E...blue M...green N...brown PK...pink D...orange Retainer No. of circuits 24 34 2 Material and Finish Glass-filled PA 66, UL94V-0, ivory 33.55 32 2.4 2.4 22 23.55 2 RoHS2 compliance 1.5 2.9 7 2 2.35 2 Model No. PNDS-24V-Z PNDS-34V-Z 7.5 Q'ty/bag 1,000 1,000
1. 物料型号:PND连接器,具有不同的型号编号,如SPND-001T-C0.5和SPND-002T-C0.5,适用于不同线规的电线。
2. 器件简介:PND连接器是一种高密度浸入式连接器,具有安全锁定机制,适用于线对板连接,能够在恶劣环境下保持稳定性和可靠性。
3. 引脚分配:文档提供了详细的引脚分配图和尺寸,包括连接器的外形尺寸和PCB布局。
4. 参数特性:包括电流额定值3A AC/DC(AWG #22)、电压额定值250V AC/DC、温度范围-25℃至+85℃、接触电阻、绝缘电阻和耐电压等。
5. 功能详解:PND连接器具有优越的操作性、耐外部力和安全锁定装置、防反插和防错配对策。
6. 应用信息:适用于多种电路和应用场景,文档提供了不同电路数量的型号和尺寸信息。
7. 封装信息:材料包括铜合金、锡镀(回流处理)、PA 66、UL94V-0、象牙色,符合RoHS2标准。
B32B-PNDZS-1(T)(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“B32B-PNDZS-1(T)(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
    • 1+6.787341+0.87813
    • 20+6.7458520+0.87276
    • 50+5.1942250+0.67202
    • 100+4.67978100+0.60546
    • 300+4.33129300+0.56037
    • 500+4.26491500+0.55178
    • 1000+4.215121000+0.54534
    库存:68
    库存:667
      • 1+7.144571+0.92434
      • 20+7.1009020+0.91869
      • 50+5.4676050+0.70738
      • 100+4.92608100+0.63732
      • 300+4.55925300+0.58986
      • 500+4.48938500+0.58082
      库存:68
